Using timer to count pulse width on interrupt pin
Hi! I'm trying to use a counter to count the pulse widths of an IR signal packet everytime it tirggers an event on a GPIO, however I've been going in loops without sucess.
Here is my current code:
void timer_handler(nrf_timer_event_t event_type, void * p_context)
    switch (event_type)
      case NRF_TIMER_EVENT_COMPARE0:
        if (timer_started){
          timer_started = false;
          NRF_TIMER0->TASKS_CAPTURE[0] = 1;
	      pulse_duration = NRF_TIMER0->CC[0];
          //pulse_duration = nrf_timer_cc_read(m_timer.p_reg, NRF_TIMER_CC_CHANNEL0);
          NRF_LOG_INFO("PULSE DURATION: %u", pulse_duration);
          //Do nothing.
void gpiote_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
  nrf_drv_gpiote_out_toggle(LED_1);
  //NRF_LOG_INFO("GPIOTE HANDLER: %d | %d", pin, action);
  if(nrf_gpio_pin_read(pin) == 1) {
    pulse_count++;
    NRF_LOG_INFO("PULSE Count: %u", pulse_count);
    nrf_drv_timer_clear(&m_timer);
  else {
    NRF_LOG_INFO("PIN IS 0");
    nrf_drv_timer_disable(&m_timer);
 * @brief Function for application main entry.
    ret_code_t err_code;
    // Initialize.
    log_init();
    timers_init();
    nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    err_code = nrf_drv_gpiote_out_init(LED_1, &out_config);
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
    in_config.pull = NRF_GPIO_PIN_NOPULL;
    err_code = nrf_drv_gpiote_in_init(IR_RECEIVER_PIN, &in_config, gpiote_handler);
    nrf_drv_gpiote_in_event_enable(IR_RECEIVER_PIN, true);
    nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, 0xFFFFFF, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    // Enter main loop.
    for (;;) {
      idle_state_handle();
I've used both methods to count pulse_duration incluing the one currently commented, in the current case I always get 0, in the commented one I get a value "16777215" which seems to be an overflowing 24 bit timer, however mine is 16bit not 24. What am I doing wrong here, can someone help?
Thanks in advance.
    My colleague Jørgen has already shared a project on how to implement this here. Could you take a look at it?
    regards
    Jared
  • Hi Jared, Thank you for your answer.
    I've been reading that thread before, but I always assumed that my application was supposed to be simpler.
    Am I then to assume that measuring an IR signal requires either 2 simultaneous timers, or GPIOTE + TIMER + PPI? Or is this possible with only GPIOTE + TIMER like I'm doing?
    Neither of the examples of your colleague Jorgen seems to directly correspond to my situation, which one should I follow?
    I'm sorry for the late reply, I was looking for other threads that might had done the same and I see that I sent you the wrong one. I was supposed to send you this example that my colleague Torbjørn made for Zephyr. It should be a small task to port it to nRF5SDK. Come back to me if you're not able to port it and I'll do it... Either way this is the correct one.
    regards
    Jared
     5736.pulse_length_measurement.zip
  • Hi Jared, thanks for the example, I have a question though.
    How do I assign the different ppi channels to the different gpiote configs? I have these two configs:
    nrf_drv_gpiote_in_config_t in_config_1 = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
    nrf_drv_gpiote_in_config_t in_config_2 = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
    nrfx_gpiote_in_init(IR_RECEIVER_PIN, &in_config_1, gpiote_handler);
    nrfx_gpiote_in_init(IR_RECEIVER_PIN, &in_config_2, gpiote_handler);
    But when I assign the ppi channels I'm doing the following:
        nrfx_ppi_channel_alloc(&ppi_channel_a);
        nrfx_ppi_channel_assign(ppi_channel_a, nrfx_gpiote_in_event_addr_get(IR_RECEIVER_PIN), nrfx_timer_task_address_get(&m_timer, NRF_TIMER_TASK_START));
        nrfx_ppi_channel_fork_assign(ppi_channel_a, nrfx_timer_task_address_get(&m_timer, NRF_TIMER_TASK_CLEAR));
        nrfx_ppi_channel_enable(ppi_channel_a);
        nrfx_ppi_channel_alloc(&ppi_channel_b);
        nrfx_ppi_channel_assign(ppi_channel_b, nrfx_gpiote_in_event_addr_get(IR_RECEIVER_PIN), nrfx_timer_task_address_get(&m_timer, NRF_TIMER_TASK_STOP));
        nrfx_ppi_channel_fork_assign(ppi_channel_b, nrfx_timer_task_address_get(&m_timer, NRF_TIMER_TASK_CAPTURE0));
        nrfx_ppi_channel_enable(ppi_channel_b);
    However this doesn't seem to be assigning the PPI to LOTOHI and HITOLO events but rather any gpiote event. Am I missing something? Can I configure GPIOTE channels in a different way?
    Thank you for your help.
  • Hi Gabriel
    Jared is currently unavailable, and I will help you out in the mean time.
    The nrfx_gpiote driver is a bit limited if you want to assign multiple GPIOTE channels to the same pin, since the pin is used to index the different channels rather than the channel index.
    In this case I think you would have to use the nrfx_gpiote driver only for allocating the channels, using the nrfx_gpiote_channel_alloc(uint8_t * p_channel) function, and then configure the channels directly using the NRF_GPIOTE->CONFIG[ch] registers. Then you need to use the channel index provided by the alloc function as an index in the CONFIG register.
    Small example:
    #define IR_PIN 9
    uint8_t gpiote_ch_a, gpiote_ch_b;
    nrfx_gpiote_channel_alloc(&gpiote_ch_a);
    nrfx_gpiote_channel_alloc(&gpiote_ch_b);
    NRF_GPIOTE->CONFIG[gpiote_ch_a] = GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos |
    						GPIOTE_CONFIG_POLARITY_LoToHi << GPIOTE_CONFIG_POLARITY_Pos |
    						IR_PIN << GPIOTE_CONFIG_PSEL_Pos;
    NRF_GPIOTE->CONFIG[gpiote_ch_b] = GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos |
    						GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos |
    Best regards
    Torbjørn
