Programming Thingy:53 with Bluetooth Mesh sensor_server example
I have successfully built the Bluetooth Mesh sensor_server example, using the thingy53_nrf5340_cpuspp_ns build configuration.
But when I come to try and program the Thingy:53, it does not appear in the Connected Devices list, when connected to an nRF5340-DK board with a standard 10-pin cable (I used one from a STLink-V3). The RGB LED on the Thingy:53 illuminates on power up and cycles through the three colours a couple of times before going out, as it does when not connected via the 10-pin cable. When the Thingy:53 is connected via the 10-pin cable to the nRF5340-DK, the LEDs on the latter are not illuminated and neither appear in the Connected Devices list.
When I unplug and replug the USB cable to the nRF5340-DK board without the Thingy:53 connected, then the nRF5340-DK is detected and does appear in the Connected Devices list.
What else do I need to do for the Thingy:53 to be detected please?
I am using nRF Connect SDK v2.3.0 on Windows 11.
  • Hi Elfving,
    As I have two other nRF5340DK board that program just fine, I think we can eliminate the computer,  USB cable and the J-Link driver as issues.
    For both good and bad boards, when I power on the board (connected to the PC via USB)  I get a window pop up called JLINK (E:) that only shows two files:
    Segger.html
    README.TXT
    I have the view hidden files option selected in File Explorer, but these are the only two files shown.
    The guide that you link to describes a folder called BOOTLOADER, I do not see that appear for either the good or bad boards.
    Should I follow this instruction please?
    If on step 4 the kit does not show up as "BOOTLOADER", try to download and install the mbed Windows serial port driver
    Regarding the syntax for logging, it is the format for the nrfjprog command to allow for logging as indicated in the above screen capture with the --log option. for example, what should I add to make this the complete command that can be executed?
    nrfjprog --recover --log
    I also note the suggestion to use J-Link Commander, but I am not sure whether the instructions are correct for the nRF5340DK.
    r
    w4 4001e504 2
    w4 4001e50c 1
    w4 4001e514 1
    qc
    Could you confirm please?
    Al
    That is the interface chip showing up as a mass storage device. You can for instance flash your board by simply dropping the .hex file there. It is expected that it pops-up for all boards as there is nothing wrong with the interface chip on any of them. There shouldn't be anything else in the folder besides what you listed.
    Ah yes for that you need to enter bootloader mode. That way you can do a DFU on the interface chip. Though I do not think that is necessary as this chip works as intended. Though are you saying that when you press the IF BOOT/RESET button while power cycling the kit the bootloader folder does not show up? Though once again, I do not think you need to reinstall the J-LINK interface MCU firmware.
    Not sure if I understand what you mean here. Are you saying running nrfjprog --recover --log doesn't work for you?
    No you don't have to worry about that step.
    Elfving
  • Hi Elfving,
    I confirm that even the working the nRF5304DK does not go into Bootloader mode when the RESET switch SW5 is kept pressed down on power up. As you say that the other measures identified are not necessary, how should I proceed with resolving the programming issue with the non-functioning nRF5340DK please? Especially as the JLINK (E:) folder contents appears to be ok.
    Al
  • Hi Elfving,
    Reading through a similar post, I found a link to this page:
    Getting started with Thingy:53 — nRF Connect SDK 2.3.99 documentation (nordicsemi.com)
    And i note that the latest version of nRF Connect for Desktop Programmer has changes to the USB DFU:
    Should I be using the Programmer application instead to fix the non-working nRF540DK board please? If so, what process should I follow, and can you provide a link to the file to program it with please?
    Al
    Not sure if I am understanding you here. Are you saying that not only does this DK not enter Bootloader mode when the RESET switch is switch is kept pressed down on power up, but the even the working nRF5340DKs don't?
    Could you send me a picture of the DK? And in the previous picture you sent one of the leds seemed to be flashing?
    No I do not think that would be necessary. In order to program using a DFU the chip in question needs to already have a functioning bootloader etc.
    Elfving
