I 're configuring GPIO pin for interrupt application.using EVK-NORA-B106 board.
My setup requires pin P1.05 then, I update the .dts file as follow:
Despite, the GPIO configuration using the functions:
gpio_pin_configure
gpio_pin_interrupt_configure
gpio_init_callback
gpio_add_callback
Interrupt doesn't work.
Issue could be genereted from warning displyed in the image? Implementation in .dts is correct?
For verification, I tried to use different pins and with P1.xx result is the same instead using pin P0.xx, interrupt works.
Thank you.
MP
