NRF24LE1
Hello, first of all, I am an engineering student. I want to learn communication and I just started it. I don't understand exactly what the following lines do. How can I do? What are the current resources? I couldn't understand the following lines of code.... Waiting for your support. ((The codes are completely taken from (enhanced_shockburst_ptx_nrf24le1.uvproj))
What part of the code does the actual work? Where is the ACK part? I don't want ACK and I want to work at 1 Mbps.
I don't know about addressing either, I don't know where to start :)
Thank you from now...
  • I've been trying for days, I still can't understand the problem. were you able to look?
  • /* Copyright (c) 2009 Nordic Semiconductor. All Rights Reserved.
    * The information contained herein is property of Nordic Semiconductor ASA.
    * Terms and conditions of usage are described in detail in NORDIC
    * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
    * Licensees are granted free, non-transferable use of the information. NO
    * WARRENTY of ANY KIND is provided. This heading must NOT be removed from
    * the file.
    * $LastChangedRevision: 2513 $
    /** @file
    * @brief Enhanced ShockBurst Primary Transmitter example
    * @defgroup esb_ptx_example Enhanced ShockBurst Primary Transmitter (PTX) example
    * @ingroup nrf_examples
    * @brief This example sends packets continuously. The contents of P0 are
    * sent in the first payload byte (byte 0).
    * The example shows the minimum required setup for transmitting packets to a
    * primary receiver (PRX) device.
    * The following default radio parameters are being used:
    * - RF channel 2
    * - 2 Mbps data rate
    * - TX address 0xE7E7E7E7E7
    * - 1 byte CRC
    * The project @ref esb_prx_example can be used as a counterpart for receiving the data.
    //lint -e717
    //lint -e714
    //lint -e640
    #ifdef MCU_NRF24LE1
    #include "nrf24le1.h"
    #include "hal_clk.h"
    #include <stdint.h>
    #include <stdbool.h>
    #include "hal_nrf.h"
    // Global variables
    static bool volatile radio_busy;
    uint8_t address[5]={0xB3,0xB4,0xB5,0xB6,0xF2};
    void main(void)
    uint8_t payload[3];
    #ifdef MCU_NRF24LE1
    while(hal_clk_get_16m_source() != HAL_CLK_XOSC16M)
    // Wait until 16 MHz crystal oscillator is running
    // Enable the radio clock
    RFCKEN = 1U;
    // Enable RF interrupt
    RF = 1U;
    // Enable global interrupt
    EA = 1U;
    hal_nrf_set_operation_mode(HAL_NRF_PTX);
    hal_nrf_set_address_width(HAL_NRF_AW_5BYTES); // 5 bytes address width
    hal_nrf_set_address(HAL_NRF_PIPE0, address); // Set device's addresses
    // Power up radio
    hal_nrf_set_power_mode(HAL_NRF_PWR_UP);
    for(;;)
    // Put P0 contents in payload[0]
    payload[0] = P0;
    // Write payload to radio TX FIFO
    hal_nrf_write_tx_payload(payload, 3U);
    // Toggle radio CE signal to start transmission
    CE_PULSE();
    radio_busy = true;
    // Wait for radio operation to finish
    while (radio_busy)
    // Radio interrupt
    NRF_ISR()
    uint8_t irq_flags;
    // Read and clear IRQ flags from radio
    irq_flags = hal_nrf_get_clear_irq_flags();
    switch(irq_flags)
    // Transmission success
    case (1 << (uint8_t)HAL_NRF_TX_DS):
    radio_busy = false;
    // Data has been sent
    // Transmission failed (maximum re-transmits)
    case (1 << (uint8_t)HAL_NRF_MAX_RT):
    // When a MAX_RT interrupt occurs the TX payload will not be removed from the TX FIFO.
    // If the packet is to be discarded this must be done manually by flushing the TX FIFO.
    // Alternatively, CE_PULSE() can be called re-starting transmission of the payload.
    // (Will only be possible after the radio irq flags are cleared)
    hal_nrf_flush_tx();
    radio_busy = false;
    * The information contained herein is confidential property of Nordic
    * Semiconductor ASA.Terms and conditions of usage are described in detail
    * in NORDIC SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
    * the file.
    * $LastChangedRevision: 2211 $
    /** @file
    * @brief Enhanced ShockBurst Primary Receiver example
    * @defgroup esb_prx_example Enhanced ShockBurst Primary Receiver (PRX) example
    * @brief This example monitors for data and writes the first byte (byte 0) of the
    * received payloads to P0.
    * The example shows the minimum required setup for receiving packets from a
    * primary transmitter (PTX) device.
    * - RF channel 2
    * - RX address 0xE7E7E7E7E7 (pipe 0) and 0xC2C2C2C2C2 (pipe 1)
    * - 1 byte CRC
    * The project @ref esb_ptx_example can be used as a counterpart for transmitting the data.
    //lint -e717
    //lint -e534
    //lint -e714
    //lint -e783
    #ifdef MCU_NRF24LE1
    #ifdef MCU_NRF24LU1P
    #include "nrf24lu1p.h"
    #include <stdint.h>
    // Global variables
    uint8_t payload[3];
    void main()
    #ifdef MCU_NRF24LE1
    // Enable radio SPI
    RFCTL = 0x10;
    // Set P0 as output
    P0DIR = 0;
    RFCKEN = 1;
    RF = 1;
    EA = 1;
    Radyoyu birincil alıcı (PRX) hal_nrf_set_operation_mode(HAL_NRF_PRX)
    olarak yapılandırma;
    Yük genişliğini 3 bayta ayarlayın
    hal_nrf_set_rx_payload_width((int)HAL_NRF_PIPE0, 3);
    Radyo
    hal_nrf_set_power_mode (HAL_NRF_PWR_UP) açın;
    Alıcı
    CE_HIGH();
    için(;;) {}
    Radyo kesme
    NRF_ISR()
    uint8_t irq_flags;
    IRQ bayraklarını radyo
    irq_flags okuma ve temizleme = hal_nrf_get_clear_irq_flags();
    if data
    ((irq_flags & (1<<(uint8_t))HAL_NRF_RX_DR)) > 0) { /
    / Read payload while(!hal_nrf_rx_fifo_empty())
    hal_nrf_read_rx_payload(payload
    Alınan yükü[0] bağlantı noktasına 0
    P0 = payload[0] yazın;
  • Hi
    I can't really see any obvious errors in the code that would explain this behavior. I would have to try to test this myself, and unfortunately I don't have any LE1 kits available at the moment. I will try to get some time to test this by the end of the week (please note we are working limited hours over christmas).
    In the mean time can you give me a bit more information about how you are testing this?
    Are you simply using the nRF24LE1 development kits, pushing buttons on one side and looking for LED updates on the other side?
    If you are not using standard Nordic devkits, could you send me a picture of your setup?
    Best regards
    Torbjørn
