PRECISERR due to the address violation at 0x40009500 (BFAR) cause hardfault for NRF9160ns
I have a legacy code base  for NRF9160 with a custom board folder which created manually by applying installing manually steps in the past. I have neither experience with Nordic ecosystem nor Zephyr before.
Codebase is building successfully however it falls hard fault whenever I attempted to run zephyr.elf file via OZONE.
Ozone says there is PRECISERR and BFAR = 0x4000 9500.
Software are using uarte and this adress could be related with this. On the other hand, an instruction on my hand says " before the build, you should copy custom uarte.c driver to zephyr/driver/serial/uarte" I do not know why.
Here is the code snippet.
As far as I reviewed. This address is belongs to the uarte enable register. The project are using uart0 and uart1. I do not know which prj.conf I need to share with you please navigate me.
 * Copyright (c) 2018 Nordic Semiconductor ASA
 * @brief Driver for Nordic Semiconductor nRF UARTE
#include <drivers/uart.h>
#include <hal/nrf_gpio.h>
#include <hal/nrf_uarte.h>
#include <nrfx_timer.h>
#include <sys/util.h>
#include <kernel.h>
#include <logging/log.h>
#include <helpers/nrfx_gppi.h>
LOG_MODULE_REGISTER(uart_nrfx_uarte, LOG_LEVEL_ERR);
/* Generalize PPI or DPPI channel management */
#if defined(CONFIG_HAS_HW_NRF_PPI)
#include <nrfx_ppi.h>
#define gppi_channel_t nrf_ppi_channel_t
#define gppi_channel_alloc nrfx_ppi_channel_alloc
#define gppi_channel_enable nrfx_ppi_channel_enable
#elif defined(CONFIG_HAS_HW_NRF_DPPIC)
#include <nrfx_dppi.h>
#define gppi_channel_t uint8_t
#define gppi_channel_alloc nrfx_dppi_channel_alloc
#define gppi_channel_enable nrfx_dppi_channel_enable
#else
#error "No PPI or DPPI"
#if (defined(CONFIG_UART_0_NRF_UARTE) &&         \
     defined(CONFIG_UART_0_INTERRUPT_DRIVEN)) || \
    (defined(CONFIG_UART_1_NRF_UARTE) &&         \
     defined(CONFIG_UART_1_INTERRUPT_DRIVEN)) || \
    (defined(CONFIG_UART_2_NRF_UARTE) &&         \
     defined(CONFIG_UART_2_INTERRUPT_DRIVEN)) || \
    (defined(CONFIG_UART_3_NRF_UARTE) &&         \
     defined(CONFIG_UART_3_INTERRUPT_DRIVEN))
	#define UARTE_INTERRUPT_DRIVEN	1
#if	(defined(CONFIG_UART_0_NRF_UARTE) && !defined(CONFIG_UART_0_ASYNC)) || \
	(defined(CONFIG_UART_1_NRF_UARTE) && !defined(CONFIG_UART_1_ASYNC)) || \
	(defined(CONFIG_UART_2_NRF_UARTE) && !defined(CONFIG_UART_2_ASYNC)) || \
	(defined(CONFIG_UART_3_NRF_UARTE) && !defined(CONFIG_UART_3_ASYNC))
#define UARTE_ANY_NONE_ASYNC 1
uint32_t uarte_prev_rx_amount;
uint8_t uarte_prev_dirty;
uint8_t po_flush_buf[5];
 * RX timeout is divided into time slabs, this define tells how many divisions
 * should be made. More divisions - higher timeout accuracy and processor usage.
#define RX_TIMEOUT_DIV 5
#ifdef CONFIG_UART_ASYNC_API
struct uarte_async_cb {
	uart_callback_t user_callback;
	void *user_data;
	const uint8_t *tx_buf;
	volatile size_t tx_size;
	uint8_t *pend_tx_buf;
	struct k_timer tx_timeout_timer;
	uint8_t *rx_buf;
	size_t rx_buf_len;
	size_t rx_offset;
	uint8_t *rx_next_buf;
	size_t rx_next_buf_len;
	uint32_t rx_total_byte_cnt; /* Total number of bytes received */
	uint32_t rx_total_user_byte_cnt; /* Total number of bytes passed to user */
	int32_t rx_timeout; /* Timeout set by user */
	int32_t rx_timeout_slab; /* rx_timeout divided by RX_TIMEOUT_DIV */
	int32_t rx_timeout_left; /* Current time left until user callback */
	struct k_timer rx_timeout_timer;
	union {
		gppi_channel_t ppi;
		uint32_t cnt;
	} rx_cnt;
	volatile int tx_amount;
	bool rx_enabled;
	bool hw_rx_counting;
	/* Flag to ensure that RX timeout won't be executed during ENDRX ISR */
	volatile bool is_in_irq;
#ifdef UARTE_INTERRUPT_DRIVEN
struct uarte_nrfx_int_driven {
	uart_irq_callback_user_data_t cb; /**< Callback function pointer */
	void *cb_data; /**< Callback function arg */
	uint8_t *tx_buffer;
	uint16_t tx_buff_size;
	volatile bool disable_tx_irq;
#ifdef CONFIG_PM_DEVICE
	bool rx_irq_enabled;
	atomic_t fifo_fill_lock;
/* Device data structure */
struct uarte_nrfx_data {
	const struct device *dev;
	struct uart_config uart_config;
	struct uarte_nrfx_int_driven *int_driven;
	struct uarte_async_cb *async;
	atomic_val_t poll_out_lock;
	uint32_t pm_state;
	uint8_t char_out;
	uint8_t rx_data;
	gppi_channel_t ppi_ch_endtx;
#define CTS_PIN_SET_MASK BIT(1)
#define RTS_PIN_SET_MASK BIT(2)
#define IS_CTS_PIN_SET(mask) (mask & CTS_PIN_SET_MASK)
#define IS_RTS_PIN_SET(mask) (mask & RTS_PIN_SET_MASK)
 * @brief Structure for UARTE configuration.
struct uarte_nrfx_config {
	NRF_UARTE_Type *uarte_regs; /* Instance address */
	uint8_t rts_cts_pins_set;
	bool gpio_mgmt;
	bool ppi_endtx;
	nrfx_timer_t timer;
struct uarte_init_config {
	uint32_t  pseltxd; /* PSEL.TXD register value */
	uint32_t  pselrxd; /* PSEL.RXD register value */
	uint32_t  pselcts; /* PSEL.CTS register value */
	uint32_t  pselrts; /* PSEL.RTS register value */
static inline struct uarte_nrfx_data *get_dev_data(const struct device *dev)
	return dev->data;
static inline const struct uarte_nrfx_config *get_dev_config(const struct device *dev)
	return dev->config;
static inline NRF_UARTE_Type *get_uarte_instance(const struct device *dev)
	const struct uarte_nrfx_config *config = get_dev_config(dev);
	return config->uarte_regs;
static void endtx_isr(const struct device *dev)
	NRF_UARTE_Type *uarte = get_uarte_instance(dev);
	int key = irq_lock();
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDTX)) {
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_ENDTX);
		nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STOPTX);
	irq_unlock(key);
#ifdef UARTE_ANY_NONE_ASYNC
 * @brief Interrupt service routine.
