as indicated in the subject, I can't port the attached program to higher version ncs 2.2.0 and I have compiling errors for ADXL372.
In ncs 2.0.0 it works fine, I haven't found any information about it.
aren't those at the beginning of this ticket?
babos
Your initial problem was compiling, and now I am quite uncertain about what is happening. Without any logs or similar of you showing what the runtime error is, it is a bit hard for me to pin-point what can be the possible issue.
Could you share more information on what is failing?
Håkon
compiling with 2.2.0 or 2.0.0, commenting the ADXL372_SPI configuration on 2.2.0 which is not accepted in this version, there are no errors but I have no answers on the serial when I exceed the programmed threshold. I attach results.
log 2.2.0
Building adxl372_fall_2.2.0 west build --build-dir /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0 --pristine --board thingy91_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/prj.conf" -DDTC_OVERLAY_FILE:STRING="/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/thingy91_nrf9160_ns.overlay" -- west build: generating a build system -- Application: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0 Loading Zephyr default modules (Zephyr base). -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/silvio/Library/Caches/zephyr -- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.2.0/zephyr) -- Found west (found suitable version "0.14.0", minimum required is "0.7.1") -- Board: thingy91_nrf9160_ns -- Found host-tools: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk) -- Found toolchain: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/v2.2.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns.dts -- Found devicetree overlay: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/thingy91_nrf9160_ns.overlay -- Generated zephyr.dts: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/zephyr/zephyr.dts -- Generated devicetree_generated.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.2.0/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns_defconfig' Merged configuration '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/prj.conf' Configuration saved to '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/zephyr/.config' Kconfig header saved to '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 12.1.0 -- The CXX compiler identification is GNU 12.1.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found version "3.9.6") found components: Interpreter Changed board to secure thingy91_nrf9160 (NOT NS) ....... [35/93] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj [36/93] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj [37/93] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj [38/93] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/base64.c.obj [39/93] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/asn1parse.c.obj [40/93] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/asn1write.c.obj [40/93] Performing build step for 'tfm' [1/38] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o [2/38] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o [3/38] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o [4/38] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o [5/38] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o [6/38] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch_v8m_main.o [7/38] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_boot_data.o [8/38] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/static_load.o [9/38] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.o [10/38] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o [11/38] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o [12/38] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/plat_test.o [13/38] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o [14/38] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o [15/38] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_Flash.o [16/38] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/spm_hal.o [17/38] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o [18/38] Building C object platform/target/nrf9160/nrf_common/CMakeFiles/tfm_s_scatter.dir/gcc/nordic_nrf_s.ld [19/38] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_isolation.o [20/38] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_platform_hal_ioctl.o [21/38] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o [22/38] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o [23/38] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/plat_test.o [24/38] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/target_cfg.o [25/38] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/src/tfm_platform_system.o [26/38] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/plat_test.o [27/38] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/attest_hal.o [28/38] Linking C static library platform/libplatform_s.a [29/38] Linking C static library secure_fw/partitions/platform/libtfm_psa_rot_partition_platform.a [30/38] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libcrypto_service_mbedcrypto.a [31/38] Linking C static library secure_fw/partitions/crypto/libtfm_psa_rot_partition_crypto.a [32/38] Linking C static library secure_fw/partitions/lib/sprt/libtfm_sprt.a [33/38] Linking C static library secure_fw/spm/libtfm_spm.a [34/38] Linking C executable bin/tfm_s.axf [35/38] Generating ../bin/tfm_s.bin [36/38] Generating ../bin/tfm_s.hex [37/38] Generating ../bin/tfm_s.elf [38/38] Linking C static library secure_fw/libtfm_s_veneers.a [51/93] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json [52/86] Performing build step for 'mcuboot_subimage' [1/30] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json [2/30] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj [3/30] Building C object CMakeFiles/app.dir/main.c.obj [4/30] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj [5/30] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj [6/30] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj [7/30] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj [8/30] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj [9/30] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj [10/30] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj [11/30] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj [12/30] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj [13/30] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj [14/30] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj [15/30] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj [16/30] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj [17/30] Generating linker_zephyr_pre0.cmd [18/30] Generating linker_zephyr_pre1.cmd [19/30] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a [20/30] Linking C static library app/libapp.a [21/30] Linking C static library zephyr/libzephyr.a [22/30] Linking C executable zephyr/zephyr_pre0.elf [23/30] Generating dev_handles.c [24/30] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj [25/30] Linking C executable zephyr/zephyr_pre1.elf [26/30] Generating linker.cmd [27/30] Generating isr_tables.c, isrList.bin [28/30] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj [29/30] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj [30/30] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 40410 B 48 KB 82.21% RAM: 28024 B 211736 B 13.24% IDT_LIST: 0 GB 2 KB 0.00% [66/86] Linking C executable zephyr/zephyr_pre0.elf [69/86] Linking C executable zephyr/zephyr_pre1.elf [73/86] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj [75/84] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 77724 B 380416 B 20.43% RAM: 26824 B 211736 B 12.67% IDT_LIST: 0 GB 2 KB 0.00% [76/84] Generating zephyr/tfm_nonsecure.hex [77/84] Generating zephyr/mcuboot_primary.hex [78/84] Generating zephyr/mcuboot_primary_app.hex [79/84] Generating ../../zephyr/app_update.bin sign the payload [80/84] Generating ../../zephyr/dfu_application.zip [81/84] Generating ../../zephyr/app_signed.hex sign the payload [82/84] Generating ../../zephyr/app_test_update.hex sign the payload [83/84] Generating ../../zephyr/app_moved_test_update.hex [84/84] Generating zephyr/merged.hex * Terminal will be reused by tasks, press any key to close it. * Executing task: nRF Connect: Build: adxl372_fall_2.2.0/build (active) Building adxl372_fall_2.2.0 west build --build-dir /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0 [0/30] Performing build step for 'tfm' ninja: no work to do. [1/5] Performing build step for 'mcuboot_subimage' ninja: no work to do. * Terminal will be reused by tasks, press any key to close it. * Executing task: nRF Connect: Build: adxl372_fall_2.2.0/build (active) Building adxl372_fall_2.2.0 west build --build-dir /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0 [0/30] Performing build step for 'tfm' ninja: no work to do. [1/5] Performing build step for 'mcuboot_subimage' ninja: no work to do. * Terminal will be reused by tasks, press any key to close it. * Executing task: nRF Connect: Build [pristine]: adxl372_fall_2.2.0/build (active) Building adxl372_fall_2.2.0 west build --build-dir /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0 --pristine --board thingy91_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/prj.conf" -DDTC_OVERLAY_FILE:STRING="/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/thingy91_nrf9160_ns.overlay" -- west build: generating a build system -- Application: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0 Loading Zephyr default modules (Zephyr base). -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/silvio/Library/Caches/zephyr -- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.2.0/zephyr) -- Found west (found suitable version "0.14.0", minimum required is "0.7.1") -- Board: thingy91_nrf9160_ns -- Found host-tools: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk) -- Found toolchain: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/v2.2.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns.dts -- Found devicetree overlay: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/thingy91_nrf9160_ns.overlay -- Generated zephyr.dts: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/zephyr/zephyr.dts -- Generated devicetree_generated.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.2.0/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns_defconfig' Merged configuration '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/prj.conf' Configuration saved to '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/zephyr/.config' Kconfig header saved to '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 12.1.0 -- The CXX compiler identification is GNU 12.1.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found version "3.9.6") found components: Interpreter Changed board to secure thingy91_nrf9160 (NOT NS) === child image mcuboot - begin === loading initial cache file /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/mcuboot/child_image_preload.cmake Loading Zephyr default modules (Zephyr base). -- Application: /opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr * Terminal will be reused by tasks, press any key to close it. * Executing task: nRF Connect: Build: adxl372_fall_2.2.0/build (active) Building adxl372_fall_2.2.0 west build --build-dir /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0 [1/278] Preparing syscall dependency handling [2/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/asn1parse.c.obj [3/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/asn1write.c.obj [4/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/base64.c.obj [5/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/bignum.c.obj [6/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/nist_kw.c.obj [7/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/oid.c.obj [8/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/platform.c.obj [9/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/padlock.c.obj [10/278] Generating include/generated/version.h -- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1 [11/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/platform_util.c.obj [12/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/version.c.obj [13/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/constant_time.c.obj [14/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pem.c.obj [15/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkcs12.c.obj [16/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkcs5.c.obj [17/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkparse.c.obj [18/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkwrite.c.obj [19/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/dhm.c.obj [20/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cipher.c.obj [21/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cipher_wrap.c.obj [22/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/md.c.obj [23/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pk.c.obj [24/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pk_wrap.c.obj [25/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha1.c.obj [26/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha256.c.obj [27/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha512.c.obj [28/278] Creating directories for 'mcuboot_subimage' [29/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/md5.c.obj [30/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ripemd160.c.obj [31/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/aesni.c.obj [32/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/aria.c.obj [33/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/camellia.c.obj [34/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/des.c.obj [35/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cmac.c.obj [36/278] No download step for 'mcuboot_subimage' [37/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ccm.c.obj [38/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/chachapoly.c.obj [39/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecdh.c.obj [40/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecdsa.c.obj [41/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecp.c.obj [42/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecp_curves.c.obj [43/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/gcm.c.obj [44/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/hkdf.c.obj [45/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/hmac_drbg.c.obj [46/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/rsa.c.obj [47/278] No update step for 'mcuboot_subimage' [48/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/rsa_alt_helpers.c.obj [49/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ctr_drbg.c.obj [50/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/entropy.c.obj [51/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj [52/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj [53/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj [54/278] No patch step for 'mcuboot_subimage' [55/278] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto_base.a [56/278] No configure step for 'mcuboot_subimage' [56/278] Performing build step for 'mcuboot_subimage' [1/280] Preparing syscall dependency