PRECISERR due to the address violation at 0x40009500 (BFAR) cause hardfault for NRF9160ns
I have a legacy code base  for NRF9160 with a custom board folder which created manually by applying installing manually steps in the past. I have neither experience with Nordic ecosystem nor Zephyr before.
Codebase is building successfully however it falls hard fault whenever I attempted to run zephyr.elf file via OZONE.
Ozone says there is PRECISERR and BFAR = 0x4000 9500.
Software are using uarte and this adress could be related with this. On the other hand, an instruction on my hand says " before the build, you should copy custom uarte.c driver to zephyr/driver/serial/uarte" I do not know why.
Here is the code snippet.
As far as I reviewed. This address is belongs to the uarte enable register. The project are using uart0 and uart1. I do not know which prj.conf I need to share with you please navigate me.
 * Copyright (c) 2018 Nordic Semiconductor ASA
 * @brief Driver for Nordic Semiconductor nRF UARTE
#include <drivers/uart.h>
#include <hal/nrf_gpio.h>
#include <hal/nrf_uarte.h>
#include <nrfx_timer.h>
#include <sys/util.h>
#include <kernel.h>
#include <logging/log.h>
#include <helpers/nrfx_gppi.h>
LOG_MODULE_REGISTER(uart_nrfx_uarte, LOG_LEVEL_ERR);
/* Generalize PPI or DPPI channel management */
#if defined(CONFIG_HAS_HW_NRF_PPI)
#include <nrfx_ppi.h>
#define gppi_channel_t nrf_ppi_channel_t
#define gppi_channel_alloc nrfx_ppi_channel_alloc
#define gppi_channel_enable nrfx_ppi_channel_enable
#elif defined(CONFIG_HAS_HW_NRF_DPPIC)
#include <nrfx_dppi.h>
#define gppi_channel_t uint8_t
#define gppi_channel_alloc nrfx_dppi_channel_alloc
#define gppi_channel_enable nrfx_dppi_channel_enable
#else
#error "No PPI or DPPI"
#if (defined(CONFIG_UART_0_NRF_UARTE) &&         \
     defined(CONFIG_UART_0_INTERRUPT_DRIVEN)) || \
    (defined(CONFIG_UART_1_NRF_UARTE) &&         \
     defined(CONFIG_UART_1_INTERRUPT_DRIVEN)) || \
    (defined(CONFIG_UART_2_NRF_UARTE) &&         \
     defined(CONFIG_UART_2_INTERRUPT_DRIVEN)) || \
    (defined(CONFIG_UART_3_NRF_UARTE) &&         \
     defined(CONFIG_UART_3_INTERRUPT_DRIVEN))
	#define UARTE_INTERRUPT_DRIVEN	1
#if	(defined(CONFIG_UART_0_NRF_UARTE) && !defined(CONFIG_UART_0_ASYNC)) || \
	(defined(CONFIG_UART_1_NRF_UARTE) && !defined(CONFIG_UART_1_ASYNC)) || \
	(defined(CONFIG_UART_2_NRF_UARTE) && !defined(CONFIG_UART_2_ASYNC)) || \
	(defined(CONFIG_UART_3_NRF_UARTE) && !defined(CONFIG_UART_3_ASYNC))
#define UARTE_ANY_NONE_ASYNC 1
uint32_t uarte_prev_rx_amount;
uint8_t uarte_prev_dirty;
uint8_t po_flush_buf[5];
 * RX timeout is divided into time slabs, this define tells how many divisions
 * should be made. More divisions - higher timeout accuracy and processor usage.
#define RX_TIMEOUT_DIV 5
#ifdef CONFIG_UART_ASYNC_API
struct uarte_async_cb {
	uart_callback_t user_callback;
	void *user_data;
	const uint8_t *tx_buf;
	volatile size_t tx_size;
	uint8_t *pend_tx_buf;
	struct k_timer tx_timeout_timer;
	uint8_t *rx_buf;
	size_t rx_buf_len;
	size_t rx_offset;
	uint8_t *rx_next_buf;
	size_t rx_next_buf_len;
	uint32_t rx_total_byte_cnt; /* Total number of bytes received */
	uint32_t rx_total_user_byte_cnt; /* Total number of bytes passed to user */
	int32_t rx_timeout; /* Timeout set by user */
	int32_t rx_timeout_slab; /* rx_timeout divided by RX_TIMEOUT_DIV */
	int32_t rx_timeout_left; /* Current time left until user callback */
	struct k_timer rx_timeout_timer;
	union {
		gppi_channel_t ppi;
		uint32_t cnt;
	} rx_cnt;
	volatile int tx_amount;
	bool rx_enabled;
	bool hw_rx_counting;
	/* Flag to ensure that RX timeout won't be executed during ENDRX ISR */
	volatile bool is_in_irq;
#ifdef UARTE_INTERRUPT_DRIVEN
struct uarte_nrfx_int_driven {
	uart_irq_callback_user_data_t cb; /**< Callback function pointer */
	void *cb_data; /**< Callback function arg */
	uint8_t *tx_buffer;
	uint16_t tx_buff_size;
	volatile bool disable_tx_irq;
#ifdef CONFIG_PM_DEVICE
	bool rx_irq_enabled;
	atomic_t fifo_fill_lock;
/* Device data structure */
struct uarte_nrfx_data {
	const struct device *dev;
	struct uart_config uart_config;
	struct uarte_nrfx_int_driven *int_driven;
	struct uarte_async_cb *async;
	atomic_val_t poll_out_lock;
	uint32_t pm_state;
	uint8_t char_out;
	uint8_t rx_data;
	gppi_channel_t ppi_ch_endtx;
#define CTS_PIN_SET_MASK BIT(1)
#define RTS_PIN_SET_MASK BIT(2)
#define IS_CTS_PIN_SET(mask) (mask & CTS_PIN_SET_MASK)
#define IS_RTS_PIN_SET(mask) (mask & RTS_PIN_SET_MASK)
 * @brief Structure for UARTE configuration.
struct uarte_nrfx_config {
	NRF_UARTE_Type *uarte_regs; /* Instance address */
	uint8_t rts_cts_pins_set;
	bool gpio_mgmt;
	bool ppi_endtx;
	nrfx_timer_t timer;
struct uarte_init_config {
	uint32_t  pseltxd; /* PSEL.TXD register value */
	uint32_t  pselrxd; /* PSEL.RXD register value */
	uint32_t  pselcts; /* PSEL.CTS register value */
	uint32_t  pselrts; /* PSEL.RTS register value */
static inline struct uarte_nrfx_data *get_dev_data(const struct device *dev)
	return dev->data;
static inline const struct uarte_nrfx_config *get_dev_config(const struct device *dev)
	return dev->config;
static inline NRF_UARTE_Type *get_uarte_instance(const struct device *dev)
	const struct uarte_nrfx_config *config = get_dev_config(dev);
	return config->uarte_regs;
static void endtx_isr(const struct device *dev)
	NRF_UARTE_Type *uarte = get_uarte_instance(dev);
	int key = irq_lock();
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDTX)) {
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_ENDTX);
		nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STOPTX);
	irq_unlock(key);
#ifdef UARTE_ANY_NONE_ASYNC
 * @brief Interrupt service routine.
