NRF 5340 Audio DK - Demo - FATAL ERROR: CMake is not installed or cannot be found; cannot build.
I am having trouble getting the build to complete for the Audio DK demo (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/nrf5340_audio/README.html#nrf53-audio-app-configuration-select-bis). I have the "FATAL ERROR: CMake is not installed or cannot be found; cannot build"
I have the cmake extension installed, I am opening VS code from the toolchain manager. I checked in the nrf connect: generate support information and it looks like CMake has a path to tools. I noticed there isn't one to nrfutil. I'm not sure if this could cause the issue or how to fix it.
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Enterprise",
    "osKernel": "10.0.19044",
    "vscode": "1.74.2",
    "electron": "19.1.8",
    "node": "v16.14.2"
  "system": {
    "date": "2022-12-29T15:50:44.549Z",
    "vscodeRoot": "c:\\Users\\armstrk1\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:12:32",
    "osUptime": "790:53:06",
    "cpu": {
      "model": "Intel(R) Core(TM) i5-6300HQ CPU @ 2.30GHz",
      "speed": "2304 MHz",
      "count": 2
    "memory": {
      "total": "15.89 GB",
      "free": "3.67 GB"
  "workspace": {
    "name": "nrf5340_audio",
    "workspaceFile": null,
    "folders": [
      "c:\\EGR636_nRF\\MyTest\\nrf5340_audio"
  "extensions": {
    "internal": {
        "version": "2022.11.140",
        "path": "c:\\Users\\armstrk1\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.11.140-win32-x64",
        "isActive": true
        "version": "2022.11.29",
        "path": "c:\\Users\\armstrk1\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.11.29",
        "isActive": true
        "version": "2022.11.153",
        "path": "c:\\Users\\armstrk1\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2022.11.153",
        "isActive": true
        "version": "2022.11.50",
        "path": "c:\\Users\\armstrk1\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2022.11.50",
        "isActive": true
    "external": {
      "marus25.cortex-debug": "1.6.9",
      "ms-vscode.cpptools": "1.13.8",
      "ms-vscode-remote.remote-wsl-recommender": "0.0.18",
      "ms-vscode.js-debug": "1.74.1",
      "ms-vscode.js-debug-companion": "1.0.18",
      "ms-vscode.vscode-js-profile-table": "1.0.3",
      "batisteo.vscode-django": "1.10.0",
      "cschlosser.doxdocgen": "1.4.0",
      "donjayamanne.python-environment-manager": "1.0.4",
      "donjayamanne.python-extension-pack": "1.7.0",
      "jeff-hykin.better-cpp-syntax": "1.17.2",
      "KevinRose.vsc-python-indent": "1.18.0",
      "mcu-debug.debug-tracker-vscode": "0.0.13",
      "mcu-debug.memory-view": "0.0.18",
      "mcu-debug.rtos-views": "0.0.2",
      "ms-python.isort": "2022.8.0",
      "ms-python.python": "2022.20.1",
      "ms-python.vscode-pylance": "2022.12.20",
      "ms-toolsai.jupyter": "2022.11.1003412109",
      "ms-toolsai.jupyter-keymap": "1.0.0",
      "ms-toolsai.vscode-jupyter-cell-tags": "0.1.6",
      "ms-toolsai.vscode-jupyter-slideshow": "0.1.5",
      "njpwerner.autodocstring": "0.6.1",
      "twxs.cmake": "0.0.17",
      "VisualStudioExptTeam.intellicode-api-usage-examples": "0.2.6",
      "VisualStudioExptTeam.vscodeintellicode": "1.2.29",
      "wholroyd.jinja": "0.0.8"
  "tools": {
    "c:\\ncs\\toolchains\\v2.2.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.15.1",
    "C:\\Program Files (x86)\\SEGGER\\JLink\\JLink.exe": "7.80c",
    "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.18.1",
    "nrfutil": "Not found",
    "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\cmake.exe": "3.20.5",
    "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\Scripts\\west.exe": "0.14.0",
    "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\python.exe": "3.8.2",
    "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\ninja.exe": "1.9.0",
    "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\gperf.exe": "3.1",
    "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\dtc.exe": "1.4.7",
    "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\gn.exe": "2073",
    "c:\\ncs\\toolchains\\v2.2.0\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    "gdbPath": "c:\\ncs\\toolchains\\v2.2.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
  "sdks": [
      "version": "2.0.0",
      "path": "c:\\ncs\\v2.0.0"
      "version": "2.2.0",
      "path": "c:\\ncs\\v2.2.0"
  "toolchains": [
      "version": "2.0.0",
      "path": "c:\\ncs\\toolchains\\v2.0.0"
      "version": "2.2.0",
      "path": "c:\\ncs\\toolchains\\v2.2.0"
  "connectedDevices": [
      "serialNumber": "1050199355"
  "deviceProviders": [
    "nrfjprog"
  "config": {
      "topdir": "c:\\EGR636_nRF\\MyTest",
      "toolchain": {
        "path": "${nrf-connect.toolchain:2.2.0}"
      "ozonePath": "",
      "applications": [
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig",
