Is there a tutorial to add DFU MESH to an existing application?
Potentially integrating this DFU example into a project:
I can confirm that with the wrong application_id it is progressing further because it is relaying:
00> <t: 5>, main.c, 227, ----- Bluetooth Mesh DFU Example ----- 00> <t: 8848>, nrf_mesh_dfu.c, 753, Version info: BL(ver, id): 0x01 0x01 SD: 0x0101 00> <t: 8855>, nrf_mesh_dfu.c, 755, Version info: APP company: 0x00000059 id: 0x0001 version: 0x00000001 00> <t: 8897>, serial_handler_prov.c, 267, Generating encryption keypair... 00> <t: 14964>, main.c, 233, Initialization complete! 00> <t: 21029>, main.c, 254, Enabling serial interface... 00> <t: 21035>, mesh_app_utils.c, 66, Device UUID (raw): 7FCD918FF4054D1CA602A4E4ECED7735 00> <t: 21041>, mesh_app_utils.c, 67, Device UUID : 7FCD918F-F405-4D1C-A602-A4E4ECED7735 00> <t: 21060>, nrf_mesh_dfu.c, 554, RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE 00> <t: 21069>, nrf_mesh_dfu.c, 593, SERIAL TX (type: 65534) 00> <t: 21081>, main.c, 262, DFU example started! 00> <t: 4838111>, nrf_mesh_dfu.c, 418, New firmware! 00> <t: 4838116>, main.c, 79, DFU type Application 00> <t: 4838121>, main.c, 123, Requesting DFU transfer with bank at 0x00059000 00> <t: 4838128>, nrf_mesh_dfu.c, 554, RADIO TX! SLOT 0, count 3, interval: periodic, handle: FFFD 00> <t: 4838137>, nrf_mesh_dfu.c, 593, SERIAL TX (type: 65533) 00> <t: 4905405>, nrf_mesh_dfu.c, 554, RADIO TX! SLOT 0, count 3, interval: periodic, handle: FFFD 00> <t: 4905413>, nrf_mesh_dfu.c, 593, SERIAL TX (type: 65533) 00> <t: 4971630>, nrf_mesh_dfu.c, 411, Abort event. Reason: 0xC 00> <t: 4971640>, nrf_mesh_dfu.c, 554, RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE 00> <t: 4971648>, nrf_mesh_dfu.c, 593, SERIAL TX (type: 65534) 00> <t: 4971655>, nrf_mesh_dfu.c, 554, RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE 00> <t: 4971663>, nrf_mesh_dfu.c, 565, Killing a TX slot prematurely (repeats done: 0). 00> <t: 4971670>, nrf_mesh_dfu.c, 593, SERIAL TX (type: 65534) 00> <t: 5>, main.c, 227, ----- Bluetooth Mesh DFU Example ----- 00> <t: 8772>, nrf_mesh_dfu.c, 753, Version info: BL(ver, id): 0x01 0x01 SD: 0x0101 00> <t: 8779>, nrf_mesh_dfu.c, 755, Version info: APP company: 0x00000059 id: 0x0001 version: 0x00000001 00> <t: 8803>, serial_handler_prov.c, 267, Generating encryption keypair... 00> <t: 14936>, main.c, 233, Initialization complete! 00> <t: 21000>, main.c, 254, Enabling serial interface... 00> <t: 21006>, mesh_app_utils.c, 66, Device UUID (raw): 7FCD918FF4054D1CA602A4E4ECED7735 00> <t: 21012>, mesh_app_utils.c, 67, Device UUID : 7FCD918F-F405-4D1C-A602-A4E4ECED7735 00> <t: 21033>, nrf_mesh_dfu.c, 554, RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE 00> <t: 21041>, nrf_mesh_dfu.c, 593, SERIAL TX (type: 65534) 00> <t: 21055>, main.c, 262, DFU example started! 00> <t: 116955>, nrf_mesh_dfu.c, 418, New firmware! 00> <t: 116960>, main.c, 79, DFU type Application 00> <t: 116965>, main.c, 148, Starting relay
My assumption is that it is due to flash size as the example runs in dual bank
Thank you for the files and detailed information. It doesn't look like I can finish this today, and I am off tomorrow, so I will resume to this on Thursday. I will update you latest by the end of Friday Feb 24.
Hi, just a quick update. I have been looking into it but met some difficulties with the setup. I will continue with it and update you when got to run some test.
Hi, I set things up yesterday. Because I don't have a nRF52832 with me, I could not use your project files.
I instead built the DFU example for the nRF52840, with one small modification to a log line to show "v1" and "v2" to differentiate between the original firmware and the DFU firmware.
What I found is that the setup works just fine. Screenshot of my result is attached below.
I reviewed nrf_mesh_dfu.c and your log, and found that "Abort event. Reason: 0xC" indicates NRF_MESH_DFU_END_ERROR_BANK_IN_BOOTLOADER_AREA.
Your assumption about the flash size should be correct. I checked the hex files you provided, and see that the application is about 205kB (0x0002_6000 to 0x0005_81F3), while the free space between the application and the next region is only ~130.5kB (0x0005_81F4 to 0x0007_8000).
Are you attempting with an unmodified DFU example?
It seems strange to me that the example could not work, since it is supposed to be really barebone.
There are a few things we can try here:
- Build the DFU Example with Release build configuration
- Use a different SoftDevice with smaller footprint. This will require updating the DFU Example project setup.
I am working from home and won't have access to a nRF52832 device for the next few days. For the next steps, could you try the options above and let me know the result?
