PWM Interrupts / Interrupt Priority Levels
Zephyr 3.2.99 - nRF Connect 2.2.0
We have a 4 digit 7 segment display that we use on one of our products. Instead of using something like timers to keep the display updated we designed it to use PWM interrupts instead. So every time an interrupt happens we increment the current digit and set the PWM pulse cycles / brightness. The PWM is inverted and it's set to use a 4ms period. So, each segment can have a min brightness of 4ms - 100us (3,999,900ns) and a max brightness of 160us (160,000ns). We never use full brightness (0ns) or no brightness (4,000,000ns) because the interrupts would get disabled and cause the display to no longer work. This has been working great, but we noticed there was a "bleed" on the display (some of the segments are partially lit when they shouldn't be). After looking into it we found that the interrupt callback timing was not consistent. The callback gets fired usually around 130us to a little over 200us (normally around 150us). This is causing the digit switch to be delayed, which partially lights a segment up. This all goes back to the max brightness; the lower the value the more it bleeds and the higher the value the more stable it is (but at the sacrifice of a dimmer display). Here is a visual example of what we are seeing:
"Set Digit" (the top reading) happens as soon as the interrupt callback is fired. The "Display Seg A" is a wire hooked to the capacitor that the segment A LED uses.
Here is what it should look like and has no bleeding (you can see it fires before the period starts giving it enough time to switch digits properly):
I guess I have three questions.
1) Is there any way to make the callback a little more consistent, or can the variable 130us - 200us be expected? I know there's always going to be variable timings, but it would be nice to minimize the range if possible. My goal is to find the optimal max brightness value that causes the least bleeding.
2) Is there any way to shorten the time it takes for the callback to be fired? The quicker it gets called the brighter we can make the display. I don't think it will make a drastic difference, but every little bit helps.
3) One thing we tried was to increase the priority of PWM1 and PWM2. By default everything has a priority of 1 (NRF_DEFAULT_IRQ_PRIORITY), so we change this to 3 and made the PWM1 and PWM2 have a priority of 2. This didn't help. However, it does bring up a question about the interrupt priorities. According to the documentation (https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsds_s140%2FSDS%2Fs1xx%2Fprocessor_avail_interrupt_latency%2Fexception_mgmt_sd.html) it states that priority level 1 is reserved by the SoftDevice. So, is it OK to use priority level 1 (like NRF_DEFAULT_IRQ_PRIORITY) or should we stick to using 2 & 3? We want the display to have the highest priority over the other devices.
Here is a quick mock-up of something similar to what we're doing (see configure_pwm and pwm_callback):
struct pwm_nrfx_config {
    nrfx_pwm_t pwm;
    nrfx_pwm_config_t initial_config;
    nrf_pwm_sequence_t seq;
    #ifdef CONFIG_PINCTRL
        const struct pinctrl_dev_config *pcfg;
static bool configure_digits(void);
static bool configure_pwm(void);
static void pwm_callback(nrfx_pwm_evt_type_t event_type, void *context);
static uint32_t pwm_period;
static uint32_t min_brightness;
static uint32_t max_brightness;
static struct k_work update_display_work;
