FOTA - THINGY91 lwm2m Leshan Demo Server
Good day
I have recently updated my toolchain and now I seem to be have having trouble with FOTA updates over lwm2m using the lwm2m client and over NBIOT.  I am following the instructions and help stated in this link https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.2.0/nrf/ug_nrf91_features.html#nrf9160-fota  .  Please assist if possible.
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_ASSERT=y
CONFIG_REBOOT=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_IPV6=n
CONFIG_NET_IPV4=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# Sensors
CONFIG_I2C=y
CONFIG_SPI=y
CONFIG_SENSOR=y
# LwM2M and IPSO
CONFIG_LWM2M=y
CONFIG_LWM2M_COAP_BLOCK_SIZE=512
CONFIG_LWM2M_COAP_MAX_MSG_SIZE=1280
CONFIG_LWM2M_ENGINE_MAX_OBSERVER=15
CONFIG_LWM2M_ENGINE_MAX_MESSAGES=15
CONFIG_LWM2M_ENGINE_MAX_PENDING=15
CONFIG_LWM2M_ENGINE_MAX_REPLIES=15
CONFIG_LWM2M_DNS_SUPPORT=y
CONFIG_LWM2M_RW_JSON_SUPPORT=n
CONFIG_LWM2M_SERVER_DEFAULT_PMIN=1
CONFIG_LWM2M_SERVER_DEFAULT_PMAX=300
CONFIG_LWM2M_CLIENT_UTILS=y
CONFIG_LWM2M_CLIENT_UTILS_LOCATION_OBJ_SUPPORT=n
CONFIG_LWM2M_IPSO_SUPPORT=y
# DTLS settings
CONFIG_LWM2M_DTLS_SUPPORT=y
# nRF9160 helper libraries
CONFIG_MODEM_KEY_MGMT=y
# Default app to debug logging
CONFIG_LOG=y
CONFIG_APP_LOG_LEVEL_DBG=y
# Support HEX style PSK values (double the size + NULL char)
CONFIG_LWM2M_SECURITY_KEY_SIZE=33
# extend CoAP retry timing to 4 seconds for LTE/LTE-M
CONFIG_COAP_INIT_ACK_TIMEOUT_MS=4000
# Enable CoAP extended option length
CONFIG_COAP_EXTENDED_OPTIONS_LEN=y
CONFIG_COAP_EXTENDED_OPTIONS_LEN_VALUE=40
# Enable settings storage
CONFIG_SETTINGS=y
CONFIG_FCB=y
CONFIG_SETTINGS_FCB=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
# Modem library
CONFIG_NRF_MODEM_LIB=y
# Modem info
CONFIG_MODEM_INFO=y
CONFIG_MODEM_INFO_ADD_DATE_TIME=n
# Enable shell
CONFIG_LWM2M_SHELL=y
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_LWM2M_ENGINE_STACK_SIZE=3072
# Allow FOTA downloads using download-client
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
CONFIG_FOTA_DOWNLOAD=y
CONFIG_DFU_TARGET=y
CONFIG_BOOTLOADER_MCUBOOT=y
# CONFIG_COAP_WELL_KNOWN_BLOCK_WISE=y
# Application version
CONFIG_MCUBOOT_IMAGE_VERSION="1.0.0"
# Set LwM2M Server IP address here
CONFIG_LWM2M_CLIENT_UTILS_SERVER="coaps://leshan.eclipseprojects.io:5684"
CONFIG_APP_LWM2M_PSK="000102030405060708090a0b0c0d0e0f"
# Application Event Manager
CONFIG_APP_EVENT_MANAGER=y
# Date-Time library
CONFIG_DATE_TIME=y
CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=86400
# NBIOT
CONFIG_LTE_NETWORK_MODE_NBIOT=y
CONFIG_PDN=y
CONFIG_PDN_DEFAULTS_OVERRIDE=y
CONFIG_PDN_DEFAULT_APN="nbiot.vodacom.za"
