nRF5340 clock sources
Hello !
It is not so clear default clock sources on nRF5340 app and net cores.
1.
As zephyr clock sources, SYSTICK timers are in use in both cores and timer clocking from external 32kHz XTAL oscillator.
Is this so ?
Should I specify  CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y in prj.conf this line and for what core ?
2. RTCx timers is not used by default.
if I need to use those ( RTC0 on app core, RTC1 on net core), I should specify CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y on both core's configuration ?
3. App core CPU clock is 128Mhz by default.
How to be sure if it clocked from XTAL oscillator ?
How to change clock to 64Mhz ?
4. Net core CPU clock is 64 Mhz by default.
How I be sure if it clocked from crystal oscillator ?
I can see clock_init() what use
clk_mgr = z_nrf_clock_control_get_onoff(CLOCK_CONTROL_NRF_SUBSYS_HF);
Should I use this code for app core as well or only on net core ?
On net core I use NRF_TIMER2 and RADIO and they need to be clocked form HF XTAL.
Eugene
  • Hi Eugene
    Do you remember to allocate and enable the DPPI channels that you are using?
    You should allocate them first (like shown here), then configure the publish and subscribe registers, before ensuring to enable the channels you need (like shown here).
    Best regards
    Torbjørn
  • Hi Torbjørn !
    Yes,
    I allocate and specify publish/subscribe pairs.
    After that after each disable period
    nrf_radio_task_trigger(NRF_RADIO, NRF_RADIO_TASK_DISABLE);
    I have enabled  required channels, enable RX or TX task.
    and  disable all channels after RX/TX transaction or timeout.
    So I can just enable/disable channels and clearing source of event if need.
    No need to refresh publish/subscribe pairs and clean/enable something else ?
    Looks like in my scheme only timer can cause problems if event is not generated.
    Eugene
  • Hi Eugene
    Once configured a PPI or DPPI channel will just operate in the background without needing any upkeep, refresh etc.
    Even if the event register is not cleared, or you don't have interrupts enabled for certain events, they will still be available through the DPPI and trigger tasks whenever they occur.
    If the channels don't appear to work it's typically caused by a configuration issue, by forgetting to enable the channels, or that the receiving peripheral gets the task at the wrong time (when it is not in a state to process that task for instance).
    Is it intentional that you have two different events connected to the same capture register (CAPTURE1), and that you use the same compare register to trigger both TXEN and RXEN (COMPARE2) ?
    Best regards
    Torbjørn
  • Hi Torbjørn !
    Yes TX and RX is not enabled at the same time.
    I can see difference between nRF52 and nRF53 only in case that  DPPI channel need to be allocated from pool once and used after that.
    Channels should be usable all the time.
    TX/RX need to be enabled/disabled only when mode change from TX to RX and vise versa.
    Channels publish and subscribe can be reconfigured with the same values multiple times.
    If channel enabled, it should conduct event from source to target . (  Timer's event ISR can be enabled or not )
    All DPPI operations can be done in ISR context.
    If radio disabled for a while, no need to refresh public/subscribe pairs.
    When radio disabled, all DPPI channels are also disabled.
    But something else exist what do DPPI not working as expected.
    I need to write more simple radio for be sure if all pairs works as expected.
    Eugene
  • Hi Torbjørn !
    I found difference.
    It is not possible to specify beforehand pairs where the same subscribe is used ( even channel is different)
    Internally it make last subscribe active only. Even channels are disabled and freed every TX loop.
    nrf_radio_publish_set(NRF_RADIO, NRF_RADIO_EVENT_READY, ppi_radio_events_ready);
    nrf_timer_subscribe_set(NRF_TIMERX, NRF_TIMER_TASK_CAPTURE1, ppi_radio_events_ready);
    nrf_radio_publish_set(NRF_RADIO, NRF_RADIO_EVENT_ADDRESS, ppi_radio_events_address);
    nrf_timer_subscribe_set(NRF_TIMERX, NRF_TIMER_TASK_CAPTURE1, ppi_radio_events_address);
    nrf_radio_publish_set(NRF_RADIO, NRF_RADIO_EVENT_END, ppi_radio_events_end);
    nrf_timer_subscribe_set(NRF_TIMERX, NRF_TIMER_TASK_CAPTURE1, ppi_radio_events_end);
     I need to to do sequentially if would like to collect all events
    enable
    Get interrupt for READY
    enable
    Get interrupt for ADDRESS
    enable
    Get interrupt for END
    In this way it works.
    Have it sense for DPPI ?
    Eugene
