I am currently trying to use SPI for the nrf9160. I tried building the SPI_BITBANNG sample for the nrf9160dk_nrf9160_ns board for the nrf9160dk that I have.
However, when building, I get the following error:
Executing task: nRF Connect: Build: spi_bitbang/build_1 (active)
Building spi_bitbang
west build --build-dir /Users/davidlu/nordic/myapps/spi_bitbang/build_1 /Users/davidlu/nordic/myapps/spi_bitbang
[0/24] Performing build step for 'tfm'
ninja: no work to do.
[2/16] Building C object CMakeFiles/app.dir/src/main.c.obj
FAILED: CMakeFiles/app.dir/src/main.c.obj
ccache /opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_USER_CONFIG_FILE=\"nrf-config-user.h\" -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DTFM_PSA_API -DUSE_PARTITION_MANAGER=1 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I/opt/nordic/ncs/v2.2.0/zephyr/include -Izephyr/include/generated -I/opt/nordic/ncs/v2.2.0/zephyr/soc/arm/nordic_nrf/nrf91 -I/opt/nordic/ncs/v2.2.0/zephyr/lib/libc/newlib/include -I/opt/nordic/ncs/v2.2.0/zephyr/soc/arm/nordic_nrf/common/. -I/opt/nordic/ncs/v2.2.0/nrf/include -I/opt/nordic/ncs/v2.2.0/nrf/include/tfm -I/opt/nordic/ncs/v2.2.0/nrf/tests/include -Itfm/generated/interface/include -I/opt/nordic/ncs/v2.2.0/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v2.2.0/zephyr/modules/hal_nordic/nrfx/. -I/opt/nordic/ncs/v2.2.0/nrfxlib/nrf_modem/include -Itfm/install/interface/include -Imodules/nrfxlib/nrfxlib/nrf_security/src/include/generated -I/opt/nordic/ncs/v2.2.0/nrfxlib/nrf_security/include -I/opt/nordic/ncs/v2.2.0/nrfxlib/nrf_security/include/mbedtls -I/opt/nordic/ncs/v2.2.0/mbedtls/include -I/opt/nordic/ncs/v2.2.0/mbedtls/include/mbedtls -I/opt/nordic/ncs/v2.2.0/mbedtls/include/psa -I/opt/nordic/ncs/v2.2.0/mbedtls/library -I/opt/nordic/ncs/v2.2.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -I/opt/nordic/ncs/v2.2.0/nrfxlib/crypto/nrf_oberon/include -fno-strict-aliasing -Og -imacros /Users/davidlu/nordic/myapps/spi_bitbang/build_1/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/Users/davidlu/nordic/myapps/spi_bitbang=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v2.2.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v2.2.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles/app.dir/src/main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c ../src/main.c
In file included from /opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/toolchain/gcc.h:88,
from /opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/toolchain.h:50,
from /opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/sys/cbprintf.h:13,
from /opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/logging/log_msg.h:11,
from /opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/logging/log_core.h:9,
from /opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/logging/log.h:11,
from /Users/davidlu/nordic/myapps/spi_bitbang/src/main.c:7:
../src/main.c: In function 'main':
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/device.h:83:41: error: '__device_dts_ord_DT_N_NODELABEL_spibb0_ORD' undeclared (first use in this function)
83 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/toolchain/common.h:132:26: note: in definition of macro '_DO_CONCAT'
132 | #define _DO_CONCAT(x, y) x ## y
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/device.h:83:33: note: in expansion of macro '_CONCAT'
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/device.h:209:37: note: in expansion of macro 'DEVICE_NAME_GET'
209 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/device.h:226:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
226 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
/Users/davidlu/nordic/myapps/spi_bitbang/src/main.c:123:42: note: in expansion of macro 'DEVICE_DT_GET'
123 | const struct device *const dev = DEVICE_DT_GET(SPIBB_NODE);
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/device.h:83:41: note: each undeclared identifier is reported only once for each function it appears in
