Hello and thank you for your help.
I am working on a project that uses distance measurements (DM). According to the Introduction to Nordic Distance Toolbox webinar, the largest distance tested was around 18m with a standard deviation of 37cm using high precision. Could I check if there is a theoretical maximum distance at which DM will work with similar accuracy?
I found some articles that have tested that the BLE range of the nRF DKs can be well over 500m (https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/testing-long-range-coded-phy-with-nordic-solution-it-simply-works-922075585). Should DM work at similar ranges or is there a point at which the accuracy diminishes?
I'm currently working on the nRF52840 DKs, using nRFConnect SDK v2.2.99. The code I am running is the sample code for distance measurements modified to output high precision results only.
Thank you.