static const struct gpio_dt_spec display_d1 = GPIO_DT_SPEC_GET(DT_ALIAS(display_d1), gpios); // Digit 1
static const struct gpio_dt_spec display_d2 = GPIO_DT_SPEC_GET(DT_ALIAS(display_d2), gpios); // Digit 2
static const struct gpio_dt_spec display_d3 = GPIO_DT_SPEC_GET(DT_ALIAS(display_d3), gpios); // Digit 3
static const struct gpio_dt_spec display_d4 = GPIO_DT_SPEC_GET(DT_ALIAS(display_d4), gpios); // Digit 4
static const struct pwm_dt_spec display_a = PWM_DT_SPEC_GET(DT_ALIAS(display_a));   // Segment A - PWM1
static const struct pwm_dt_spec display_b = PWM_DT_SPEC_GET(DT_ALIAS(display_b));   // Segment B - PWM1
static const struct pwm_dt_spec display_c = PWM_DT_SPEC_GET(DT_ALIAS(display_c));   // Segment C - PWM1
static const struct pwm_dt_spec display_d = PWM_DT_SPEC_GET(DT_ALIAS(display_d));   // Segment D - PWM1
static const struct pwm_dt_spec display_e = PWM_DT_SPEC_GET(DT_ALIAS(display_e));   // Segment E - PWM2
static const struct pwm_dt_spec display_f = PWM_DT_SPEC_GET(DT_ALIAS(display_f));   // Segment F - PWM2
static const struct pwm_dt_spec display_g = PWM_DT_SPEC_GET(DT_ALIAS(display_g));   // Segment G - PWM2
static const struct pwm_dt_spec display_dp = PWM_DT_SPEC_GET(DT_ALIAS(display_dp)); // Segment DP - PWM2
void main(void)
    __ASSERT_NO_MSG(configure_pwm());
    pwm_period = display_a.period;      // 4ms
    min_brightness = pwm_period - 100U; // 3.9ms
    max_brightness = 160000U;           // 160us
    // Initialize and kick off an update to get the interrupts going
    k_work_init(&update_display_work, update_display);
    k_work_submit(&update_display_work);
    const struct device *pwm1_device = DEVICE_DT_GET(DT_NODELABEL(pwm1));
    const struct device *pwm2_device = DEVICE_DT_GET(DT_NODELABEL(pwm2));
    const struct pwm_nrfx_config *config = !pwm2_device ? NULL : pwm2_device->config;
    if (!device_is_ready(pwm1_device) || !device_is_ready(pwm2_device) || config == NULL)
        LOG_DISPLAY_E("[Critical] The PWM device(s) are not ready.");
        return false;
    nrfx_pwm_uninit(&config->pwm);
    IRQ_DIRECT_CONNECT(PWM2_IRQn, 0, nrfx_pwm_2_irq_handler, 0);
    return nrfx_pwm_init(&config->pwm, &config->initial_config, &pwm_callback, NULL) == NRFX_SUCCESS;
    // [Enable "Set Digit" Trace Pin]
    // gpio_pin_set(current digit)
    // [Disable "Set Digit" Trace Pin]
    // Setting the PWM cycles is slow (>200us), offload it so it's doesn't hold up the interrupt
static void update_display(struct k_work *item)
    // Compute segment brightness, set PWM pulse cycles, etc.
Appreciate any help.
  • The dead band is actually free, just adjust the active time "on" for the digit selects slightly shorter than you were doing. Brightness control works exactly the same way; constant refresh frequency with less active digit time gives lower brightness. Here is a working example for the 4 digits; I just do a burst so the levels are easy to see on a 'scope
    // These settings give active-low digit selects which remain high if the sequence stops
    #define T_TOP_COUNT     4095            // 12-bit
    #define DEAD_BAND_WIDTH  400
    #define T_DEAD         (DEAD_BAND_WIDTH)
    #define T_OFF         ((T_TOP_COUNT+1) | 0x8000)
    #define T_DIGIT       (DEAD_BAND_WIDTH | 0x8000)
    #define T_SEGMENT     ((DEAD_BAND_WIDTH/2) | 0x8000)
    #define T_PERIODS       16
    #include "nrf_drv_pwm.h"
    #include "nrf_delay.h"