 * This simply calls the callback function, if one exists.
 * @param arg Argument to ISR.
 * @return N/A
static void uarte_nrfx_isr_int(void *arg)
	const struct device *dev = arg;
	/* If interrupt driven and asynchronous APIs are disabled then UART
	 * interrupt is still called to stop TX. Unless it is done using PPI.
	if (nrf_uarte_int_enable_check(uarte, NRF_UARTE_INT_ENDTX_MASK) &&
		endtx_isr(dev);
	struct uarte_nrfx_data *data = get_dev_data(dev);
	if (!data->int_driven) {
		return;
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_TXSTOPPED)) {
		data->int_driven->fifo_fill_lock = 0;
		if (data->int_driven->disable_tx_irq) {
			nrf_uarte_int_disable(uarte,
					      NRF_UARTE_INT_TXSTOPPED_MASK);
			data->int_driven->disable_tx_irq = false;
			return;
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ERROR)) {
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_ERROR);
	if (data->int_driven->cb) {
		data->int_driven->cb(dev, data->int_driven->cb_data);
#endif /* UARTE_INTERRUPT_DRIVEN */
#endif /* UARTE_ANY_NONE_ASYNC */
 * @brief Set the baud rate
 * This routine set the given baud rate for the UARTE.
 * @param dev UARTE device struct
 * @param baudrate Baud rate
 * @return 0 on success or error code
static int baudrate_set(const struct device *dev, uint32_t baudrate)
	nrf_uarte_baudrate_t nrf_baudrate; /* calculated baudrate divisor */
	switch (baudrate) {
	case 300:
		/* value not supported by Nordic HAL */
		nrf_baudrate = 0x00014000;
	case 600:
		nrf_baudrate = 0x00027000;
	case 1200:
		nrf_baudrate = NRF_UARTE_BAUDRATE_1200;
	case 2400:
		nrf_baudrate = NRF_UARTE_BAUDRATE_2400;
	case 4800:
		nrf_baudrate = NRF_UARTE_BAUDRATE_4800;
	case 9600:
		nrf_baudrate = NRF_UARTE_BAUDRATE_9600;
	case 14400:
		nrf_baudrate = NRF_UARTE_BAUDRATE_14400;
	case 19200:
		nrf_baudrate = NRF_UARTE_BAUDRATE_19200;
	case 28800:
		nrf_baudrate = NRF_UARTE_BAUDRATE_28800;
	case 31250:
		nrf_baudrate = NRF_UARTE_BAUDRATE_31250;
	case 38400:
		nrf_baudrate = NRF_UARTE_BAUDRATE_38400;
	case 56000:
		nrf_baudrate = NRF_UARTE_BAUDRATE_56000;
	case 57600:
		nrf_baudrate = NRF_UARTE_BAUDRATE_57600;
	case 76800:
		nrf_baudrate = NRF_UARTE_BAUDRATE_76800;
	case 115200:
		nrf_baudrate = NRF_UARTE_BAUDRATE_115200;
	case 230400:
		nrf_baudrate = NRF_UARTE_BAUDRATE_230400;
	case 250000:
		nrf_baudrate = NRF_UARTE_BAUDRATE_250000;
	case 460800:
		nrf_baudrate = NRF_UARTE_BAUDRATE_460800;
	case 921600:
		nrf_baudrate = NRF_UARTE_BAUDRATE_921600;
	case 1000000:
		nrf_baudrate = NRF_UARTE_BAUDRATE_1000000;
		return -EINVAL;
	nrf_uarte_baudrate_set(uarte, nrf_baudrate);
	return 0;
static int uarte_nrfx_configure(const struct device *dev,
				const struct uart_config *cfg)
	nrf_uarte_config_t uarte_cfg;
#if defined(UARTE_CONFIG_STOP_Msk)
	switch (cfg->stop_bits) {
	case UART_CFG_STOP_BITS_1:
		uarte_cfg.stop = NRF_UARTE_STOP_ONE;
	case UART_CFG_STOP_BITS_2:
		uarte_cfg.stop = NRF_UARTE_STOP_TWO;
		return -ENOTSUP;
#else
	if (cfg->stop_bits != UART_CFG_STOP_BITS_1) {
		return -ENOTSUP;
	if (cfg->data_bits != UART_CFG_DATA_BITS_8) {
		return -ENOTSUP;
	switch (cfg->flow_ctrl) {
	case UART_CFG_FLOW_CTRL_NONE:
		uarte_cfg.hwfc = NRF_UARTE_HWFC_DISABLED;
	case UART_CFG_FLOW_CTRL_RTS_CTS:
		if (get_dev_config(dev)->rts_cts_pins_set) {
			uarte_cfg.hwfc = NRF_UARTE_HWFC_ENABLED;
		} else {
			return -ENOTSUP;
		return -ENOTSUP;
#if defined(UARTE_CONFIG_PARITYTYPE_Msk)
	uarte_cfg.paritytype = NRF_UARTE_PARITYTYPE_EVEN;
	switch (cfg->parity) {
	case UART_CFG_PARITY_NONE:
		uarte_cfg.parity = NRF_UARTE_PARITY_EXCLUDED;
	case UART_CFG_PARITY_EVEN:
		uarte_cfg.parity = NRF_UARTE_PARITY_INCLUDED;
	case UART_CFG_PARITY_ODD:
		uarte_cfg.paritytype = NRF_UARTE_PARITYTYPE_ODD;
		return -ENOTSUP;
	if (baudrate_set(dev, cfg->baudrate) != 0) {
		return -ENOTSUP;
	nrf_uarte_configure(get_uarte_instance(dev), &uarte_cfg);
	get_dev_data(dev)->uart_config = *cfg;
	return 0;
static int uarte_nrfx_config_get(const struct device *dev,
	*cfg = get_dev_data(dev)->uart_config;
	return 0;
static int uarte_nrfx_err_check(const struct device *dev)
	/* register bitfields maps to the defines in uart.h */
	return nrf_uarte_errorsrc_get_and_clear(uarte);
/* Function returns true if new transfer can be started. Since TXSTOPPED
 * (and ENDTX) is cleared before triggering new transfer, TX is ready for new
 * transfer if any event is set.
static bool is_tx_ready(const struct device *dev)
	bool ppi_endtx = get_dev_config(dev)->ppi_endtx;
	return nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_TXSTOPPED) ||
		(!ppi_endtx ?
		       nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDTX) : 0);
/* Wait until the transmitter is in the idle state. When this function returns,
 * IRQ's are locked with the returned key.
