How to implement a simple zigbee cluster that tow-way data transfer between zigbee coordinator and device?
I want to implement a simple Zigbee cluster that can transfer bytes between zc or zd, like UART TXRX.
I found Messaging Cluster might be the one. After checking these posts below, I still do not have an idea of how to implement it in Zigbee Template example.
https://devzone.nordicsemi.com/f/nordic-q-a/74238/zigbee-messaging-cluster
https://devzone.nordicsemi.com/f/nordic-q-a/69469/question-how-to-send-payload-from-zed-to-zc/285676
https://devzone.nordicsemi.com/f/nordic-q-a/68430/question-can-i-use-zigbee-and-uart-at-the-same-time
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_tz_v4.0.0%2Fgroup___z_b___z_c_l___m_e_s_s_a_g_i_n_g.html
I am aware that there are some libs that seem to have been implemented.
ncs\v2.1.0\nrfxlib\zboss\production\include\zcl\zb_zcl_messaging.h
ncs\v2.1.0\nrfxlib\zboss\production\src\zcl\zcl_c_messaging.c
ncs\v2.1.0\nrfxlib\zboss\production\src\zcl\zcl_s_messaging.c
Could you guild me on how to implement it on the Template example code and use the Shell example ad zc to send and receive data from that message cluster?
many thanks
  • Hi
    Please check out this ticket where a customer has implemented the ZCL messaging cluster, unfortunately we don't have an application using the messaging libraries in our SDK yet. The ZBOSS stack and thus ZCL messaging cluster commands are identical to the commands listed in the Infocenter. How you implement these commands into your project will be up to you.
    Simon
  • Hi
    How to DECLARE cluster and EP for messaging cluster?
    I have checked those posts that did not mention it.
    many thanks
    Arik
  • Hi
    In I.E. the zb_dimmable_light.h file located in <NCS_folder>\<NCS_version>\nrf\manifest-tmp\samples\zigbee\light_bulb\include\zb_dimmable_light.h there is an example on how to declare a cluster list for I.E. a dimmable light device, declaration of a cluster in general should be similar to this I believe:
     * @brief Declare cluster list for Dimmable Light device
     * @param cluster_list_name - cluster list variable name
     * @param basic_attr_list - attribute list for Basic cluster
     * @param identify_attr_list - attribute list for Identify cluster
     * @param groups_attr_list - attribute list for Groups cluster
     * @param scenes_attr_list - attribute list for Scenes cluster
     * @param on_off_attr_list - attribute list for On/Off cluster
     * @param level_control_attr_list - attribute list for Level Control cluster
    #define ZB_DECLARE_DIMMABLE_LIGHT_CLUSTER_LIST(					   \
    	cluster_list_name,							   \
    	basic_attr_list,							   \
    	identify_attr_list,							   \
    	groups_attr_list,							   \
    	scenes_attr_list,							   \
    	on_off_attr_list,							   \
    	level_control_attr_list)						   \
    	zb_zcl_cluster_desc_t cluster_list_name[] =				   \
    		ZB_ZCL_CLUSTER_DESC(						   \
    			ZB_ZCL_CLUSTER_ID_IDENTIFY,				   \
    			ZB_ZCL_ARRAY_SIZE(identify_attr_list, zb_zcl_attr_t),	   \
    			(identify_attr_list),					   \
    			ZB_ZCL_CLUSTER_SERVER_ROLE,				   \
    			ZB_ZCL_MANUF_CODE_INVALID				   \
    			ZB_ZCL_CLUSTER_ID_BASIC,				   \
    			ZB_ZCL_ARRAY_SIZE(basic_attr_list, zb_zcl_attr_t),	   \
    			(basic_attr_list),					   \
    			ZB_ZCL_CLUSTER_ID_SCENES,				   \
    			ZB_ZCL_ARRAY_SIZE(scenes_attr_list, zb_zcl_attr_t),	   \
    			(scenes_attr_list),					   \
    			ZB_ZCL_CLUSTER_ID_GROUPS,				   \
    			ZB_ZCL_ARRAY_SIZE(groups_attr_list, zb_zcl_attr_t),	   \
    			(groups_attr_list),					   \
    			ZB_ZCL_CLUSTER_ID_ON_OFF,				   \
    			ZB_ZCL_ARRAY_SIZE(on_off_attr_list, zb_zcl_attr_t),	   \
    			(on_off_attr_list),					   \
    			ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL,			   \
    			ZB_ZCL_ARRAY_SIZE(level_control_attr_list, zb_zcl_attr_t), \
    			(level_control_attr_list),				   \
    Simon