    static nrf_pwm_values_individual_t PWM_DigitTable[] = {
        //   Index     DIGIT 1    DIGIT 2    DIGIT 3    DIGIT 4
        { /*   0  */   (T_DIGIT), (T_OFF),   (T_OFF),   (T_OFF)   },
        { /*   1  */   (T_OFF),   (T_DIGIT), (T_OFF),   (T_OFF)   },
        { /*   2  */   (T_OFF),   (T_OFF),   (T_DIGIT), (T_OFF)   },
        { /*   3  */   (T_OFF),   (T_OFF),   (T_OFF),   (T_DIGIT) },
    // |H       |E       |L       |P       |
    // |.BC.EFG.|A..DEFG.|...DEF..|AB..EFGP|
    static nrf_pwm_values_individual_t PWM_SegmentTableABCD[] = {
        //   Index     Segment A    Segment B    Segment C    Segment D
        { /*   0  */   (T_OFF),     (T_SEGMENT), (T_SEGMENT), (T_OFF)     }, // 'H'
        { /*   1  */   (T_SEGMENT), (T_OFF),     (T_OFF),     (T_SEGMENT) }, // 'E'
        { /*   2  */   (T_OFF),     (T_OFF),     (T_OFF),     (T_SEGMENT) }, // 'L'
        { /*   3  */   (T_SEGMENT), (T_SEGMENT), (T_OFF),     (T_OFF)     }, // 'P'
    static nrf_pwm_values_individual_t PWM_SegmentTableEFGP[] = {
        //   Index     Segment E    Segment F    Segment G    Segment P
        { /*   0  */   (T_SEGMENT), (T_SEGMENT), (T_SEGMENT), (T_OFF)     }, // 'H'
        { /*   1  */   (T_SEGMENT), (T_SEGMENT), (T_SEGMENT), (T_OFF)     }, // 'E'
        { /*   2  */   (T_SEGMENT), (T_SEGMENT), (T_OFF),     (T_OFF)     }, // 'L'
        { /*   3  */   (T_SEGMENT), (T_SEGMENT), (T_SEGMENT), (T_SEGMENT) }, // 'P'
    #define NUM_PWM_ITERATIONS_DIGIT  ( sizeof(PWM_DigitTable)/sizeof(PWM_DigitTable[0].channel_0) )
    #define NUM_PWM_ITERATIONS_7SEG   ( sizeof(PWM_SegmentTableABCD)/sizeof(PWM_SegmentTableABCD[0].channel_0) )
    #define PIN_DIGIT_1 17  // LED1 Red
    #define PIN_DIGIT_2 18  // LED2 Red
    #define PIN_DIGIT_3 19  // LED3 Green
    #define PIN_DIGIT_4 20  // LED4 Green
    NRF_PWM_Type * const pNRF_PWM = NRF_PWM1;
    #define PWM_IRQn PWM1_IRQn
    static volatile bool mSequenceComplete = false;
    static volatile uint32_t mPwmInterruptCounter = 0;
    void PWM1_IRQHandler(void)
       // All enabled interrupts MUST be handled to avoid thrashing
       if (pNRF_PWM->EVENTS_STOPPED)
          pNRF_PWM->EVENTS_STOPPED = 0;
       if (pNRF_PWM->EVENTS_SEQEND[0])
          pNRF_PWM->EVENTS_SEQEND[0] = 0;
          // Set flag to update brightness or 7-segment values in sequence 0
       if (pNRF_PWM->EVENTS_SEQEND[1])
          pNRF_PWM->EVENTS_SEQEND[1] = 0;
          // Set flag to update brightness or 7-segment values in sequence 1
       if (pNRF_PWM->EVENTS_LOOPSDONE)
         pNRF_PWM->EVENTS_LOOPSDONE = 0;
       // Clear pending hardware register bus operations - Cortex-M4 issue
       __DSB();
       mSequenceComplete = true;
       mPwmInterruptCounter++;
    void stuff(void)
       // If PWM is alive, disable it after stopping first before changing parameters
       if (pNRF_PWM->ENABLE)
          NVIC_DisableIRQ(PWM_IRQn);
          pNRF_PWM->TASKS_STOP;
          __DSB();
          // Using only sequence 0; as long as at least sequence is stopped proceed
          while ((pNRF_PWM->EVENTS_STOPPED == 0) && (pNRF_PWM->EVENTS_SEQEND[0] == 0))
          pNRF_PWM->ENABLE = 0;
       // Configure PWM pins as High-Drive outputs, and set to 0
       nrf_gpio_pin_set(PIN_DIGIT_1);
       nrf_gpio_pin_set(PIN_DIGIT_2);
       nrf_gpio_pin_set(PIN_DIGIT_3);
       nrf_gpio_pin_set(PIN_DIGIT_4);
       nrf_gpio_cfg(PIN_DIGIT_1,  NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
