nrf52832 OTA over ESB based on SDK17.1.0
Hi everyone:    I developed an application based on ESB wireless communication protocol ofr the nRF52832, and I would like to perform an OTA DFU with it.    Do you know any example of some over the air FW upgrade of nRF52832 chip via ESB protocol.
    SDK is 17.1.0.
Lurn.
  • Sorry, I still can't update.
    this log is program the mbr, bootloader, app, settings.
    # SEGGER J-Link RTT Viewer V7.00a Terminal Log File
    # Compiled: 15:35:52 on Apr 16 2021
    # Logging started @ 21 Apr 2023 10:32:04
    00> <info> app: Inside main
    00>
    00> <info> app: Bootloader 0
    00> Settings 2
    00>  Application 0
    00>
    00> <debug> app: In nrf_bootloader_init
    00>
    00> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    00>
    00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    00>
    00> <debug> nrf_dfu_settings: Using settings page.
    00>
    00> <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    00>
    00> <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    00>
    00> <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
    00>
    00>
    00> <debug> app: Enter nrf_bootloader_fw_activate
    00>
    00> <info> app: No firmware to activate.
    00>
    00> <debug> app: App is valid
    00>
    00> <debug> app: DFU mode requested via GPREGRET.
    00>
    00> <info> nrf_bootloader_wdt: WDT is not enabled
    00>
    00> <debug> app: in weak nrf_dfu_init_user
    00>
    00> <debug> app: timer_stop (0x20000020)
    00>
    00> <debug> app: timer_activate (0x20000020)
    00>
    00> <info> app: Entering DFU mode.
    00>
    00> <debug> app: Initializing transports (found: 1)
    00>
    00> <debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
    00>
    00> <debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
    00>
    00>
    00> <debug> nrf_dfu_validation: PB: Init packet data len: 63
    00>
    00> <info> nrf_dfu_serial_uart: Allocated buffer 20000554
    00>
    00> <debug> app: Enter main loop
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Writing valid init command to flash.
    00>
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    00>
    00> <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0000B000, len=1 pages), queue usage: 0
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0000B000, pending 0
    00>
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
    00>
    00>
    00> <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    00>
    00> <info> nrf_dfu_serial_uart: Allocated buffer 200005D8
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0000B000, src=0x20000558, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0000B000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0000B040, src=0x200005DC, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0000B040, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0000B080, src=0x20000558, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0000B080, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0000B0C0, src=0x200005DC, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0000B0C0, pending 0
    00>
    00>
    00>
    00>
    00> ding 0
    00>
    00>
    00>
    00>
    00> Settings 2
    00>  Application 0
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_serial: Received ping 1
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_PING
    00>
    00>
    00> <debug> nrf_dfu_serial: Sending Response: [0x9, 0x1]
    00>
    00> <debug> app: Shutting down transports (found: 1)
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    00>
    00>
    00>
    00>
    00>
    00> <error> app: Received an error: 0x00000004!
    00>
    # Logging stopped @ 21 Apr 2023 10:36:16
    and this is my flash region
    I also try to make a script even use your script, but not worked.
    I was only used bootloader and mbr.hex  without application too.
    this log is only have bootloader and mbr.
    # Logging started @ 21 Apr 2023 10:51:44
    00>
    00> Settings 2
    00>  Application 0
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <info> app: Boot validation failed. No valid app to boot.
    00>
    00> <debug> app: DFU mode because app is not valid.
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    00>
    00>
    00> <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    00>
    00>
    00>
    00>
    00> <info> nrf_dfu_validation: Signature required. Checking signature.
    00>
    00> <info> nrf_dfu_validation: Calculating hash (len: 63)
    00>
    00> <info> nrf_dfu_validation: Verify signature
    00>
    00> <info> nrf_dfu_validation: Image verified
    00>
    00> <debug> app: Enter nrf_dfu_cache_prepare()
    00>
    00> <debug> app: required_size: 0x9AB4.
    00>
    00> <debug> app: single_bank: false.
    00>
    00> <debug> app: keep_app: false.
    00>
    00> <debug> app: keep_softdevice: false.
    00>
    00> <debug> app: SD_PRESENT: false.
    00>
    00> <debug> app: Bank contents:
    00>
    00> <debug> app: Bank 0 code: 0x00: Size: 0x0
    00>
    00> <debug> app: Bank 1 code: 0x00: Size: 0x0
    00>
    00> <debug> app: pass: 0.
    00>
    00> <debug> app: cache_address: 0x1000.
    00>
    00> <debug> app: cache_too_small: false.
    00>
    00> <debug> app: keep_firmware: false.
    00>
    00> <debug> app: delete_more: false.
    00>
    00> <debug> nrf_dfu_validation: Write address set to 0x00001000
    00>
    00> <debug> nrf_dfu_settings: Writing settings...
    00>
    00> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 0
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x2000073C, len=896 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
    00>
    00>
    00>
    00> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007E000
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007E000, pending 0
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x20000ABC, len=896 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0007E000, pending 0
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00001000, len=1 pages), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00001000, pending 0
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001000, src=0x200005DC, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001040, src=0x20000558, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001040, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001080, src=0x200005DC, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001080, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000010C0, src=0x20000558, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000010C0, pending 0
    00>
    00>
    00>
    # Logging stopped @ 21 Apr 2023 10:52:21
    Is my file too large causing insufficient space? Because the return error is 4.