static int wait_tx_ready(const struct device *dev)
	int key;
	do {
		/* wait arbitrary time before back off. */
		bool res;
		NRFX_WAIT_FOR(is_tx_ready(dev), 100, 1, res);
		if (res) {
			key = irq_lock();
			if (is_tx_ready(dev)) {
			irq_unlock(key);
		k_msleep(1);
	} while (1);
	return key;
static void tx_start(NRF_UARTE_Type *uarte, const uint8_t *buf, size_t len)
	nrf_uarte_tx_buffer_set(uarte, buf, len);
	nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_TXSTOPPED);
	nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STARTTX);
static inline bool hw_rx_counting_enabled(struct uarte_nrfx_data *data)
	if (IS_ENABLED(CONFIG_UARTE_NRF_HW_ASYNC)) {
		return data->async->hw_rx_counting;
	} else {
		return false;
static void timer_handler(nrf_timer_event_t event_type, void *p_context) { }
static void rx_timeout(struct k_timer *timer);
static void tx_timeout(struct k_timer *timer);
static int uarte_nrfx_rx_counting_init(const struct device *dev)
	const struct uarte_nrfx_config *cfg = get_dev_config(dev);
	int ret;
	if (hw_rx_counting_enabled(data)) {
		nrfx_timer_config_t tmr_config = NRFX_TIMER_DEFAULT_CONFIG;
		tmr_config.mode = NRF_TIMER_MODE_COUNTER;
		tmr_config.bit_width = NRF_TIMER_BIT_WIDTH_32;
		ret = nrfx_timer_init(&cfg->timer,
				      &tmr_config,
				      timer_handler);
		if (ret != NRFX_SUCCESS) {
			LOG_ERR("Timer already initialized, "
				"switching to software byte counting.");
			data->async->hw_rx_counting = false;
		} else {
			nrfx_timer_enable(&cfg->timer);
			nrfx_timer_clear(&cfg->timer);
		ret = gppi_channel_alloc(&data->async->rx_cnt.ppi);
			LOG_ERR("Failed to allocate PPI Channel, "
			nrfx_timer_uninit(&cfg->timer);
#if CONFIG_HAS_HW_NRF_PPI
		ret = nrfx_ppi_channel_assign(
			data->async->rx_cnt.ppi,
			nrf_uarte_event_address_get(uarte,
						    NRF_UARTE_EVENT_RXDRDY),
			nrfx_timer_task_address_get(&cfg->timer,
						    NRF_TIMER_TASK_COUNT));
			return -EIO;
#else
		nrf_uarte_publish_set(uarte,
				      NRF_UARTE_EVENT_RXDRDY,
		nrf_timer_subscribe_set(cfg->timer.p_reg,
					NRF_TIMER_TASK_COUNT,
		ret = gppi_channel_enable(data->async->rx_cnt.ppi);
			return -EIO;
	} else {
		nrf_uarte_int_enable(uarte, NRF_UARTE_INT_RXDRDY_MASK);
	return 0;
static int uarte_nrfx_init(const struct device *dev)
	int ret = uarte_nrfx_rx_counting_init(dev);
	if (ret != 0) {
		return ret;
			     NRF_UARTE_INT_ENDRX_MASK |
			     NRF_UARTE_INT_RXSTARTED_MASK |
			     NRF_UARTE_INT_ERROR_MASK |
			     NRF_UARTE_INT_RXTO_MASK);
	nrf_uarte_enable(uarte);
	 * Stop any currently running RX operations. This can occur when a
	 * bootloader sets up the UART hardware and does not clean it up
	 * before jumping to the next application.
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXSTARTED)) {
		nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STOPRX);
		while (!nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXTO)) {
			/* Busy wait for event to register */
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_RXSTARTED);
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_ENDRX);
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_RXTO);
	k_timer_init(&data->async->rx_timeout_timer, rx_timeout, NULL);
	k_timer_user_data_set(&data->async->rx_timeout_timer, data);
	k_timer_init(&data->async->tx_timeout_timer, tx_timeout, NULL);
	k_timer_user_data_set(&data->async->tx_timeout_timer, data);
	return 0;
static int uarte_nrfx_tx(const struct device *dev, const uint8_t *buf,
			 size_t len,
			 int32_t timeout)
	if (!nrfx_is_in_ram(buf)) {
		return -ENOTSUP;
	if (data->async->tx_size) {
		irq_unlock(key);
		return -EBUSY;
	} else {
		data->async->tx_size = len;
	nrf_uarte_int_enable(uarte, NRF_UARTE_INT_TXSTOPPED_MASK);
	if (!is_tx_ready(dev)) {
		/* Active poll out, postpone until it is completed. */
		data->async->pend_tx_buf = (uint8_t *)buf;
	} else {
		data->async->tx_buf = buf;
		data->async->tx_amount = -1;
		tx_start(uarte, buf, len);
	irq_unlock(key);
	if (data->uart_config.flow_ctrl == UART_CFG_FLOW_CTRL_RTS_CTS
	    && timeout != SYS_FOREVER_MS) {
		k_timer_start(&data->async->tx_timeout_timer, K_MSEC(timeout),
			      K_NO_WAIT);
	return 0;
static int uarte_nrfx_tx_abort(const struct device *dev)
	if (data->async->tx_buf == NULL) {
		return -EFAULT;
	k_timer_stop(&data->async->tx_timeout_timer);
	return 0;
static int uarte_nrfx_rx_enable(const struct device *dev, uint8_t *buf,
				size_t len,
				int32_t timeout)
	if (nrf_uarte_rx_pin_get(uarte) == NRF_UARTE_PSEL_DISCONNECTED) {
		__ASSERT(false, "TX only UARTE instance");
		return -ENOTSUP;
	data->async->rx_timeout = timeout;
	data->async->rx_timeout_slab =
		MAX(timeout / RX_TIMEOUT_DIV,
		    NRFX_CEIL_DIV(1000, CONFIG_SYS_CLOCK_TICKS_PER_SEC));
	data->async->rx_buf = buf;
	data->async->rx_buf_len = len;
	data->async->rx_offset = 0;
	data->async->rx_next_buf = NULL;
	data->async->rx_next_buf_len = 0;
	nrf_uarte_rx_buffer_set(uarte, buf, len);
	data->async->rx_enabled = true;
	nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STARTRX);
	return 0;
static int uarte_nrfx_rx_buf_rsp(const struct device *dev, uint8_t *buf,
				 size_t len)
	int err;
	if ((data->async->rx_buf == NULL)) {
		err = -EACCES;
	} else if (data->async->rx_next_buf == NULL) {
		data->async->rx_next_buf = buf;
		data->async->rx_next_buf_len = len;
		nrf_uarte_shorts_enable(uarte, NRF_UARTE_SHORT_ENDRX_STARTRX);
		err = 0;
	} else {
		err = -EBUSY;
	irq_unlock(key);
	return err;
static int uarte_nrfx_callback_set(const struct device *dev,
				   uart_callback_t callback,
				   void *user_data)
	data->async->user_callback = callback;
	data->async->user_data = user_data;
	return 0;
static int uarte_nrfx_rx_disable(const struct device *dev)
	if (data->async->rx_buf == NULL) {
		return -EFAULT;
	if (data->async->rx_next_buf != NULL) {
		nrf_uarte_shorts_disable(uarte, NRF_UARTE_SHORT_ENDRX_STARTRX);
	k_timer_stop(&data->async->rx_timeout_timer);
	data->async->rx_enabled = false;
	return 0;
	struct uarte_nrfx_data *data = k_timer_user_data_get(timer);
	(void) uarte_nrfx_tx_abort(data->dev);
static void user_callback(const struct device *dev, struct uart_event *evt)
	if (data->async->user_callback) {
		data->async->user_callback(dev, evt, data->async->user_data);
 * Whole timeout is divided by RX_TIMEOUT_DIV into smaller units, rx_timeout
 * is executed periodically every rx_timeout_slab ms. If between executions
 * data was received, then we start counting down time from start, if not, then
 * we subtract rx_timeout_slab from rx_timeout_left.