       nrf_gpio_cfg(PIN_DIGIT_2,  NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
       nrf_gpio_cfg(PIN_DIGIT_3,  NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
       nrf_gpio_cfg(PIN_DIGIT_4,  NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
       // Wait to get clean signal for oscilloscope
       nrf_delay_ms(10);
       pNRF_PWM->PRESCALER = 2; // Prescaler - Base clock frequenc: 0 == /1, 2 == /4 so 16MHz/4 -> 4MHz
       pNRF_PWM->PSEL.OUT[0] = PIN_DIGIT_1;
       pNRF_PWM->PSEL.OUT[1] = PIN_DIGIT_2;
       pNRF_PWM->PSEL.OUT[2] = PIN_DIGIT_3;
       pNRF_PWM->PSEL.OUT[3] = PIN_DIGIT_4;
       pNRF_PWM->MODE = PWM_MODE_UPDOWN_Up;
       pNRF_PWM->DECODER = PWM_DECODER_LOAD_Individual | (PWM_DECODER_MODE_RefreshCount << PWM_DECODER_MODE_Pos);
       pNRF_PWM->LOOP = T_PERIODS;
       pNRF_PWM->COUNTERTOP = T_TOP_COUNT; // 16-bit Value up to which the pulse generator counter counts: 3-32767, Not used in waveform mode
       // Sequence 0:
       pNRF_PWM->SEQ[0].CNT = NUM_PWM_ITERATIONS_DIGIT;
       pNRF_PWM->SEQ[0].ENDDELAY = 0; // 24-bit
       pNRF_PWM->SEQ[0].PTR = (uint32_t)PWM_DigitTable;
       pNRF_PWM->SEQ[0].REFRESH = 0;
       // Sequence 1 (not used):
       pNRF_PWM->SEQ[1].CNT = NUM_PWM_ITERATIONS_DIGIT;
       pNRF_PWM->SEQ[1].ENDDELAY = 0;                // 24-bit
       pNRF_PWM->SEQ[1].PTR = (uint32_t)&PWM_DigitTable[0];
       pNRF_PWM->SEQ[1].REFRESH = 0;
       // Loop throgh digit cycle table T_PERIODS times then stop
       pNRF_PWM->SHORTS = PWM_SHORTS_LOOPSDONE_STOP_Msk;
       pNRF_PWM->EVENTS_STOPPED = 0;                   // Response to STOP task, emitted when PWM pulses are no longer generated
                                                       // pNRF_PWM->EVENTS_SEQSTARTED[0] = (0.0); // First PWM period started on sequence 0, 1
       pNRF_PWM->EVENTS_SEQEND[0] = 0;                 // Emitted at end of every sequence 0, 1, when last value from RAM has been applied to wave counter
       pNRF_PWM->EVENTS_SEQSTARTED[0] = 0;
       pNRF_PWM->EVENTS_SEQSTARTED[1] = 0;
       pNRF_PWM->EVENTS_PWMPERIODEND = 0; // Emitted at the end of each PWM period
       pNRF_PWM->EVENTS_LOOPSDONE = 0;    // Concatenated sequences have been played the amount of times defined in LOOP.CNT
       // Disable all interrupts
       pNRF_PWM->INTENCLR = 0x000000FEul;
       // Enable selected interrupts - best to SHORT the TASKS_STOP command and only interrupt on EVENTS_STOPPED
       pNRF_PWM->INTENSET = PWM_INTEN_STOPPED_Msk; // EVENTS_STOPPED and EVENTS_SEQEND[0] and EVENTS_SEQEND[1]
       // Set interrupt priority and enable interrupt
       NVIC_SetPriority(PWM_IRQn, 6);
       NVIC_ClearPendingIRQ(PWM_IRQn);
       NVIC_EnableIRQ(PWM_IRQn);
       Start a burst of cycles
       pNRF_PWM->ENABLE = 1;
       pNRF_PWM->TASKS_SEQSTART[0] = 1;
       while(1)
    The digit and segment sequence is as noted before; not sure if the segment is active low or active high so this sequence shows digit select active low and segment select active high; the example code uses active-low digit drives
    //                        .BC.EFG.   A..DEFG.  ...DEF..  AB..EFGP                        +--- Optional blanking interval, change segment data here
    //                       +-- START                                                       |
    //                 !     |<------------------- Display Cycle 1 --------------------->|   |   |<------------------- Display Cycle 2 --------------------->|
