I made a custom board with a nRF52840 module on it. Now I want test it blinking its led. So in VS Code and nRF Connect extension I created my custom board with the wizard tool. The DTS is
// Copyright (c) 2023 Nordic Semiconductor ASA // SPDX-License-Identifier: Apache-2.0 /dts-v1/; #include <nordic/nrf52840_qiaa.dtsi> / { model = "gravity5_board"; compatible = "ardesiatechnolgies,gravity5-board"; chosen { zephyr,sram = &sram0; zephyr,flash = &flash0; zephyr,code-partition = &slot0_partition; }; leds { compatible = "gpio-leds"; led0: led_0{ gpios = < &gpio1 2 GPIO_ACTIVE_LOW >; label = "LED 0"; }; }; aliases { ledred = &led0; }; }; &flash0 { partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; boot_partition: partition@0 { label = "mcuboot"; reg = <0x0 0xc000>; }; slot0_partition: partition@c000 { label = "image-0"; reg = <0xc000 0x72000>; }; slot1_partition: partition@7e000 { label = "image-1"; reg = <0x7e000 0x72000>; }; scratch_partition: partition@f0000 { label = "image-scratch"; reg = <0xf0000 0xa000>; }; storage_partition: partition@fa000 { label = "storage"; reg = <0xfa000 0x6000>; }; }; };
I added the aliases as suggested in the README.rst but using my own alias 'redled' for the 'led0'.
When I build the project I get the '__device_dts_ord_13' undeclared here (not in a function)' error:
Building blinky_custom west build --build-dir c:\ncsapps\blinky_custom\build c:\ncsapps\blinky_custom --pristine --board gravity5_board -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/ncsapps/blinky_custom" -DCONF_FILE:STRING="c:/ncsapps/blinky_custom/prj.conf" -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: C:/ncsapps/blinky_custom -- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter -- Cache files will be written to: C:/ncs/v2.2.0/zephyr/.cache -- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr) -- Found west (found suitable version "0.14.0", minimum required is "0.7.1") -- Board: gravity5_board -- Found host-tools: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk) -- Found toolchain: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk) -- Found Dtc: C:/ncs/toolchains/v2.2.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6") -- Found BOARD.dts: C:/ncsapps/blinky_custom/boards/arm/gravity5_board/gravity5_board.dts -- Generated zephyr.dts: C:/ncsapps/blinky_custom/build/zephyr/zephyr.dts -- Generated devicetree_generated.h: C:/ncsapps/blinky_custom/build/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: C:/ncsapps/blinky_custom/build/zephyr/dts.cmake Parsing C:/ncs/v2.2.0/zephyr/Kconfig Loaded configuration 'C:/ncsapps/blinky_custom/boards/arm/gravity5_board/gravity5_board_defconfig' Merged configuration 'c:/ncsapps/blinky_custom/prj.conf' Configuration saved to 'C:/ncsapps/blinky_custom/build/zephyr/.config' Kconfig header saved to 'C:/ncsapps/blinky_custom/build/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 12.1.0 -- The CXX compiler identification is GNU 12.1.0 -- The ASM compiler identification is GNU -- Found assembler: C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe CMake Warning at C:/ncs/v2.2.0/zephyr/CMakeLists.txt:824 (message): No SOURCES given to Zephyr library: drivers__gpio Excluding target from build. -- Configuring done -- Generating done -- Build files have been written to: C:/ncsapps/blinky_custom/build -- west build: building application [1/154] Generating include/generated/version.h -- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1 [2/154] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json [3/154] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h [4/154] Generating include/generated/driver-validation.h [5/154] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h [6/154] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj [7/154] Generating include/generated/offsets.h [8/154] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj [9/154] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj [10/154] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj [11/154] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj [12/154] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj [13/154] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj [14/154] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj [15/154] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj [16/154] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj [17/154] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj [18/154] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj [19/154] Generating linker_zephyr_pre0.cmd [20/154] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj [21/154] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj [22/154] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj [23/154] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj [24/154] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj [25/154] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj [26/154] Generating ../../../include/generated/libc/minimal/strerror_table.h [27/154] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj [28/154] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj [29/154] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj [30/154] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj [31/154] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj [32/154] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj [33/154] Linking C static library zephyr\arch\common\libisr_tables.a [34/154] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj [35/154] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj [36/154] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj [37/154] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a [38/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj [39/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj [40/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj [41/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj [42/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj [43/154] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj [44/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj [45/154] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj [46/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj [47/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj [48/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj [49/154] Linking C static library zephyr\arch\common\libarch__common.a [50/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj [51/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj [52/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj [53/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj [54/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj [55/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj [56/154] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a [57/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj [58/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj [59/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj [60/154] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a [61/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj [62/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj [63/154] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a [64/154] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj [65/154] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a [66/154] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj [67/154] Linking C static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a [68/154] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj [69/154] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj [70/154] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj [71/154] Building C object CMakeFiles/app.dir/src/main.c.obj FAILED: CMakeFiles/app.dir/src/main.c.obj C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=0 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.2.0/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.2.0/zephyr/soc/arm/nordic_nrf/nrf52 -IC:/ncs/v2.2.0/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.2.0/nrf/include -IC:/ncs/v2.2.0/nrf/tests/include -IC:/ncs/v2.2.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.2.0/zephyr/modules/hal_nordic/nrfx/. -isystem C:/ncs/v2.2.0/zephyr/lib/libc/minimal/include -isystem c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include -isystem c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include-fixed -isystem C:/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros C:/ncsapps/blinky_custom/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.2.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/ncsapps/blinky_custom=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.2.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.2.0=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles\app.dir\src\main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c ../src/main.c In file included from C:\ncs\v2.2.0\zephyr\include\zephyr\toolchain\gcc.h:88, from C:\ncs\v2.2.0\zephyr\include\zephyr\toolchain.h:50, from C:\ncs\v2.2.0\zephyr\include\zephyr\kernel_includes.h:19, from C:\ncs\v2.2.0\zephyr\include\zephyr\kernel.h:17, from c:\ncsapps\blinky_custom\src\main.c:7: C:\ncs\v2.2.0\zephyr\include\zephyr\device.h:83:41: error: '__device_dts_ord_13' undeclared here (not in a function); did you mean '__device_dts_ord_14'? 83 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id) | ^~~~~~~~~ C:\ncs\v2.2.0\zephyr\include\zephyr\toolchain\common.h:132:26: note: in definition of macro '_DO_CONCAT' 132 | #define _DO_CONCAT(x, y) x ## y | ^ C:\ncs\v2.2.0\zephyr\include\zephyr\device.h:83:33: note: in expansion of macro '_CONCAT' 83 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id) | ^~~~~~~ C:\ncs\v2.2.0\zephyr\include\zephyr\device.h:209:37: note: in expansion of macro 'DEVICE_NAME_GET' 209 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id)) | ^~~~~~~~~~~~~~~ C:\ncs\v2.2.0\zephyr\include\zephyr\device.h:226:34: note: in expansion of macro 'DEVICE_DT_NAME_GET' 226 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id)) | ^~~~~~~~~~~~~~~~~~ C:\ncs\v2.2.0\zephyr\include\zephyr\drivers\gpio.h:340:25: note: in expansion of macro 'DEVICE_DT_GET' 340 | .port = DEVICE_DT_GET(DT_GPIO_CTLR_BY_IDX(node_id, prop, idx)),\ | ^~~~~~~~~~~~~ C:\ncs\v2.2.0\zephyr\include\zephyr\drivers\gpio.h:376:9: note: in expansion of macro 'GPIO_DT_SPEC_GET_BY_IDX' 376 | GPIO_DT_SPEC_GET_BY_IDX(node_id, prop, 0) | ^~~~~~~~~~~~~~~~~~~~~~~ c:\ncsapps\blinky_custom\src\main.c:20:40: note: in expansion of macro 'GPIO_DT_SPEC_GET' 20 | static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios); | ^~~~~~~~~~~~~~~~ [72/154] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj [73/154] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj [74/154] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj [75/154] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj [76/154] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf52840.c.obj [77/154] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj [78/154] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj [79/154] Linking C static library zephyr\drivers\timer\libdrivers__timer.a [80/154] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a [81/154] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a [82/154] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj [83/154] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj [84/154] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.2.0\opt\bin\cmake.EXE' --build 'c:\ncsapps\blinky_custom\build'
Why and how can I resolve it?