 * If rx_timeout_left is less than rx_timeout_slab it means that receiving has
 * timed out and we should tell user about that.
	const struct device *dev = data->dev;
	uint32_t read;
	if (data->async->is_in_irq) {
		return;
	/* Disable ENDRX ISR, in case ENDRX event is generated, it will be
	 * handled after rx_timeout routine is complete.
	nrf_uarte_int_disable(get_uarte_instance(dev),
			      NRF_UARTE_INT_ENDRX_MASK);
		read = nrfx_timer_capture(&cfg->timer, 0);
	} else {
		read = data->async->rx_cnt.cnt;
	/* Check if data was received since last function call */
	if (read != data->async->rx_total_byte_cnt) {
		data->async->rx_total_byte_cnt = read;
		data->async->rx_timeout_left = data->async->rx_timeout;
	/* Check if there is data that was not sent to user yet
	 * Note though that 'len' is a count of data bytes received, but not
	 * necessarily the amount available in the current buffer
	int32_t len = data->async->rx_total_byte_cnt
		    - data->async->rx_total_user_byte_cnt;
	/* Check for current buffer being full.
	 * if the UART receives characters before the the ENDRX is handled
	 * and the 'next' buffer is set up, then the SHORT between ENDRX and
	 * STARTRX will mean that data will be going into to the 'next' buffer
	 * until the ENDRX event gets a chance to be handled.
	bool clipped = false;
	if (len + data->async->rx_offset > data->async->rx_buf_len) {
		len = data->async->rx_buf_len - data->async->rx_offset;
		clipped = true;
	if (len > 0) {
		if (clipped ||
			(data->async->rx_timeout_left
				< data->async->rx_timeout_slab)) {
			/* rx_timeout ms elapsed since last receiving */
			struct uart_event evt = {
				.type = UART_RX_RDY,
				.data.rx.buf = data->async->rx_buf,
				.data.rx.len = len,
				.data.rx.offset = data->async->rx_offset
			data->async->rx_offset += len;
			data->async->rx_total_user_byte_cnt += len;
			user_callback(dev, &evt);
		} else {
			data->async->rx_timeout_left -=
				data->async->rx_timeout_slab;
		/* If theres nothing left to report until the buffers are
		 * switched then the timer can be stopped
		if (clipped) {
	nrf_uarte_int_enable(get_uarte_instance(dev),
#define UARTE_ERROR_FROM_MASK(mask)					\
	((mask) & NRF_UARTE_ERROR_OVERRUN_MASK ? UART_ERROR_OVERRUN	\
	 : (mask) & NRF_UARTE_ERROR_PARITY_MASK ? UART_ERROR_PARITY	\
	 : (mask) & NRF_UARTE_ERROR_FRAMING_MASK ? UART_ERROR_FRAMING	\
	 : (mask) & NRF_UARTE_ERROR_BREAK_MASK ? UART_BREAK		\
	 : 0)
static void error_isr(const struct device *dev)
	uint32_t err = nrf_uarte_errorsrc_get_and_clear(uarte);
		.type = UART_RX_STOPPED,
		.data.rx_stop.reason = UARTE_ERROR_FROM_MASK(err),
	(void) uarte_nrfx_rx_disable(dev);
static void rxstarted_isr(const struct device *dev)
		.type = UART_RX_BUF_REQUEST,
	if (data->async->rx_timeout != SYS_FOREVER_MS) {
		k_timer_start(&data->async->rx_timeout_timer,
			      K_MSEC(data->async->rx_timeout_slab),
			      K_MSEC(data->async->rx_timeout_slab));
static void endrx_isr(const struct device *dev)
	if (!data->async->rx_enabled) {
			/* This condition can occur only after triggering
			 * FLUSHRX task.
			const int rx_amount = nrf_uarte_rx_amount_get(uarte);
			int real_rx_amount = 0;
			if(rx_amount != uarte_prev_rx_amount) {
				real_rx_amount = rx_amount;
			} else {
				for(int i = 0; i < sizeof(po_flush_buf); i++) {
					if(po_flush_buf[i] != uarte_prev_dirty) {
				.type = UART_RX_DISABLED,
				.data.rx.buf = &po_flush_buf,
				.data.rx.len = real_rx_amount,
				.data.rx.offset = -1,
			return;
	data->async->is_in_irq = true;
	/* ensure rx timer is stopped - it will be restarted in RXSTARTED
	 * handler if needed
	/* this is the amount that the EasyDMA controller has copied into the
	 * buffer
	/* The 'rx_offset' can be bigger than 'rx_amount', so it the length
	 * of data we report back the the user may need to be clipped.
	 * This can happen because the 'rx_offset' count derives from RXRDY
	 * events, which can occur already for the next buffer before we are
	 * here to handle this buffer. (The next buffer is now already active
	 * because of the ENDRX_STARTRX shortcut)
	int rx_len = rx_amount - data->async->rx_offset;
	if (rx_len < 0) {
		rx_len = 0;
	data->async->rx_total_user_byte_cnt += rx_len;
	if (!hw_rx_counting_enabled(data)) {
		/* Prevent too low value of rx_cnt.cnt which may occur due to
		 * latencies in handling of the RXRDY interrupt. Because whole
		 * buffer was filled we can be sure that rx_total_user_byte_cnt
		 * is current total number of received bytes.
		data->async->rx_cnt.cnt = data->async->rx_total_user_byte_cnt;
	/* Only send the RX_RDY event if there is something to send */
	if (rx_len > 0) {
			.data.rx.len = rx_len,
			.data.rx.offset = data->async->rx_offset,
		data->async->is_in_irq = false;
		return;
		.type = UART_RX_BUF_RELEASED,
		.data.rx_buf.buf = data->async->rx_buf,
	/* If there is a next buffer, then STARTRX will have already been
	 * invoked by the short (the next buffer will be filling up already)
	 * and here we just do the swap of which buffer the driver is following,
	 * the next rx_timeout() will update the rx_offset.
	if (data->async->rx_next_buf) {
		data->async->rx_buf = data->async->rx_next_buf;
		data->async->rx_buf_len = data->async->rx_next_buf_len;
		/* Check is based on assumption that ISR handler handles
		 * ENDRX before RXSTARTED so if short was set on time, RXSTARTED
		 * event will be set.
		if (!nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXSTARTED)) {
		/* Remove the short until the subsequent next buffer is setup */
	} else {
		data->async->rx_buf = NULL;
	irq_unlock(key);
		evt.type = UART_RX_DISABLED;
/* This handler is called when the reception is interrupted, in contrary to
 * finishing the reception after filling all provided buffers, in which case
 * the events UART_RX_BUF_RELEASED and UART_RX_DISABLED are reported
 * from endrx_isr.
static void rxto_isr(const struct device *dev)
	static const uint8_t dirty;
		evt.type = UART_RX_BUF_RELEASED;
		evt.data.rx_buf.buf = data->async->rx_next_buf;
	/* Flushing RX fifo requires buffer bigger than 4 bytes to empty fifo */
	uarte_prev_rx_amount = nrf_uarte_rx_amount_get(get_uarte_instance(dev));
	uarte_prev_dirty = dirty;
	memset(po_flush_buf, dirty, sizeof(po_flush_buf));
	nrf_uarte_rx_buffer_set(get_uarte_instance(dev), po_flush_buf, 5);
	/* Final part of handling RXTO event is in ENDRX interrupt handler.