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/device.h:83:41: error: '__device_dts_ord_DT_N_NODELABEL_spibb0_P_cs_gpios_IDX_0_PH_ORD' undeclared (first use in this function)
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/drivers/gpio.h:340:25: note: in expansion of macro 'DEVICE_DT_GET'
340 | .port = DEVICE_DT_GET(DT_GPIO_CTLR_BY_IDX(node_id, prop, idx)),\
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/drivers/gpio.h:376:9: note: in expansion of macro 'GPIO_DT_SPEC_GET_BY_IDX'
376 | GPIO_DT_SPEC_GET_BY_IDX(node_id, prop, 0)
/Users/davidlu/nordic/myapps/spi_bitbang/src/main.c:131:25: note: in expansion of macro 'GPIO_DT_SPEC_GET'
131 | .gpio = GPIO_DT_SPEC_GET(SPIBB_NODE, cs_gpios),
In file included from /opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/arch/arm/aarch32/arch.h:20,
from /opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/arch/cpu.h:19,
from /opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/sys/cbprintf_internal.h:17,
from /opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/sys/cbprintf.h:101:
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/devicetree.h:190:36: error: 'DT_N_NODELABEL_spibb0_P_cs_gpios_IDX_0_VAL_pin' undeclared (first use in this function)
190 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/devicetree.h:3901:9: note: in definition of macro 'DT_CAT7'
3901 | a1 ## a2 ## a3 ## a4 ## a5 ## a6 ## a7
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/devicetree/gpio.h:164:9: note: in expansion of macro 'DT_PHA_BY_IDX'
164 | DT_PHA_BY_IDX(node_id, gpio_pha, idx, pin)
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/drivers/gpio.h:341:24: note: in expansion of macro 'DT_GPIO_PIN_BY_IDX'
341 | .pin = DT_GPIO_PIN_BY_IDX(node_id, prop, idx), \
/opt/nordic/ncs/v2.2.0/zephyr/include/zephyr/devicetree.h:190:29: note: in expansion of macro 'DT_CAT'
/Users/davidlu/nordic/myapps/spi_bitbang/src/main.c:17:25: note: in expansion of macro 'DT_NODELABEL'
17 | #define SPIBB_NODE DT_NODELABEL(spibb0)
/Users/davidlu/nordic/myapps/spi_bitbang/src/main.c:131:42: note: in expansion of macro 'SPIBB_NODE'
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/v2.2.0/bin/cmake --build /Users/davidlu/nordic/myapps/spi_bitbang/build_1
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
I also tried adding this to the .overlay file according to this ticket:
spibb0: spibb0 {
compatible = "zephyr,spi-bitbang";
status = "okay";
#address-cells = <1>;
#size-cells = <0>;
clk-gpios = <&gpio0 10 GPIO_ACTIVE_HIGH>;
mosi-gpios = <&gpio0 11 GPIO_ACTIVE_HIGH>;
miso-gpios = <&gpio0 6 0>;
cs-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>;
I have also attached my generate support information here below:
"platform": {
"os": "darwin",
"osVersion": "Darwin Kernel Version 22.1.0: Sun Oct 9 20:15:09 PDT 2022; root:xnu-8792.41.9~2/RELEASE_ARM64_T6000",
"osKernel": "22.1.0",
"vscode": "1.74.1",
"electron": "19.1.8",
"node": "v16.14.2"
"system": {
"date": "2022-12-31T02:54:49.175Z",
"vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
"vscodeUptime": "71:26:00",
"osUptime": "1382:21:57",
"cpu": {
"model": "Apple M1 Pro",
"speed": "24 MHz",
"count": 5
"memory": {
"total": "32.00 GB",
"free": "0.04 GB"
"workspace": {
"name": "myapps_nordic (Workspace)",
"workspaceFile": "/Users/davidlu/nordic/myapps/myapps_nordic.code-workspace",
"folders": [
"/Users/davidlu/nordic/myapps/myfirstapp",
"/Users/davidlu/nordic/myapps/mysecondapp",
"/Users/davidlu/nordic/myapps/gpio_counter",
"/Users/davidlu/nordic/myapps/nRF-Connect-SDK-Fundamentals",
"/Users/davidlu/nordic/myapps/gpio_counter_1",
"/Users/davidlu/nordic/myapps/at_client",
"/Users/davidlu/nordic/myapps/at_client2",
"/Users/davidlu/nordic/myapps/spi_bitbang"
"extensions": {
"internal": {
"version": "2022.11.140",
"path": "/Users/davidlu/.vscode/extensions/nordic-semiconductor.nrf-connect-2022.11.140-darwin-x64",
"isActive": true
"version": "2022.11.29",
"path": "/Users/davidlu/.vscode/extensions/nordic-semiconductor.nrf-terminal-2022.11.29",
"isActive": true
"version": "2022.11.153",
