as indicated in the subject, I can't port the attached program to higher version ncs 2.2.0 and I have compiling errors for ADXL372.
In ncs 2.0.0 it works fine, I haven't found any information about it.
If it is a build error, it should be posted in the lower right corner of vscode.
Is there a serial output that shows it does not work? If so, you can either connect it via vscode, or manually open the COM port with 115200 baud rate to see the log.
Håkon
hi Håkon,
probably the old 'BOARD' was selected. I removed the deprecated 'ADXL372 SPI' configuration setting, replaced the board by deleting the old builds one and it now compiled . I'll let you know if it physically works because I don't have the board here with me.
A thousand thanks
babos
the terminal truck log when it is very long ...
Not work on 2.2.0 but only 2.0.0 ....
sadness...
Can you please paste the log of the working and failing example?
Håkon
