We want to certified our product but I have some information I didn't find in the datasheet of the nRF52820.
Can you help me please ?
Do you miss all the information, or only the two items with question marks on them?
It is a bit hard to guess from the French labels what exact information is asked for. Is there a guide explaining the fields of the form? (French descriptions should suffice, if it must be translated then it's better for me to get the original text.)
Terje
Thank you sorry I didn't precise.
I already complet like this but I want details for duty cycle and OBW and if the nRF52820 is already certified FCC or CE ?
You have any answer to give me ?
Duty cycle for BLE is theoretically max at around 60 %, but for testing purposes you can use 100 %.
Occupied Bandwidth (OBW) is 1.05 MHz for 1 Mbps and 2.1 MHz for 2 Mbps. (Normal BLE is 1 Mbps; Bluetooth 5 added 2 Mbps as an option. Most likely you are only using 1 Mbps.)
FCC and CE certification is for the end product (or if you use a module, the module can be certified), but not for the SoC alone. You need to do those certifications yourself (or use a certified module.)
Terje