"path": "/Users/davidlu/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2022.11.153",
"isActive": true
"version": "2022.11.50",
"path": "/Users/davidlu/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2022.11.50",
"isActive": true
"external": {
"marus25.cortex-debug": null,
"ms-vscode.cpptools": null,
"ms-vscode.js-debug": "1.74.1",
"ms-vscode.js-debug-companion": "1.0.18",
"ms-vscode.vscode-js-profile-table": "1.0.3",
"DavidAnson.vscode-markdownlint": "0.48.1",
"esbenp.prettier-vscode": "9.10.3",
"GrapeCity.gc-excelviewer": "4.2.56",
"ms-azuretools.vscode-docker": "1.23.3",
"ms-python.isort": "2022.8.0",
"ms-python.python": "2022.20.1",
"ms-python.vscode-pylance": "2022.12.20",
"ms-toolsai.jupyter": "2022.11.1003412109",
"ms-toolsai.jupyter-keymap": "1.0.0",
"ms-toolsai.jupyter-renderers": "1.0.12",
"ms-toolsai.vscode-jupyter-cell-tags": "0.1.6",
"ms-toolsai.vscode-jupyter-slideshow": "0.1.5",
"ms-vscode-remote.remote-containers": "0.266.1",
"ms-vscode.cmake-tools": "1.12.27",
"ms-vscode.makefile-tools": "0.6.0",
"twxs.cmake": "0.0.17"
"tools": {
"/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.15.1",
"/Applications/SEGGER/JLink/JLinkExe": "7.80c",
"/usr/local/bin/nrfjprog": "10.18.1",
"nrfutil": "Not found",
"/opt/nordic/ncs/toolchains/v2.2.0/bin/cmake": "3.20.5",
"/opt/nordic/ncs/toolchains/v2.2.0/bin/west": "0.14.0",
"/opt/nordic/ncs/toolchains/v2.2.0/bin/python3": "3.9.6",
"/opt/nordic/ncs/toolchains/v2.2.0/bin/ninja": "1.10.2",
"/opt/nordic/ncs/toolchains/v2.2.0/bin/gperf": "3.1",
"/opt/nordic/ncs/toolchains/v2.2.0/bin/dtc": "1.6.1",
"/opt/nordic/ncs/toolchains/v2.2.0/bin/gn": "2073",
"/opt/nordic/ncs/toolchains/v2.2.0/bin/git": "2.37.3",
"gdbPath": "/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb"
"sdks": [
"version": "2.2.0",
"path": "/opt/nordic/ncs/v2.2.0"
"toolchains": [
"version": "2.2.0",
"path": "/opt/nordic/ncs/toolchains/v2.2.0"
"connectedDevices": [
"serialNumber": "960062177"
"deviceProviders": [
"nrfjprog"
"config": {
"topdir": "${nrf-connect.sdk:2.2.0}",
"toolchain": {
"path": "${nrf-connect.toolchain:2.2.0}"
"ozonePath": "",
"applications": [
"${workspaceFolder:nRF-Connect-SDK-Fundamentals}/v2.x.x/lesson2/fund_less2_exer1",
"${workspaceFolder:nRF-Connect-SDK-Fundamentals}/v2.x.x/lesson2/fund_less2_exer2",
"${workspaceFolder:nRF-Connect-SDK-Fundamentals}/v2.x.x/lesson3/fund_less3_exer1",
"applicationOptions": {},
"kconfig": {
"interface": "kconfig",
"executeInDefaultShell": false
"welcome": {
"showOnStartup": true
"west": {
"env": {
"$base": "terminal"
"boardRoots": [],
"enableTelemetry": null,
"taskBindings": {},
"debugging": {
"backend": "nRF Debug",
"flash": true,
"bindings": {}
"activeAppFollowActiveEditor": true
"terminalMode": "character",
"scrollBack": 1000
"environment": {
"westExe": "west",
"westEnv": {
"ELECTRON_RUN_AS_NODE": "1",
"GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/v2.2.0/Cellar/git/2.37.3/libexec/git-core",
"HOME": "/Users/davidlu",
"PATH": "/opt/nordic/ncs/toolchains/v2.2.0/bin:/opt/nordic/ncs/toolchains/v2.2.0/opt/bin:/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/v2.2.0/arm-zephyr-eabi/bin:/Users/davidlu/.pyenv/shims:/Users/davidlu/.pyenv/bin:/Users/davidlu/opt/anaconda3/bin:/Users/davidlu/opt/anaconda3/condabin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/Library/Apple/usr/bin",
"ZEPHYR_BASE": "/opt/nordic/ncs/v2.2.0/zephyr",
"ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk",
"USER": "davidlu"
"inherited": {
"PATH": "/Users/davidlu/.pyenv/shims:/Users/davidlu/.pyenv/bin:/Users/davidlu/opt/anaconda3/bin:/Users/davidlu/opt/anaconda3/condabin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/Library/Apple/usr/bin",
"USER": "davidlu"
"toolchainPath": "/opt/nordic/ncs/toolchains/v2.2.0",
"toolchainBinPath": "/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin",
"toolchainVersion": "2.2.0"
"terminal": {
"shell": null,
"defaultProfile": null
I am using nRF Connect SDK v 2.2.0.
Do you have any suggestions on why this error is occurring and how to resolve it?
Thanks.