 * This simply calls the callback function, if one exists.
 * @param arg Argument to ISR.
 * @return N/A
static void uarte_nrfx_isr_int(void *arg)
	const struct device *dev = arg;
	/* If interrupt driven and asynchronous APIs are disabled then UART
	 * interrupt is still called to stop TX. Unless it is done using PPI.
	if (nrf_uarte_int_enable_check(uarte, NRF_UARTE_INT_ENDTX_MASK) &&
		endtx_isr(dev);
	struct uarte_nrfx_data *data = get_dev_data(dev);
	if (!data->int_driven) {
		return;
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_TXSTOPPED)) {
		data->int_driven->fifo_fill_lock = 0;
		if (data->int_driven->disable_tx_irq) {
			nrf_uarte_int_disable(uarte,
					      NRF_UARTE_INT_TXSTOPPED_MASK);
			data->int_driven->disable_tx_irq = false;
			return;
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ERROR)) {
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_ERROR);
	if (data->int_driven->cb) {
		data->int_driven->cb(dev, data->int_driven->cb_data);
#endif /* UARTE_INTERRUPT_DRIVEN */
#endif /* UARTE_ANY_NONE_ASYNC */
 * @brief Set the baud rate
 * This routine set the given baud rate for the UARTE.
 * @param dev UARTE device struct
 * @param baudrate Baud rate
 * @return 0 on success or error code
static int baudrate_set(const struct device *dev, uint32_t baudrate)
	nrf_uarte_baudrate_t nrf_baudrate; /* calculated baudrate divisor */
	switch (baudrate) {
	case 300:
		/* value not supported by Nordic HAL */
		nrf_baudrate = 0x00014000;
	case 600:
		nrf_baudrate = 0x00027000;
	case 1200:
		nrf_baudrate = NRF_UARTE_BAUDRATE_1200;
	case 2400:
		nrf_baudrate = NRF_UARTE_BAUDRATE_2400;
	case 4800:
		nrf_baudrate = NRF_UARTE_BAUDRATE_4800;
	case 9600:
		nrf_baudrate = NRF_UARTE_BAUDRATE_9600;
	case 14400:
		nrf_baudrate = NRF_UARTE_BAUDRATE_14400;
	case 19200:
		nrf_baudrate = NRF_UARTE_BAUDRATE_19200;
	case 28800:
		nrf_baudrate = NRF_UARTE_BAUDRATE_28800;
	case 31250:
		nrf_baudrate = NRF_UARTE_BAUDRATE_31250;
	case 38400:
		nrf_baudrate = NRF_UARTE_BAUDRATE_38400;
	case 56000:
		nrf_baudrate = NRF_UARTE_BAUDRATE_56000;
	case 57600:
		nrf_baudrate = NRF_UARTE_BAUDRATE_57600;
	case 76800:
		nrf_baudrate = NRF_UARTE_BAUDRATE_76800;
	case 115200:
		nrf_baudrate = NRF_UARTE_BAUDRATE_115200;
	case 230400:
		nrf_baudrate = NRF_UARTE_BAUDRATE_230400;
	case 250000:
		nrf_baudrate = NRF_UARTE_BAUDRATE_250000;
	case 460800:
		nrf_baudrate = NRF_UARTE_BAUDRATE_460800;
	case 921600:
		nrf_baudrate = NRF_UARTE_BAUDRATE_921600;
	case 1000000:
		nrf_baudrate = NRF_UARTE_BAUDRATE_1000000;
		return -EINVAL;
	nrf_uarte_baudrate_set(uarte, nrf_baudrate);
	return 0;
static int uarte_nrfx_configure(const struct device *dev,
				const struct uart_config *cfg)
	nrf_uarte_config_t uarte_cfg;
#if defined(UARTE_CONFIG_STOP_Msk)
	switch (cfg->stop_bits) {
	case UART_CFG_STOP_BITS_1:
		uarte_cfg.stop = NRF_UARTE_STOP_ONE;
	case UART_CFG_STOP_BITS_2:
		uarte_cfg.stop = NRF_UARTE_STOP_TWO;
		return -ENOTSUP;
#else
	if (cfg->stop_bits != UART_CFG_STOP_BITS_1) {
		return -ENOTSUP;
	if (cfg->data_bits != UART_CFG_DATA_BITS_8) {
		return -ENOTSUP;
	switch (cfg->flow_ctrl) {
	case UART_CFG_FLOW_CTRL_NONE:
		uarte_cfg.hwfc = NRF_UARTE_HWFC_DISABLED;
	case UART_CFG_FLOW_CTRL_RTS_CTS:
		if (get_dev_config(dev)->rts_cts_pins_set) {
			uarte_cfg.hwfc = NRF_UARTE_HWFC_ENABLED;
		} else {
			return -ENOTSUP;
		return -ENOTSUP;
#if defined(UARTE_CONFIG_PARITYTYPE_Msk)
	uarte_cfg.paritytype = NRF_UARTE_PARITYTYPE_EVEN;
	switch (cfg->parity) {
	case UART_CFG_PARITY_NONE:
		uarte_cfg.parity = NRF_UARTE_PARITY_EXCLUDED;
	case UART_CFG_PARITY_EVEN:
		uarte_cfg.parity = NRF_UARTE_PARITY_INCLUDED;
	case UART_CFG_PARITY_ODD:
		uarte_cfg.paritytype = NRF_UARTE_PARITYTYPE_ODD;
		return -ENOTSUP;
	if (baudrate_set(dev, cfg->baudrate) != 0) {
		return -ENOTSUP;
	nrf_uarte_configure(get_uarte_instance(dev), &uarte_cfg);
	get_dev_data(dev)->uart_config = *cfg;
	return 0;
static int uarte_nrfx_config_get(const struct device *dev,
	*cfg = get_dev_data(dev)->uart_config;
	return 0;
static int uarte_nrfx_err_check(const struct device *dev)
	/* register bitfields maps to the defines in uart.h */
	return nrf_uarte_errorsrc_get_and_clear(uarte);
/* Function returns true if new transfer can be started. Since TXSTOPPED
 * (and ENDTX) is cleared before triggering new transfer, TX is ready for new
 * transfer if any event is set.
static bool is_tx_ready(const struct device *dev)
	bool ppi_endtx = get_dev_config(dev)->ppi_endtx;
	return nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_TXSTOPPED) ||
		(!ppi_endtx ?
		       nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDTX) : 0);
/* Wait until the transmitter is in the idle state. When this function returns,
 * IRQ's are locked with the returned key.