	 * ENDRX is generated as a result of FLUSHRX task.
	nrf_uarte_task_trigger(get_uarte_instance(dev), NRF_UARTE_TASK_FLUSHRX);
static void txstopped_isr(const struct device *dev)
	int key;
	if (!data->async->tx_buf) {
		/* If there is a pending tx request, it means that uart_tx()
		 * was called when there was ongoing uart_poll_out. Handling
		 * TXSTOPPED interrupt means that uart_poll_out has completed.
		if (data->async->pend_tx_buf) {
			key = irq_lock();
				data->async->tx_buf = data->async->pend_tx_buf;
				data->async->pend_tx_buf = NULL;
				tx_start(uarte, data->async->tx_buf,
					 data->async->tx_size);
			irq_unlock(key);
		return;
	key = irq_lock();
	size_t amount = (data->async->tx_amount >= 0) ?
			data->async->tx_amount : nrf_uarte_tx_amount_get(uarte);
	irq_unlock(key);
		.data.tx.buf = data->async->tx_buf,
		.data.tx.len = amount,
	if (amount == data->async->tx_size) {
		evt.type = UART_TX_DONE;
	} else {
		evt.type = UART_TX_ABORTED;
	nrf_uarte_int_disable(uarte, NRF_UARTE_INT_TXSTOPPED_MASK);
	data->async->tx_buf = NULL;
	data->async->tx_size = 0;
static void uarte_nrfx_isr_async(const struct device *dev)
	    && nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXDRDY)) {
		nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_RXDRDY);
		data->async->rx_cnt.cnt++;
		return;
		error_isr(dev);
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDRX)) {
		endrx_isr(dev);
		rxstarted_isr(dev);
	if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXTO)) {
		rxto_isr(dev);
	    && nrf_uarte_int_enable_check(uarte, NRF_UARTE_INT_ENDTX_MASK)) {
		endtx_isr(dev);
					  NRF_UARTE_INT_TXSTOPPED_MASK)) {
		txstopped_isr(dev);
#endif /* CONFIG_UART_ASYNC_API */
 * @brief Poll the device for input.
 * @param c Pointer to character
 * @return 0 if a character arrived, -1 if the input buffer is empty.
static int uarte_nrfx_poll_in(const struct device *dev, unsigned char *c)
	const struct uarte_nrfx_data *data = get_dev_data(dev);
	if (data->async) {
		return -ENOTSUP;
	if (!nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDRX)) {
		return -1;
	*c = data->rx_data;
	/* clear the interrupt */
	return 0;
 * @brief Output a character in polled mode.
 * @param c Character to send
static void uarte_nrfx_poll_out(const struct device *dev, unsigned char c)
	bool isr_mode = k_is_in_isr() || k_is_pre_kernel();
	int key;
	if (data->pm_state != DEVICE_PM_ACTIVE_STATE) {
		return;
	if (isr_mode) {
		while (1) {
			key = irq_lock();
#if CONFIG_UART_ASYNC_API
				if (data->async && data->async->tx_size &&
					data->async->tx_amount < 0) {
			irq_unlock(key);
	} else {
		key = wait_tx_ready(dev);
	/* At this point we should have irq locked and any previous transfer
	 * completed. Transfer can be started, no need to wait for completion.
	data->char_out = c;
	tx_start(uarte, &data->char_out, 1);
	irq_unlock(key);
/** Interrupt driven FIFO fill function */
static int uarte_nrfx_fifo_fill(const struct device *dev,
				const uint8_t *tx_data,
				int len)
	len = MIN(len, data->int_driven->tx_buff_size);
	if (!atomic_cas(&data->int_driven->fifo_fill_lock, 0, 1)) {
		return 0;
	/* Copy data to RAM buffer for EasyDMA transfer */
	for (int i = 0; i < len; i++) {
		data->int_driven->tx_buffer[i] = tx_data[i];
		len = 0;
	} else {
		tx_start(uarte, data->int_driven->tx_buffer, len);
	irq_unlock(key);
	return len;
/** Interrupt driven FIFO read function */
static int uarte_nrfx_fifo_read(const struct device *dev,
				uint8_t *rx_data,
				const int size)
	int num_rx = 0;
		/* Clear the interrupt */
		/* Receive a character */
		rx_data[num_rx++] = (uint8_t)data->rx_data;
	return num_rx;
/** Interrupt driven transfer enabling function */
static void uarte_nrfx_irq_tx_enable(const struct device *dev)
	irq_unlock(key);
/** Interrupt driven transfer disabling function */
static void uarte_nrfx_irq_tx_disable(const struct device *dev)
	/* TX IRQ will be disabled after current transmission is finished */
	data->int_driven->disable_tx_irq = true;
/** Interrupt driven transfer ready function */
static int uarte_nrfx_irq_tx_ready_complete(const struct device *dev)
	/* ENDTX flag is always on so that ISR is called when we enable TX IRQ.
	 * Because of that we have to explicitly check if ENDTX interrupt is
	 * enabled, otherwise this function would always return true no matter
	 * what would be the source of interrupt.
