nRF5340 clock sources
Hello !
It is not so clear default clock sources on nRF5340 app and net cores.
1.
As zephyr clock sources, SYSTICK timers are in use in both cores and timer clocking from external 32kHz XTAL oscillator.
Is this so ?
Should I specify  CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y in prj.conf this line and for what core ?
2. RTCx timers is not used by default.
if I need to use those ( RTC0 on app core, RTC1 on net core), I should specify CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y on both core's configuration ?
3. App core CPU clock is 128Mhz by default.
How to be sure if it clocked from XTAL oscillator ?
How to change clock to 64Mhz ?
4. Net core CPU clock is 64 Mhz by default.
How I be sure if it clocked from crystal oscillator ?
I can see clock_init() what use
clk_mgr = z_nrf_clock_control_get_onoff(CLOCK_CONTROL_NRF_SUBSYS_HF);
Should I use this code for app core as well or only on net core ?
On net core I use NRF_TIMER2 and RADIO and they need to be clocked form HF XTAL.
Eugene
