nrf52832 OTA over ESB based on SDK17.1.0
Hi everyone:    I developed an application based on ESB wireless communication protocol ofr the nRF52832, and I would like to perform an OTA DFU with it.    Do you know any example of some over the air FW upgrade of nRF52832 chip via ESB protocol.
    SDK is 17.1.0.
Lurn.
  • Regarding the 8.15.9 DeviceFamilyPack, click the "Select Software Packs button in the toolbar in Keil, and select "latest" instead of "fixed":
    Then, you need to click "OK" -> "OK" (in the next popup), then right click "device" in the project menu to the left, select "options for..." then select "8.44.1" in the "Version" option (or whatever version the "latest" in the previous step selected).
    As long as you placed the sample in SDK14.2.0\examples\peripheral, so that it has a similar folder structure as the other examples, it should compile.
    Lurn_Z said:
    can you give me a code base SDK 17.1.0 ? I want to test it.
    Sorry, I don't have time to port this to 17.1.0 now. Seeing as you probably won't be running this on an nRF in the end either way, and this is only to see a possible implementation, I don't think you need to port it either.
    What you probably want to start looking into is how the uart_send_init_packet() sends the init packet, and how uart_send_application_image() is used to send the application image (which is split over several packets).
    Edvin
  • Hi Edvin,
    Yes, I won't run it on nRF, but I think the quickest way to test whether there is a problem with this process is to use this example
    About the DFU master, I can transfer the packet successfully(i think), but my pending update device log shows no data received.
    The process is as follows
    I set the device in DFU mode, connect the DFU master with UART, then just run the DFU master.
    In order to confirm that there is no abnormality in my DFU mode, I use the nrfutil to update it, and it was worked.
    the dfu master log like this
    10> RX Id:2 len:100
    10> UART initialized
    10> TX req id:2 length: 3.
    10> Tx data[0]: = 9
    10> Tx data[1]: = 1
    10> Tx data[2]: = 192
    10> uart_send_ping_packet
    10> while  start_DFU
    10> TX done len:3
    10> Init data size: 1
    10> Data : FF FF 62
    10> TX req id:2 length: 7.
    10> Tx data[0]: = 1
    10> Tx data[1]: = 1
    10> Tx data[2]: = 1
    10> Tx data[3]: = 0
    10> Tx data[4]: = 0
    10> Tx data[5]: = 0
    10> Tx data[6]: = 192
    10> TX done len:7
    10> Data : 0 536881536 62
    10> Tx data[0]: = 8
    10> Tx data[1]: = 255
    10> TX done len:3
    10> TX req id:2 length: 2.
    10> Tx data[0]: = 3
    10> Tx data[1]: = 192
    10> TX done len:2
    10> Tx data[0]: = 4
    10> TX done len:2
    10> Image size: 1
    10> Tx data[0]: = 1
    10> Tx data[1]: = 2
    10> Tx data[2]: = 1
    10> Tx data[3]: = 0
    10> Tx data[4]: = 0
    10> Tx data[5]: = 0
    10> TX done len:7
    10> Tx data[0]: = 8
    10> TX done len:3
    10> Tx data[0]: = 3
    10> TX done len:2
    10> Tx data[0]: = 4
    10> TX done len:2
    and my device in DFU mode log is here
    10> <info> app: Inside main
    10>
    10> <info> app: Bootloader -1
    10> Settings -1
    10>  Application -1
    10>
    10> <debug> app: In nrf_bootloader_init
    10>
    10> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    10>
    10> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    10>
    10> <warning> nrf_dfu_settings: Resetting bootloader settings since neither the settings page nor the backup are valid (CRC error).
    10>
    10> <debug> nrf_dfu_settings: Writing settings...
    10>
    10> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
    10>
    10> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 0
    10>
    10> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
    10>
    10> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x2000073C, len=896 bytes), queue usage: 1
    10>
    10> <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
    10>
    10> <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
    10>
    10>
    10> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007E000
    10>
    10> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 1
    10>
    10> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007E000, pending 0
    10>
    10> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x20000ABC, len=896 bytes), queue usage: 1
    10>
    10> <debug> nrf_dfu_flash: Flash write success: addr=0x0007E000, pending 0
    10>
    10> <debug> app: Enter nrf_bootloader_fw_activate
    10>
    10> <info> app: No firmware to activate.
    10>
    10> <info> app: Boot validation failed. No valid app to boot.
    10>
    10> <debug> app: DFU mode because app is not valid.
    10>
    10> <info> nrf_bootloader_wdt: WDT is not enabled
    10>
    10> <debug> app: in weak nrf_dfu_init_user
    10>
    10> <debug> app: timer_stop (0x20000020)
    10>
    10> <debug> app: timer_activate (0x20000020)
    10>
    10> <info> app: Entering DFU mode.
    10>
    10> <debug> app: Initializing transports (found: 1)
    10>
    10> <debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
    10>
    10> <debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
    10>
    10>
    10> <debug> app: Enter main loop
    10>
    Can you tell me what is wrong?
