ADXL372 do not work from ncs 2.0.0 to 2.2.0
as indicated in the subject, I can't port the attached program to higher version ncs 2.2.0 and I have compiling errors for ADXL372.
In ncs 2.0.0 it works fine, I haven't found any information about it.
Babosadxl372FALL_2.0.0.zip
    What is the error that you're seeing? Can you share the full build log?
    If you are configuring for thingy91_nrf9160_ns, then you need to comment out prj.conf::CONFIG_ADXL372_SPI=y
    Håkon
    the condensed log(s) with two version; the source is the same
    Thank You
    B
    compiling with 2.2.0 (do not work)
     *  Executing task: nRF Connect: Generate config thingy91_nrf9160_ns for /opt/nordic/adxl372FALL
    Building adxl372FALL
    west build --build-dir /opt/nordic/adxl372FALL/build /opt/nordic/adxl372FALL --pristine --board thingy91_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/opt/nordic/ncs/Carraro_Release/bt310_shell_release2023"
    -- Application: /opt/nordic/adxl372FALL
    -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter
    -- Cache files will be written to: /Users/babos/Library/Caches/zephyr
    -- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.2.0/zephyr)
    -- Board: thingy91_nrf9160_ns
    -- Found host-tools: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/v2.2.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /opt/nordic/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns.dts
    -- Found devicetree overlay: /opt/nordic/adxl372FALL/thingy91_nrf9160_ns.overlay
    -- Generated zephyr.dts: /opt/nordic/adxl372FALL/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /opt/nordic/adxl372FALL/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /opt/nordic/adxl372FALL/build/zephyr/dts.cmake
    /opt/nordic/adxl372FALL/prj.conf:10: warning: attempt to assign the value 'y' to the undefined symbol ADXL372_SPI
    error: Aborting due to Kconfig warnings
    Parsing /opt/nordic/ncs/v2.2.0/zephyr/Kconfig
    Loaded configuration '/opt/nordic/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns_defconfig'
    Merged configuration '/opt/nordic/adxl372FALL/prj.conf'
    CMake Error at /opt/nordic/ncs/v2.2.0/zephyr/cmake/modules/kconfig.cmake:328 (message):
      command failed with return code: 1
      /opt/nordic/ncs/v2.2.0/nrf/cmake/modules/kconfig.cmake:29 (include)
      /opt/nordic/ncs/v2.2.0/zephyr/cmake/modules/zephyr_default.cmake:108 (include)
      /opt/nordic/ncs/v2.2.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      /opt/nordic/ncs/v2.2.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:5 (find_package)
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/v2.2.0/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/v2.2.0/bin/python3 -B/opt/nordic/adxl372FALL/build -GNinja -DBOARD=thingy91_nrf9160_ns -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DBOARD_ROOT:STRING=/opt/nordic/ncs/Carraro_Release/bt310_shell_release2023 -S/opt/nordic/adxl372FALL
     *  The terminal process terminated with exit code: 1.