static int wait_tx_ready(const struct device *dev)
	int key;
	do {
		/* wait arbitrary time before back off. */
		bool res;
		NRFX_WAIT_FOR(is_tx_ready(dev), 100, 1, res);
		if (res) {
			key = irq_lock();
			if (is_tx_ready(dev)) {
			irq_unlock(key);
		k_msleep(1);
	} while (1);
	return key;
static void tx_start(NRF_UARTE_Type *uarte, const uint8_t *buf, size_t len)
	nrf_uarte_tx_buffer_set(uarte, buf, len);
	nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_TXSTOPPED);
	nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STARTTX);
static inline bool hw_rx_counting_enabled(struct uarte_nrfx_data *data)
	if (IS_ENABLED(CONFIG_UARTE_NRF_HW_ASYNC)) {
		return data->async->hw_rx_counting;
	} else {
		return false;
static void timer_handler(nrf_timer_event_t event_type, void *p_context) { }
static void rx_timeout(struct k_timer *timer);
static void tx_timeout(struct k_timer *timer);
static int uarte_nrfx_rx_counting_init(const struct device *dev)
	const struct uarte_nrfx_config *cfg = get_dev_config(dev);
	int ret;
	if (hw_rx_counting_enabled(data)) {
		nrfx_timer_config_t tmr_config = NRFX_TIMER_DEFAULT_CONFIG;
		tmr_config.mode = NRF_TIMER_MODE_COUNTER;
		tmr_config.bit_width = NRF_TIMER_BIT_WIDTH_32;
		ret = nrfx_timer_init(&cfg->timer,
				      &tmr_config,
				      timer_handler);
		if (ret != NRFX_SUCCESS) {
			LOG_ERR("Timer already initialized, "
				"switching to software byte counting.");
			data->async->hw_rx_counting = false;
		} else {
			nrfx_timer_enable(&cfg->timer);
			nrfx_timer_clear(&cfg->timer);
		ret = gppi_channel_alloc(&data->async->rx_cnt.ppi);
			LOG_ERR("Failed to allocate PPI Channel, "
			nrfx_timer_uninit(&cfg->timer);
#if CONFIG_HAS_HW_NRF_PPI
		ret = nrfx_ppi_channel_assign(
			data->async->rx_cnt.ppi,
			nrf_uarte_event_address_get(uarte,
						    NRF_UARTE_EVENT_RXDRDY),
			nrfx_timer_task_address_get(&cfg->timer,
						    NRF_TIMER_TASK_COUNT));
			return -EIO;
#else
		nrf_uarte_publish_set(uarte,
				      NRF_UARTE_EVENT_RXDRDY,
		nrf_timer_subscribe_set(cfg->timer.p_reg,
					NRF_TIMER_TASK_COUNT,
		ret = gppi_channel_enable(data->async->rx_cnt.ppi);
			return -EIO;
	} else {
		nrf_uarte_int_enable(uarte, NRF_UARTE_INT_RXDRDY_MASK);
	return 0;
static int uarte_nrfx_init(const struct device *dev)
	int ret = uarte_nrfx_rx_counting_init(dev);
	if (ret != 0) {
		return ret;
			     NRF_UARTE_INT_ENDRX_MASK |
			     NRF_UARTE_INT_RXSTARTED_MASK |
			     NRF_UARTE_INT_ERROR_MASK |
			     NRF_UARTE_INT_RXTO_MASK);
	nrf_uarte_enable(uarte);
	 * Stop any currently running RX operations. This can occur when a
	 * bootloader sets up the UART hardware and does not clean it up
	 * before jumping to the next application.
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXSTARTED)) {
		nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STOPRX);
		while (!nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXTO)) {
			/* Busy wait for event to register */
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_RXSTARTED);
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_ENDRX);
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_RXTO);
	k_timer_init(&data->async->rx_timeout_timer, rx_timeout, NULL);
	k_timer_user_data_set(&data->async->rx_timeout_timer, data);
	k_timer_init(&data->async->tx_timeout_timer, tx_timeout, NULL);
	k_timer_user_data_set(&data->async->tx_timeout_timer, data);
	return 0;
static int uarte_nrfx_tx(const struct device *dev, const uint8_t *buf,
			 size_t len,
			 int32_t timeout)
	if (!nrfx_is_in_ram(buf)) {
		return -ENOTSUP;
	if (data->async->tx_size) {
		irq_unlock(key);
		return -EBUSY;
	} else {
		data->async->tx_size = len;
	nrf_uarte_int_enable(uarte, NRF_UARTE_INT_TXSTOPPED_MASK);
	if (!is_tx_ready(dev)) {
		/* Active poll out, postpone until it is completed. */
		data->async->pend_tx_buf = (uint8_t *)buf;
	} else {
		data->async->tx_buf = buf;
		data->async->tx_amount = -1;
		tx_start(uarte, buf, len);
	irq_unlock(key);
	if (data->uart_config.flow_ctrl == UART_CFG_FLOW_CTRL_RTS_CTS
	    && timeout != SYS_FOREVER_MS) {
		k_timer_start(&data->async->tx_timeout_timer, K_MSEC(timeout),
			      K_NO_WAIT);
	return 0;
static int uarte_nrfx_tx_abort(const struct device *dev)
	if (data->async->tx_buf == NULL) {
		return -EFAULT;
	k_timer_stop(&data->async->tx_timeout_timer);
	return 0;
static int uarte_nrfx_rx_enable(const struct device *dev, uint8_t *buf,
				size_t len,
				int32_t timeout)
	if (nrf_uarte_rx_pin_get(uarte) == NRF_UARTE_PSEL_DISCONNECTED) {
		__ASSERT(false, "TX only UARTE instance");
		return -ENOTSUP;
	data->async->rx_timeout = timeout;
	data->async->rx_timeout_slab =
		MAX(timeout / RX_TIMEOUT_DIV,
		    NRFX_CEIL_DIV(1000, CONFIG_SYS_CLOCK_TICKS_PER_SEC));
	data->async->rx_buf = buf;
	data->async->rx_buf_len = len;
	data->async->rx_offset = 0;
	data->async->rx_next_buf = NULL;
	data->async->rx_next_buf_len = 0;
	nrf_uarte_rx_buffer_set(uarte, buf, len);
	data->async->rx_enabled = true;
	nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STARTRX);
	return 0;
static int uarte_nrfx_rx_buf_rsp(const struct device *dev, uint8_t *buf,
				 size_t len)
	int err;
	if ((data->async->rx_buf == NULL)) {
		err = -EACCES;
	} else if (data->async->rx_next_buf == NULL) {
		data->async->rx_next_buf = buf;
		data->async->rx_next_buf_len = len;
		nrf_uarte_shorts_enable(uarte, NRF_UARTE_SHORT_ENDRX_STARTRX);
		err = 0;
	} else {
		err = -EBUSY;
	irq_unlock(key);
	return err;
static int uarte_nrfx_callback_set(const struct device *dev,
				   uart_callback_t callback,
				   void *user_data)
	data->async->user_callback = callback;
	data->async->user_data = user_data;
	return 0;
static int uarte_nrfx_rx_disable(const struct device *dev)
	if (data->async->rx_buf == NULL) {
		return -EFAULT;
	if (data->async->rx_next_buf != NULL) {
		nrf_uarte_shorts_disable(uarte, NRF_UARTE_SHORT_ENDRX_STARTRX);
	k_timer_stop(&data->async->rx_timeout_timer);
	data->async->rx_enabled = false;
	return 0;
	struct uarte_nrfx_data *data = k_timer_user_data_get(timer);
	(void) uarte_nrfx_tx_abort(data->dev);
static void user_callback(const struct device *dev, struct uart_event *evt)
	if (data->async->user_callback) {
		data->async->user_callback(dev, evt, data->async->user_data);
 * Whole timeout is divided by RX_TIMEOUT_DIV into smaller units, rx_timeout
 * is executed periodically every rx_timeout_slab ms. If between executions
 * data was received, then we start counting down time from start, if not, then
 * we subtract rx_timeout_slab from rx_timeout_left.