    Update:
    I checked the log when updating with nrfutil, at first I get a PING event and the data is 0x9, 0x1 with a SLIP_BYTE_END  0300
    10> <info> nrf_dfu_serial_uart: len = 1, ret_code = 17, p_data[0] = 9
    10>
    10> <info> nrf_dfu_serial_uart: len = 1, ret_code = 17, p_data[0] = 1
    10>
    10> <info> nrf_dfu_serial_uart: len = 1, ret_code = 0, p_data[0] = C0
    10>
    10> <debug> nrf_dfu_serial: Received ping 1
    10>
    10> <info> nrf_dfu_serial_uart: Allocated buffer 20000554
    10>
    10> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_PING
    10>
    10> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    10>
    10> <debug> nrf_dfu_serial: Sending Response: [0x9, 0x1]
    in the DFU master, it also send the ping command log, you can see it in the dfu mater log, but my device didn't get it.
    In order to confirm that the DFU mater send it ok, I connect it to my pc with UART, and I can get the data.
    So I think maybe my device which is in DFU mode didn't receive the packet, but why?
    Update 2:
    I found that the GND of both of them is not connected, when I connect them, I can receive data.
    Lurn
  • Update:
    I can transfer files but never succeed.
    The process is as follows.
    1. I flash the DFU master application on the master board.
    2. make sure my target board in DFU mode.
    3. program the init.bin and app.bin to master board.
    4. connect master board and target board.
    5. run the DFU master.
    In source code the application_image_address = 0x30000;
    and I get error like this
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    00> <debug> nrf_dfu_req_handler: Whole firmware image received. Postvalidating.
    00> <error> app: Received a fault! id: 0x00004002, pc: 0x00000000, info: 0x200046F0
    the full log file is here.
    # SEGGER J-Link RTT Viewer V7.00a Terminal Log File
    # Compiled: 15:35:52 on Apr 16 2021
    # Logging started @ 20 Apr 2023 14:48:20
    (Connection lost)
    (Connection lost)(Connection lost)(Connection lost)(Connection lost)(Connection lost)
    (Connection lost)(Connection lost)(Connection lost)(Connection lost)(Connection lost)(Connection lost)(Connection lost)(Connect
    00> <info> app: Inside main
    00>
    00> <info> app: Bootloader 0
    00> Settings 2
    00>  Application 0
    00>
    00> <debug> app: In nrf_bootloader_init
    00>
    00> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    00>
    00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    00>
    00> <debug> nrf_dfu_settings: Using settings page.
    00>
    00> <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    00>
    00> <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    00>
    00> <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
    00>
    00>
    00> <debug> app: Enter nrf_bootloader_fw_activate
    00>
    00> <info> app: No firmware to activate.
    00>
    00> <info> app: Boot validation failed. No valid app to boot.
    00>
    00> <debug> app: DFU mode because app is not valid.
    00>
    00> <info> nrf_bootloader_wdt: WDT is not enabled
    00>
    00> <debug> app: in weak nrf_dfu_init_user
    00>
    00> <debug> app: timer_stop (0x20000020)
    00>
    00> <debug> app: timer_activate (0x20000020)
    00>
    00> <info> app: Entering DFU mode.
    00>
    00> <debug> app: Initializing transports (found: 1)
    00>
    00> <debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
    00>
    00> <debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
    00>
    00>
    00> <debug> app: Enter main loop
    00>
    00> <debug> nrf_dfu_serial: Received ping 1
    00>
    00> <info> nrf_dfu_serial_uart: Allocated buffer 20000554
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_PING
    00>
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    00>
    00> <debug> nrf_dfu_serial: Sending Response: [0x9, 0x1]
    00>
    00> <debug> app: Shutting down transports (found: 1)
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    00>
    00> <info> nrf_dfu_serial_uart: Allocated buffer 200005D8
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    00>
    00>
    00> <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    00>
    00> <error> nrf_dfu_validation: Execute with faulty offset
    00>
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x8
    00>
    00> <warning> nrf_dfu_serial: DFU request completed with result: 0x8
    00>
    00> <debug> nrf_dfu_serial: Sending Response: [0x4, 0x8]
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    00>
    00> <error> nrf_dfu_req_handler: Cannot create data object without valid init command
    00>
    00>
    00>
    00> <debug> nrf_dfu_serial: Sending Response: [0x1, 0x8]
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    00>
    00> <debug> nrf_dfu_req_handler: Offset:0, CRC:0x00000000
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    # Logging stopped @ 20 Apr 2023 14:50:07
    In readme it shows the address.
    so I change the application_image_address = 0x10000;
    the error log is here
    00> <error> app: Received an error: 0x00000004!
    and log file:
    # Logging started @ 20 Apr 2023 14:56:49
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x4
    00>
    00> <warning> nrf_dfu_serial: DFU request completed with result: 0x4
    00>
    00> <debug> nrf_dfu_serial: Sending Response: [0x1, 0x4]
    00>
    00>
    00>
    00> <error> nrf_dfu_validation: Init command larger than expected.