    compiling with 2.0.0 (work)
    [4/213] Creating directories for 'spm_subimage'
    [5/213] Creating directories for 'mcuboot_subimage'
    [6/213] No download step for 'mcuboot_subimage'
    [7/213] No download step for 'spm_subimage'
    [8/213] No update step for 'mcuboot_subimage'
    [9/213] No update step for 'spm_subimage'
    [10/213] No patch step for 'mcuboot_subimage'
    [11/213] No patch step for 'spm_subimage'
    [12/213] No configure step for 'mcuboot_subimage'
    [12/213] Performing build step for 'mcuboot_subimage'
    [1/279] Preparing syscall dependency handling
    [2/279] Generating include/generated/version.h
    -- Zephyr version: 3.0.99 (/opt/nordic/ncs/v2.0.0/zephyr), build: v3.0.99-ncs1
    [3/279] Generating misc/generated/syscalls_subdirs.trigger
    [4/279] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [5/279] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [6/279] Generating include/generated/driver-validation.h
    [7/279] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [8/279] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [9/279] Generating include/generated/offsets.h
    [10/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [11/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [12/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [13/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [14/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [15/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [16/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/base64.c.obj
    [17/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [18/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [19/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [20/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [21/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [22/279] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [23/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
    [24/279] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [25/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [26/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [27/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [28/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [29/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [30/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [31/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [32/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [33/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [34/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [35/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [36/279] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [37/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [38/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [39/279] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [40/279] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [41/279] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [42/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/boot_serial/src/serial_recovery_cbor.c.obj
    [43/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/boot_serial/src/cbor_decode.c.obj
    [44/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/boot_serial/src/cbor_encode.c.obj
    [45/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/boot_serial/src/cbor_common.c.obj
    [46/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/nrf52840_reset.c.obj
    [47/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [48/279] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [49/279] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [50/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/lib/adp536x/adp536x.c.obj
    [51/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [52/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [53/279] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [54/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [55/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
    [56/279] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [57/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj
    [58/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [59/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj
    [60/279] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [61/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [62/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [63/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [64/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [65/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [66/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [67/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [68/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [69/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [70/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [71/279] Generating linker_zephyr_pre0.cmd
    [72/279] Generating linker_zephyr_pre1.cmd
    [73/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [74/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [75/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [76/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [77/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [78/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [79/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [80/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [81/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [82/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [83/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [84/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [85/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [86/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [87/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [88/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [89/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [90/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [91/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [92/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [93/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [94/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [95/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [96/279] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [97/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [98/279] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [99/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [100/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [101/279] Linking C static library zephyr/arch/common/libisr_tables.a
    [102/279] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [103/279] Generating zephyr/autogen-pubkey.c
    [104/279] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [105/279] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [106/279] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [107/279] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [108/279] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [109/279] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [110/279] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [111/279] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [112/279] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [113/279] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [114/279] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [115/279] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [116/279] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [117/279] Linking C static library zephyr/libzephyr.a
    [118/279] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [119/279] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [120/279] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
    [121/279] Building C object CMakeFiles/app.dir/keys.c.obj
    [122/279] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [123/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    [124/279] Building C object CMakeFiles/app.dir/os.c.obj
    [125/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
    [126/279] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
    [127/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    [128/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    [129/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
    [130/279] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [131/279] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [132/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
    [133/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
    [134/279] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
    [135/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    [136/279] Building C object CMakeFiles/app.dir/main.c.obj
    [137/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    [138/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    [139/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
    [140/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
    [141/279] Linking C static library zephyr/arch/common/libarch__common.a
    [142/279] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [143/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
    [144/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/aesni.c.obj
    [145/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/aria.c.obj
    [146/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/aes.c.obj
    [147/279] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
    [148/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/asn1parse.c.obj
    [149/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/asn1write.c.obj
    [150/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/base64.c.obj