 * If rx_timeout_left is less than rx_timeout_slab it means that receiving has
 * timed out and we should tell user about that.
	const struct device *dev = data->dev;
	uint32_t read;
	if (data->async->is_in_irq) {
		return;
	/* Disable ENDRX ISR, in case ENDRX event is generated, it will be
	 * handled after rx_timeout routine is complete.
	nrf_uarte_int_disable(get_uarte_instance(dev),
			      NRF_UARTE_INT_ENDRX_MASK);
		read = nrfx_timer_capture(&cfg->timer, 0);
	} else {
		read = data->async->rx_cnt.cnt;
	/* Check if data was received since last function call */
	if (read != data->async->rx_total_byte_cnt) {
		data->async->rx_total_byte_cnt = read;
		data->async->rx_timeout_left = data->async->rx_timeout;
	/* Check if there is data that was not sent to user yet
	 * Note though that 'len' is a count of data bytes received, but not
	 * necessarily the amount available in the current buffer
	int32_t len = data->async->rx_total_byte_cnt
		    - data->async->rx_total_user_byte_cnt;
	/* Check for current buffer being full.
	 * if the UART receives characters before the the ENDRX is handled
	 * and the 'next' buffer is set up, then the SHORT between ENDRX and
	 * STARTRX will mean that data will be going into to the 'next' buffer
	 * until the ENDRX event gets a chance to be handled.
	bool clipped = false;
	if (len + data->async->rx_offset > data->async->rx_buf_len) {
		len = data->async->rx_buf_len - data->async->rx_offset;
		clipped = true;
	if (len > 0) {
		if (clipped ||
			(data->async->rx_timeout_left
				< data->async->rx_timeout_slab)) {
			/* rx_timeout ms elapsed since last receiving */
			struct uart_event evt = {
				.type = UART_RX_RDY,
				.data.rx.buf = data->async->rx_buf,
				.data.rx.len = len,
				.data.rx.offset = data->async->rx_offset
			data->async->rx_offset += len;
			data->async->rx_total_user_byte_cnt += len;
			user_callback(dev, &evt);
		} else {
			data->async->rx_timeout_left -=
				data->async->rx_timeout_slab;
		/* If theres nothing left to report until the buffers are
		 * switched then the timer can be stopped
		if (clipped) {
	nrf_uarte_int_enable(get_uarte_instance(dev),
#define UARTE_ERROR_FROM_MASK(mask)					\
	((mask) & NRF_UARTE_ERROR_OVERRUN_MASK ? UART_ERROR_OVERRUN	\
	 : (mask) & NRF_UARTE_ERROR_PARITY_MASK ? UART_ERROR_PARITY	\
	 : (mask) & NRF_UARTE_ERROR_FRAMING_MASK ? UART_ERROR_FRAMING	\
	 : (mask) & NRF_UARTE_ERROR_BREAK_MASK ? UART_BREAK		\
	 : 0)
static void error_isr(const struct device *dev)
	uint32_t err = nrf_uarte_errorsrc_get_and_clear(uarte);
		.type = UART_RX_STOPPED,
		.data.rx_stop.reason = UARTE_ERROR_FROM_MASK(err),
	(void) uarte_nrfx_rx_disable(dev);
static void rxstarted_isr(const struct device *dev)
		.type = UART_RX_BUF_REQUEST,
	if (data->async->rx_timeout != SYS_FOREVER_MS) {
		k_timer_start(&data->async->rx_timeout_timer,
			      K_MSEC(data->async->rx_timeout_slab),
			      K_MSEC(data->async->rx_timeout_slab));
static void endrx_isr(const struct device *dev)
	if (!data->async->rx_enabled) {
			/* This condition can occur only after triggering
			 * FLUSHRX task.
			const int rx_amount = nrf_uarte_rx_amount_get(uarte);
			int real_rx_amount = 0;
			if(rx_amount != uarte_prev_rx_amount) {
				real_rx_amount = rx_amount;
			} else {
				for(int i = 0; i < sizeof(po_flush_buf); i++) {
					if(po_flush_buf[i] != uarte_prev_dirty) {
				.type = UART_RX_DISABLED,
				.data.rx.buf = &po_flush_buf,
				.data.rx.len = real_rx_amount,
				.data.rx.offset = -1,
			return;
	data->async->is_in_irq = true;
	/* ensure rx timer is stopped - it will be restarted in RXSTARTED
	 * handler if needed
	/* this is the amount that the EasyDMA controller has copied into the
	 * buffer
	/* The 'rx_offset' can be bigger than 'rx_amount', so it the length
	 * of data we report back the the user may need to be clipped.
	 * This can happen because the 'rx_offset' count derives from RXRDY
	 * events, which can occur already for the next buffer before we are
	 * here to handle this buffer. (The next buffer is now already active
	 * because of the ENDRX_STARTRX shortcut)
	int rx_len = rx_amount - data->async->rx_offset;
	if (rx_len < 0) {
		rx_len = 0;
	data->async->rx_total_user_byte_cnt += rx_len;
	if (!hw_rx_counting_enabled(data)) {
		/* Prevent too low value of rx_cnt.cnt which may occur due to
		 * latencies in handling of the RXRDY interrupt. Because whole
		 * buffer was filled we can be sure that rx_total_user_byte_cnt
		 * is current total number of received bytes.
		data->async->rx_cnt.cnt = data->async->rx_total_user_byte_cnt;
	/* Only send the RX_RDY event if there is something to send */
	if (rx_len > 0) {
			.data.rx.len = rx_len,
			.data.rx.offset = data->async->rx_offset,
		data->async->is_in_irq = false;
		return;
		.type = UART_RX_BUF_RELEASED,
		.data.rx_buf.buf = data->async->rx_buf,
	/* If there is a next buffer, then STARTRX will have already been
	 * invoked by the short (the next buffer will be filling up already)
	 * and here we just do the swap of which buffer the driver is following,
	 * the next rx_timeout() will update the rx_offset.
	if (data->async->rx_next_buf) {
		data->async->rx_buf = data->async->rx_next_buf;
		data->async->rx_buf_len = data->async->rx_next_buf_len;
		/* Check is based on assumption that ISR handler handles
		 * ENDRX before RXSTARTED so if short was set on time, RXSTARTED
		 * event will be set.
		if (!nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXSTARTED)) {
		/* Remove the short until the subsequent next buffer is setup */
	} else {
		data->async->rx_buf = NULL;
	irq_unlock(key);
		evt.type = UART_RX_DISABLED;
/* This handler is called when the reception is interrupted, in contrary to
 * finishing the reception after filling all provided buffers, in which case
 * the events UART_RX_BUF_RELEASED and UART_RX_DISABLED are reported
 * from endrx_isr.
static void rxto_isr(const struct device *dev)
	static const uint8_t dirty;
		evt.type = UART_RX_BUF_RELEASED;
		evt.data.rx_buf.buf = data->async->rx_next_buf;
	/* Flushing RX fifo requires buffer bigger than 4 bytes to empty fifo */
	uarte_prev_rx_amount = nrf_uarte_rx_amount_get(get_uarte_instance(dev));
	uarte_prev_dirty = dirty;
	memset(po_flush_buf, dirty, sizeof(po_flush_buf));
	nrf_uarte_rx_buffer_set(get_uarte_instance(dev), po_flush_buf, 5);
	/* Final part of handling RXTO event is in ENDRX interrupt handler.