    //                 !     |                                            Optional blank |<-/~/->|                                            Optional blank |<-/~
    //                 !     |<---- C1 ---->|<---- C2 ---->|<---- C3 ---->|<---- C4 ---->|       |<---- C1 ---->|<---- C2 ---->|<---- C3 ---->|<---- C4 ---->|
    //                 !     | |<--- D1 --->| |<--- D2 --->| |<--- D3 --->| |<--- D4 --->|       | |<--- D1 --->| |<--- D2 --->| |<--- D3 --->| |<--- D4 --->|
    //   Dead Bands >  !  -->| |<--      -->| |<--      -->| |<--      -->| |<--         |    -->| |<--      -->| |<--      -->| |<--      -->| |<--         | < Dead Bands
    // DIGIT-1         !     | |     D1     | |            | |            | |            |       | |    D1      | |            | |            | |            |
    // DIGIT-2         !     | |            | |     D2     | |            | |            |       | |            | |     D2     | |            | |            |
    // DIGIT-3         !     | |            | |            | |     D3     | |            |       | |            | |            | |     D3     | |            |
    // DIGIT-4         !     | |            | |            | |            | |    D4      |       | |            | |            | |            | |     D4     |
    // Display "HELP"  !     | |            | |            | |            | |            |       | |            | |            | |            | |            |
    //  'X'=DON'T CARE |     X+             X+=============X|            |X+=============XXXXXXXXX|            |X+=============X|            |X+=============X|
    //                 !     X|    'H'      X|    'E'      X|    'L'     |X|    'P'      XXXXXXXXX|    'H'     |X|    'E'      X|    'L'     |X|    'P'      X|
    // SEGMENT-A0      !     X|             X|             X|            |X|             XXXXXXXXX|            |X|             X|            |X|             X|
    // ================/~/===X+=============X+             X==============X+             XXXX/~/XX==============X+             X==============X+             X==/~
    //                 !     X+=============X+=============X|            |X+=============XXXXXXXXX+=============X+=============X|            |X+=============X|
    //                 !     X|    'H'      X|    'E'      X|    'L'     |X|    'P'      XXXXXXXXX|    'H'      X|    'E'      X|    'L'     |X|    'P'      X|
    // SEGMENT-G0      !     X|             X|             X|            |X|             XXXXXXXXX|             X|             X|            |X|             X|
    // ================/~/===X+             X+             X==============X+             XXXX/~/XX+             X+             X==============X+             X==/~
  • I edited the waveform notes to show active-low digit  selects which the sample code uses; the dead band prefixes the digit select. Making dead band wider is a useful way of dimming the display
  • Thank you all for the help and thank you hmolesworth for really explaining it and providing example code. Between you and Torbjørn I'm sure I'll have enough to get it working properly. Kudos on the nice ascii art too, that looks like and must have taken a while. I appreciate it.
  • My hat of to you Hugh, that is a much better solution. I will make sure to keep it in mind it for future reference Slight smile
    Best of luck James, hope you get this working nicely!
    Regards
    Torbjørn