    [151/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ccm.c.obj
    [152/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/camellia.c.obj
    [153/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/bignum.c.obj
    [154/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/chacha20.c.obj
    [155/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/chachapoly.c.obj
    [156/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/cipher.c.obj
    [157/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/cipher_wrap.c.obj
    [158/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/zephyr_init.c.obj
    [159/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/cmac.c.obj
    [160/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ctr_drbg.c.obj
    [161/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/debug.c.obj
    [162/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/des.c.obj
    [163/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/dhm.c.obj
    [164/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ecdh.c.obj
    [165/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ecdsa.c.obj
    [166/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ecjpake.c.obj
    [167/279] Linking C static library zephyr/lib/posix/liblib__posix.a
    [168/279] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [169/279] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
    [170/279] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [171/279] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [172/279] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [173/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ecp.c.obj
    [174/279] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [175/279] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a
    [176/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ecp_curves.c.obj
    [177/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/entropy.c.obj
    [178/279] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [179/279] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [180/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/entropy_poll.c.obj
    [181/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/error.c.obj
    [182/279] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [183/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/gcm.c.obj
    [184/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/hkdf.c.obj
    [185/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/hmac_drbg.c.obj
    [186/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/md5.c.obj
    [187/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/mps_reader.c.obj
    [188/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
    [189/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/md.c.obj
    [190/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/mps_trace.c.obj
    [191/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/net_sockets.c.obj
    [192/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/nist_kw.c.obj
    [193/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/padlock.c.obj
    [194/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pem.c.obj
    [195/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pk.c.obj
    [196/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pk_wrap.c.obj
    [197/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/oid.c.obj
    [198/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pkcs12.c.obj
    [199/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pkparse.c.obj
    [200/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pkcs5.c.obj
    [201/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pkwrite.c.obj
    [202/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/platform.c.obj
    [203/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/platform_util.c.obj
    [204/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/poly1305.c.obj
    [205/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto.c.obj
    [206/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_aead.c.obj
    [207/279] Linking C static library app/libapp.a
    [208/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_cipher.c.obj
    [209/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_ecp.c.obj
    [210/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_hash.c.obj
    [211/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_mac.c.obj
    [212/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_client.c.obj
    [213/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_driver_wrappers.c.obj
    [214/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_rsa.c.obj
    [215/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_se.c.obj
    [216/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_slot_management.c.obj
    [217/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_storage.c.obj
    [218/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_its_file.c.obj
    [219/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ripemd160.c.obj
    [220/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/rsa.c.obj
    [221/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj
    [222/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/sha1.c.obj
    [223/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/sha256.c.obj
    [224/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/sha512.c.obj
    [225/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_cache.c.obj
    [226/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj
    [227/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_cli.c.obj
    [228/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_cookie.c.obj
    [229/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_msg.c.obj
    [230/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_srv.c.obj
    [231/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_ticket.c.obj
    [232/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_tls.c.obj
    [233/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj
    [234/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/threading.c.obj
    [235/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/timing.c.obj
    [236/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/version.c.obj
    [237/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/version_features.c.obj
    [238/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509.c.obj
    [239/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509_create.c.obj
    [240/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509_crl.c.obj
    [241/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509_crt.c.obj
    [242/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509_csr.c.obj
    [243/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509write_crt.c.obj
    [244/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509write_csr.c.obj
    [245/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [246/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [247/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [248/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [249/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [250/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [251/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [252/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [253/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [254/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [255/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [256/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [257/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [258/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [259/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [260/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [261/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [262/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [263/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [264/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [265/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [266/279] Linking C static library modules/mbedtls/libmodules__mbedtls.a
    [267/279] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [268/279] Linking C static library zephyr/kernel/libkernel.a
    [269/279] Linking C executable zephyr/zephyr_pre0.elf
    [270/279] Generating dev_handles.c
    [271/279] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [272/279] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [273/279] Linking C executable zephyr/zephyr_pre1.elf
    [274/279] Generating linker.cmd
    [275/279] Generating isr_tables.c, isrList.bin
    [276/279] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [277/279] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [278/279] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [279/279] Linking C executable zephyr/zephyr.elf
               FLASH:       40864 B        48 KB     83.14%
                SRAM:       26992 B     211736 B     12.75%
            IDT_LIST:          0 GB         2 KB      0.00%
    [17/213] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [18/213] Performing build step for 'spm_subimage'
    [1/268] Preparing syscall dependency handling
    [2/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_storage.c.obj
    [3/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pkcs12.c.obj
    [4/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pkwrite.c.obj
    [5/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pem.c.obj
    [6/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/dhm.c.obj
    [7/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pkcs5.c.obj
    [8/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pkparse.c.obj
    [9/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_aead.c.obj