	bool ready = !data->int_driven->disable_tx_irq &&
		     nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_TXSTOPPED) &&
	if (ready) {
	return ready;
static int uarte_nrfx_irq_rx_ready(const struct device *dev)
	return nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDRX);
/** Interrupt driven receiver enabling function */
static void uarte_nrfx_irq_rx_enable(const struct device *dev)
	nrf_uarte_int_enable(uarte, NRF_UARTE_INT_ENDRX_MASK);
/** Interrupt driven receiver disabling function */
static void uarte_nrfx_irq_rx_disable(const struct device *dev)
	nrf_uarte_int_disable(uarte, NRF_UARTE_INT_ENDRX_MASK);
/** Interrupt driven error enabling function */
static void uarte_nrfx_irq_err_enable(const struct device *dev)
	nrf_uarte_int_enable(uarte, NRF_UARTE_INT_ERROR_MASK);
/** Interrupt driven error disabling function */
static void uarte_nrfx_irq_err_disable(const struct device *dev)
	nrf_uarte_int_disable(uarte, NRF_UARTE_INT_ERROR_MASK);
/** Interrupt driven pending status function */
static int uarte_nrfx_irq_is_pending(const struct device *dev)
	return ((nrf_uarte_int_enable_check(uarte,
					    NRF_UARTE_INT_TXSTOPPED_MASK) &&
		 uarte_nrfx_irq_tx_ready_complete(dev))
					    NRF_UARTE_INT_ENDRX_MASK) &&
		 uarte_nrfx_irq_rx_ready(dev)));
/** Interrupt driven interrupt update function */
static int uarte_nrfx_irq_update(const struct device *dev)
	return 1;
/** Set the callback function */
static void uarte_nrfx_irq_callback_set(const struct device *dev,
					uart_irq_callback_user_data_t cb,
					void *cb_data)
	data->int_driven->cb = cb;
	data->int_driven->cb_data = cb_data;
static const struct uart_driver_api uart_nrfx_uarte_driver_api = {
	.poll_in		= uarte_nrfx_poll_in,
	.poll_out		= uarte_nrfx_poll_out,
	.err_check		= uarte_nrfx_err_check,
	.configure              = uarte_nrfx_configure,
	.config_get             = uarte_nrfx_config_get,
	.callback_set		= uarte_nrfx_callback_set,
	.tx			= uarte_nrfx_tx,
	.tx_abort		= uarte_nrfx_tx_abort,
	.rx_enable		= uarte_nrfx_rx_enable,
	.rx_buf_rsp		= uarte_nrfx_rx_buf_rsp,
	.rx_disable		= uarte_nrfx_rx_disable,
	.fifo_fill		= uarte_nrfx_fifo_fill,
	.fifo_read		= uarte_nrfx_fifo_read,
	.irq_tx_enable		= uarte_nrfx_irq_tx_enable,
	.irq_tx_disable		= uarte_nrfx_irq_tx_disable,
	.irq_tx_ready		= uarte_nrfx_irq_tx_ready_complete,
	.irq_rx_enable		= uarte_nrfx_irq_rx_enable,
	.irq_rx_disable		= uarte_nrfx_irq_rx_disable,
	.irq_tx_complete	= uarte_nrfx_irq_tx_ready_complete,
	.irq_rx_ready		= uarte_nrfx_irq_rx_ready,
	.irq_err_enable		= uarte_nrfx_irq_err_enable,
	.irq_err_disable	= uarte_nrfx_irq_err_disable,
	.irq_is_pending		= uarte_nrfx_irq_is_pending,
	.irq_update		= uarte_nrfx_irq_update,
	.irq_callback_set	= uarte_nrfx_irq_callback_set,
static int endtx_stoptx_ppi_init(NRF_UARTE_Type *uarte,
	nrfx_err_t ret;
	ret = gppi_channel_alloc(&data->ppi_ch_endtx);
		LOG_ERR("Failed to allocate PPI Channel");
		return -EIO;
	nrfx_gppi_channel_endpoints_setup(data->ppi_ch_endtx,
		nrf_uarte_event_address_get(uarte, NRF_UARTE_EVENT_ENDTX),
		nrf_uarte_task_address_get(uarte, NRF_UARTE_TASK_STOPTX));
	nrfx_gppi_channels_enable(BIT(data->ppi_ch_endtx));
	return 0;
static int uarte_instance_init(const struct device *dev,
			       const struct uarte_init_config *config,
			       uint8_t interrupts_active)
	int err;
	nrf_uarte_disable(uarte);
	data->dev = dev;
	nrf_gpio_pin_write(config->pseltxd, 1);
	nrf_gpio_cfg_output(config->pseltxd);
	if (config->pselrxd !=  NRF_UARTE_PSEL_DISCONNECTED) {
		nrf_gpio_cfg_input(config->pselrxd, NRF_GPIO_PIN_NOPULL);
	nrf_uarte_txrx_pins_set(uarte, config->pseltxd, config->pselrxd);
	if (config->pselcts != NRF_UARTE_PSEL_DISCONNECTED) {
		nrf_gpio_cfg_input(config->pselcts, NRF_GPIO_PIN_NOPULL);
	if (config->pselrts != NRF_UARTE_PSEL_DISCONNECTED) {
		nrf_gpio_pin_write(config->pselrts, 1);
		nrf_gpio_cfg_output(config->pselrts);
	nrf_uarte_hwfc_pins_set(uarte, config->pselrts, config->pselcts);
	err = uarte_nrfx_configure(dev, &get_dev_data(dev)->uart_config);
	if (err) {
		return err;
	data->pm_state = DEVICE_PM_ACTIVE_STATE;
	if (get_dev_config(dev)->ppi_endtx) {
		err = endtx_stoptx_ppi_init(uarte, data);
		if (err < 0) {
			return err;
	if (data->async) {
		err = uarte_nrfx_init(dev);
		if (err < 0) {
			return err;
	} else
		/* Enable receiver and transmitter */
			nrf_uarte_rx_buffer_set(uarte, &data->rx_data, 1);
	if (!get_dev_config(dev)->ppi_endtx) {
		nrf_uarte_int_enable(uarte, NRF_UARTE_INT_ENDTX_MASK);
	/* Set TXSTOPPED event by requesting fake (zero-length) transfer.
	 * Pointer to RAM variable (data->tx_buffer) is set because otherwise
	 * such operation may result in HardFault or RAM corruption.
	nrf_uarte_tx_buffer_set(uarte, &data->char_out, 0);
	/* switch off transmitter to save an energy */
	return 0;
static void uarte_nrfx_pins_enable(const struct device *dev, bool enable)
	if (!get_dev_config(dev)->gpio_mgmt) {
		return;
	uint32_t tx_pin = nrf_uarte_tx_pin_get(uarte);
	uint32_t rx_pin = nrf_uarte_rx_pin_get(uarte);
	uint32_t cts_pin = nrf_uarte_cts_pin_get(uarte);
	uint32_t rts_pin = nrf_uarte_rts_pin_get(uarte);
	if (enable) {
		nrf_gpio_pin_write(tx_pin, 1);
		nrf_gpio_cfg_output(tx_pin);
		if (rx_pin != NRF_UARTE_PSEL_DISCONNECTED) {
			nrf_gpio_cfg_input(rx_pin, NRF_GPIO_PIN_NOPULL);
		if (IS_RTS_PIN_SET(get_dev_config(dev)->rts_cts_pins_set)) {
			nrf_gpio_pin_write(rts_pin, 1);
			nrf_gpio_cfg_output(rts_pin);
		if (IS_CTS_PIN_SET(get_dev_config(dev)->rts_cts_pins_set)) {
			nrf_gpio_cfg_input(cts_pin,
	} else {
		nrf_gpio_cfg_default(tx_pin);
			nrf_gpio_cfg_default(rx_pin);
			nrf_gpio_cfg_default(rts_pin);
			nrf_gpio_cfg_default(cts_pin);
static void uarte_nrfx_set_power_state(const struct device *dev,
				       uint32_t new_state)
	if (new_state == DEVICE_PM_ACTIVE_STATE) {
		uarte_nrfx_pins_enable(dev, true);
		data->pm_state = new_state;
		if (hw_rx_counting_enabled(get_dev_data(dev))) {
			nrfx_timer_enable(&get_dev_config(dev)->timer);
		if (get_dev_data(dev)->async) {
			return;
		if (nrf_uarte_rx_pin_get(uarte) !=
			if (data->int_driven &&
			    data->int_driven->rx_irq_enabled) {
	} else {
		__ASSERT_NO_MSG(new_state == DEVICE_PM_LOW_POWER_STATE ||
				new_state == DEVICE_PM_SUSPEND_STATE ||
				new_state == DEVICE_PM_OFF_STATE);
		/* if pm is already not active, driver will stay indefinitely
		 * in while loop waiting for event NRF_UARTE_EVENT_RXTO
			return;
		/* Disabling UART requires stopping RX, but stop RX event is
		 * only sent after each RX if async UART API is used.
			nrfx_timer_disable(&get_dev_config(dev)->timer);
			/* Timer/counter value is reset when disabled. */
			data->async->rx_total_byte_cnt = 0;
			data->async->rx_total_user_byte_cnt = 0;
			/* Wait for the transmitter to go idle.