# Enable LwM2M Queue Mode
CONFIG_LWM2M_QUEUE_MODE_ENABLED=n
# Enable TLS session caching to prevent doing a full TLS handshake for every send.
CONFIG_LWM2M_TLS_SESSION_CACHING=y
# Socket close is skipped at RX off idle state which optimize power consumption
# Socket close call will enable RCC connection for send Alert message to server
# Alert is now send right before opening a new connection.
CONFIG_LWM2M_RD_CLIENT_SUSPEND_SOCKET_AT_IDLE=y
# Sets the duration that the lwm2m engine will be polling for data after transmission before
# the socket is closed.
# Adjust so that we can detach from network in 30 seconds
CONFIG_LWM2M_QUEUE_MODE_UPTIME=30
# Set lifetime of 12 hours
CONFIG_LWM2M_ENGINE_DEFAULT_LIFETIME=43200
# Do registration update after 5400 seconds (90 minutes)
CONFIG_LWM2M_SECONDS_TO_UPDATE_EARLY=37800
# Configure PSM mode
# Request periodic TAU of 3600 seconds (60 minutes)
CONFIG_LTE_PSM_REQ_RPTAU="00000110"
# Set Requested Active Time (RAT) to 30 seconds. Preferably a little bit longer than the
# configured LWM2M_QUEUE_MODE_UPTIME. Due to NAT/firewall UDP connections are usually
# closed within 30-60 seconds so there is in general no point in setting a longer
# Queue mode uptime / LTE PSM active time.
CONFIG_LTE_PSM_REQ_RAT="00001111"
# Request eDRX mode
CONFIG_LTE_EDRX_REQ=y
# Request eDRX cycle length of 10.24 seconds for LTE-M
CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="0001"
# Request eDRX cycle length of 20.48 seconds for NB-IoT
CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="0010"
# Request Paging time window of 1.28 seconds for LTE-M
CONFIG_LTE_PTW_VALUE_LTE_M="0000"
# Request Paging time window of 2.56 seconds for NB-IoT
CONFIG_LTE_PTW_VALUE_NBIOT="0000"
# Get notification before Tracking Area Update (TAU). Notification triggers registration
# update and TAU will be sent with the update which decreases power consumption.
CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS=y
The error i get is
Obtained date-time from modem[0m[1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:58.221,557]
[0m<inf> lwm2m_firmware: Image type 1 [0m[1;32muart:~$ [m[8D[J[00:00:58.226,379]
[0m<inf> lwm2m_firmware: Application firmware download started.[0m[1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:59.594,360]
[1;31m<err> net_lwm2m_message_handling: Cannot find block context[0m[1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:02:08.828,063]
  • Hi Håkon
    Thank you for your assistance. Is this "package" method a feature I can expect to work in future updates or would it be worthwhile to build with the assumption that a "Package URI" method will only be available.
    Hassan
  • Hi Hassan,
    As stated in the former link, this is not a recommended method by leshan either.
    It is recommended that you provide an URI to the object.
    Håkon
  • Hi Håkon
    I've attempted to do this by pulling an update from our own server.  This is the error I'm getting.
    2023-04-17T10:51:55.817Z DEBUG modem << [m[1;32muart:~$ [m[8D[J*** Booting Zephyr OS build v3.2.99-ncs2 ***
    2023-04-17T10:51:55.822Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:01.507,812] [0m<inf> app_lwm2m_client: Run LWM2M client[0m
    2023-04-17T10:51:55.826Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:01.507,812] [0m<inf> app_lwm2m_client: Initializing modem.[0m
    2023-04-17T10:51:55.829Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:01.509,918] [0m<inf> BH1749: BH1749 initialized[0m
    2023-04-17T10:51:55.833Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:01.524,810] [0m<inf> app_lwm2m_client: endpoint: urn:imei:******[0m
    2023-04-17T10:51:55.836Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:01.571,014] [0m<dbg> app_lwm2m: buzzer_intensity_cb: Intensity: 100[0m
    2023-04-17T10:51:57.900Z DEBUG modem << [1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:03.572,448] [0m<inf> app_sensors: Finished accelerometer calibration[0m
    2023-04-17T10:51:57.905Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:03.572,753] [0m<dbg> app_sensors: colour_sensor_create: Created IPSO Colour Sensor instance: 0[0m
    2023-04-17T10:51:57.908Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:03.572,906] [0m<dbg> app_sensors: colour_sensor_create: Created IPSO Colour Sensor instance: 1[0m
    2023-04-17T10:51:57.912Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:03.573,059] [0m<inf> lwm2m_lte_notification: Registering ncell notification handler[0m
    2023-04-17T10:51:57.915Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:03.573,150] [0m<inf> lwm2m_firmware: Image is confirmed OK[0m
    2023-04-17T10:51:57.919Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:03.582,031] [0m<inf> app_lwm2m_client: PSM mode requested[0m
    2023-04-17T10:51:57.922Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:03.582,031] [0m<inf> app_lwm2m_client: Connecting to network.[0m
    2023-04-17T10:51:57.925Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:03.582,061] [0m<inf> app_lwm2m_client: This may take several minutes.[0m
    2023-04-17T10:52:00.799Z DEBUG modem << [1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:06.542,358] [0m<dbg> app_lwm2m_client: lwm2m_lte_reg_handler_notify: LTE NW status: 2[0m
    2023-04-17T10:52:03.020Z DEBUG modem << [1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:08.711,151] [0m<dbg> app_lwm2m_client: lwm2m_lte_reg_handler_notify: LTE NW status: 1[0m
