MCUBoot without Partition Manager
Hi, I want to implement DFU on an nRF52832 with a mx25r1635f external flash, originally I implement the partitions and everything using the devicetree since I find it a lot more comfortable to use. I followed this proccess: https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/ncs-dfu , but the CONFIG_BOOTLOADER_MCUBOOT option enables the partition manager by default, is there a way to use it with the devicetree method for partitions? I saw that most applications on Zephyr do actually use the devicetree instead of the partition manager, so I expect it to be possible, but couldn't find a way to do it.
    Not sure what causes the issue, but the overlay seems you are using qpsi for mx25r16. If you disable qpsi as following
    &qspi {
    	status = "disabled";
    L114 &mx25r16 will not work because the parent's node &qspi is disabled. To use SPI_NOR driver with your external mx25r16, it should have the thing like this example . Here is my overlay for your reference:
     * Copyright (c) 2022 Nordic Semiconductor ASA
    /* This DTS overlay allows to test MX25R6435F  using SPI_NOR driver */
    &pinctrl {
    	spi1_alt_default: spi1_alt_default {
    		group1 {
    			psels = <NRF_PSEL(SPIM_SCK, 0, 19)>,
    				<NRF_PSEL(SPIM_MOSI, 0, 20)>,
    				<NRF_PSEL(SPIM_MISO, 0, 21)>;
    	spi1_alt_sleep: spi1_alt_sleep {
    		group1 {
    			low-power-enable;
    /delete-node/ &mx25r64;
    	chosen {
    		nordic,pm-ext-flash = &mx25r64;
    	fstab {
    	compatible = "zephyr,fstab";
    	lfs1: lfs1 {
    		compatible = "zephyr,fstab,littlefs";
    		mount-point = "/lfs1";
    		partition = <&lfs1_part>;
    		automount;
    		read-size = <16>;
    		prog-size = <16>;
    		cache-size = <64>;
    		lookahead-size = <32>;
    		block-cycles = <512>;
    &spi1 {
    	compatible = "nordic,nrf-spi";
    	status = "okay";
    	cs-gpios = <&gpio0 17 GPIO_ACTIVE_LOW>;
    	pinctrl-0 = <&spi1_alt_default>;
    	pinctrl-1 = <&spi1_alt_sleep>;
    	mx25r64: mx25r6435f@0  {
    		compatible = "jedec,spi-nor";
    		reg = <0>;
    		spi-max-frequency = <33000000>;
    		jedec-id = [c2 28 17];
    		size = <67108864>;
    		wp-gpios = <&gpio0 22 GPIO_ACTIVE_LOW>;
    		hold-gpios = <&gpio0 23 GPIO_ACTIVE_LOW>;
    		partitions {
    			#address-cells = <1>;
    			#size-cells = <1>;
    &qspi {
    Then, it would show the FS at the external flash as
    -Amanda H.
  • Hi, I don't have it in the QSPI bus, as I'm using a nrf52832 it does not even include a QSPI bus, I have the flash SPI definitions on the dts file for the custom board:
     &spi1 {
    	 status = "okay";
    	 pinctrl-0 = <&spi1_default>;
    	 pinctrl-1 = <&spi1_sleep>;
    	 clock-frequency = <20000000>;
    	 mx25r16: mx25r1635f@0 {
    		reg = <0>;
    		jedec-id = [c2 28 15];
    		size = <DT_SIZE_M(16)>;
    I forgot to add this piece of code before, sorry.
  • Does the issue only happen when the CONFIG_PM_PARTITION_SIZE_LITTLEFS is 0x6000? If not, is it possible to provide the log and the updated overly?
    -Amanda H.
  • it happens only when CONFIG_PM_PARTITION_SIZE_LITTLEFS is 0xf000 or more
  • Please upload the latest overlay file. Thanks.
    -Amanda H.