			 * While the async API can wait for transmission to
			 * complete before disabling the peripheral, the poll
			 * API exits before the character is sent on the wire.
			 * If the transmission is ongoing when the peripheral
			 * is disabled, the ENDTX and TXSTOPPED events will
			 * never be generated. This will block the driver in
			 * any future calls to poll_out.
			irq_unlock(wait_tx_ready(dev));
			uarte_nrfx_pins_enable(dev, false);
			return;
			if (data->int_driven) {
				data->int_driven->rx_irq_enabled =
				if (data->int_driven->rx_irq_enabled) {
static int uarte_nrfx_pm_control(const struct device *dev,
				 uint32_t ctrl_command,
				 void *context, device_pm_cb cb, void *arg)
	if (ctrl_command == DEVICE_PM_SET_POWER_STATE) {
		uint32_t new_state = *((const uint32_t *)context);
		if (new_state != data->pm_state) {
			uarte_nrfx_set_power_state(dev, new_state);
	} else {
		__ASSERT_NO_MSG(ctrl_command == DEVICE_PM_GET_POWER_STATE);
		*((uint32_t *)context) = data->pm_state;
	if (cb) {
		cb(dev, 0, context, arg);
	return 0;
#endif /* CONFIG_PM_DEVICE */
#define UARTE(idx)			DT_NODELABEL(uart##idx)
#define UARTE_HAS_PROP(idx, prop)	DT_NODE_HAS_PROP(UARTE(idx), prop)
#define UARTE_PROP(idx, prop)		DT_PROP(UARTE(idx), prop)
#define UARTE_PSEL(idx, pin_prop)					       \
	COND_CODE_1(UARTE_HAS_PROP(idx, pin_prop),			       \
		    (UARTE_PROP(idx, pin_prop)),			       \
		    (NRF_UARTE_PSEL_DISCONNECTED))
#define HWFC_AVAILABLE(idx)					       \
	(UARTE_HAS_PROP(idx, rts_pin) || UARTE_HAS_PROP(idx, cts_pin))
#define UARTE_IRQ_CONFIGURE(idx, isr_handler)				       \
	do {								       \
		IRQ_CONNECT(DT_IRQN(UARTE(idx)), DT_IRQ(UARTE(idx), priority), \
			    isr_handler, DEVICE_DT_GET(UARTE(idx)), 0); \
		irq_enable(DT_IRQN(UARTE(idx)));			       \
	} while (0)
#define HWFC_CONFIG_CHECK(idx) \
	BUILD_ASSERT( \
		(UARTE_PROP(idx, hw_flow_control) && HWFC_AVAILABLE(idx)) \
		!UARTE_PROP(idx, hw_flow_control) \
#define UART_NRF_UARTE_DEVICE(idx)					       \
	HWFC_CONFIG_CHECK(idx);						       \
	UARTE_INT_DRIVEN(idx);						       \
	UARTE_ASYNC(idx);						       \
	static struct uarte_nrfx_data uarte_##idx##_data = {		       \
		UARTE_CONFIG(idx),					       \
		IF_ENABLED(CONFIG_UART_##idx##_ASYNC,			       \
			    (.async = &uarte##idx##_async,))		       \
		IF_ENABLED(CONFIG_UART_##idx##_INTERRUPT_DRIVEN,	       \
			    (.int_driven = &uarte##idx##_int_driven,))	       \
	static const struct uarte_nrfx_config uarte_##idx##z_config = {	       \
		.uarte_regs = (NRF_UARTE_Type *)DT_REG_ADDR(UARTE(idx)),       \
		.rts_cts_pins_set =					       \
			(UARTE_HAS_PROP(idx, rts_pin) ? RTS_PIN_SET_MASK : 0) |\
			(UARTE_HAS_PROP(idx, cts_pin) ? CTS_PIN_SET_MASK : 0), \
		.gpio_mgmt = IS_ENABLED(CONFIG_UART_##idx##_GPIO_MANAGEMENT),  \
		.ppi_endtx = IS_ENABLED(CONFIG_UART_##idx##_ENHANCED_POLL_OUT),\
		IF_ENABLED(CONFIG_UART_##idx##_NRF_HW_ASYNC,		       \
			(.timer = NRFX_TIMER_INSTANCE(			       \
				CONFIG_UART_##idx##_NRF_HW_ASYNC_TIMER),))     \
	static int uarte_##idx##_init(const struct device *dev)		       \
		const struct uarte_init_config init_config = {		       \
			.pseltxd = UARTE_PROP(idx, tx_pin),  /* must be set */ \
			.pselrxd = UARTE_PSEL(idx, rx_pin),  /* optional */    \
			.pselcts = UARTE_PSEL(idx, cts_pin), /* optional */    \
			.pselrts = UARTE_PSEL(idx, rts_pin), /* optional */    \
		COND_CODE_1(CONFIG_UART_##idx##_ASYNC,			       \
			   (UARTE_IRQ_CONFIGURE(idx, uarte_nrfx_isr_async);),  \
			   (UARTE_IRQ_CONFIGURE(idx, uarte_nrfx_isr_int);))    \
		return uarte_instance_init(				       \
			dev,						       \
			&init_config,					       \
			IS_ENABLED(CONFIG_UART_##idx##_INTERRUPT_DRIVEN));     \
	DEVICE_DT_DEFINE(UARTE(idx),					       \
		      uarte_##idx##_init,				       \
		      uarte_nrfx_pm_control,				       \
		      &uarte_##idx##_data,				       \
		      &uarte_##idx##z_config,				       \
		      PRE_KERNEL_1,					       \
		      CONFIG_KERNEL_INIT_PRIORITY_DEVICE,		       \
		      &uart_nrfx_uarte_driver_api)
#define UARTE_CONFIG(idx)						       \
	.uart_config = {						       \
		.baudrate = UARTE_PROP(idx, current_speed),		       \
		.data_bits = UART_CFG_DATA_BITS_8,			       \
		.stop_bits = UART_CFG_STOP_BITS_1,			       \
		.parity = IS_ENABLED(CONFIG_UART_##idx##_NRF_PARITY_BIT)       \
			  ? UART_CFG_PARITY_EVEN			       \
			  : UART_CFG_PARITY_NONE,			       \
		.flow_ctrl = UARTE_PROP(idx, hw_flow_control)  \
			     ? UART_CFG_FLOW_CTRL_RTS_CTS		       \
			     : UART_CFG_FLOW_CTRL_NONE,			       \
#define UARTE_ASYNC(idx)						       \
		(struct uarte_async_cb uarte##idx##_async = {		       \
			.hw_rx_counting =				       \
				IS_ENABLED(CONFIG_UART_##idx##_NRF_HW_ASYNC),  \
#define UARTE_INT_DRIVEN(idx)						       \
		(static uint8_t uarte##idx##_tx_buffer[\
			MIN(CONFIG_UART_##idx##_NRF_TX_BUFFER_SIZE,	       \
			    BIT_MASK(UARTE##idx##_EASYDMA_MAXCNT_SIZE))];      \
		 static struct uarte_nrfx_int_driven			       \
			uarte##idx##_int_driven = {			       \
				.tx_buffer = uarte##idx##_tx_buffer,	       \
				.tx_buff_size = sizeof(uarte##idx##_tx_buffer),\