    But my application should be this size, and I can update via nrfutil.
    I have no idea about this.
  • Update:
    1. I modify the bootloader addr and size.
    due to the bootloader is debug mode, I can't set the address to 0x78000, because if end address is 0x7E000, the size is not enough.
    this is my set now.
    2. Base the 1. sometime the error like this.
    # Logging started @ 21 Apr 2023 13:56:59
    00>
    00> <info> app: Bootloader -1
    00> Settings -1
    00>  Application -1
    00>
    00>
    00>
    00>
    00> <warning> nrf_dfu_settings: Resetting bootloader settings since neither the settings page nor the backup are valid (CRC error).
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> app: required_size: 0x9E60.
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001100, src=0x200005DC, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001100, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001140, src=0x20000558, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001140, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001180, src=0x200005DC, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001180, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000011C0, src=0x20000558, len=39 bytes), queue usage: 1
    00>
    00> <error> app: Received a fault! id: 0x00004002, pc: 0x00000000, info: 0x20004710
    00>
    00>
    00> <info> nrf_dfu_serial_uart: Allocated buffer 2000065C
    00>
    00> <error> nrf_dfu_serial_uart: Failed to allocate buffer
    00>
    00>
    # Logging stopped @ 21 Apr 2023 13:57:56
    Is this error because the length is not a multiple of 4 bytes?
    But I think this packet is the last packte, so i can't decide his size.
    Should I need to modify the bootloader? I mean if the target device in DFU mode need some special state?
    such as the macro NRF_DFU_SINGLE_BANK_APP_UPDATES is 0 now.
  • Hi Edvin,
    I think the reason is that the UART tx pin of my mast device is floating, causing some unpredictable things.
    I set the gpio to PULLUP, and it solved tht problem.
        if (p_config->pselrxd != NRF_UART_PSEL_DISCONNECTED)
            nrf_gpio_cfg_input(p_config->pselrxd, NRF_GPIO_PIN_PULLUP);
    But after that I get anoter error.
    00> <debug> nrf_dfu_validation: Hash verification. start address: 0x1000, size: 0x9E60
    00> <warning> nrf_dfu_validation: Hash verification failed.
    00> <debug> nrf_dfu_validation: Expected FW hash:
    00> <debug> nrf_dfu_validation:  58 BD B7 97 03 3B 8A 07|X....;..
    00> <debug> nrf_dfu_validation:  50 C0 C3 07 70 B5 37 10|P...p.7.
    00> <debug> nrf_dfu_validation:  DC 8D 10 71 31 F3 FF 54|...q1..T
    00> <debug> nrf_dfu_validation:  1D 39 BF 14 77 EC 79 AD|.9..w.y.
    00> <debug> nrf_dfu_validation: Actual FW hash:
    00> <debug> nrf_dfu_validation:  43 FB 69 A9 B1 CF FB A8|C.i.....
    00> <debug> nrf_dfu_validation:  98 9C D5 89 FA D5 4D BB|......M.
    00> <debug> nrf_dfu_validation:  9A 65 6E E1 30 58 CD DE|.en.0X..
    00> <debug> nrf_dfu_validation:  CB 38 DB E3 D9 33 F8 07|.8...3..
    00> <warning> nrf_dfu_serial: DFU request completed with result: 0xB
    00> <debug> nrf_dfu_serial: Sending Response: [0x4, 0xB]
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=<info> app: Inside main
    0421_DFU_test_1755.log
    Lurn
  • OK, I was update successfully one time(I think), after I modify the TX pin state, and then, I never success.
    The last log shows:
    # Logging started @ 21 Apr 2023 18:28:08
    00>
    00> <info> nrf_dfu_serial_uart: Allocated buffer 20000558
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <info> nrf_dfu_serial_uart: Allocated buffer 200005DC
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> app: keep_app: true.
    00>
    00>
    00>
    00>
    00> <debug> app: Bank 0 code: 0x01: Size: 0x39A0
    00>
    00>
    00>
    00> <debug> app: cache_address: 0x5000.
    00>
    00>
    00> <debug> app: keep_firmware: true.
    00>
    00>
    00> <debug> nrf_dfu_validation: Write address set to 0x00005000
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x20000848, len=896 bytes), queue usage: 1
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x20000BC8, len=896 bytes), queue usage: 1
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00005000, len=1 pages), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00005000, pending 0
    00>
    00>
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00005000, src=0x200005E0, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00005000, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00005040, src=0x2000055C, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00005040, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00005080, src=0x200005E0, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00005080, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000050C0, src=0x2000055C, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000050C0, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00005100, src=0x200005E0, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00005100, pending 0
    00>
    00>
    00>
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00005140, src=0x2000055C, len=64 bytes), queue usage: 1
    00>
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00005140, pending 0
    00>
    00>
    00>
    # Logging stopped @ 21 Apr 2023 18:31:39
    And I still get the error “ Hash verification failed. ”
  • Hi Edvin,
    First of all thank you for taking so much time to help me with this problem.
    Now I can update successfully although I always get something wrong, but I think the question is on my hardware and the connect way.
    I'll start porting it to other devices to test.
    Thanks again for your help
    Lurn