	 * ENDRX is generated as a result of FLUSHRX task.
	nrf_uarte_task_trigger(get_uarte_instance(dev), NRF_UARTE_TASK_FLUSHRX);
static void txstopped_isr(const struct device *dev)
	int key;
	if (!data->async->tx_buf) {
		/* If there is a pending tx request, it means that uart_tx()
		 * was called when there was ongoing uart_poll_out. Handling
		 * TXSTOPPED interrupt means that uart_poll_out has completed.
		if (data->async->pend_tx_buf) {
			key = irq_lock();
				data->async->tx_buf = data->async->pend_tx_buf;
				data->async->pend_tx_buf = NULL;
				tx_start(uarte, data->async->tx_buf,
					 data->async->tx_size);
			irq_unlock(key);
		return;
	key = irq_lock();
	size_t amount = (data->async->tx_amount >= 0) ?
			data->async->tx_amount : nrf_uarte_tx_amount_get(uarte);
	irq_unlock(key);
		.data.tx.buf = data->async->tx_buf,
		.data.tx.len = amount,
	if (amount == data->async->tx_size) {
		evt.type = UART_TX_DONE;
	} else {
		evt.type = UART_TX_ABORTED;
	nrf_uarte_int_disable(uarte, NRF_UARTE_INT_TXSTOPPED_MASK);
	data->async->tx_buf = NULL;
	data->async->tx_size = 0;
static void uarte_nrfx_isr_async(const struct device *dev)
	    && nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXDRDY)) {
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_RXDRDY);
		data->async->rx_cnt.cnt++;
		return;
		error_isr(dev);
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDRX)) {
		endrx_isr(dev);
		rxstarted_isr(dev);
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXTO)) {
		rxto_isr(dev);
	    && nrf_uarte_int_enable_check(uarte, NRF_UARTE_INT_ENDTX_MASK)) {
		endtx_isr(dev);
					  NRF_UARTE_INT_TXSTOPPED_MASK)) {
		txstopped_isr(dev);
#endif /* CONFIG_UART_ASYNC_API */
 * @brief Poll the device for input.
 * @param c Pointer to character
 * @return 0 if a character arrived, -1 if the input buffer is empty.
static int uarte_nrfx_poll_in(const struct device *dev, unsigned char *c)
	const struct uarte_nrfx_data *data = get_dev_data(dev);
	if (data->async) {
		return -ENOTSUP;
	if (!nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDRX)) {
		return -1;
	*c = data->rx_data;
	/* clear the interrupt */
	return 0;
 * @brief Output a character in polled mode.
 * @param c Character to send
static void uarte_nrfx_poll_out(const struct device *dev, unsigned char c)
	bool isr_mode = k_is_in_isr() || k_is_pre_kernel();
	int key;
	if (data->pm_state != DEVICE_PM_ACTIVE_STATE) {
		return;
	if (isr_mode) {
		while (1) {
			key = irq_lock();
#if CONFIG_UART_ASYNC_API
				if (data->async && data->async->tx_size &&
					data->async->tx_amount < 0) {
			irq_unlock(key);
	} else {
		key = wait_tx_ready(dev);
	/* At this point we should have irq locked and any previous transfer
	 * completed. Transfer can be started, no need to wait for completion.
	data->char_out = c;
	tx_start(uarte, &data->char_out, 1);
	irq_unlock(key);
/** Interrupt driven FIFO fill function */
static int uarte_nrfx_fifo_fill(const struct device *dev,
				const uint8_t *tx_data,
				int len)
	len = MIN(len, data->int_driven->tx_buff_size);
	if (!atomic_cas(&data->int_driven->fifo_fill_lock, 0, 1)) {
		return 0;
	/* Copy data to RAM buffer for EasyDMA transfer */
	for (int i = 0; i < len; i++) {
		data->int_driven->tx_buffer[i] = tx_data[i];
		len = 0;
	} else {
		tx_start(uarte, data->int_driven->tx_buffer, len);
	irq_unlock(key);
	return len;
/** Interrupt driven FIFO read function */
static int uarte_nrfx_fifo_read(const struct device *dev,
				uint8_t *rx_data,
				const int size)
	int num_rx = 0;
		/* Clear the interrupt */
		/* Receive a character */
		rx_data[num_rx++] = (uint8_t)data->rx_data;
	return num_rx;
/** Interrupt driven transfer enabling function */
static void uarte_nrfx_irq_tx_enable(const struct device *dev)
	irq_unlock(key);
/** Interrupt driven transfer disabling function */
static void uarte_nrfx_irq_tx_disable(const struct device *dev)
	/* TX IRQ will be disabled after current transmission is finished */
	data->int_driven->disable_tx_irq = true;
/** Interrupt driven transfer ready function */
static int uarte_nrfx_irq_tx_ready_complete(const struct device *dev)
	/* ENDTX flag is always on so that ISR is called when we enable TX IRQ.
	 * Because of that we have to explicitly check if ENDTX interrupt is
	 * enabled, otherwise this function would always return true no matter
	 * what would be the source of interrupt.