    [10/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_cipher.c.obj
    [11/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_client.c.obj
    [12/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_hash.c.obj
    [13/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_mac.c.obj
    [14/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/random_ext.c.obj
    [15/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/cipher.c.obj
    [16/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/cipher_wrap.c.obj
    [17/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto.c.obj
    [18/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_ecp.c.obj
    [19/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_rsa.c.obj
    [20/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_slot_management.c.obj
    [21/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/psa_crypto_driver_wrappers.c.obj
    [22/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pk.c.obj
    [23/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/md.c.obj
    [24/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pk_wrap.c.obj
    [25/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/sha1.c.obj
    [26/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/sha256.c.obj
    [27/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ripemd160.c.obj
    [28/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/sha512.c.obj
    [29/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/md5.c.obj
    [30/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/aesni.c.obj
    [31/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/aria.c.obj
    [32/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/camellia.c.obj
    [33/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/des.c.obj
    [34/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ccm.c.obj
    [35/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/cmac.c.obj
    [36/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/chachapoly.c.obj
    [37/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ecdh.c.obj
    [38/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ecp_curves.c.obj
    [39/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ecp.c.obj
    [40/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/hmac_drbg.c.obj
    [41/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ecdsa.c.obj
    [42/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/gcm.c.obj
    [43/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/hkdf.c.obj
    [44/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/rsa_alt_helpers.c.obj
    [45/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/chacha20.c.obj
    [46/268] Generating include/generated/version.h
    [47/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/poly1305.c.obj
    [48/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ecjpake.c.obj
    [49/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
    [50/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509_create.c.obj
    [51/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj
    [52/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
    [53/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509write_csr.c.obj
    [54/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/rsa.c.obj
    [55/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509.c.obj
    [56/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509_crl.c.obj
    [57/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509_crt.c.obj
    [58/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/nist_kw.c.obj
    [59/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509_csr.c.obj
    [60/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/base64.c.obj
    [61/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/asn1parse.c.obj
    [62/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/asn1write.c.obj
    [63/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/padlock.c.obj
    [64/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/bignum.c.obj
    [65/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/net_sockets.c.obj
    [66/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/platform.c.obj
    [67/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/version.c.obj
    [68/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/debug.c.obj
    [69/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/oid.c.obj
    [70/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/platform_util.c.obj
    [71/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_cache.c.obj
    [72/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_ciphersuites.c.obj
    [73/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_ticket.c.obj
    [74/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_cli.c.obj
    [75/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_cookie.c.obj
    [76/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_srv.c.obj
    [77/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_msg.c.obj
    [78/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_tls13_keys.c.obj
    [79/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_tls.c.obj
    [80/268] Generating misc/generated/syscalls_subdirs.trigger
    [81/268] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto_base.a
    [82/268] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a
    [83/268] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedx509.a
    [84/268] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedtls.a
    [85/268] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [86/268] Generating include/generated/driver-validation.h
    [87/268] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [88/268] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [89/268] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [90/268] Generating include/generated/offsets.h
    [91/268] Building C object CMakeFiles/app.dir/src/main.c.obj
    [92/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [93/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [94/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [95/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [96/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [97/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [98/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [99/268] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [100/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [101/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [102/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [103/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [104/268] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [105/268] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [106/268] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
    [107/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [108/268] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [109/268] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
    [110/268] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [111/268] Linking C static library app/libapp.a
    [112/268] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [113/268] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
    [114/268] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
    [115/268] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [116/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/lib/adp536x/adp536x.c.obj
    [117/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/spm/spm.c.obj
    [118/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [119/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [120/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [121/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [122/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [123/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [124/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [125/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [126/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [127/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [128/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/spm/secure_services.c.obj
    [129/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [130/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [131/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
    [132/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [133/268] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [134/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [135/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [136/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [137/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [138/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [139/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [140/268] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [141/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [142/268] Generating linker_zephyr_pre0.cmd
    [143/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [144/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [145/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [146/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [147/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [148/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [149/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [150/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [151/268] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [152/268] Generating linker_zephyr_pre1.cmd
