FOTA - THINGY91 lwm2m Leshan Demo Server
Good day
I have recently updated my toolchain and now I seem to be have having trouble with FOTA updates over lwm2m using the lwm2m client and over NBIOT.  I am following the instructions and help stated in this link https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.2.0/nrf/ug_nrf91_features.html#nrf9160-fota  .  Please assist if possible.
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_ASSERT=y
CONFIG_REBOOT=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_IPV6=n
CONFIG_NET_IPV4=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# Sensors
CONFIG_I2C=y
CONFIG_SPI=y
CONFIG_SENSOR=y
# LwM2M and IPSO
CONFIG_LWM2M=y
CONFIG_LWM2M_COAP_BLOCK_SIZE=512
CONFIG_LWM2M_COAP_MAX_MSG_SIZE=1280
CONFIG_LWM2M_ENGINE_MAX_OBSERVER=15
CONFIG_LWM2M_ENGINE_MAX_MESSAGES=15
CONFIG_LWM2M_ENGINE_MAX_PENDING=15
CONFIG_LWM2M_ENGINE_MAX_REPLIES=15
CONFIG_LWM2M_DNS_SUPPORT=y
CONFIG_LWM2M_RW_JSON_SUPPORT=n
CONFIG_LWM2M_SERVER_DEFAULT_PMIN=1
CONFIG_LWM2M_SERVER_DEFAULT_PMAX=300
CONFIG_LWM2M_CLIENT_UTILS=y
CONFIG_LWM2M_CLIENT_UTILS_LOCATION_OBJ_SUPPORT=n
CONFIG_LWM2M_IPSO_SUPPORT=y
# DTLS settings
CONFIG_LWM2M_DTLS_SUPPORT=y
# nRF9160 helper libraries
CONFIG_MODEM_KEY_MGMT=y
# Default app to debug logging
CONFIG_LOG=y
CONFIG_APP_LOG_LEVEL_DBG=y
# Support HEX style PSK values (double the size + NULL char)
CONFIG_LWM2M_SECURITY_KEY_SIZE=33
# extend CoAP retry timing to 4 seconds for LTE/LTE-M
CONFIG_COAP_INIT_ACK_TIMEOUT_MS=4000
# Enable CoAP extended option length
CONFIG_COAP_EXTENDED_OPTIONS_LEN=y
CONFIG_COAP_EXTENDED_OPTIONS_LEN_VALUE=40
# Enable settings storage
CONFIG_SETTINGS=y
CONFIG_FCB=y
CONFIG_SETTINGS_FCB=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
# Modem library
CONFIG_NRF_MODEM_LIB=y
# Modem info
CONFIG_MODEM_INFO=y
CONFIG_MODEM_INFO_ADD_DATE_TIME=n
# Enable shell
CONFIG_LWM2M_SHELL=y
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_LWM2M_ENGINE_STACK_SIZE=3072
# Allow FOTA downloads using download-client
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
CONFIG_FOTA_DOWNLOAD=y
CONFIG_DFU_TARGET=y
CONFIG_BOOTLOADER_MCUBOOT=y
# CONFIG_COAP_WELL_KNOWN_BLOCK_WISE=y
# Application version
CONFIG_MCUBOOT_IMAGE_VERSION="1.0.0"
# Set LwM2M Server IP address here
CONFIG_LWM2M_CLIENT_UTILS_SERVER="coaps://leshan.eclipseprojects.io:5684"
CONFIG_APP_LWM2M_PSK="000102030405060708090a0b0c0d0e0f"
# Application Event Manager
CONFIG_APP_EVENT_MANAGER=y
# Date-Time library
CONFIG_DATE_TIME=y
CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=86400
# NBIOT
CONFIG_LTE_NETWORK_MODE_NBIOT=y
CONFIG_PDN=y
CONFIG_PDN_DEFAULTS_OVERRIDE=y
CONFIG_PDN_DEFAULT_APN="nbiot.vodacom.za"
# Enable LwM2M Queue Mode
CONFIG_LWM2M_QUEUE_MODE_ENABLED=n
# Enable TLS session caching to prevent doing a full TLS handshake for every send.
CONFIG_LWM2M_TLS_SESSION_CACHING=y
# Socket close is skipped at RX off idle state which optimize power consumption
# Socket close call will enable RCC connection for send Alert message to server
# Alert is now send right before opening a new connection.
CONFIG_LWM2M_RD_CLIENT_SUSPEND_SOCKET_AT_IDLE=y
# Sets the duration that the lwm2m engine will be polling for data after transmission before
# the socket is closed.
# Adjust so that we can detach from network in 30 seconds
CONFIG_LWM2M_QUEUE_MODE_UPTIME=30
# Set lifetime of 12 hours
CONFIG_LWM2M_ENGINE_DEFAULT_LIFETIME=43200
# Do registration update after 5400 seconds (90 minutes)
CONFIG_LWM2M_SECONDS_TO_UPDATE_EARLY=37800
# Configure PSM mode
# Request periodic TAU of 3600 seconds (60 minutes)
CONFIG_LTE_PSM_REQ_RPTAU="00000110"
# Set Requested Active Time (RAT) to 30 seconds. Preferably a little bit longer than the
# configured LWM2M_QUEUE_MODE_UPTIME. Due to NAT/firewall UDP connections are usually
# closed within 30-60 seconds so there is in general no point in setting a longer
# Queue mode uptime / LTE PSM active time.
CONFIG_LTE_PSM_REQ_RAT="00001111"
# Request eDRX mode
CONFIG_LTE_EDRX_REQ=y
# Request eDRX cycle length of 10.24 seconds for LTE-M
CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="0001"
# Request eDRX cycle length of 20.48 seconds for NB-IoT
CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="0010"
# Request Paging time window of 1.28 seconds for LTE-M
CONFIG_LTE_PTW_VALUE_LTE_M="0000"
# Request Paging time window of 2.56 seconds for NB-IoT
CONFIG_LTE_PTW_VALUE_NBIOT="0000"
# Get notification before Tracking Area Update (TAU). Notification triggers registration
# update and TAU will be sent with the update which decreases power consumption.
CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS=y
The error i get is
Obtained date-time from modem[0m[1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:58.221,557]
[0m<inf> lwm2m_firmware: Image type 1 [0m[1;32muart:~$ [m[8D[J[00:00:58.226,379]
[0m<inf> lwm2m_firmware: Application firmware download started.[0m[1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:59.594,360]
[1;31m<err> net_lwm2m_message_handling: Cannot find block context[0m[1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:02:08.828,063]