#ifdef CONFIG_UART_0_NRF_UARTE
UART_NRF_UARTE_DEVICE(0);
#ifdef CONFIG_UART_1_NRF_UARTE
UART_NRF_UARTE_DEVICE(1);
#ifdef CONFIG_UART_2_NRF_UARTE
UART_NRF_UARTE_DEVICE(2);
#ifdef CONFIG_UART_3_NRF_UARTE
UART_NRF_UARTE_DEVICE(3);
prj.conf
# NEWLIB C
CONFIG_NEWLIB_LIBC=y
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
# General
# CONFIG_REBOOT=y
# CONFIG_EVENT_MANAGER=y
# CONFIG_LINKER_ORPHAN_SECTION_PLACE=y
# CONFIG_SPEED_OPTIMIZATIONS=y
# CONFIG_DEVICE_POWER_MANAGEMENT=y
# CONFIG_PM_POLICY_APP=y
#  # UART
# CONFIG_SERIAL=y
# CONFIG_UART_INTERRUPT_DRIVEN=y
# CONFIG_UART_0_INTERRUPT_DRIVEN=n
# CONFIG_UART_1_INTERRUPT_DRIVEN=n
# CONFIG_UART_LINE_CTRL=y
# CONFIG_UART_ASYNC_API=y
# CONFIG_UART_0_ASYNC=y
# CONFIG_UART_1_ASYNC=y
# CONFIG_UART_0_NRF_HW_ASYNC=y
# CONFIG_UART_1_NRF_HW_ASYNC=y
# CONFIG_UART_0_NRF_HW_ASYNC_TIMER=1
# CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
# CONFIG_NRFX_UARTE=y
# CONFIG_NRFX_UARTE0=y
# CONFIG_NRFX_UARTE1=y
# CONFIG_NRFX_TIMER=y
# CONFIG_NRFX_TIMER1=y
# CONFIG_NRFX_TIMER2=y
# CONFIG_NRFX_PPI=y
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_MODEM_LIB_SYS_INIT=n
# Modem information
CONFIG_MODEM_INFO=y
CONFIG_NETWORKING=y
CONFIG_NET_TCP=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_NATIVE=n
CONFIG_NET_IPV6=n
CONFIG_NET_IPV4=y
CONFIG_NET_SOCKETS_POLL_MAX=4
CONFIG_NET_CONNECTION_MANAGER=y
# Network buffers
CONFIG_NET_PKT_RX_COUNT=16
CONFIG_NET_PKT_TX_COUNT=16
CONFIG_NET_BUF_RX_COUNT=80
CONFIG_NET_BUF_TX_COUNT=80
CONFIG_NET_CONTEXT_NET_PKT_POOL=y
#CONFIG_NET_IF_MAX_IPV4_COUNT=2
#CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=3
#CONFIG_DNS_SERVER_IP_ADDRESSES=y
#CONFIG_DNS_SERVER1="8.8.8.8"
#CONFIG_DNS_RESOLVER=y
#CONFIG_DNS_RESOLVER_ADDITIONAL_BUF_CTR=2
#CONFIG_SNTP=y
CONFIG_HTTP_CLIENT=y
CONFIG_HTTP_PARSER_URL=y
CONFIG_HEAP_MEM_POOL_SIZE=65536
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_PRIVILEGED_STACK_SIZE=8192
CONFIG_ISR_STACK_SIZE=8192
#CONFIG_AT_CMD_THREAD_STACK_SIZE=4096
CONFIG_MODEM_KEY_MGMT=y
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# CONFIG_DFU_TARGET=y
CONFIG_BOOTLOADER_MCUBOOT=y
#CONFIG_BOOT_ENCRYPT_RSA=n
#CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
#CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=n
#CONFIG_BOOT_SIGNATURE_KEY_FILE="tinykey.pem"
CONFIG_MCUBOOT_IMAGE_VERSION="1.0.10"
CONFIG_HWINFO=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_IMG_MANAGER=y
CONFIG_FLASH=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
CONFIG_LOG=y
CONFIG_LOG_PRINTK=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_IMMEDIATE=n
CONFIG_OBJECT_TRACING=y
CONFIG_THREAD_MONITOR=y
CONFIG_ASSERT=y
CONFIG_BASE64=y
#CONFIG_FILE_SYSTEM=y
#CONFIG_FILE_SYSTEM_LITTLEFS=y
#CONFIG_ASSERT=n
#CONFIG_LOG_BUFFER_SIZE=1024
#CONFIG_LOG_STRDUP_BUF_COUNT=2
#CONFIG_LOG_STRDUP_MAX_STRING=512
#CONFIG_LOG_MIPI_SYST_ENABLE=y
#CONFIG_LOG_BACKEND_UART_SYST_ENABLE=y
#CONFIG_SOC_LOG_LEVEL_OFF=y
#CONFIG_ARCH_LOG_LEVEL_OFF=y
#CONFIG_KERNEL_LOG_LEVEL_OFF=y
#CONFIG_LOG_RUNTIME_FILTERING=n
#CONFIG_MAIN_THREAD_PRIORITY=10
#CONFIG_LOG_FUNC_NAME_PREFIX_DBG=n
#CONFIG_LOG_PROCESS_THREAD=y
#CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=100
#CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=2
#CONFIG_LOG_PRINTK_MAX_STRING_LENGTH=256
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=8192
CONFIG_SECURE_BOOT=y
#CONFIG_BUILD_S1_VARIANT=y
CONFIG_SB_SIGNING_KEY_FILE="configuration/tinycarrierv1/tiny_b0_priv.pem"
CONFIG_DFU_TARGET=y
CONFIG_DFU_TARGET_MCUBOOT=y
CONFIG_DFU_TARGET_MODEM_DELTA=y
CONFIG_DFU_TARGET_FULL_MODEM=n
CONFIG_MCUMGR=y
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_FW_INFO=y
CONFIG_FW_INFO_FIRMWARE_VERSION=1
prj.overlay
&uart0 {
  • Hi Ismail,
    We did not manage to replicate this yet. Sorry for the delays and thanks for your patience. My colleague will be trying to reproduce it.
    I asked ex-developer and got some response like
    His first assumption is that APPROTECT is enabled and it prevents debugger access. This is likely option with "new products" which are not yet disabled. There should be a Nordic tool called 'nrfjprog', which contains recover option to disable APPROTECT. It will erase the entire flash. Then you will need to flash some encryption keys to UICR, the name could be ’provision.hex’ or similar. Can you check this out?
    what I did is to check APPPROTECT register but was 0, on the other hand, I could able to erase entire filash, if there is something related with protected memory, it shouldn't be erased. but I couldnt understand other steps writing UICR and provision.hex , does he say write  provision.hex to UICR register ?
  • I can reproduce this in NCSv1.5 and I am not sure what is causing this. But that version is quite old and debugging anything on that old version will not yield us anything productive as the R&D team wont be interested to debug anything that cannot be reproduced on latest versions.
    You also seems to have added a lot of features in your proj.conf file. I edited it a bit to be able to run the http_client example but I am not sure which sample you are running.
    Can you please try to port your project to work on NCSv2,2?