    [153/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [154/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [155/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [156/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [157/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [158/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [159/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [160/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [161/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [162/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [163/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [164/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [165/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj
    [166/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [167/268] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [168/268] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [169/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [170/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [171/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [172/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [173/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [174/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [175/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [176/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [177/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [178/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [179/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [180/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [181/268] Linking C static library zephyr/arch/common/libisr_tables.a
    [182/268] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [183/268] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [184/268] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [185/268] Linking C static library zephyr/libzephyr.a
    [186/268] Building C object zephyr/boards/boards/arm/thingy91_nrf9160/CMakeFiles/..__nrf__boards__arm__thingy91_nrf9160.dir/nrf52840_reset.c.obj
    [187/268] Building C object zephyr/boards/boards/arm/thingy91_nrf9160/CMakeFiles/..__nrf__boards__arm__thingy91_nrf9160.dir/adp5360_init.c.obj
    [188/268] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [189/268] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [190/268] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [191/268] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj
    [192/268] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [193/268] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/opt/nordic/ncs/v2.0.0/nrf/drivers/entropy/entropy_cc3xx.c.obj
    [194/268] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/cortex_m_systick.c.obj
    [195/268] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj
    [196/268] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [197/268] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
    [198/268] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [199/268] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [200/268] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/libarch__arm__core__aarch32__cortex_m__tz.a
    [201/268] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
    [202/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [203/268] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [204/268] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [205/268] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [206/268] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [207/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [208/268] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [209/268] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [210/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [211/268] Linking C static library zephyr/arch/common/libarch__common.a
    [212/268] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
    [213/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [214/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [215/268] Linking C static library zephyr/lib/posix/liblib__posix.a
    [216/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj
    [217/268] Linking C static library zephyr/subsys/random/libsubsys__random.a
    [218/268] Linking C static library zephyr/boards/boards/arm/thingy91_nrf9160/lib..__nrf__boards__arm__thingy91_nrf9160.a
    [219/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj
    [220/268] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [221/268] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [222/268] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [223/268] Linking C static library zephyr/drivers/i2c/libdrivers__i2c.a
    [224/268] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [225/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [226/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [227/268] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
    [228/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [229/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [230/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [231/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [232/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [233/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [234/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [235/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [236/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [237/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [238/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [239/268] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [240/268] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [241/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [242/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [243/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [244/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [245/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [246/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [247/268] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a
    [248/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [249/268] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [250/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [251/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [252/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [253/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [254/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [255/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [256/268] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [257/268] Linking C static library zephyr/kernel/libkernel.a
    [258/268] Linking C executable zephyr/zephyr_pre0.elf
    [259/268] Generating dev_handles.c
    [260/268] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [261/268] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [262/268] Linking C executable zephyr/zephyr_pre1.elf
    [263/268] Generating linker.cmd
    [264/268] Generating isr_tables.c, isrList.bin
    [265/268] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [266/268] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [267/268] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [268/268] Linking C executable zephyr/zephyr.elf
               FLASH:       48640 B        48 KB     98.96%
                SRAM:       11968 B        32 KB     36.52%
    [20/213] Completed 'mcuboot_subimage'
    [22/213] No install step for 'spm_subimage'
    [23/213] Completed 'spm_subimage'
    [24/213] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [25/213] Generating include/generated/offsets.h
    [26/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [27/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [28/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [29/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [30/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [31/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [32/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [33/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [34/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [35/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [36/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [37/213] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [38/213] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [39/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [40/213] Building C object CMakeFiles/app.dir/src/main.c.obj
    [41/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [42/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [43/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [44/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [45/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [46/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [47/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [48/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [49/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [50/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [51/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [52/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [53/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [54/213] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [55/213] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/nrf52840_reset.c.obj
    [56/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_list.c.obj
    [57/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
    [58/213] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
    [59/213] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [60/213] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [61/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
    [62/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
    [63/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
    [64/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