	bool ready = !data->int_driven->disable_tx_irq &&
		     nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_TXSTOPPED) &&
	if (ready) {
	return ready;
static int uarte_nrfx_irq_rx_ready(const struct device *dev)
	return nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDRX);
/** Interrupt driven receiver enabling function */
static void uarte_nrfx_irq_rx_enable(const struct device *dev)
	nrf_uarte_int_enable(uarte, NRF_UARTE_INT_ENDRX_MASK);
/** Interrupt driven receiver disabling function */
static void uarte_nrfx_irq_rx_disable(const struct device *dev)
	nrf_uarte_int_disable(uarte, NRF_UARTE_INT_ENDRX_MASK);
/** Interrupt driven error enabling function */
static void uarte_nrfx_irq_err_enable(const struct device *dev)
	nrf_uarte_int_enable(uarte, NRF_UARTE_INT_ERROR_MASK);
/** Interrupt driven error disabling function */
static void uarte_nrfx_irq_err_disable(const struct device *dev)
	nrf_uarte_int_disable(uarte, NRF_UARTE_INT_ERROR_MASK);
/** Interrupt driven pending status function */
static int uarte_nrfx_irq_is_pending(const struct device *dev)
	return ((nrf_uarte_int_enable_check(uarte,
					    NRF_UARTE_INT_TXSTOPPED_MASK) &&
		 uarte_nrfx_irq_tx_ready_complete(dev))
					    NRF_UARTE_INT_ENDRX_MASK) &&
		 uarte_nrfx_irq_rx_ready(dev)));
/** Interrupt driven interrupt update function */
static int uarte_nrfx_irq_update(const struct device *dev)
	return 1;
/** Set the callback function */
static void uarte_nrfx_irq_callback_set(const struct device *dev,
					uart_irq_callback_user_data_t cb,
					void *cb_data)
	data->int_driven->cb = cb;
	data->int_driven->cb_data = cb_data;
static const struct uart_driver_api uart_nrfx_uarte_driver_api = {
	.poll_in		= uarte_nrfx_poll_in,
	.poll_out		= uarte_nrfx_poll_out,
	.err_check		= uarte_nrfx_err_check,
	.configure              = uarte_nrfx_configure,
	.config_get             = uarte_nrfx_config_get,
	.callback_set		= uarte_nrfx_callback_set,
	.tx			= uarte_nrfx_tx,
	.tx_abort		= uarte_nrfx_tx_abort,
	.rx_enable		= uarte_nrfx_rx_enable,
	.rx_buf_rsp		= uarte_nrfx_rx_buf_rsp,
	.rx_disable		= uarte_nrfx_rx_disable,
	.fifo_fill		= uarte_nrfx_fifo_fill,
	.fifo_read		= uarte_nrfx_fifo_read,
	.irq_tx_enable		= uarte_nrfx_irq_tx_enable,
	.irq_tx_disable		= uarte_nrfx_irq_tx_disable,
	.irq_tx_ready		= uarte_nrfx_irq_tx_ready_complete,
	.irq_rx_enable		= uarte_nrfx_irq_rx_enable,
	.irq_rx_disable		= uarte_nrfx_irq_rx_disable,
	.irq_tx_complete	= uarte_nrfx_irq_tx_ready_complete,
	.irq_rx_ready		= uarte_nrfx_irq_rx_ready,
	.irq_err_enable		= uarte_nrfx_irq_err_enable,
	.irq_err_disable	= uarte_nrfx_irq_err_disable,
	.irq_is_pending		= uarte_nrfx_irq_is_pending,
	.irq_update		= uarte_nrfx_irq_update,
	.irq_callback_set	= uarte_nrfx_irq_callback_set,
static int endtx_stoptx_ppi_init(NRF_UARTE_Type *uarte,
	nrfx_err_t ret;
	ret = gppi_channel_alloc(&data->ppi_ch_endtx);
		LOG_ERR("Failed to allocate PPI Channel");
		return -EIO;
	nrfx_gppi_channel_endpoints_setup(data->ppi_ch_endtx,
		nrf_uarte_event_address_get(uarte, NRF_UARTE_EVENT_ENDTX),
		nrf_uarte_task_address_get(uarte, NRF_UARTE_TASK_STOPTX));
	nrfx_gppi_channels_enable(BIT(data->ppi_ch_endtx));
	return 0;
static int uarte_instance_init(const struct device *dev,
			       const struct uarte_init_config *config,
			       uint8_t interrupts_active)
	int err;
	nrf_uarte_disable(uarte);
	data->dev = dev;
	nrf_gpio_pin_write(config->pseltxd, 1);
	nrf_gpio_cfg_output(config->pseltxd);
	if (config->pselrxd !=  NRF_UARTE_PSEL_DISCONNECTED) {
		nrf_gpio_cfg_input(config->pselrxd, NRF_GPIO_PIN_NOPULL);
	nrf_uarte_txrx_pins_set(uarte, config->pseltxd, config->pselrxd);
	if (config->pselcts != NRF_UARTE_PSEL_DISCONNECTED) {
		nrf_gpio_cfg_input(config->pselcts, NRF_GPIO_PIN_NOPULL);
	if (config->pselrts != NRF_UARTE_PSEL_DISCONNECTED) {
		nrf_gpio_pin_write(config->pselrts, 1);
		nrf_gpio_cfg_output(config->pselrts);
	nrf_uarte_hwfc_pins_set(uarte, config->pselrts, config->pselcts);
	err = uarte_nrfx_configure(dev, &get_dev_data(dev)->uart_config);
	if (err) {
		return err;
	data->pm_state = DEVICE_PM_ACTIVE_STATE;
	if (get_dev_config(dev)->ppi_endtx) {
		err = endtx_stoptx_ppi_init(uarte, data);
		if (err < 0) {
			return err;
	if (data->async) {
		err = uarte_nrfx_init(dev);
		if (err < 0) {
			return err;
	} else
		/* Enable receiver and transmitter */
			nrf_uarte_rx_buffer_set(uarte, &data->rx_data, 1);
	if (!get_dev_config(dev)->ppi_endtx) {
		nrf_uarte_int_enable(uarte, NRF_UARTE_INT_ENDTX_MASK);
	/* Set TXSTOPPED event by requesting fake (zero-length) transfer.
	 * Pointer to RAM variable (data->tx_buffer) is set because otherwise
	 * such operation may result in HardFault or RAM corruption.
	nrf_uarte_tx_buffer_set(uarte, &data->char_out, 0);
	/* switch off transmitter to save an energy */
	return 0;
static void uarte_nrfx_pins_enable(const struct device *dev, bool enable)
	if (!get_dev_config(dev)->gpio_mgmt) {
		return;
	uint32_t tx_pin = nrf_uarte_tx_pin_get(uarte);
	uint32_t rx_pin = nrf_uarte_rx_pin_get(uarte);
	uint32_t cts_pin = nrf_uarte_cts_pin_get(uarte);
	uint32_t rts_pin = nrf_uarte_rts_pin_get(uarte);
	if (enable) {
		nrf_gpio_pin_write(tx_pin, 1);
		nrf_gpio_cfg_output(tx_pin);
		if (rx_pin != NRF_UARTE_PSEL_DISCONNECTED) {
			nrf_gpio_cfg_input(rx_pin, NRF_GPIO_PIN_NOPULL);
		if (IS_RTS_PIN_SET(get_dev_config(dev)->rts_cts_pins_set)) {
			nrf_gpio_pin_write(rts_pin, 1);
			nrf_gpio_cfg_output(rts_pin);
		if (IS_CTS_PIN_SET(get_dev_config(dev)->rts_cts_pins_set)) {
			nrf_gpio_cfg_input(cts_pin,
	} else {
		nrf_gpio_cfg_default(tx_pin);
			nrf_gpio_cfg_default(rx_pin);
			nrf_gpio_cfg_default(rts_pin);
			nrf_gpio_cfg_default(cts_pin);
static void uarte_nrfx_set_power_state(const struct device *dev,
				       uint32_t new_state)
	if (new_state == DEVICE_PM_ACTIVE_STATE) {
		uarte_nrfx_pins_enable(dev, true);
		data->pm_state = new_state;
		if (hw_rx_counting_enabled(get_dev_data(dev))) {
			nrfx_timer_enable(&get_dev_config(dev)->timer);
		if (get_dev_data(dev)->async) {
			return;
		if (nrf_uarte_rx_pin_get(uarte) !=
			if (data->int_driven &&
			    data->int_driven->rx_irq_enabled) {
	} else {
		__ASSERT_NO_MSG(new_state == DEVICE_PM_LOW_POWER_STATE ||
				new_state == DEVICE_PM_SUSPEND_STATE ||
				new_state == DEVICE_PM_OFF_STATE);
		/* if pm is already not active, driver will stay indefinitely
		 * in while loop waiting for event NRF_UARTE_EVENT_RXTO
			return;
		/* Disabling UART requires stopping RX, but stop RX event is
		 * only sent after each RX if async UART API is used.
			nrfx_timer_disable(&get_dev_config(dev)->timer);
			/* Timer/counter value is reset when disabled. */
			data->async->rx_total_byte_cnt = 0;
			data->async->rx_total_user_byte_cnt = 0;
			/* Wait for the transmitter to go idle.