    00>
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x3
    00>
    00> <warning> nrf_dfu_serial: DFU request completed with result: 0x3
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <error> nrf_dfu_validation: Handler: Invalid init command.
    00>
    00> <error> nrf_dfu_validation: Failed to decode init packet
    00>
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x5
    00>
    00> <warning> nrf_dfu_serial: DFU request completed with result: 0x5
    00>
    00> <debug> nrf_dfu_serial: Sending Response: [0x4, 0x5]
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    # Logging stopped @ 20 Apr 2023 14:57:33
    Another question:
    In readme it said that
    3) Open the .zip file and unzip the init .dat file and the binary image .bin of the application or the softdevice/bootloader.
    it should be unzip the .zip file instead of unzip the init.data?
    Hope you can give some solutions.
    Lurn
  • Ok, so I ran the DFU Master sample (for the first time, actually).
    It is correct, as you said that at least the UART sample expects the application binary to be present at address 0x30000 on the device running the DFU Master application. The init packet is expected at address 0x9000.
    Important:
    I found one bug that caused the bootloader to assert after the first application image packet was sent. The reason was that the bootloader was trying to write 62 bytes to flash. The reason for this was that in the DFU Master application, the MAX_ACTUAL_PAYLOAD is set to (MTU_SIZE/2-2), which gives 62. nrf_fstorage_write requires the length of the chunk that it is going to write to be a multiple of 4 bytes. So I changed MAX_ACTUAL_PAYLOAD to MTU_SIZE/2 instead of (MTU_SIZE/2-2), and after that it worked.
    So, what I did was that I unzipped the dfu image which was a zip file. Inside that file, there are 3 files. The json file we will not use. The smallest file, called new_app.dat is the init packet. I renamed it init_packet.bin. The other, which is the application file, I renamed app_image.bin. Just to keep track of what is what.
    Then I used this script (in a .bat file):
    del files\dfu_img\app_image.hex
    del files\dfu_img\init_packet.hex
    bin2hex.py --offset 0x9000 files\dfu_img\init_packet.bin files\dfu_img\init_packet.hex
    bin2hex.py --offset 0x30000 files\dfu_img\app_image.bin files\dfu_img\app_image.hex
    This generated the init packet and app image hex files, which I then programmed together with the dfu master (compiled in SDK14.2.0)
    nrfjprog -e --snr 682396787
    nrfjprog --program files\DFU_MASTER.hex --verify --snr 682396787
    nrfjprog --program files\dfu_img\init_packet.hex --verify --snr 682396787
    nrfjprog --program files\dfu_img\app_image.hex --verify --snr 682396787
    nrfjprog --reset --snr 682396787
    now, connecting the UART wires between the two DKs. Put the target DK in DFU mode, and pressed button 1 on the DFU Master. That performed the DFU transfer of the new image, and the application changed.
    Actually, I scripted everything, except unpacking the application image (which you could probably also script). Attached for reference:
    make -j9
    make -j9 -C ..\..\..\..\peripheral\blinky\pca10056\mbr\armgcc
    del files\app.hex
    del files\settings.hex
    del files\bl.hex
    copy ..\arm5_no_packs\_build\nrf52840_xxaa_mbr.hex files\bl.hex
    copy ..\..\..\..\peripheral\blinky\pca10056\mbr\armgcc\_build\nrf52840_xxaa.hex files\app.hex
    nrfutil settings generate --family NRF52840 --application files\app.hex --application-version 1 --bootloader-version 1 --bl-settings-version 1 files\settings.hex
    nrfjprog -e --snr 683963588
    nrfjprog --program ..\..\..\..\..\components\softdevice\mbr\hex\mbr_nrf52_2.4.1_mbr.hex --verify  --snr 683963588
    nrfjprog --program files\bl.hex --verify  --snr 683963588
    nrfjprog --program files\app.hex --verify --snr 683963588
    nrfjprog --program files\settings.hex --verify --snr 683963588
    nrfjprog --reset --snr 683963588
    nrfutil pkg generate --application files\new_app.hex --application-version 2 --hw-version 52 --sd-req 0x00 --key-file ..\..\..\private.key files\dfu_img.zip
    timeout 10
    del files\DFU_MASTER.hex
    copy ..\..\..\..\..\..\14.2.0\examples\test\DFUMaster_UART\pca10040\blank\arm5_no_packs\_build\nrf52832_xxaa.hex files\DFU_MASTER.hex
    ::nrfutil dfu serial -pkg files\dfu_img.zip -p COM8
    Edvin
  • Hi Edvin,
    At first, thanks for your help.
    So now you can run the DFU master correctly.
    Due to the time difference, I will try to modify the MAX_ACTUAL_PAYLOAD to MTU_SIZE/2 tomorrow.
    And I used the  j-flash to program the init.bin and app.bin, it can set the offset. and I think there won't be a problem with that. If something wrong, I will make a script to do this.
    Lurn