    [65/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
    [66/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [67/213] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/nonsecure/soc_secure.c.obj
    [68/213] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/lib/adp536x/adp536x.c.obj
    [69/213] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/nonsecure/secure_services_ns.c.obj
    [70/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg2.c.obj
    [71/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
    [72/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [73/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [74/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_backend_uart.c.obj
    [75/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [76/213] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [77/213] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [78/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [79/213] Linking C static library app/libapp.a
    [80/213] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [81/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [82/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [83/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [84/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [85/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [86/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [87/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [88/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [89/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [90/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [91/213] Generating linker_zephyr_pre1.cmd
    [92/213] Generating linker_zephyr_pre0.cmd
    [93/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [94/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [95/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [96/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [97/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [98/213] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [99/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [100/213] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [101/213] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [102/213] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [103/213] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [104/213] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
    [105/213] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [106/213] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [107/213] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [108/213] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [109/213] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj
    [110/213] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [111/213] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj
    [112/213] Linking C static library zephyr/arch/common/libisr_tables.a
    [113/213] Building C object zephyr/drivers/sensor/adxl372/CMakeFiles/drivers__sensor__adxl372.dir/adxl372.c.obj
    [114/213] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    [115/213] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/opt/nordic/ncs/v2.0.0/nrf/drivers/entropy/entropy_cc3xx.c.obj
    [116/213] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [117/213] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [118/213] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [119/213] Linking C static library zephyr/libzephyr.a
    [120/213] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [121/213] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [122/213] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [123/213] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [124/213] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
    [125/213] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
    [126/213] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/shmem_sanity.c.obj
    [127/213] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/errno_sanity.c.obj
    [128/213] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
    [129/213] Linking C static library zephyr/lib/posix/liblib__posix.a
    [130/213] Linking C static library zephyr/subsys/random/libsubsys__random.a
    [131/213] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [132/213] Linking C static library zephyr/lib/libc/newlib/liblib__libc__newlib.a
    [133/213] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [134/213] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [135/213] Linking C static library zephyr/drivers/i2c/libdrivers__i2c.a
    [136/213] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
    [137/213] Building C object modules/cjson/CMakeFiles/cjson.dir/opt/nordic/ncs/v2.0.0/modules/lib/cjson/cJSON_Utils.c.obj
    [138/213] Building C object modules/cjson/CMakeFiles/cjson.dir/opt/nordic/ncs/v2.0.0/modules/lib/cjson/cJSON.c.obj
    [139/213] Linking C static library zephyr/arch/common/libarch__common.a
    [140/213] Linking C static library zephyr/drivers/sensor/adxl372/libdrivers__sensor__adxl372.a
    [141/213] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
    [142/213] Linking C static library zephyr/drivers/spi/libdrivers__spi.a
    [143/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [144/213] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
    [145/213] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [146/213] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [147/213] Building C object modules/nrf/lib/modem_antenna/CMakeFiles/..__nrf__lib__modem_antenna.dir/modem_antenna.c.obj
    [148/213] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [149/213] Building C object modules/cjson/CMakeFiles/cjson.dir/os/cJSON_os.c.obj
    [150/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [151/213] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [152/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [153/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
    [154/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [155/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [156/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [157/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [158/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj
    [159/213] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [160/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
    [161/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj
    [162/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [163/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [164/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [165/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [166/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [167/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [168/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [169/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [170/213] Linking C static library modules/nrf/lib/nrf_modem_lib/lib..__nrf__lib__nrf_modem_lib.a
    [171/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [172/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [173/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [174/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [175/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [176/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [177/213] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [178/213] Linking C static library modules/nrf/lib/modem_antenna/lib..__nrf__lib__modem_antenna.a
    [179/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [180/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [181/213] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [182/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [183/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [184/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [185/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [186/213] Linking C static library modules/cjson/libcjson.a
    [187/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [188/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [189/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [190/213] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [191/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [192/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [193/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [194/213] Linking C static library zephyr/kernel/libkernel.a
    [195/213] Linking C executable zephyr/zephyr_pre0.elf
    [196/213] Generating dev_handles.c
    [197/213] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [198/213] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [199/213] Linking C executable zephyr/zephyr_pre1.elf
    [200/213] Generating linker.cmd
    [201/213] Generating isr_tables.c, isrList.bin
    [202/213] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [203/213] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [204/213] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [205/213] Linking C executable zephyr/zephyr.elf
               FLASH:       74204 B     380416 B     19.51%
                SRAM:       26872 B     211736 B     12.69%
    [206/213] Generating zephyr/mcuboot_primary_app.hex
    [207/213] Generating zephyr/mcuboot_primary.hex
    [208/213] Generating ../../zephyr/app_update.bin
    [209/213] Generating ../../zephyr/dfu_application.zip
    [210/213] Generating ../../zephyr/app_signed.hex
    [211/213] Generating ../../zephyr/app_test_update.hex
    [212/213] Generating ../../zephyr/app_moved_test_update.hex
    [213/213] Generating zephyr/merged.hex
  • I also tried removing 'ADXL372 SPI' from the config file
  • Can you share logs/output if it still fails?
  • I use visual studio code. Where can I find the build log?
