Is there a tutorial to add DFU MESH to an existing application?
Potentially integrating this DFU example into a project:
I had the application-id different to the MCU, hence why it went through as it wasn't saving to the device, it was just relaying it and failed at the end. when I changed it to the correct application ID it has the save errors as above so we are back to square one
I am confused.
With the test that takes two hours, did you use the correct application ID?
In this latest reply, what, in details, have you done and happened?
I understood your replies as it took two hours to update with the wrong application ID, and then fail; meanwhile it failed right away with the correct application ID; but that would make no sense.
So with the correct application IDs, it fails straight away, with the wrong application ID is runs and fails at the end of the update.
I am assuming that it fails straight away with the correct ID as it sees something wrong, but with the wrong ID, it checks that it's not for the device and so it runs to relay it to another device that it may potentially be for
Your assumption makes sense. I will take a dive into this and see what could be wrong. I will try to figure it out within tomorrow.
I think it might be useful if I uploaded my files for you to test - Device nRF52-DK (nRF52832)
Github - https://github.com/ShahinHaque97-Corintech/nRF52832_DFU
Files contained are:
Blinky hex, Device Page, DFU hex, Bootloader, Soft device, Private Key
Using the private key, a public key is created
nrfutil keys --show-vk hex private_key.txt -
Verification key Qx: 39bc4f76a99c792a2c21f8571face882b83761b3b2838387c647115ef4d2ab70
Verification key Qy: 044b45c618b277a0f760929d920d0271f5b5f97afc15fc40851537b50945c09f
Device Page is created:{
"bootloader_config": {
"bootloader_id": 1,
"bootloader_version": 1,
"company_id": 89,
"application_id": 1,
"application_version": 1,
"public_key": "39bc4f76a99c792a2c21f8571face882b83761b3b2838387c647115ef4d2ab70044b45c618b277a0f760929d920d0271f5b5f97afc15fc40851537b50945c09f"
Flashed onto the MCU:nrfjprog --program s132_nrf52_7.2.0_softdevice.hex --chiperase --verify
nrfjprog --program mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex --verify
nrfjprog --program dfu_nrf52832_xxAA_s132_7.2.0.hex --verify
nrfjprog --program device_page_nrf52832_xxAA_s132_7.2.0.hex --verify
nrfjprog --reset
Device is now ready to accept new updates, with matching company_id, application_id and a higher application_version.
Creating the Blinky zip, Note hex 59 is decimal 89:
nrfutil dfu genpkg --application blinky_nrf52832_xxAA_s132_7.2.0.hex --company-id 0x00000059 --application-id 1 --application-version 2 --key-file private_key.txt --sd-req 0x0101 --mesh dfu_blinky.zip
Upload to MCU
nrfutil --verbose dfu serial -pkg dfu_blinky.zip -p COM16 -b 115200 -fc --mesh
// **** This Works **** //
I would like to see if the device can be reflashed over and over again and so I cannot use the Blinky example as it does not contain a DFU routine. instead of integrating DFU into an existing application, it would be easier to reflash the DFU example for this test.
