How to configure memory layout in Asset Tracker v2 app
We are currently using NRF Connect SDK 2.2.0 and even more specifically the Asset Tracker v2 application in nrf9160dk board. By the moment we are only including some dependencies which our future application will need. This dependencies include new kernel modules and new application libraries (only modified CMakeList).
After building the application, when is time to link we have the following error:
"zephyr/zephyr_pre0.elf section `rodata' will not fit in region `FLASH'"
I saw other posts related to mine like this one MCUBootloader won't build for custom board - zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH' but not sure if we have the same issue.
Therefore, How can i modified the memory layout of Asset tracker application in order to give it more space to the APP?
This is my current memory layout:
Javier
  • Hello  ,
    I mistake Partition Manager with Secure Partition Manager, which is in deprecated status.
    I have included MCUBoot.
    The image which is failing during the linking stage is "tfm". By the moment, I will follow your recommendations of reducing the code size as well as removing unnecessary dependencies.
    Therefore, If I understood well, Partition Manager is configuring automatically each partition, no? Then, the only way that I have now to solve this is issue is reducing the size or going to a static approach.
    What do you recommend?
    Regards
    That is correct.
    There might be some Kconfig options you can use instead. It depends.
    First:
    Is the flash space limitation in the application or a child image?
    Sigurd Hellesvik
  • Hello  ,
    First of all thank you for the answer.
    And regarding your question, the limitation is on the child image, to be more precise, s1_image.
    The last days, I was trying to reduce the memory used but I did not success yet.
    Regards
    That would mean that MCUboot is is the one with too little space.
    Have a look at this child_image/mcuboot.conf from the Machine Learning sample to see an example of how to reduce MCUboot flash size.
    Also see my explanation on How to configure the bootloader.
    For more general tips, see our Optimizing application docs.
    Does this help?
    Sigurd Hellesvik
  • Hello  ,
    It was helping the information that you shared with me. I was optimising the application, however it is not enough. I am overlapping 235412bytes... quite a lot.
    I was doing some test using static partition, it looks promising. However, I would like to know how to increase the flash_primary partition.
     Below you can find the static configuration of my application:
    EMPTY_0:
      address: 0xc000
      end_address: 0x10000
      placement:
        before:
        - mcuboot_pad
      region: flash_primary
    EMPTY_1:
      address: 0xff000
      end_address: 0x100000
      placement:
        after:
        - settings_storage
    EMPTY_2:
      address: 0xfc000
      end_address: 0xfd000
      placement:
        after:
        - mcuboot_secondary
    app:
      address: 0x1c200
      end_address: 0x86000
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x10000
      end_address: 0x10200
      placement:
        align:
          start: 0x8000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0x10000
      orig_span: &id001
      - tfm
      - mcuboot_pad
      - app
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0x10200
      orig_span: &id002
      - app
      - tfm
      span: *id002
    mcuboot_secondary:
      address: 0x86000
      end_address: 0xfc000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x8000
      share_size:
      - mcuboot_primary
    nonsecure_storage:
      address: 0xfd000
      end_address: 0xff000
      orig_span: &id003
      - settings_storage
      span: *id003
    nrf_modem_lib_ctrl:
      address: 0x20008000
      end_address: 0x200084e8
      inside:
      - sram_nonsecure
      placement:
        after:
        - tfm_sram
        - start
      region: sram_primary
    nrf_modem_lib_rx:
      address: 0x2000a4e8
      end_address: 0x2000c4e8
      inside:
      - sram_nonsecure
      placement:
        after:
        - nrf_modem_lib_tx
    nrf_modem_lib_sram:
      address: 0x20008000
      orig_span: &id004
      - nrf_modem_lib_ctrl
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id004
    nrf_modem_lib_tx:
      address: 0x200084e8
      end_address: 0x2000a4e8
      inside:
      - sram_nonsecure
      placement:
        after:
    otp:
      address: 0xff8108
      end_address: 0xff83fc
      region: otp
    settings_storage:
      address: 0xfd000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - end
    sram_nonsecure:
      address: 0x20008000
      end_address: 0x20040000
      orig_span: &id005
      - sram_primary
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id005
    sram_primary:
      address: 0x2000c4e8
    sram_secure:
      address: 0x20000000
      end_address: 0x20008000
      orig_span: &id006
      - tfm_sram
      span: *id006
    tfm:
      address: 0x10200
      end_address: 0x1c200
      inside:
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x1c200
      orig_span: &id007
      - app
      span: *id007
    tfm_secure:
      address: 0x10000
      orig_span: &id008
      - mcuboot_pad
      - tfm
      span: *id008
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
    This configuration is currently working AT2 application, if we focus on "EMPTY_1" partition, we can see that the ending address is 0x100000. If I try to increase this partition to 0x180000, for instance. It will throw an error:
    However, I think that the problem comes from flash_primary region:
    --flash_primary-size;0x100000;--flash_primary-base-address;0x0;--flash_primary-placement-strategy;complex;--flash_primary-device;flash_controller;--flash_primary-default-driver-kconfig;CONFIG_SOC_FLASH_NRF
    As  can see in the error the flash_primary_size is 0x100000, therefore it is not going to fit. PM is not taking into consideration the ending addrees.
    How can I increase this region? as I can see here, we have lot of space available.
