nRF5340 clock sources
Hello !
It is not so clear default clock sources on nRF5340 app and net cores.
1.
As zephyr clock sources, SYSTICK timers are in use in both cores and timer clocking from external 32kHz XTAL oscillator.
Is this so ?
Should I specify  CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y in prj.conf this line and for what core ?
2. RTCx timers is not used by default.
if I need to use those ( RTC0 on app core, RTC1 on net core), I should specify CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y on both core's configuration ?
3. App core CPU clock is 128Mhz by default.
How to be sure if it clocked from XTAL oscillator ?
How to change clock to 64Mhz ?
4. Net core CPU clock is 64 Mhz by default.
How I be sure if it clocked from crystal oscillator ?
I can see clock_init() what use
clk_mgr = z_nrf_clock_control_get_onoff(CLOCK_CONTROL_NRF_SUBSYS_HF);
Should I use this code for app core as well or only on net core ?
On net core I use NRF_TIMER2 and RADIO and they need to be clocked form HF XTAL.
Eugene
  • Hi Torbjorn !
    I think for avoid collisions , have sense to use different radio events for profile radio and dedicated  dppi channels
    e,g RX/TX ready and PHYEND.
    if shorts:
    nrf_radio_shorts_set(NRF_RADIO,
    (NRF_RADIO_SHORT_READY_START_MASK | NRF_RADIO_SHORT_END_DISABLE_MASK | NRF_RADIO_SHORT_ADDRESS_RSSISTART_MASK));
    For example in case of TX path
    nrfx_gppi_channel_endpoints_setup(ppi_radio_event_rxtxready,
          nrf_radio_event_address_get(NRF_RADIO, NRF_RADIO_EVENT_TXREADY),           nrfx_gpiote_set_task_addr_get(DBG_PIN5));
    nrfx_gppi_channel_endpoints_setup(ppi_radio_event_phyend,
         nrf_radio_event_address_get(NRF_RADIO, NRF_RADIO_EVENT_PHYEND),
      nrfx_gpiote_clr_task_addr_get(DBG_PIN5));
    I think TXREADY nad PHYEND have almost exact timimg as READY and END events.
    Do you see any problem with this scheme ?
    No idea yet if exist some anomalies what generate false events sometimes.
    Eugene
  • Hi Eugene
    TXREADY and READY should have exactly the same timing in TX mode. The TXREADY and RXREADY events are basically a replacement for the READY event, but the READY event was kept in the radio to avoid breaking the backwards compatibility.
    The PHYEND event is mainly used in 802.15.4 mode, and I don't know how much delay there would be in other modes, but I would expect it to happen very quickly after the END event.
    Best regards
    Torbjørn
  • Hi Torbjorn !
    Thank you !
    I think I get point of DPPI on nRF53 and can compose pairs what are need.
    Eugene
