Programming Thingy:53 with Bluetooth Mesh sensor_server example
I have successfully built the Bluetooth Mesh sensor_server example, using the thingy53_nrf5340_cpuspp_ns build configuration.
But when I come to try and program the Thingy:53, it does not appear in the Connected Devices list, when connected to an nRF5340-DK board with a standard 10-pin cable (I used one from a STLink-V3). The RGB LED on the Thingy:53 illuminates on power up and cycles through the three colours a couple of times before going out, as it does when not connected via the 10-pin cable. When the Thingy:53 is connected via the 10-pin cable to the nRF5340-DK, the LEDs on the latter are not illuminated and neither appear in the Connected Devices list.
When I unplug and replug the USB cable to the nRF5340-DK board without the Thingy:53 connected, then the nRF5340-DK is detected and does appear in the Connected Devices list.
What else do I need to do for the Thingy:53 to be detected please?
I am using nRF Connect SDK v2.3.0 on Windows 11.
  • Thingy:53 serial number label.
    Al
  • Hi Elfving,
    I have three nRF5340DK boards, two purchased via Farnell UK in January 2022 and a third that I received as a gift during last October's Nordic roadshow.
    I have been using the newer board for programming the Thingy:53 in the above discussion thread.
    I am doing the Nordic DevAcademy nRF Fundamentals course and have found that now whilst I can flash the other two boards ok, I am getting an error report when I attempt to flash the newer board.
    As you've seen in the captures above, under the Connected Devices tab, COM0 and COM1 are listed as well as RTT. On the older boards COM0 and COM1 are not listed.
    What is also significant is that the nRF5340_xxAA_ENGD entry also appears automatically for the two older boards (along with just RTT) in the Connected Devices tab, but it does not appear for the newer board that I was using with the Thingy:53.
    This is the error message I get when I attempt to flash this board.
    Flashing build to 1050006835
    west flash -d c:\Workspace\Nordic\ncs-fund\v2.x.x\lesson3\fund_less3_exer1\build --skip-rebuild -r nrfjprog --dev-id 1050006835
    -- west flash: using runner nrfjprog
    -- runners.nrfjprog: Flashing file: C:\Workspace\Nordic\ncs-fund\v2.x.x\lesson3\fund_less3_exer1\build\zephyr\merged.hex
    ERROR: Unable to connect to a debugger.
    ERROR: JLinkARM DLL reported an error. Try again. If error condition
    ERROR: persists, run the same command again with argument --log, contact Nordic
    ERROR: Semiconductor and provide the generated log.log file to them.
    NOTE: For additional output, try running again with logging enabled (--log).
    NOTE: Any generated log error messages will be displayed.
    FATAL ERROR: command exited with status 33: nrfjprog --program 'C:\Workspace\Nordic\ncs-fund\v2.x.x\lesson3\fund_less3_exer1\build\zephyr\merged.hex' --sectorerase --verify -f NRF53 --snr 1050006835 --coprocessor CP_APPLICATION
    * The terminal process terminated with exit code: 33.
    * Terminal will be reused by tasks, press any key to close it.
    Is there some way to recover this board please?
    Al
  • Hello Al,
    Ah okey, that makes a lot of sense. I thought you mentioned that you could flash the DK sometime earlier, but I guess that was just an oversight on my part. If the main SoC on the DK is not working (for some reason, we can get into that later) then it makes sense that NRF5340_xxAA_ENGD won't pop-up without anything else connected to the debug output of the DK. After all, NRF5340_xxAA_ENGD is just the SoC variant read from the UICR of the SoC its programming.
    There might be, to start off we can try just that. Without the Thingy connected to the DK, run:
    nrfjprog --recover --coprocessor CP_NETWORK
    nrfjprog --recover
    alwalker said:
    I select the NRF5340_xxAA_ENGD option in the normal way using the mouse pointer and right-clicking.
    This still doesn't make much sense to me, but as long as you are able to flash the device I guess that isn't really a problem.
    Elfving
  • Hi Elfving,
    I tried using nrfjprog without success:
    This was without the Thingy attached to the nRF540DK. What should the syntax be for using the logging please?
    Any other suggestions please?
    Al
  • Well it might be that the SoC on that DK has been bricked somehow. Could you run through the steps in this guide
    Could you expand a bit on what you mean by this?
    Elfving
