TIMER 2 not capturing value
I am currently trying to set up TIMER 2 to cause a compare event near overflow. I have the default timer configurations set up, and the compare event seems to trigger as I see in the debugger. When I try to capture the value of CC[1] when it compares, the value is never near the max value of the timer. I am setting the CC[1] register to 60000 to capture around then. I have attached the code as well. Thanks
nrf_drv_timer_config_t timer_cfg2 = NRF_DRV_TIMER_DEFAULT_CONFIG; //default settings should use NRF_TIMER_FREQ_8MHz, changable in sdk_config.h
    err_code = nrf_drv_timer_init(&system_timer_cc_0_2, &timer_cfg2, system_timer_cc_0_2_handler);
    //note NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK clears out the current timer base value, good for the initilizer but not the next CC event handler
    nrf_drv_timer_extended_compare(&system_timer_cc_0_2, NRF_TIMER_CC_CHANNEL1, 60000, NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK, true);
    system_timer_cc_0_1_init(); //setup system timer 1 events and tasks
    system_timer_cc_0_2_init(); //setup system timer 2 events and tasks
void system_timer_cc_0_2_init(void)
    uint32_t capture_task_addr;
    uint32_t compare_evt_addr;
    uint32_t gpiote_evt_addr;
    ret_code_t err_code;
    nrf_drv_gpiote_in_config_t in_config;
    /* CC[1]
     * Set PPI task for overflow on system timer channel[1]
    compare_evt_addr = nrf_drv_timer_event_address_get(&system_timer_cc_0_2, NRF_TIMER_EVENT_COMPARE1);
    // setup ppi channel to compare to timer 2 value
    err_code = nrf_drv_ppi_channel_alloc(&(ppi_channel[1]));
    // enable this through BLE commands for now
    err_code = nrf_drv_ppi_channel_enable(ppi_channel[1]);
    /* CC[2]
     * Setup PPI tasks for GPIOTE and system timer channel[2]
     * for speedo/tach
    //VCE: The below block needs to be called for each pin
    in_config.pull = NRF_GPIO_PIN_NOPULL; //User defined
    in_config.sense = NRF_GPIOTE_POLARITY_LOTOHI; //User defined
    in_config.hi_accuracy = true; //User defined
    in_config.is_watcher = false; //Don't change this
    in_config.skip_gpio_setup = false; //Don't change this
    //enable the pin for GPIOTE
    err_code = nrf_drv_gpiote_in_init(SPEEDO_TACHO_PIN_NUMBER, &in_config, speedo_tach_input_handler);
    //setup a ppi channel to associate with the system_timer_cc_0_2 capture events
    err_code = nrf_drv_ppi_channel_alloc(&(ppi_channel[2]));
    capture_task_addr = nrf_drv_timer_event_address_get(&system_timer_cc_0_2, NRF_TIMER_TASK_CAPTURE2);
    gpiote_evt_addr = nrf_drv_gpiote_in_event_addr_get(SPEEDO_TACHO_PIN_NUMBER);
    err_code = nrf_drv_ppi_channel_assign(ppi_channel[2],  gpiote_evt_addr, capture_task_addr);
    err_code = nrf_drv_ppi_channel_enable(ppi_channel[2]);
    nrf_drv_gpiote_in_event_enable(SPEEDO_TACHO_PIN_NUMBER, true);
    //Once all system_timer_cc_0_2 shared peripherals are ready, enable the shared timer
    nrf_drv_timer_enable(&system_timer_cc_0_2);
void system_timer_cc_0_2_handler (nrf_timer_event_t event_type, void * p_context)
    volatile uint32_t timerCount = 0;
    switch(event_type)
        case NRF_TIMER_EVENT_COMPARE1:                    //call when timer 2 overflows
            NRF_TIMER2->TASKS_CAPTURE[1] = 1;             // This is asking to capture the current counter into CC[2]
            timerCount = NRF_TIMER2->CC[1];               // counter value  at the instant when capture task was triggered is now ready to be read in CC[2]
            NRF_TIMER2->TASKS_STOP = 1;                   // Stop Timer
            NRF_TIMER2->TASKS_CLEAR = 1;                  // set count value to 0
            mOverFlowCount++;
            if (accumSpdCnt > (SPD_PERIOD_MAX - SPD_COUNT_MAX))
                    accumSpdCnt = SPD_PERIOD_MAX;    // limit peak value
                    // If we are at the max value (and really we should never
                    // get here since previous passed through this code should
                    // have published the value).  This is a fail safe and therefore
                    // we should not scale the value by the hw divider
                  accumSpdCnt += SPD_COUNT_MAX;    // room to add more ticks
                  // When the pulse count exceeds the current value, we are slowing down
                  // and need to publish the values so the gauge values decrease
                  if (accumSpdCnt > curSpdCnt)
                      curSpdCnt = accumSpdCnt;
            timerSetCC1(60000);
            NRF_TIMER2->TASKS_START = 1;   // Start timer
