Hi: I'm fresh in use BLE. when i installed SDK, i could not install the lastest version v4_4_1,but can install v3_0_0. My system is MS win XP Pro SP3. Please tell me what the difference of twe version,and SDK v3.0.0 can work well or not.
I recommend you to install the latest version of the SDK, version 4.4.2. It can be downloaded here: www.nordicsemi.com/.../18304315 There have been several posts with a similar question on devzone. Perhaps this post solves your issue?
Regards, Kristin
Thank Kristin very much. SDK v4.4.1 can be installed successfully after i installed .net framework.:)
Sounds good! Can you please accept Kristin's answer, since it solved your problem? :)
