Please help reply the following questions
1、We use nRF52840+nRF21540, nRF52840 we use 1.8V IO level, can nRF21540 also use 1.8V IO level?
2. If the nRF21540 is powered by 1.8V, will it affect its RF indicators such as transmission power and receiving sensitivity?
3. With the maximum power of nRF52840+nRF21540, how far can the point-to-point transmission distance be in the open area?
4. The maximum current consumption described in the specification is 110mA. Is this based on the current of 3V power supply?
5. The maximum current of 110mA described in the specification refers to the average current or peak current at the time of transmission? For example, if we continue to broadcast and transmit data at a rate of 2.4Kbps, will the current at this transmission stage continue to be 110mA?
6. All control signals of nRF21540 are received from nRF52840. If the RESET signal of nRF52840 is pulled down, will nRF21540 automatically enter the power down mode?
7. Will the control of TX Power be automatically controlled by nRF52840 or need the user to manually adjust it in the code?
8. Is the switching between antenna TX and RX automatically controlled by nRF52840?
9. If dual antennas are used, is antenna switching automatic?
10. NRF21540 What scenarios are recommended to use dual antennas and what scenarios are recommended to use single antennas