Recreating the Update Zip:
nrfutil dfu genpkg --application dfu_nrf52832_xxAA_s132_7.2.0.hex --company-id 0x00000059 --application-id 1 --application-version 2 --key-file private_key.txt --sd-req 0x0101 --mesh dfu_DFU.zip
Upload to MCU
nrfutil --verbose dfu serial -pkg dfu_DFU.zip -p COM16 -b 115200 -fc --mesh
// **** This fails**** //
Terminal:
Flushing com-port... Opened com-port Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 205300 Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing. 1: PC -> target: 0502aabbccdd target -> PC: 0582aabbccdd Got echo response Sending DFU init packet Sending ready packet 1: PC -> target: 1378fdff040f3688371059000000010002000000 target -> PC: 16a6045900000001000200000059000000010001000000 target -> PC: 1378fdff04000000000059000000010002000000 target -> PC: 03847800 1: PC -> target: 1378fdff040f3688371059000000010002000000 target -> PC: 1378fdff040f3688371059000000010002000000 target -> PC: 03847800 Sending start packet 1: PC -> target: 1478fcff000036883710ffffffff7dc8000040000c target -> PC: 0ea30104590000000100020000000c target -> PC: 1178feff0101010159000000010001000000 target -> PC: 1178feff0101010159000000010001000000 target -> PC: 03847884 2: PC -> target: 1478fcff000036883710ffffffff7dc8000040000c target -> PC: 03847887 3: PC -> target: 1478fcff000036883710ffffffff7dc8000040000c target -> PC: 03847887 4: PC -> target: 1478fcff000036883710ffffffff7dc8000040000c target -> PC: 03847887 5: PC -> target: 1478fcff000036883710ffffffff7dc8000040000c target -> PC: 03847887 6: PC -> target: 1478fcff000036883710ffffffff7dc8000040000c target -> PC: 03847887 7: PC -> target: 1478fcff000036883710ffffffff7dc8000040000c target -> PC: 03847887 8: PC -> target: 1478fcff000036883710ffffffff7dc8000040000c target -> PC: 03847887 9: PC -> target: 1478fcff000036883710ffffffff7dc8000040000c target -> PC: 03847887 10: PC -> target: 1478fcff000036883710ffffffff7dc8000040000c target -> PC: 03847887 Failed to upgrade target. Error is: Device returned status code ERROR_INVALID_DATA (135) on a DFU data packet. Possible causes: - bootloader, SoftDevice or application on target does not match the requirements in the DFU package. - baud rate or flow control is not the same as in the target bootloader. - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode. - if the error is ERROR_BUSY at the beginning of the DFU process,increase the value of PAGE_ERASE_TIME_MAX by few milliseconds. Closing serial port...
RTT:
00> <t: 5>, main.c, 227, ----- Bluetooth Mesh DFU Example ----- 00> <t: 8848>, nrf_mesh_dfu.c, 753, Version info: BL(ver, id): 0x01 0x01 SD: 0x0101 00> <t: 8855>, nrf_mesh_dfu.c, 755, Version info: APP company: 0x00000059 id: 0x0001 version: 0x00000001 00> <t: 8897>, serial_handler_prov.c, 267, Generating encryption keypair... 00> <t: 14964>, main.c, 233, Initialization complete! 00> <t: 21029>, main.c, 254, Enabling serial interface... 00> <t: 21035>, mesh_app_utils.c, 66, Device UUID (raw): 7FCD918FF4054D1CA602A4E4ECED7735 00> <t: 21041>, mesh_app_utils.c, 67, Device UUID : 7FCD918F-F405-4D1C-A602-A4E4ECED7735 00> <t: 21060>, nrf_mesh_dfu.c, 554, RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE 00> <t: 21069>, nrf_mesh_dfu.c, 593, SERIAL TX (type: 65534) 00> <t: 21081>, main.c, 262, DFU example started! 00> <t: 4838111>, nrf_mesh_dfu.c, 418, New firmware! 00> <t: 4838116>, main.c, 79, DFU type Application 00> <t: 4838121>, main.c, 123, Requesting DFU transfer with bank at 0x00059000 00> <t: 4838128>, nrf_mesh_dfu.c, 554, RADIO TX! SLOT 0, count 3, interval: periodic, handle: FFFD 00> <t: 4838137>, nrf_mesh_dfu.c, 593, SERIAL TX (type: 65533) 00> <t: 4905405>, nrf_mesh_dfu.c, 554, RADIO TX! SLOT 0, count 3, interval: periodic, handle: FFFD 00> <t: 4905413>, nrf_mesh_dfu.c, 593, SERIAL TX (type: 65533) 00> <t: 4971630>, nrf_mesh_dfu.c, 411, Abort event. Reason: 0xC 00> <t: 4971640>, nrf_mesh_dfu.c, 554, RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE 00> <t: 4971648>, nrf_mesh_dfu.c, 593, SERIAL TX (type: 65534) 00> <t: 4971655>, nrf_mesh_dfu.c, 554, RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE 00> <t: 4971663>, nrf_mesh_dfu.c, 565, Killing a TX slot prematurely (repeats done: 0). 00> <t: 4971670>, nrf_mesh_dfu.c, 593, SERIAL TX (type: 65534)