			 * While the async API can wait for transmission to
			 * complete before disabling the peripheral, the poll
			 * API exits before the character is sent on the wire.
			 * If the transmission is ongoing when the peripheral
			 * is disabled, the ENDTX and TXSTOPPED events will
			 * never be generated. This will block the driver in
			 * any future calls to poll_out.
			irq_unlock(wait_tx_ready(dev));
			uarte_nrfx_pins_enable(dev, false);
			return;
			if (data->int_driven) {
				data->int_driven->rx_irq_enabled =
				if (data->int_driven->rx_irq_enabled) {
static int uarte_nrfx_pm_control(const struct device *dev,
				 uint32_t ctrl_command,
				 void *context, device_pm_cb cb, void *arg)
	if (ctrl_command == DEVICE_PM_SET_POWER_STATE) {
		uint32_t new_state = *((const uint32_t *)context);
		if (new_state != data->pm_state) {
			uarte_nrfx_set_power_state(dev, new_state);
	} else {
		__ASSERT_NO_MSG(ctrl_command == DEVICE_PM_GET_POWER_STATE);
		*((uint32_t *)context) = data->pm_state;
	if (cb) {
		cb(dev, 0, context, arg);
	return 0;
#endif /* CONFIG_PM_DEVICE */
#define UARTE(idx)			DT_NODELABEL(uart##idx)
#define UARTE_HAS_PROP(idx, prop)	DT_NODE_HAS_PROP(UARTE(idx), prop)
#define UARTE_PROP(idx, prop)		DT_PROP(UARTE(idx), prop)
#define UARTE_PSEL(idx, pin_prop)					       \
	COND_CODE_1(UARTE_HAS_PROP(idx, pin_prop),			       \
		    (UARTE_PROP(idx, pin_prop)),			       \
		    (NRF_UARTE_PSEL_DISCONNECTED))
#define HWFC_AVAILABLE(idx)					       \
	(UARTE_HAS_PROP(idx, rts_pin) || UARTE_HAS_PROP(idx, cts_pin))
#define UARTE_IRQ_CONFIGURE(idx, isr_handler)				       \
	do {								       \
		IRQ_CONNECT(DT_IRQN(UARTE(idx)), DT_IRQ(UARTE(idx), priority), \
			    isr_handler, DEVICE_DT_GET(UARTE(idx)), 0); \
		irq_enable(DT_IRQN(UARTE(idx)));			       \
	} while (0)
#define HWFC_CONFIG_CHECK(idx) \
	BUILD_ASSERT( \
		(UARTE_PROP(idx, hw_flow_control) && HWFC_AVAILABLE(idx)) \
		!UARTE_PROP(idx, hw_flow_control) \
#define UART_NRF_UARTE_DEVICE(idx)					       \
	HWFC_CONFIG_CHECK(idx);						       \
	UARTE_INT_DRIVEN(idx);						       \
	UARTE_ASYNC(idx);						       \
	static struct uarte_nrfx_data uarte_##idx##_data = {		       \
		UARTE_CONFIG(idx),					       \
		IF_ENABLED(CONFIG_UART_##idx##_ASYNC,			       \
			    (.async = &uarte##idx##_async,))		       \
		IF_ENABLED(CONFIG_UART_##idx##_INTERRUPT_DRIVEN,	       \
			    (.int_driven = &uarte##idx##_int_driven,))	       \
	static const struct uarte_nrfx_config uarte_##idx##z_config = {	       \
		.uarte_regs = (NRF_UARTE_Type *)DT_REG_ADDR(UARTE(idx)),       \
		.rts_cts_pins_set =					       \
			(UARTE_HAS_PROP(idx, rts_pin) ? RTS_PIN_SET_MASK : 0) |\
			(UARTE_HAS_PROP(idx, cts_pin) ? CTS_PIN_SET_MASK : 0), \
		.gpio_mgmt = IS_ENABLED(CONFIG_UART_##idx##_GPIO_MANAGEMENT),  \
		.ppi_endtx = IS_ENABLED(CONFIG_UART_##idx##_ENHANCED_POLL_OUT),\
		IF_ENABLED(CONFIG_UART_##idx##_NRF_HW_ASYNC,		       \
			(.timer = NRFX_TIMER_INSTANCE(			       \
				CONFIG_UART_##idx##_NRF_HW_ASYNC_TIMER),))     \
	static int uarte_##idx##_init(const struct device *dev)		       \
		const struct uarte_init_config init_config = {		       \
			.pseltxd = UARTE_PROP(idx, tx_pin),  /* must be set */ \
			.pselrxd = UARTE_PSEL(idx, rx_pin),  /* optional */    \
			.pselcts = UARTE_PSEL(idx, cts_pin), /* optional */    \
			.pselrts = UARTE_PSEL(idx, rts_pin), /* optional */    \
		COND_CODE_1(CONFIG_UART_##idx##_ASYNC,			       \
			   (UARTE_IRQ_CONFIGURE(idx, uarte_nrfx_isr_async);),  \
			   (UARTE_IRQ_CONFIGURE(idx, uarte_nrfx_isr_int);))    \
		return uarte_instance_init(				       \
			dev,						       \
			&init_config,					       \
			IS_ENABLED(CONFIG_UART_##idx##_INTERRUPT_DRIVEN));     \
	DEVICE_DT_DEFINE(UARTE(idx),					       \
		      uarte_##idx##_init,				       \
		      uarte_nrfx_pm_control,				       \
		      &uarte_##idx##_data,				       \
		      &uarte_##idx##z_config,				       \
		      PRE_KERNEL_1,					       \
		      CONFIG_KERNEL_INIT_PRIORITY_DEVICE,		       \
		      &uart_nrfx_uarte_driver_api)
#define UARTE_CONFIG(idx)						       \
	.uart_config = {						       \
		.baudrate = UARTE_PROP(idx, current_speed),		       \
		.data_bits = UART_CFG_DATA_BITS_8,			       \
		.stop_bits = UART_CFG_STOP_BITS_1,			       \
		.parity = IS_ENABLED(CONFIG_UART_##idx##_NRF_PARITY_BIT)       \
			  ? UART_CFG_PARITY_EVEN			       \
			  : UART_CFG_PARITY_NONE,			       \
