The firmware that i flashed onto it worked on others dongles but mine doesnt boot up or windows doesnt detect it or play the usb sound
Are you using this nRF52840 Dongle? or provide by other vendors?
How do you program the dongle? and What firmware are you flashing?
This tutorial nRF52840 Dongle Programming Tutorial might help.
Amanda H.
I'm using the normal dongle nrf52840 trying to flash it through programmer as a steamvr dongle it replaces the bootloader with nothing I believe the issue is that I need bootloader.hex
Check the "Revert to production bootloader" section in that tutorial.
-Amanda H.
The firmware im flashing does not have the bootloader region
and when i flash it then the log is
The updated image seems only have SD+APP. If you want to update the bootloader, you can use the Open bootloader example project from the SDK.
-Amanda H.
