nRF5340 clock sources
Hello !
It is not so clear default clock sources on nRF5340 app and net cores.
1.
As zephyr clock sources, SYSTICK timers are in use in both cores and timer clocking from external 32kHz XTAL oscillator.
Is this so ?
Should I specify  CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y in prj.conf this line and for what core ?
2. RTCx timers is not used by default.
if I need to use those ( RTC0 on app core, RTC1 on net core), I should specify CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y on both core's configuration ?
3. App core CPU clock is 128Mhz by default.
How to be sure if it clocked from XTAL oscillator ?
How to change clock to 64Mhz ?
4. Net core CPU clock is 64 Mhz by default.
How I be sure if it clocked from crystal oscillator ?
I can see clock_init() what use
clk_mgr = z_nrf_clock_control_get_onoff(CLOCK_CONTROL_NRF_SUBSYS_HF);
Should I use this code for app core as well or only on net core ?
On net core I use NRF_TIMER2 and RADIO and they need to be clocked form HF XTAL.
Eugene
  • Hi Eugene
    Sounds good. If you have any more questions or comments just let me know.
    Best regards
    Torbjørn
  • Hi Torbjorn !
    Does gpiote task is also can't be added in 2 places ?
    I create GPIOTE task for toggle GPIO pin and would like to measure TX frame duration between READY and END events.
    nrfx_gppi_fork_endpoint_setup(ppi_radio_event_ready, nrfx_gpiote_out_task_addr_get(DBG_PIN5));
    nrfx_gppi_fork_endpoint_setup(ppi_radio_event_end, nrfx_gpiote_out_task_addr_get(DBG_PIN5));
    nrfx_gpiote_out_task_enable(DBG_PIN5);
    Should it work or not ?
    Eugene
  • Hi Eugene
    It should be possible to associate two different events with the same GPIOTE OUT task, yes.
    Are you not able to get it to work?
    If so, could you try using the nrfx_gppi_task_endpoint_setup(..) function instead and see if it works better?
    Best regards
    Torbjørn
  • Hi Torbjorn !
    It dosn't work for me.
    But looks like SET and CLR tasks are created automatically and I can use OUT or SET with READY_EVENT and CLR with END event.
    Can it be counted as right solution as well OR better try to use OUT task twice ?
    and nrfx_gppi_task_endpoint_setup(..) ?
    I use like this now.
    nrf_radio_publish_set(NRF_RADIO, NRF_RADIO_EVENT_READY, ppi_radio_event_ready);
    nrf_timer_subscribe_set(NRF_TIMERX, NRF_TIMER_TASK_CAPTURE1, ppi_radio_event_ready);
    uint32_t channels_mask = BIT(ppi_radio_event_ready);
    and attach different GPIO lines ( RX and TX activity ) after that as usually :
    if (is_tx) {
    nrfx_gppi_fork_endpoint_clear(ppi_radio_event_ready, nrfx_gpiote_set_task_addr_get(DBG_PIN6));
    nrfx_gppi_fork_endpoint_setup(ppi_radio_event_ready, nrfx_gpiote_set_task_addr_get(DBG_PIN5));
    } else {
    nrfx_gppi_fork_endpoint_clear(ppi_radio_event_ready, nrfx_gpiote_set_task_addr_get(DBG_PIN5));
    nrfx_gppi_fork_endpoint_setup(ppi_radio_event_ready, nrfx_gpiote_set_task_addr_get(DBG_PIN6));
    nrfx_gpiote_out_task_enable(DBG_PIN6);
    I will also try to use RXREADY and TXREADY events instead of READY,( I have radio shortcut READY)
    Eugene
  • Hi Eugene
    Yes, in the nRF52 series and later there are dedicated SET and CLR tasks for a GPIOTE OUT channel, allowing you to easily connect different events that will either clear or set the output pin.
    The OUT event is really only useful if you want to be able to toggle a pin, rather than set or clear it.
    Your code should be updated with another ppi channel that you can use to clear the pin when the END event occurs in the radio.
    Best regards
    Torbjørn