        "executeInDefaultShell": false
      "welcome": {
        "showOnStartup": true
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "enableTelemetry": false,
      "taskBindings": {},
      "debugging": {
        "backend": "nRF Debug",
        "flash": true,
        "bindings": {}
      "activeAppFollowActiveEditor": true
      "terminalMode": "character",
      "scrollBack": 1000
    "marus25.cortex-debug": {
      "armToolchainPath": null,
      "armToolchainPrefix": "arm-none-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": null,
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "enableTelemetry": true,
      "registerUseNaturalFormat": true,
      "variableUseNaturalFormat": true,
      "dbgServerLogfile": null,
      "showDevDebugOutput": "none"
  "environment": {
    "westExe": "west",
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "HOME": "C:\\Users\\armstrk1",
      "HOMEDRIVE": "C:",
      "HOMEPATH": "\\Users\\armstrk1",
      "Path": "c:\\ncs\\toolchains\\v2.2.0\\mingw64\\bin;c:\\ncs\\toolchains\\v2.2.0\\mingw64\\libexec\\git-core;c:\\ncs\\toolchains\\v2.2.0\\opt\\bin;c:\\ncs\\toolchains\\v2.2.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\v2.2.0\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\Scripts;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Rockwell Software\\RSCommon;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Common Files\\Rockwell\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X64\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X86\\;C:\\Program Files (x86)\\Common Files\\Pulse Secure\\TNC Client Plugin\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\Git\\cmd;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Rockwell Software\\RSCommon;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Common Files\\Rockwell\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X64\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X86\\;C:\\Program Files (x86)\\Common Files\\Pulse Secure\\TNC Client Plugin\\;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Python\\Python310;C:\\Program Files (x86)\\Microsoft VS Code\\bin;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;",
      "ZEPHYR_BASE": "c:\\EGR636_nRF\\MyTest\\zephyr",
      "ZEPHYR_SDK_INSTALL_DIR": "c:\\ncs\\toolchains\\v2.2.0\\opt\\zephyr-sdk",
      "PYTHONPATH": "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin;c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\Lib;c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\Lib\\site-packages",
      "Python3_ROOT": "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin"
    "inherited": {
      "HOMEDRIVE": "C:",
      "Path": "C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Rockwell Software\\RSCommon;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Common Files\\Rockwell\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X64\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X86\\;C:\\Program Files (x86)\\Common Files\\Pulse Secure\\TNC Client Plugin\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\Git\\cmd;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Rockwell Software\\RSCommon;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Common Files\\Rockwell\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X64\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X86\\;C:\\Program Files (x86)\\Common Files\\Pulse Secure\\TNC Client Plugin\\;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Python\\Python310;C:\\Program Files (x86)\\Microsoft VS Code\\bin;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;",
      "PATH": "C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Rockwell Software\\RSCommon;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Common Files\\Rockwell\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X64\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X86\\;C:\\Program Files (x86)\\Common Files\\Pulse Secure\\TNC Client Plugin\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\Git\\cmd;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Rockwell Software\\RSCommon;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Common Files\\Rockwell\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X64\\;C:\\Program Files (x86)\\Pulse Secure\\VC142.CRT\\X86\\;C:\\Program Files (x86)\\Common Files\\Pulse Secure\\TNC Client Plugin\\;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Python\\Python310;C:\\Program Files (x86)\\Microsoft VS Code\\bin;C:\\Users\\armstrk1\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;"
    "toolchainPath": "c:\\ncs\\toolchains\\v2.2.0",
    "toolchainBinPath": "c:\\ncs\\toolchains\\v2.2.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
    "toolchainVersion": "2.2.0"
  "terminal": {
    "shell": null,
    "defaultProfile": null
I'm not sure what else to try?