    2023-04-17T10:52:03.024Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:08.712,036] [0m<inf> app_lwm2m_client: Connected to NB-IoT network[0m
    2023-04-17T10:52:03.027Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:08.712,432] [1;31m<err> gnss_module: Failed to set GNSS use case (-13)[0m
    2023-04-17T10:52:03.030Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:08.712,554] [0m<inf> app_lwm2m_client: Client connect to server[0m
    2023-04-17T10:52:03.033Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:08.712,615] [0m<inf> 3: Start LWM2M Client: urn:*************[0m
    2023-04-17T10:52:03.036Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:09.508,758] [0m<inf> 3: RD Client started with endpoint '********' with client lifetime 43200[0m
    2023-04-17T10:52:05.311Z DEBUG modem << [1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:11.032,226] [0m<inf> lwm2m_security: Need to write credentials, requesting LTE and GNSS offline...[0m
    2023-04-17T10:52:05.316Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:11.573,089] [0m<dbg> app_lwm2m_client: lwm2m_lte_reg_handler_notify: LTE NW status: 0[0m
    2023-04-17T10:52:05.319Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:11.573,242] [0m<inf> app_lwm2m_client: LwM2M is connecting to server[0m
    2023-04-17T10:52:06.424Z DEBUG modem << [1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:12.168,334] [0m<inf> lwm2m_security: Requesting LTE and GNSS online[0m
    2023-04-17T10:52:09.417Z DEBUG modem << [1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:15.161,254] [0m<dbg> app_lwm2m_client: lwm2m_lte_reg_handler_notify: LTE NW status: 2[0m
    2023-04-17T10:52:10.843Z DEBUG modem << [1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:16.567,321] [0m<inf> lwm2m_security: Modem connection restored[0m
    2023-04-17T10:52:10.849Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:16.767,120] [0m<dbg> app_lwm2m_client: lwm2m_lte_reg_handler_notify: LTE NW status: 1[0m
    2023-04-17T10:52:10.866Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:16.767,425] [0m<inf> app_lwm2m_client: LwM2M is connecting to server[0m
    2023-04-17T10:52:12.263Z DEBUG modem << [1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:17.969,573] [0m<inf> net_lwm2m_engine: Connected, sock id 0[0m
    2023-04-17T10:52:12.267Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:18.547,973] [0m<dbg> app_lwm2m_client: rd_client_event: Registration complete[0m
    2023-04-17T10:52:12.270Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:18.548,034] [0m<inf> 3: Registration Done (EP='9CjKyTlser')[0m
    2023-04-17T10:52:12.273Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:18.548,339] [0m<inf> app_lwm2m_client: LwM2M is connected to server[0m
    2023-04-17T10:52:12.277Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:18.548,431] [0m<inf> app_lwm2m_client: Obtained date-time from modem[0m
    2023-04-17T10:52:19.743Z DEBUG modem << [1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:25.425,445] [0m<inf> download_client: Setting up TLS credentials, tag 16842753[0m
    2023-04-17T10:52:19.748Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:25.425,567] [0m<inf> download_client: Connecting to https://download.*redacted*.com[0m
    2023-04-17T10:52:19.751Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:25.682,983] [1;31m<err> download_client: Unable to connect, errno 116[0m
    2023-04-17T10:52:19.754Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:25.683,380] [1;31m<err> lwm2m_firmware: fota_download_start() failed, return code -116[0m
    2023-04-17T10:52:19.757Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:25.684,783] [1;33m<wrn> fota_download: fota_download_cancel invalid state[0m
    2023-04-17T10:52:19.760Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:25.684,814] [1;31m<err> lwm2m_firmware: Unsupported Image type 0[0m
    2023-04-17T10:52:19.763Z DEBUG modem << [1;32muart:~$ [m[8D[J[00:00:25.684,814] [1;31m<err> lwm2m_firmware: Failed to reset DFU target, err: -13[0m
    2023-04-17T10:52:49.241Z DEBUG modem << [1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:54.987,121] [0m<dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed[0m
    The error is documented as a connection timeout.  Have you any idea what the issue could be ?
    All i've changed is the prj.conf file as follows:
    # General config
    CONFIG_ASSERT=y
    CONFIG_REBOOT=y
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=n
    CONFIG_NET_IPV6=n
    CONFIG_NET_IPV4=y
    # Sensors
    CONFIG_I2C=y
    CONFIG_SPI=y
    CONFIG_SENSOR=y
    # LwM2M and IPSO
    CONFIG_LWM2M=y
    # DTLS settings
    CONFIG_LOG=y
    CONFIG_SETTINGS=y
    CONFIG_FCB=y
    # LTE link control
    # Modem library
    # Modem info
    CONFIG_MODEM_INFO=y
    # Enable shell
    # Heap and stacks
    CONFIG_LWM2M_FIRMWARE_UPDATE_PULL_SUPPORT=y
    # Date-Time library
    CONFIG_DATE_TIME=y
    # Request eDRX mode
    # NBIOT
    CONFIG_PDN=y
    CONFIG_PDN_DEFAULT_APN="nbiot.*******"
    CONFIG_LWM2M_FIRMWARE_UPDATE_OBJ_SUPPORT=y
    CONFIG_DFU_TARGET=y
    The main.c file remains the same.  Kind regards,
    Hassan
  • Try to push http:// instead of https:// first, to see if this works better.
    The reason for getting an error is highly likely because you do not have the root CA for that specific domain.
    Håkon
