Unable to connect nrf9160 https-client over NB-IOT
I am trying to create a socket and create a https request over NB-IOT. We started with the nrf9160 https-client sample, and changed the prefered and connection mode from LTE-M to NB-IOT.
We are located in Germany, and are connecting though a O2 telefonica sim, not the included iBasis one that comes with DK. We know the O2 sim can connect and send data over NB-IOT here as we have previously used the same sim with the SIM7020 modem.
The device when unset to the default, or set to LTE-M can connect and make the request fine. But when changed to NB-IOT the connection still occurs (as seen in the sim dashboard on O2's management system, kite platform).
I am adding the following lines near the startup of the program along with making changes in the proj.config. I have also enabled LTE link controller logging as the issue is occurring on the opening socket command, not the connect command.
proj.config
CONFIG_LTE_NETWORK_MODE_NBIOT=y
CONFIG_LOG=y
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG=y
Near the start of the main function in main.c
lte_lc_offline();
lte_lc_system_mode_set(LTE_LC_SYSTEM_MODE_NBIOT, LTE_LC_SYSTEM_MODE_PREFER_NBIOT);
lte_lc_init();
lte_lc_normal();
lte_lc_connect();
The modem firmware has also been manually updated to the most recent on the website (version 1.3.4), although the DK was purchased recently, so I doubt it even had the incompatible firmware.
Could NB-IOT not support https, and an example with http work? Would testing over AT commands provide more information using the AT client sample and LTE link monitor (is there a example of AT commands somewhere to make a http/https request)? Or is there any sample code or example the makes GET/POST requests as looking though the forum or github yields no examples.
Sawaiz
    Not sure if changing to HTTP would make much of a change compared to HTTPS. It looks like the device is connected to the network from the log, but there is a timeout (error 116) so the server is not responding for some reason.
    You can test with legacy PCO. Alternatives that I can come to think of are some subscription restrictions with the SIM like no data for NB-IOT network or maybe a different APN.
    Jonathan
    I have some updates from testing. I installed the serial modem client and ran some testing with AT commands and was able to make a http request over NB-IOT. I did not figure out how to make https commands though that.
    Doing some more testing, it turned out the response was ~2300 characters which was causing problems.
    We are able to make a connection over NB-IOT to httpbin.org/ip with the https-client example (although it takes ~10-30s for the 62 bytes to be sent. But it does not work with our own server. Although everything responds quickly, both our server and httpbin, when we set it back to LTE-M.
    Our guess is the lower bandwidth of NB-IOT isn't suited for https connections and we need to test this over http. I haven't found any example code, or what lines I can comment out to make the https-client example connect over http instead. Is there any example code or suggestion for testing http connections?
    Sawaiz
    I couldn't find any test samples for http specifically. If there are any tests, you would most probably find them under nrf/tests in the NCS repository.
    This is true. Using any TCP based protocol is not recommended, because of the lower bandwidth of NB-IoT. Instead, you should consider using a UDP based protocol like CoAP.
  • TCP isn't really a "match" for NB-IoT. If you want to use it with TLS, you must even care of a couple more details.
    TCP inject some inner protocol messages, which are usually used to implement the TCP grants (reliability and congestion control). The larger RTT of NB-IoT makes the default timing for such additional traffic inadequate, therefore it takes even some more injected messages to control that. You can't do too much except to relax your application timeouts (e.g. TCP connect timeout, HTTP request timeouts) and you may potential need retries for the TCP connect.
    If TLS comes into play, the you need to take care about the authentication mechanism. Usually only x509 is available and that comes with certificate chains. The size of such chains vary. Using a couple RSA 2048/4096 gets fast very large, AFAIK the TLS stack of the modem accepts only chains up to 4096 bytes at all, so usually you should better got for ECDSA certificates. TLS libraries usually also comes with timing assumption during the handshake, you need to relax them as good as you can.
    With both, relaxing TCP, TLS and HTTP timings, and ensure to use small x509 certificate chains, you may have a chance to make it working. But as I started, that's far away from being a "winning match". In the end it's far not that stable as CoAP/DTLS 1.2 CID, especially, if the radio conditions are not that good.