handling [2/280] Generating include/generated/version.h -- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1 [3/280] Generating misc/generated/syscalls_subdirs.trigger [4/280] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json [5/280] Generating include/generated/driver-validation.h [6/280] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h [7/280] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h [8/280] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj [9/280] Generating include/generated/offsets.h [10/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/base64.c.obj [11/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj [12/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj [13/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj [14/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj [15/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj [16/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj [17/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj [18/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj [19/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj [20/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj [21/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj [22/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj [23/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj [24/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj [25/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj [26/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj [27/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj [28/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj [29/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj [30/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj [31/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj [32/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj [33/280] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj [34/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj [35/280] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj [36/280] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj [37/280] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj [38/280] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/nrf52840_reset.c.obj [39/280] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj [40/280] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj [41/280] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj [42/280] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj [43/280] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj [44/280] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj [45/280] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj [46/280] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/boot_serial/src/serial_recovery_cbor.c.obj [47/280] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj [48/280] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/boot_serial/src/zcbor_decode.c.obj [49/280] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/boot_serial/src/zcbor_encode.c.obj [50/280] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/boot_serial/src/zcbor_common.c.obj [51/280] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj [52/280] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrf/lib/adp536x/adp536x.c.obj [53/280] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj [54/280] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj [55/280] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj [56/280] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj [57/280] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj [58/280] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj [59/280] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj [60/280] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj [61/280] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj [62/280] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj [63/280] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj [64/280] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj [65/280] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj [66/280] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj [67/280] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj [68/280] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj [69/280] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj [70/280] Linking C static library zephyr/arch/common/libisr_tables.a [71/280] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj [72/280] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj [73/280] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj [74/280] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj [75/280] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj [76/280] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj [77/280] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj [78/280] Generating linker_zephyr_pre1.cmd [79/280] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj [80/280] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a [81/280] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj [82/280] Generating linker_zephyr_pre0.cmd [83/280] Linking C static library zephyr/arch/common/libarch__common.a [84/280] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj [85/280] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj [86/280] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a [87/280] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a [88/280] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj [89/280] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj [90/280] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a [91/280] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj [92/280] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a [93/280] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj [94/280] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj [95/280] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj [96/280] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj [97/280] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj [98/280] Linking C static library zephyr/drivers/flash/libdrivers__flash.a [99/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/zephyr_init.c.obj [100/280] Linking C static library zephyr/drivers/serial/libdrivers__serial.a [101/280] Linking C static library zephyr/drivers/timer/libdrivers__timer.a [102/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/aria.c.obj [103/280] Generating ../../../include/generated/libc/minimal/strerror_table.h [104/280] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a [105/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/aes.c.obj [106/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/aesni.c.obj [107/280] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a [108/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/asn1parse.c.obj [109/280] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a [110/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj [111/280] Linking C static library zephyr/libzephyr.a [112/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj [113/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj [114/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj [115/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj [116/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj [117/280] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a [118/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj [119/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj [120/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj [121/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj [122/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj [123/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj [124/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj [125/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj [126/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj [127/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj [128/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj [129/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj [130/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj [131/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj [132/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/asn1write.c.obj [133/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/base64.c.obj [134/280] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj [135/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/bignum.c.obj [136/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/camellia.c.obj [137/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ccm.c.obj [138/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/chacha20.c.obj [139/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/chachapoly.c.obj [140/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/cipher.c.obj [141/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/cipher_wrap.c.obj [142/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/cmac.c.obj [143/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ctr_drbg.c.obj [144/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/constant_time.c.obj [145/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/debug.c.obj [146/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/des.c.obj [147/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/dhm.c.obj [148/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ecdh.c.obj [149/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ecdsa.c.obj [150/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ecjpake.c.obj [151/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ecp.c.obj [152/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ecp_curves.c.obj [153/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/entropy.c.obj [154/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/entropy_poll.c.obj [155/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/error.c.obj [156/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/gcm.c.obj [157/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/hkdf.c.obj [158/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/hmac_drbg.c.obj [159/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/md.c.obj [160/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/md5.c.obj [161/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj [162/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/mps_reader.c.obj [163/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/mps_trace.c.obj [164/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/net_sockets.c.obj [165/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/nist_kw.c.obj [166/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/oid.c.obj [167/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/padlock.c.obj [168/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/pem.c.obj [169/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/pk.c.obj [170/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/pk_wrap.c.obj [171/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/pkcs12.c.obj [172/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/pkcs5.c.obj [173/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/pkparse.c.obj [174/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/pkwrite.c.obj [175/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/platform.c.obj [176/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/platform_util.c.obj [177/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/poly1305.c.obj [178/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto.c.obj [179/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_aead.c.obj [180/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_cipher.c.obj [181/280] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a [182/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_client.c.obj [183/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_driver_wrappers.c.obj [184/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_ecp.c.obj [185/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_hash.c.obj [186/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_mac.c.obj [187/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_rsa.c.obj [188/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_se.c.obj [189/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_slot_management.c.obj [190/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_storage.c.obj [191/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_its_file.c.obj [192/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ripemd160.c.obj [193/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/rsa.c.obj [194/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj [195/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/sha1.c.obj [196/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/sha256.c.obj [197/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/sha512.c.obj [198/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_cache.c.obj [199/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj [200/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_cli.c.obj [201/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_cookie.c.obj [202/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_debug_helpers_generated.c.obj [203/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_msg.c.obj [204/280] Generating zephyr/autogen-pubkey.c [205/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_srv.c.obj [206/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_ticket.c.obj [207/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls.c.obj [208/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_client.c.obj [209/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_generic.c.obj [210/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj [211/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_server.c.obj [212/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/threading.c.obj [213/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/timing.c.obj [214/280] Building C object CMakeFiles/app.dir/os.c.obj [215/280] Building C object CMakeFiles/app.dir/keys.c.obj [216/280] Building C object CMakeFiles/app.dir/main.c.obj [217/280] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj [218/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj [219/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj [220/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj [221/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj [222/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj [223/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj [224/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj [225/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj [226/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj [227/280] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj [228/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj [229/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj [230/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj [231/280] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj [232/280] Building C object CMakeFiles/app.dir/arm_cleanup.c.obj [233/280] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj [234/280] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj [235/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/version.c.obj [236/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/version_features.c.obj [237/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/x509.c.obj [238/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_create.c.obj [239/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_crl.c.obj [240/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_crt.c.obj [241/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_csr.c.obj [242/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/x509write_crt.c.obj [243/280] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls/library/x509write_csr.c.obj [244/280] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj [245/280] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj [246/280] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj [247/280] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj [248/280] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj [249/280] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj [250/280] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj [251/280] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj [252/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj [253/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj [254/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj [255/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj [256/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj [257/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj [258/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj [259/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj [260/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj [261/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj [262/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj [263/280] Linking C static library app/libapp.a [264/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj [265/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj [266/280] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj [267/280] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a [268/280] Linking C static library zephyr/kernel/libkernel.a [269/280] Linking C static library modules/mbedtls/libmodules__mbedtls.a [270/280] Linking C executable zephyr/zephyr_pre0.elf [271/280] Generating dev_handles.c [272/280] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj [273/280] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj [274/280] Linking C executable zephyr/zephyr_pre1.elf [275/280] Generating linker.cmd [276/280] Generating isr_tables.c, isrList.bin [277/280] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj [278/280] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj [279/280] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj [280/280] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 40410 B 48 KB 82.21% RAM: 28024 B 211736 B 13.24% IDT_LIST: 0 GB 2 KB 0.00% [63/278] Generating ../../tfm/CMakeCache.txt -- The C compiler identification is GNU 12.1.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found version "3.9.6") found components: Interpreter -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/silvio/Library/Caches/zephyr -- Configuring done -- Generating done -- Build files have been written to: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/tfm [68/278] No configure step for 'tfm' [69/278] Performing build step for 'tfm' [1/2] Generating ../generated/secure_fw/spm/cmsis_func/tfm_spm_db_func.inc, ../generated/secure_fw/spm/cmsis_func/tfm_veneers.c, ../generated/interface/include/tfm_veneers.h, ../generated/tools/tfm_veneers_functions.txt, ../generated/secure_fw/spm/cmsis_func/tfm_secure_irq_handlers.inc, ../generated/interface/include/psa_manifest/sid.h, ../generated/interface/include/psa_manifest/pid.h, ../generated/interface/include/config_impl.h, ../generated/tools/config_impl.cmake [1/2] Re-running CMake... -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found version "3.9.6") found components: Interpreter -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/silvio/Library/Caches/zephyr -- Configuring done -- Generating done -- Build files have been written to: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.2.0/build/tfm [1/171] Generating liboberon_mbedcrypto__psa_3.0.12.a [2/171] Building C object lib/fih/CMakeFiles/tfm_fih_implementation.dir/src/fih.o [3/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/asn1parse.o [4/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/asn1write.o [5/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/oid.o [6/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/base64.o [7/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/nist_kw.o [8/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/padlock.o [9/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/bignum.o [10/171] Building ASM object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/nrf9160/gcc/startup_nrf9160_s.o [11/171] Linking C static library lib/fih/libtfm_fih_implementation.a [12/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/platform.o [13/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/interface/src/tfm_psa_call_pack.o [14/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/faults.o [15/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_core_utils.o [16/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/idle_partition/load_info_idle_sp.o [17/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o [18/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/tfm_psa_api_veneers.o [19/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o [20/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o [21/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/utilities.o [22/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/spm/cmsis_psa/psa_interface_cross.o [23/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_boot_data.o [24/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch.o [25/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/main.o [26/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_cross_call.o [27/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/plat_test.o [28/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_pools.o [29/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ns_client_ext/tfm_spm_ns_ctx.o [30/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/backend_ipc.o [31/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/interrupt.o [32/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/static_load.o [33/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_core_svcalls_ipc.o [34/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/interface/src/tfm_psa_call_pack.o [35/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/idle_partition.o [36/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/ns_agent_tz.o [37/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/thread.o [38/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch_v8m_main.o [39/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcmp.o [40/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o [41/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o [42/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/load_info_idle_sp.o [43/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_ipc.o [44/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcpy.o [45/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/load_info_ns_agent_tz.o [46/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_strnlen.o [47/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memset.o [48/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_main.o [49/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memmove.o [50/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_partition_metadata_indicator.o [51/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/psa_interface_cross.o [52/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sfn_common_thread.o [53/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_psa_call_pack.o [54/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/service_api.o [55/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/psa_api.o [56/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/platform/tfm_platform_secure_api.o [57/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o [58/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_cipher.o [59/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_hash.o [60/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_mac.o [61/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/spm/cmsis_psa/psa_interface_cross.o [62/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_aead.o [63/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_alloc.o [64/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key.o [65/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_rng.o [66/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetric.o [67/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o [68/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/interface/src/tfm_psa_call_pack.o [69/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o [70/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_init.o [71/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/version.o [72/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/platform_util.o [73/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_management.o [74/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/constant_time.o [75/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_derivation.o [76/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/spm/cmsis_psa/psa_interface_cross.o [77/171] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libmbedcrypto_base.a [78/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_cipher.o [79/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_ecp.o [80/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_mac.o [81/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_hash.o [82/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_storage.o [83/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_aead.o [84/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/memory_buffer_alloc.o [85/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_client.o [86/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_rsa.o [87/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o [88/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pem.o [89/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/random_ext.o [90/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkcs12.o [91/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkcs5.o [92/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkparse.o [93/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkwrite.o [94/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/dhm.o [95/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/md.o [96/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pk.o [97/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pk_wrap.o [98/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha1.o [99/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cipher_wrap.o [100/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha256.o [101/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha512.o [102/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ripemd160.o [103/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/md5.o [104/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/aria.o [105/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/aesni.o [106/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/camellia.o [107/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/des.o [108/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cmac.o [109/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/chachapoly.o [110/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ccm.o [111/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecdh.o [112/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecp.o [113/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecdsa.o [114/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecp_curves.o [115/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/gcm.o [116/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/hmac_drbg.o [117/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/hkdf.o [118/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/rsa.o [119/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes.o [120/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/rsa_alt_helpers.o [121/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/ecjpake_oberon.o [122/171] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o [123/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes_oberon.o [124/171] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/interface/src/tfm_psa_call_pack.o [125/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cipher.o [126/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_slot_management.o [127/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/psa_crypto_driver_wrappers.o [128/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/crypto/tfm_crypto_secure_api.o [129/171] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/spm/cmsis_psa/psa_interface_cross.o [130/171] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o [131/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mpu_armv8m_drv.o [132/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrfx_glue.o [133/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/plat_test.o [134/171] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o [135/171] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_nvic.o [136/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_Flash.o [137/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.o [138/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o [139/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_ioctl_core_s_api.o [140/171] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.o [141/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/hw_init.o [142/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/spm_hal.o [143/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_platform_hal_ioctl.o [144/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_isolation.o [145/171] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/dummy_provisioning.o [146/171] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/tfm_hal_platform.o [147/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/tfm_interrupts.o [148/171] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/dummy_otp.o [149/171] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_memory_symbols.o [150/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/plat_test.o [151/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/target_cfg.o [152/171] Building C object platform/target/nrf9160/nrf_common/CMakeFiles/tfm_s_scatter.dir/gcc/nordic_nrf_s.ld [153/171] Building C object platform/CMakeFiles/platform_s.dir/__/interface/src/tfm_psa_call_pack.o [154/171] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.o [155/171] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/src/tfm_ioctl_s_api.o [156/171] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_platform.o [157/171] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/src/tfm_platform_system.o [158/171] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/attest_hal.o [159/171] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/spm/cmsis_psa/psa_interface_cross.o [160/171] Linking C static library platform/libplatform_s.a [161/171] Linking C static library secure_fw/partitions/platform/libtfm_psa_rot_partition_platform.a [162/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto.o [163/171] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libcrypto_service_mbedcrypto.a [164/171] Linking C static library secure_fw/partitions/crypto/libtfm_psa_rot_partition_crypto.a [165/171] Linking C static library secure_fw/partitions/lib/sprt/libtfm_sprt.a [166/171] Linking C static library secure_fw/spm/libtfm_spm.a [167/171] Linking C executable bin/tfm_s.axf [168/171] Generating ../bin/tfm_s.hex [169/171] Generating ../bin/tfm_s.bin [170/171] Generating ../bin/tfm_s.elf [171/171] Linking C static library secure_fw/libtfm_s_veneers.a [71/278] Completed 'mcuboot_subimage' [73/278] Performing install step for 'tfm' -- Install configuration: "MinSizeRel" [74/278] Completed 'tfm' [75/278] Generating zephyr/tfm_secure.hex [76/278] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj [77/278] Generating include/generated/offsets.h [78/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj [79/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj [80/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj [81/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj [82/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj [83/278] Building C object CMakeFiles/app.dir/src/main.c.obj [84/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj [85/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj [86/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj [87/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj [88/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj [89/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj [90/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj [91/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj [92/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj [93/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj [94/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj [95/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj [96/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj [97/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj [98/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj [99/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj [100/278] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj [101/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj [102/278] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj [103/278] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj [104/278] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj [105/278] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_secure.c.obj [106/278] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj [107/278] Linking C static library app/libapp.a [108/278] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cache.c.obj [109/278] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj [110/278] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj [111/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj [112/278] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj [113/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj [114/278] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj [115/278] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj [116/278] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj [117/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj [118/278] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj [119/278] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj [120/278] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj [121/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj [122/278] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj [123/278] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj [124/278] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/backends/log_backend_uart.c.obj [125/278] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrf/lib/adp536x/adp536x.c.obj [126/278] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj [127/278] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj [128/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj [129/278] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj [130/278] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj [131/278] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj [132/278] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj [133/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj [134/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj [135/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj [136/278] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj [137/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj [138/278] Generating linker_zephyr_pre1.cmd [139/278] Linking C static library zephyr/arch/common/libisr_tables.a [140/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj [141/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj [142/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj [143/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj [144/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj [145/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj [146/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj [147/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj [148/278] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj [149/278] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj [150/278] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj [151/278] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj [152/278] Generating linker_zephyr_pre0.cmd [153/278] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a [154/278] Linking C static library zephyr/arch/common/libarch__common.a [155/278] Building C object zephyr/boards/boards/arm/thingy91_nrf9160_ns/CMakeFiles/..__nrf__boards__arm__thingy91_nrf9160.dir/adp5360_init.c.obj [156/278] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj [157/278] Building C object zephyr/boards/boards/arm/thingy91_nrf9160_ns/CMakeFiles/..__nrf__boards__arm__thingy91_nrf9160.dir/nrf52840_reset.c.obj [158/278] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj [159/278] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a [160/278] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj [161/278] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj [162/278] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a [163/278] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a [164/278] Linking C static library zephyr/lib/libc/newlib/liblib__libc__newlib.a [165/278] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a [166/278] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj [167/278] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj [168/278] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj [169/278] Building C object zephyr/drivers/sensor/adxl362/CMakeFiles/drivers__sensor__adxl362.dir/adxl362.c.obj [170/278] Linking C static library zephyr/boards/boards/arm/thingy91_nrf9160_ns/lib..__nrf__boards__arm__thingy91_nrf9160.a [171/278] Linking C static library zephyr/subsys/random/libsubsys__random.a [172/278] Building C object zephyr/drivers/sensor/adxl372/CMakeFiles/drivers__sensor__adxl372.dir/adxl372_spi.c.obj [173/278] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a [174/278] Linking C static library zephyr/drivers/console/libdrivers__console.a [175/278] Building C object zephyr/drivers/sensor/adxl372/CMakeFiles/drivers__sensor__adxl372.dir/adxl372.c.obj [176/278] Building C object zephyr/drivers/sensor/adxl372/CMakeFiles/drivers__sensor__adxl372.dir/adxl372_i2c.c.obj [177/278] Building C object zephyr/drivers/sensor/bme680/CMakeFiles/drivers__sensor__bme680.dir/bme680_i2c.c.obj [178/278] Building C object zephyr/drivers/sensor/bme680/CMakeFiles/drivers__sensor__bme680.dir/bme680_spi.c.obj [179/278] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a [180/278] Linking C static library zephyr/drivers/i2c/libdrivers__i2c.a [181/278] Linking C static library zephyr/drivers/sensor/adxl362/libdrivers__sensor__adxl362.a [182/278] Building C object zephyr/drivers/sensor/bme680/CMakeFiles/drivers__sensor__bme680.dir/bme680.c.obj [183/278] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj [184/278] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj [185/278] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/opt/nordic/ncs/v2.2.0/nrf/drivers/entropy/entropy_cc3xx.c.obj [186/278] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj [187/278] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj [188/278] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj [189/278] Linking C static library zephyr/drivers/sensor/adxl372/libdrivers__sensor__adxl372.a [190/278] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj [191/278] Linking C static library zephyr/drivers/sensor/bme680/libdrivers__sensor__bme680.a [192/278] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj [193/278] Linking C static library zephyr/drivers/spi/libdrivers__spi.a [194/278] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/fault.c.obj [195/278] Linking C static library zephyr/drivers/serial/libdrivers__serial.a [196/278] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a [197/278] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/src/zephyr_tfm_log.c.obj [198/278] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj [199/278] Building C object modules/nrf/modules/tfm/zephyr/CMakeFiles/tfm_api_nrf.dir/__/tfm/boards/src/tfm_ioctl_ns_api.c.obj [200/278] Building C object modules/nrf/lib/modem_antenna/CMakeFiles/..__nrf__lib__modem_antenna.dir/modem_antenna.c.obj [201/278] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a [202/278] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_platform_ipc_api.c.obj [203/278] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/interface/interface.c.obj [204/278] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_crypto_ipc_api.c.obj [205/278] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj [206/278] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_psa_ns_api.c.obj [207/278] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_ioctl_core_ns_api.c.obj [208/278] Building C object modules/cjson/CMakeFiles/cjson.dir/opt/nordic/ncs/v2.2.0/modules/lib/cjson/cJSON.c.obj [209/278] Building C object modules/cjson/CMakeFiles/cjson.dir/opt/nordic/ncs/v2.2.0/modules/lib/cjson/cJSON_Utils.c.obj [210/278] Linking C static library zephyr/drivers/timer/libdrivers__timer.a [211/278] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/sanity.c.obj [212/278] Building C object modules/cjson/CMakeFiles/cjson.dir/os/cJSON_os.c.obj [213/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj [214/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj [215/278] Linking C static library modules/nrf/modules/tfm/zephyr/libtfm_api_nrf.a [216/278] Linking C static library modules/nrf/lib/modem_antenna/lib..__nrf__lib__modem_antenna.a [217/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj [218/278] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a [219/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj [220/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj [221/278] Linking C static library modules/trusted-firmware-m/libtfm_api.a [222/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj [223/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj [224/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj [225/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj [226/278] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/platform.c.obj [227/278] Linking C static library modules/nrf/lib/nrf_modem_lib/lib..__nrf__lib__nrf_modem_lib.a [228/278] Linking C static library modules/cjson/libcjson.a [229/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj [230/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj [231/278] Linking C static library zephyr/libzephyr.a [232/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj [233/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj [234/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj [235/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj [236/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj [237/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj [238/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj [239/278] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/libmbedtls_zephyr.a [240/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj [241/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj [242/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj [243/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj [244/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj [245/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj [246/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj [247/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj [248/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj [249/278] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a [250/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj [251/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj [252/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj [253/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj [254/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj [255/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj [256/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj [257/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj [258/278] Linking C static library zephyr/kernel/libkernel.a [259/278] Linking C executable zephyr/zephyr_pre0.elf [260/278] Generating dev_handles.c [261/278] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj [262/278] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj [263/278] Linking C executable zephyr/zephyr_pre1.elf [264/278] Generating linker.cmd [265/278] Generating isr_tables.c, isrList.bin [266/278] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj [267/278] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj [268/278] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj [269/278] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 77724 B 380416 B 20.43% RAM: 26824 B 211736 B 12.67% IDT_LIST: 0 GB 2 KB 0.00% [270/278] Generating zephyr/tfm_nonsecure.hex [271/278] Generating zephyr/mcuboot_primary_app.hex [272/278] Generating zephyr/mcuboot_primary.hex [273/278] Generating ../../zephyr/app_update.bin sign the payload [274/278] Generating ../../zephyr/dfu_application.zip [275/278] Generating ../../zephyr/app_signed.hex sign the payload [276/278] Generating ../../zephyr/app_test_update.hex sign the payload [277/278] Generating ../../zephyr/app_moved_test_update.hex [278/278] Generating zephyr/merged.hex * Terminal will be reused by tasks, press any key to close it.