		.flow_ctrl = UARTE_PROP(idx, hw_flow_control)  \
			     ? UART_CFG_FLOW_CTRL_RTS_CTS		       \
			     : UART_CFG_FLOW_CTRL_NONE,			       \
#define UARTE_ASYNC(idx)						       \
		(struct uarte_async_cb uarte##idx##_async = {		       \
			.hw_rx_counting =				       \
				IS_ENABLED(CONFIG_UART_##idx##_NRF_HW_ASYNC),  \
#define UARTE_INT_DRIVEN(idx)						       \
		(static uint8_t uarte##idx##_tx_buffer[\
			MIN(CONFIG_UART_##idx##_NRF_TX_BUFFER_SIZE,	       \
			    BIT_MASK(UARTE##idx##_EASYDMA_MAXCNT_SIZE))];      \
		 static struct uarte_nrfx_int_driven			       \
			uarte##idx##_int_driven = {			       \
				.tx_buffer = uarte##idx##_tx_buffer,	       \
				.tx_buff_size = sizeof(uarte##idx##_tx_buffer),\
#ifdef CONFIG_UART_0_NRF_UARTE
UART_NRF_UARTE_DEVICE(0);
#ifdef CONFIG_UART_1_NRF_UARTE
UART_NRF_UARTE_DEVICE(1);
#ifdef CONFIG_UART_2_NRF_UARTE
UART_NRF_UARTE_DEVICE(2);
#ifdef CONFIG_UART_3_NRF_UARTE
UART_NRF_UARTE_DEVICE(3);
prj.conf
# NEWLIB C
CONFIG_NEWLIB_LIBC=y
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
# General
# CONFIG_REBOOT=y
# CONFIG_EVENT_MANAGER=y
# CONFIG_LINKER_ORPHAN_SECTION_PLACE=y
# CONFIG_SPEED_OPTIMIZATIONS=y
# CONFIG_DEVICE_POWER_MANAGEMENT=y
# CONFIG_PM_POLICY_APP=y
#  # UART
# CONFIG_SERIAL=y
# CONFIG_UART_INTERRUPT_DRIVEN=y
# CONFIG_UART_0_INTERRUPT_DRIVEN=n
# CONFIG_UART_1_INTERRUPT_DRIVEN=n
# CONFIG_UART_LINE_CTRL=y
# CONFIG_UART_ASYNC_API=y
# CONFIG_UART_0_ASYNC=y
# CONFIG_UART_1_ASYNC=y
# CONFIG_UART_0_NRF_HW_ASYNC=y
# CONFIG_UART_1_NRF_HW_ASYNC=y
# CONFIG_UART_0_NRF_HW_ASYNC_TIMER=1
# CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
# CONFIG_NRFX_UARTE=y
# CONFIG_NRFX_UARTE0=y
# CONFIG_NRFX_UARTE1=y
# CONFIG_NRFX_TIMER=y
# CONFIG_NRFX_TIMER1=y
# CONFIG_NRFX_TIMER2=y
# CONFIG_NRFX_PPI=y
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_MODEM_LIB_SYS_INIT=n
# Modem information
CONFIG_MODEM_INFO=y
CONFIG_NETWORKING=y
CONFIG_NET_TCP=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_NATIVE=n
CONFIG_NET_IPV6=n
CONFIG_NET_IPV4=y
CONFIG_NET_SOCKETS_POLL_MAX=4
CONFIG_NET_CONNECTION_MANAGER=y
# Network buffers
CONFIG_NET_PKT_RX_COUNT=16
CONFIG_NET_PKT_TX_COUNT=16
CONFIG_NET_BUF_RX_COUNT=80
CONFIG_NET_BUF_TX_COUNT=80
CONFIG_NET_CONTEXT_NET_PKT_POOL=y
#CONFIG_NET_IF_MAX_IPV4_COUNT=2
#CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=3
#CONFIG_DNS_SERVER_IP_ADDRESSES=y
#CONFIG_DNS_SERVER1="8.8.8.8"
#CONFIG_DNS_RESOLVER=y
#CONFIG_DNS_RESOLVER_ADDITIONAL_BUF_CTR=2
#CONFIG_SNTP=y
CONFIG_HTTP_CLIENT=y
CONFIG_HTTP_PARSER_URL=y
CONFIG_HEAP_MEM_POOL_SIZE=65536
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_PRIVILEGED_STACK_SIZE=8192
CONFIG_ISR_STACK_SIZE=8192
#CONFIG_AT_CMD_THREAD_STACK_SIZE=4096
CONFIG_MODEM_KEY_MGMT=y
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# CONFIG_DFU_TARGET=y
CONFIG_BOOTLOADER_MCUBOOT=y
#CONFIG_BOOT_ENCRYPT_RSA=n
#CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
#CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=n
#CONFIG_BOOT_SIGNATURE_KEY_FILE="tinykey.pem"
CONFIG_MCUBOOT_IMAGE_VERSION="1.0.10"
CONFIG_HWINFO=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_IMG_MANAGER=y
CONFIG_FLASH=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
CONFIG_LOG=y
CONFIG_LOG_PRINTK=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_IMMEDIATE=n
CONFIG_OBJECT_TRACING=y
CONFIG_THREAD_MONITOR=y
CONFIG_ASSERT=y
CONFIG_BASE64=y
#CONFIG_FILE_SYSTEM=y
#CONFIG_FILE_SYSTEM_LITTLEFS=y
#CONFIG_ASSERT=n
#CONFIG_LOG_BUFFER_SIZE=1024
#CONFIG_LOG_STRDUP_BUF_COUNT=2
#CONFIG_LOG_STRDUP_MAX_STRING=512
#CONFIG_LOG_MIPI_SYST_ENABLE=y
#CONFIG_LOG_BACKEND_UART_SYST_ENABLE=y
#CONFIG_SOC_LOG_LEVEL_OFF=y
#CONFIG_ARCH_LOG_LEVEL_OFF=y
#CONFIG_KERNEL_LOG_LEVEL_OFF=y
#CONFIG_LOG_RUNTIME_FILTERING=n
#CONFIG_MAIN_THREAD_PRIORITY=10
#CONFIG_LOG_FUNC_NAME_PREFIX_DBG=n
#CONFIG_LOG_PROCESS_THREAD=y
#CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=100
#CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=2
#CONFIG_LOG_PRINTK_MAX_STRING_LENGTH=256
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=8192
CONFIG_SECURE_BOOT=y
#CONFIG_BUILD_S1_VARIANT=y
CONFIG_SB_SIGNING_KEY_FILE="configuration/tinycarrierv1/tiny_b0_priv.pem"
CONFIG_DFU_TARGET=y
CONFIG_DFU_TARGET_MCUBOOT=y
CONFIG_DFU_TARGET_MODEM_DELTA=y
CONFIG_DFU_TARGET_FULL_MODEM=n
CONFIG_MCUMGR=y
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_FW_INFO=y
CONFIG_FW_INFO_FIRMWARE_VERSION=1
prj.overlay
&uart0 {