log 2.0.0
Building adxl372_fall_2.0.0 west build --build-dir /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1 /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0 --pristine --board thingy91_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/prj.conf" -DDTC_OVERLAY_FILE:STRING="/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/thingy91_nrf9160_ns.overlay" -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0 -- Found Python3: /opt/nordic/ncs/toolchains/v2.0.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/silvio/Library/Caches/zephyr -- Zephyr version: 3.0.99 (/opt/nordic/ncs/v2.0.0/zephyr) -- Found west (found suitable version "0.13.1", minimum required is "0.7.1") -- Board: thingy91_nrf9160_ns -- Found host-tools: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found dtc: /opt/nordic/ncs/toolchains/v2.0.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found toolchain: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found BOARD.dts: /opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns.dts -- Found devicetree overlay: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/thingy91_nrf9160_ns.overlay -- Generated zephyr.dts: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.0.0/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns_defconfig' Merged configuration '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/prj.conf' Configuration saved to '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/zephyr/.config' Kconfig header saved to '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 10.3.0 -- The CXX compiler identification is GNU 10.3.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc Changed board to secure thingy91_nrf9160 (NOT NS) === child image spm - begin === loading initial cache file /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/child_image_preload.cmake Loading Zephyr default modules (Zephyr base). -- Application: /opt/nordic/ncs/v2.0.0/nrf/samples/spm -- Found Python3: /opt/nordic/ncs/toolchains/v2.0.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/silvio/Library/Caches/zephyr -- Zephyr version: 3.0.99 (/opt/nordic/ncs/v2.0.0/zephyr) -- Found west (found suitable version "0.13.1", minimum required is "0.7.1") -- Board: thingy91_nrf9160 -- Found host-tools: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found dtc: /opt/nordic/ncs/toolchains/v2.0.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found toolchain: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found BOARD.dts: /opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160.dts -- Generated zephyr.dts: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.0.0/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/.config' No change to configuration in '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/.config' No change to Kconfig header in '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 10.3.0 -- The CXX compiler identification is GNU 10.3.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc CMake Warning at /opt/nordic/ncs/v2.0.0/zephyr/CMakeLists.txt:1803 (message): __ASSERT() statements are globally ENABLED -- Configuring done -- Generating done -- Build files have been written to: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm === child image spm - end === -- Found Python3: /opt/nordic/ncs/toolchains/v2.0.0/bin/python3.9 (found version "3.9.6") found components: Interpreter Changed board to secure thingy91_nrf9160 (NOT NS) === child image mcuboot - begin === loading initial cache file /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/child_image_preload.cmake Loading Zephyr default modules (Zephyr base). -- Application: /opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/zephyr -- Found Python3: /opt/nordic/ncs/toolchains/v2.0.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/silvio/Library/Caches/zephyr -- Zephyr version: 3.0.99 (/opt/nordic/ncs/v2.0.0/zephyr) -- Found west (found suitable version "0.13.1", minimum required is "0.7.1") -- Board: thingy91_nrf9160 -- Found host-tools: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found dtc: /opt/nordic/ncs/toolchains/v2.0.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found toolchain: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found BOARD.dts: /opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160.dts -- Found devicetree overlay: /opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/zephyr/dts.overlay -- Generated zephyr.dts: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/zephyr/dts.cmake ...... === child image spm - begin === loading initial cache file /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/child_image_preload.cmake Loading Zephyr default modules (Zephyr base). -- Application: /opt/nordic/ncs/v2.0.0/nrf/samples/spm -- Found Python3: /opt/nordic/ncs/toolchains/v2.0.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/silvio/Library/Caches/zephyr -- Zephyr version: 3.0.99 (/opt/nordic/ncs/v2.0.0/zephyr) -- Found west (found suitable version "0.13.1", minimum required is "0.7.1") -- Board: thingy91_nrf9160 -- Found host-tools: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found dtc: /opt/nordic/ncs/toolchains/v2.0.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found toolchain: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found BOARD.dts: /opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160.dts -- Generated zephyr.dts: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.0.0/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_defconfig' Merged configuration '/opt/nordic/ncs/v2.0.0/nrf/samples/spm/prj.conf' Merged configuration '/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/partition_manager_enabled.conf' Merged configuration '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/.config' Kconfig header saved to '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 10.3.0 -- The CXX compiler identification is GNU 10.3.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc CMake Warning at /opt/nordic/ncs/v2.0.0/zephyr/CMakeLists.txt:1803 (message): __ASSERT() statements are globally ENABLED -- Configuring done -- Generating done -- Build files have been written to: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/spm === child image spm - end === -- Found Python3: /opt/nordic/ncs/toolchains/v2.0.0/bin/python3.9 (found version "3.9.6") found components: Interpreter Changed board to secure thingy91_nrf9160 (NOT NS) === child image mcuboot - begin === loading initial cache file /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/child_image_preload.cmake -- Application: /opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/zephyr Loading Zephyr default modules (Zephyr base). -- Found Python3: /opt/nordic/ncs/toolchains/v2.0.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/silvio/Library/Caches/zephyr -- Zephyr version: 3.0.99 (/opt/nordic/ncs/v2.0.0/zephyr) -- Found west (found suitable version "0.13.1", minimum required is "0.7.1") -- Board: thingy91_nrf9160 -- Found host-tools: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found dtc: /opt/nordic/ncs/toolchains/v2.0.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found toolchain: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found BOARD.dts: /opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160.dts -- Found devicetree overlay: /opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/zephyr/dts.overlay -- Generated zephyr.dts: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_defconfig' Merged configuration '/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/zephyr/prj.conf' Merged configuration '/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/zephyr/boards/thingy91_nrf9160.conf' Merged configuration '/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/partition_manager_enabled.conf' Merged configuration '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/zephyr/.config' Kconfig header saved to '/opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 10.3.0 -- The CXX compiler identification is GNU 10.3.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc MCUBoot bootloader key file: /opt/nordic/ncs/v2.0.0/bootloader/mcuboot/root-rsa-2048.pem -- Configuring done -- Generating done -- Build files have been written to: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1/mcuboot === child image mcuboot - end === CMake Warning at /opt/nordic/ncs/v2.0.0/nrf/modules/mcuboot/CMakeLists.txt:281 (message): --------------------------------------------------------- --- WARNING: Using default MCUBoot key, it should not --- --- be used for production. --- --------------------------------------------------------- -- Found partition manager static configuration: /opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/thingy91_pm_static_spm.yml Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined. Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined. Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined. Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined. Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined. Partition 'spm' is not included in the dynamic resolving since it is statically defined. Dropping partition 'nrf_modem_lib_trace' since its size is 0. -- Configuring done -- Generating done -- Build files have been written to: /opt/nordic/ncs/test_2.2.0/adxl372_fall_2.0.0/build_1 -- west build: building application [1/213] Preparing syscall dependency handling [2/213] Generating include/generated/version.h -- Zephyr version: 3.0.99 (/opt/nordic/ncs/v2.0.0/zephyr), build: v3.0.99-ncs1 [3/213] Creating directories for 'mcuboot_subimage' [4/213] Creating directories for 'spm_subimage' [5/213] No download step for 'spm_subimage' [6/213] No download step for 'mcuboot_subimage' [7/213] No update step for 'mcuboot_subimage' [8/213] No update step for 'spm_subimage' [9/213] Generating misc/generated/syscalls_subdirs.trigger [10/213] No patch step for 'mcuboot_subimage' [11/213] No patch step for 'spm_subimage' [12/213] No configure step for 'mcuboot_subimage' [12/213] Performing build step for 'mcuboot_subimage' [1/279] Preparing syscall dependency handling [2/279] Generating include/generated/version.h -- Zephyr version: 3.0.99 (/opt/nordic/ncs/v2.0.0/zephyr), build: v3.0.99-ncs1 [3/279] Generating misc/generated/syscalls_subdirs.trigger [4/279] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json [5/279] Generating include/generated/driver-validation.h [6/279] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h [7/279] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h [8/279] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj [9/279] Generating include/generated/offsets.h [10/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/base64.c.obj [11/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj [12/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj [13/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj [14/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj [15/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj [16/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj [17/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj [18/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj [19/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj [20/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj [21/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj [22/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj [23/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj [24/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj [25/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj [26/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj [27/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj [28/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj [29/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj [30/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj [31/279] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj [32/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj [33/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj [34/279] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj [35/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj [36/279] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj [37/279] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj [38/279] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj [39/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/nrf52840_reset.c.obj [40/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj [41/279] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj [42/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/lib/adp536x/adp536x.c.obj [43/279] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj [44/279] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj [45/279] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj [46/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj [47/279] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj [48/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj [49/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj [50/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/boot_serial/src/cbor_decode.c.obj [51/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/boot_serial/src/serial_recovery_cbor.c.obj [52/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/boot_serial/src/cbor_encode.c.obj [53/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/boot_serial/src/cbor_common.c.obj [54/279] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj [55/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj [56/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj [57/279] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj [58/279] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj [59/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj [60/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj [61/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj [62/279] Generating linker_zephyr_pre1.cmd [63/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj [64/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj [65/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj [66/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj [67/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj [68/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj [69/279] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj [70/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj [71/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj [72/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj [73/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj [74/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj [75/279] Linking C static library zephyr/arch/common/libisr_tables.a [76/279] Linking C static library zephyr/libzephyr.a [77/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj [78/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj [79/279] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj [80/279] Generating linker_zephyr_pre0.cmd [81/279] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj [82/279] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj [83/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj [84/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj [85/279] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a [86/279] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj [87/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj [88/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj [89/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj [90/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj [91/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj [92/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj [93/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj [94/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj [95/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj [96/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj [97/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj [98/279] Linking C static library zephyr/arch/common/libarch__common.a [99/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj [100/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj [101/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj [102/279] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a [103/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj [104/279] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj [105/279] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a [106/279] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a [107/279] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj [108/279] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj [109/279] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj [110/279] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj [111/279] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj [112/279] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj [113/279] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj [114/279] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj [115/279] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj [116/279] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj [117/279] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a [118/279] Linking C static library zephyr/lib/posix/liblib__posix.a [119/279] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a [120/279] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a [121/279] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a [122/279] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj [123/279] Linking C static library zephyr/drivers/flash/libdrivers__flash.a [124/279] Linking C static library zephyr/drivers/serial/libdrivers__serial.a [125/279] Linking C static library zephyr/drivers/timer/libdrivers__timer.a [126/279] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj [127/279] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj [128/279] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj [129/279] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj [130/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/zephyr_init.c.obj [131/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/aes.c.obj [132/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/aesni.c.obj [133/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/aria.c.obj [134/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/asn1parse.c.obj [135/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/asn1write.c.obj [136/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/base64.c.obj [137/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/camellia.c.obj [138/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/bignum.c.obj [139/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ccm.c.obj [140/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/chacha20.c.obj [141/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/chachapoly.c.obj [142/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/cipher.c.obj [143/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/cipher_wrap.c.obj [144/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/cmac.c.obj [145/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ctr_drbg.c.obj [146/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/debug.c.obj [147/279] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a [148/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/des.c.obj [149/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/dhm.c.obj [150/279] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a [151/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ecdh.c.obj [152/279] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a [153/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ecdsa.c.obj [154/279] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a [155/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ecjpake.c.obj [156/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ecp.c.obj [157/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ecp_curves.c.obj [158/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/entropy.c.obj [159/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/entropy_poll.c.obj [160/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/error.c.obj [161/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/gcm.c.obj [162/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/hkdf.c.obj [163/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/hmac_drbg.c.obj [164/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/md5.c.obj [165/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/md.c.obj [166/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/mps_reader.c.obj [167/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/mps_trace.c.obj [168/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj [169/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/net_sockets.c.obj [170/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/nist_kw.c.obj [171/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/oid.c.obj [172/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/padlock.c.obj [173/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pem.c.obj [174/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pk.c.obj [175/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pk_wrap.c.obj [176/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pkcs12.c.obj [177/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pkcs5.c.obj [178/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pkparse.c.obj [179/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/pkwrite.c.obj [180/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/platform.c.obj [181/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/platform_util.c.obj [182/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/poly1305.c.obj [183/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_aead.c.obj [184/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto.c.obj [185/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_cipher.c.obj [186/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_client.c.obj [187/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_driver_wrappers.c.obj [188/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_ecp.c.obj [189/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_hash.c.obj [190/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_mac.c.obj [191/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_rsa.c.obj [192/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_se.c.obj [193/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_slot_management.c.obj [194/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_crypto_storage.c.obj [195/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/psa_its_file.c.obj [196/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ripemd160.c.obj [197/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj [198/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/sha1.c.obj [199/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/sha512.c.obj [200/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_cache.c.obj [201/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj [202/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_cli.c.obj [203/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_cookie.c.obj [204/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_msg.c.obj [205/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_srv.c.obj [206/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_ticket.c.obj [207/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_tls.c.obj [208/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/sha256.c.obj [209/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj [210/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/threading.c.obj [211/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/rsa.c.obj [212/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/timing.c.obj [213/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/version.c.obj [214/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/version_features.c.obj [215/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509.c.obj [216/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509_create.c.obj [217/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509_crl.c.obj [218/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509_crt.c.obj [219/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509_csr.c.obj [220/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509write_crt.c.obj [221/279] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.0.0/modules/crypto/mbedtls/library/x509write_csr.c.obj [222/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj [223/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj [224/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj [225/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj [226/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj [227/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj [228/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj [229/279] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj [230/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj [231/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj [232/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj [233/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj [234/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj [235/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj [236/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj [237/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj [238/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj [239/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj [240/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj [241/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj [242/279] Linking C static library modules/mbedtls/libmodules__mbedtls.a [243/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj [244/279] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj [245/279] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a [246/279] Linking C static library zephyr/kernel/libkernel.a [247/279] Generating zephyr/autogen-pubkey.c [248/279] Building C object CMakeFiles/app.dir/keys.c.obj [249/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj [250/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj [251/279] Building C object CMakeFiles/app.dir/main.c.obj [252/279] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj [253/279] Building C object CMakeFiles/app.dir/os.c.obj [254/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj [255/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj [256/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj [257/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj [258/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj [259/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj [260/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj [261/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj [262/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj [263/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj [264/279] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj [265/279] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.0.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj [266/279] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj [267/279] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj [268/279] Linking C static library app/libapp.a [269/279] Linking C executable zephyr/zephyr_pre0.elf [270/279] Generating dev_handles.c [271/279] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj [272/279] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj [273/279] Linking C executable zephyr/zephyr_pre1.elf [274/279] Generating linker.cmd [275/279] Generating isr_tables.c, isrList.bin [276/279] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj [277/279] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj [278/279] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj [279/279] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 40864 B 48 KB 83.14% SRAM: 26992 B 211736 B 12.75% IDT_LIST: 0 GB 2 KB 0.00% [17/213] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h [18/213] Performing build step for 'spm_subimage' [1/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_storage.c.obj [2/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pkcs12.c.obj [3/268] Preparing syscall dependency handling [4/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pkwrite.c.obj [5/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/dhm.c.obj [6/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pem.c.obj [7/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_slot_management.c.obj [8/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/psa_crypto_driver_wrappers.c.obj [9/268] Generating include/generated/version.h -- Zephyr version: 3.0.99 (/opt/nordic/ncs/v2.0.0/zephyr), build: v3.0.99-ncs1 [10/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pkparse.c.obj [11/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pkcs5.c.obj [12/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/cipher.c.obj [13/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/cipher_wrap.c.obj [14/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/random_ext.c.obj [15/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/md.c.obj [16/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pk.c.obj [17/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/pk_wrap.c.obj [18/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/sha1.c.obj [19/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/sha256.c.obj [20/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/sha512.c.obj [21/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ripemd160.c.obj [22/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/aria.c.obj [23/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/md5.c.obj [24/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/aesni.c.obj [25/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/camellia.c.obj [26/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/des.c.obj [27/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/cmac.c.obj [28/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ccm.c.obj [29/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj [30/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509_create.c.obj [31/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509write_csr.c.obj [32/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/asn1parse.c.obj [33/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/asn1write.c.obj [34/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/base64.c.obj [35/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/nist_kw.c.obj [36/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509.c.obj [37/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509_crl.c.obj [38/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509_csr.c.obj [39/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/x509_crt.c.obj [40/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/bignum.c.obj [41/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/oid.c.obj [42/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/padlock.c.obj [43/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/platform.c.obj [44/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/platform_util.c.obj [45/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/version.c.obj [46/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/debug.c.obj [47/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/net_sockets.c.obj [48/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_cache.c.obj [49/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_ciphersuites.c.obj [50/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_cli.c.obj [51/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_cookie.c.obj [52/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_msg.c.obj [53/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_srv.c.obj [54/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_ticket.c.obj [55/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_tls.c.obj [56/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ssl_tls13_keys.c.obj [57/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_aead.c.obj [58/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto.c.obj [59/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_cipher.c.obj [60/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_client.c.obj [61/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_ecp.c.obj [62/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_hash.c.obj [63/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_mac.c.obj [64/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/psa_crypto_rsa.c.obj [65/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/chachapoly.c.obj [66/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ecdh.c.obj [67/268] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto_base.a [68/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ecdsa.c.obj [69/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ecp.c.obj [70/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ecp_curves.c.obj [71/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/gcm.c.obj [72/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/hkdf.c.obj [73/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/hmac_drbg.c.obj [74/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/rsa.c.obj [75/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/rsa_alt_helpers.c.obj [76/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/chacha20.c.obj [77/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/poly1305.c.obj [78/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.0.0/mbedtls/library/ecjpake.c.obj [79/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj [80/268] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj [81/268] Generating misc/generated/syscalls_subdirs.trigger [82/268] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a [83/268] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedx509.a [84/268] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedtls.a [85/268] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json [86/268] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h [87/268] Generating include/generated/driver-validation.h [88/268] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h [89/268] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj [90/268] Generating include/generated/offsets.h [91/268] Building C object CMakeFiles/app.dir/src/main.c.obj [92/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj [93/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj [94/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj [95/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj [96/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj [97/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj [98/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj [99/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj [100/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj [101/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj [102/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj [103/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj [104/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj [105/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj [106/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj [107/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj [108/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj [109/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj [110/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj [111/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj [112/268] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj [113/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj [114/268] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj [115/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj [116/268] Linking C static library app/libapp.a [117/268] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj [118/268] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj [119/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj [120/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj [121/268] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj [122/268] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj [123/268] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj [124/268] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj [125/268] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj [126/268] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj [127/268] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj [128/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/lib/adp536x/adp536x.c.obj [129/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/spm/secure_services.c.obj [130/268] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj [131/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj [132/268] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj [133/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/spm/spm.c.obj [134/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj [135/268] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj [136/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj [137/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj [138/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj [139/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj [140/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj [141/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj [142/268] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj [143/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj [144/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj [145/268] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj [146/268] Linking C static library zephyr/arch/common/libisr_tables.a [147/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj [148/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj [149/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj [150/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj [151/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj [152/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj [153/268] Linking C static library zephyr/libzephyr.a [154/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj [155/268] Generating linker_zephyr_pre0.cmd [156/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj [157/268] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj [158/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj [159/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj [160/268] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj [161/268] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj [162/268] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj [163/268] Linking C static library zephyr/arch/common/libarch__common.a [164/268] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a [165/268] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj [166/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj [167/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj [168/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj [169/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj [170/268] Generating linker_zephyr_pre1.cmd [171/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj [172/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj [173/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj [174/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj [175/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj [176/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj [177/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj [178/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj [179/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj [180/268] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a [181/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj [182/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj [183/268] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a [184/268] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/libarch__arm__core__aarch32__cortex_m__tz.a [185/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj [186/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj [187/268] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj [188/268] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a [189/268] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj [190/268] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj [191/268] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj [192/268] Building C object zephyr/boards/boards/arm/thingy91_nrf9160/CMakeFiles/..__nrf__boards__arm__thingy91_nrf9160.dir/adp5360_init.c.obj [193/268] Building C object zephyr/boards/boards/arm/thingy91_nrf9160/CMakeFiles/..__nrf__boards__arm__thingy91_nrf9160.dir/nrf52840_reset.c.obj [194/268] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj [195/268] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj [196/268] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj [197/268] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a [198/268] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj [199/268] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj [200/268] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj [201/268] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a [202/268] Linking C static library zephyr/lib/posix/liblib__posix.a [203/268] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/opt/nordic/ncs/v2.0.0/nrf/drivers/entropy/entropy_cc3xx.c.obj [204/268] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj [205/268] Linking C static library zephyr/boards/boards/arm/thingy91_nrf9160/lib..__nrf__boards__arm__thingy91_nrf9160.a [206/268] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/cortex_m_systick.c.obj [207/268] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj [208/268] Linking C static library zephyr/subsys/random/libsubsys__random.a [209/268] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a [210/268] Linking C static library zephyr/drivers/console/libdrivers__console.a [211/268] Linking C static library zephyr/drivers/i2c/libdrivers__i2c.a [212/268] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj [213/268] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj [214/268] Linking C static library zephyr/drivers/serial/libdrivers__serial.a [215/268] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj [216/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj [217/268] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a [218/268] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj [219/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj [220/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj [221/268] Linking C static library zephyr/drivers/timer/libdrivers__timer.a [222/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj [223/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj [224/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj [225/268] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a [226/268] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a [227/268] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj [228/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj [229/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj [230/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj [231/268] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a [232/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj [233/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj [234/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj [235/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj [236/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj [237/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj [238/268] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a [239/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj [240/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj [241/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj [242/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj [243/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj [244/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj [245/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj [246/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj [247/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj [248/268] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a [249/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj [250/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj [251/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj [252/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj [253/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj [254/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj [255/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj [256/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj [257/268] Linking C static library zephyr/kernel/libkernel.a [258/268] Linking C executable zephyr/zephyr_pre0.elf [259/268] Generating dev_handles.c [260/268] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj [261/268] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj [262/268] Linking C executable zephyr/zephyr_pre1.elf [263/268] Generating linker.cmd [264/268] Generating isr_tables.c, isrList.bin [265/268] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj [266/268] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj [267/268] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj [268/268] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 48640 B 48 KB 98.96% SRAM: 11968 B 32 KB 36.52% IDT_LIST: 0 GB 2 KB 0.00% [20/213] Completed 'mcuboot_subimage' [22/213] No install step for 'spm_subimage' [23/213] Completed 'spm_subimage' [24/213] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj [25/213] Generating include/generated/offsets.h [26/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj [27/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj [28/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj [29/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj [30/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj [31/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj [32/213] Building C object CMakeFiles/app.dir/src/main.c.obj [33/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj [34/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj [35/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj [36/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj [37/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj [38/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj [39/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj [40/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj [41/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj [42/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj [43/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj [44/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj [45/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj [46/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj [47/213] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj [48/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj [49/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj [50/213] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj [51/213] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj [52/213] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj [53/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_list.c.obj [54/213] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj [55/213] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj [56/213] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/boards/arm/thingy91_nrf9160/nrf52840_reset.c.obj [57/213] Linking C static library app/libapp.a [58/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj [59/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj [60/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj [61/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg2.c.obj [62/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_backend_uart.c.obj [63/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj [64/213] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj [65/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj [66/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj [67/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj [68/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj [69/213] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj [70/213] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/lib/adp536x/adp536x.c.obj [71/213] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/nonsecure/secure_services_ns.c.obj [72/213] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj [73/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj [74/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj [75/213] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj [76/213] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/nonsecure/soc_secure.c.obj [77/213] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj [78/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj [79/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj [80/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj [81/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj [82/213] Generating linker_zephyr_pre0.cmd [83/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj [84/213] Generating linker_zephyr_pre1.cmd [85/213] Linking C static library zephyr/arch/common/libisr_tables.a [86/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj [87/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj [88/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj [89/213] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj [90/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj [91/213] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj [92/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj [93/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj [94/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj [95/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj [96/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj [97/213] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj [98/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj [99/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj [100/213] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj [101/213] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj [102/213] Linking C static library zephyr/libzephyr.a [103/213] Linking C static library zephyr/arch/common/libarch__common.a [104/213] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj [105/213] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj [106/213] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj [107/213] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj [108/213] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a [109/213] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj [110/213] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj [111/213] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj [112/213] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a [113/213] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a [114/213] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj [115/213] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj [116/213] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a [117/213] Linking C static library zephyr/lib/libc/newlib/liblib__libc__newlib.a [118/213] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj [119/213] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj [120/213] Linking C static library zephyr/lib/posix/liblib__posix.a [121/213] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a [122/213] Linking C static library zephyr/subsys/random/libsubsys__random.a [123/213] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a [124/213] Linking C static library zephyr/drivers/console/libdrivers__console.a [125/213] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a [126/213] Building C object zephyr/drivers/sensor/adxl372/CMakeFiles/drivers__sensor__adxl372.dir/adxl372.c.obj [127/213] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj [128/213] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj [129/213] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/opt/nordic/ncs/v2.0.0/nrf/drivers/entropy/entropy_cc3xx.c.obj [130/213] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj [131/213] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj [132/213] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj [133/213] Linking C static library zephyr/drivers/i2c/libdrivers__i2c.a [134/213] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj [135/213] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj [136/213] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj [137/213] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/errno_sanity.c.obj [138/213] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/shmem_sanity.c.obj [139/213] Linking C static library zephyr/drivers/sensor/adxl372/libdrivers__sensor__adxl372.a [140/213] Linking C static library zephyr/drivers/spi/libdrivers__spi.a [141/213] Linking C static library zephyr/drivers/serial/libdrivers__serial.a [142/213] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj [143/213] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a [144/213] Building C object modules/nrf/lib/modem_antenna/CMakeFiles/..__nrf__lib__modem_antenna.dir/modem_antenna.c.obj [145/213] Linking C static library zephyr/drivers/timer/libdrivers__timer.a [146/213] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj [147/213] Building C object modules/cjson/CMakeFiles/cjson.dir/opt/nordic/ncs/v2.0.0/modules/lib/cjson/cJSON.c.obj [148/213] Building C object modules/cjson/CMakeFiles/cjson.dir/opt/nordic/ncs/v2.0.0/modules/lib/cjson/cJSON_Utils.c.obj [149/213] Building C object modules/cjson/CMakeFiles/cjson.dir/os/cJSON_os.c.obj [150/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj [151/213] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a [152/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj [153/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj [154/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj [155/213] Linking C static library modules/nrf/lib/nrf_modem_lib/lib..__nrf__lib__nrf_modem_lib.a [156/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj [157/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj [158/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj [159/213] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a [160/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj [161/213] Linking C static library modules/nrf/lib/modem_antenna/lib..__nrf__lib__modem_antenna.a [162/213] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a [163/213] Linking C static library modules/cjson/libcjson.a [164/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj [165/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj [166/213] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj [167/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj [168/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj [169/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj [170/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj [171/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj [172/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj [173/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj [174/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj [175/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj [176/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj [177/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj [178/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj [179/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj [180/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj [181/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj [182/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj [183/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj [184/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj [185/213] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a [186/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj [187/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj [188/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj [189/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj [190/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj [191/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj [192/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj [193/213] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj [194/213] Linking C static library zephyr/kernel/libkernel.a [195/213] Linking C executable zephyr/zephyr_pre0.elf [196/213] Generating dev_handles.c [197/213] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj [198/213] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj [199/213] Linking C executable zephyr/zephyr_pre1.elf [200/213] Generating linker.cmd [201/213] Generating isr_tables.c, isrList.bin [202/213] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj [203/213] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj [204/213] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj [205/213] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 74204 B 380416 B 19.51% SRAM: 26872 B 211736 B 12.69% IDT_LIST: 0 GB 2 KB 0.00% [206/213] Generating zephyr/mcuboot_primary.hex [207/213] Generating zephyr/mcuboot_primary_app.hex [208/213] Generating ../../zephyr/app_update.bin [209/213] Generating ../../zephyr/dfu_application.zip [210/213] Generating ../../zephyr/app_signed.hex [211/213] Generating ../../zephyr/app_test_update.hex [212/213] Generating ../../zephyr/app_moved_test_update.hex [213/213] Generating zephyr/merged.hex * Terminal will be reused by tasks, press any key to close it.
result on 2.0.0
on 2.2.0
nothing appears when I exceed the threshold
With ncs v2.0.0, you see this:
*** Booting Zephyr OS build v3.0.99-ncs1 *** fall thread : intialized successfully mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 7.07, x: 1, y: 0, z: =7 [FAL]: 7.07 g: ######## mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 25.63, x: 13, y: -2, z: =22 [FAL]: 25.63 g: ########################## mag: 0.00, x: 0, y: 0, z: =0 mag: 66.27, x: 10, y: 4, z: =65 [FAL]: 66.27 g: ###################################################################
NCS v2.2.0 this is the output:
*** Booting Zephyr OS build v3.2.99-ncs2 *** fall thread : intialized successfully mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0 mag: 0.00, x: 0, y: 0, z: =0
This is because the default settings on the sensor isn't set, ie. does not match the settings from ncs v2.0.0, in the overlay.
Here's an example of setting it up as you did in ncs v2.0.0.
adxl372FALL/boards/thingy91_nrf9160_ns.overlay containing this:
&spi3 { adxl372: adxl372@1 { odr = <4>; /* 6400 Hz */ hpf = <0>; /* ODR/210 */ bw = <4>; /* 3200 Hz */ }; };
with the above overlay present, it will then use similar settings as previously, and detect fall in the same way:
*** Booting Zephyr OS build v3.2.99-ncs2 *** fall thread : intialized successfully mag: 12.08, x: 1, y: 1, z: =12 [FAL]: 12.08 g: #############
Could you try this?
Håkon
