I am trying to build the sys_heap example with tfm and mcuboot with a very simple custom board based on the nrf9160dk_nrf9160 using NCS v2.2.0. But when I run it on my board, MCUboot is unable to find a bootable image. Some times the examples runs correctly, but most of the times it doesn't. The reason for mcuboot not finding a bootable image is because it is using the flash partitions defined in the device tree, but the memory report shows the correct flash partitions . I have determined this by editing get_flash_area_from_id in flash_map_priv.h (see both code blocks). I am not sure how to fix this issue, I have included my project.
static inline struct flash_area const *get_flash_area_from_id(int idx)
for (int i = 0; i < flash_map_entries; i++) {
printk ("flash_map_priv %02u -> (%02u/%02u): %08lx-%08lx (%08x) %s\n", idx, flash_map[i].fa_id, flash_map_entries, flash_map[i].fa_off, flash_map[i].fa_off + flash_map[i].fa_size, flash_map[i].fa_size, flash_map[i].fa_dev->name);
if (flash_map[i].fa_id == idx) {
return &flash_map[i];
return NULL;
*** Booting Zephyr OS build v3.2.99-ncs1 *** I: Starting bootloader default flash_map 03 -> (00/07): 00000000-00010000 (00010000) flash-controller@39000 default flash_map 03 -> (01/07): 00010000-00050000 (00040000) flash-controller@39000 default flash_map 03 -> (02/07): 00050000-00080000 (00030000) flash-controller@39000 default flash_map 03 -> (03/07): 00080000-000c0000 (00040000) flash-controller@39000 default flash_map 09 -> (00/07): 00000000-00010000 (00010000) flash-controller@39000 default flash_map 09 -> (01/07): 00010000-00050000 (00040000) flash-controller@39000 default flash_map 09 -> (02/07): 00050000-00080000 (00030000) flash-controller@39000 default flash_map 09 -> (03/07): 00080000-000c0000 (00040000) flash-controller@39000 default flash_map 09 -> (04/07): 000c0000-000f0000 (00030000) flash-controller@39000 default flash_map 09 -> (05/07): 000f0000-000fa000 (0000a000) flash-controller@39000 default flash_map 09 -> (06/07): 000fa000-00100000 (00006000) flash-controller@39000 default flash_map 03 -> (00/07): 00000000-00010000 (00010000) flash-controller@39000 default flash_map 03 -> (01/07): 00010000-00050000 (00040000) flash-controller@39000 default flash_map 03 -> (02/07): 00050000-00080000 (00030000) flash-controller@39000 default flash_map 03 -> (03/07): 00080000-000c0000 (00040000) flash-controller@39000 default flash_map 09 -> (00/07): 00000000-00010000 (00010000) flash-controller@39000 default flash_map 09 -> (01/07): 00010000-00050000 (00040000) flash-controller@39000 default flash_map 09 -> (02/07): 00050000-00080000 (00030000) flash-controller@39000 default flash_map 09 -> (03/07): 00080000-000c0000 (00040000) flash-controller@39000 default flash_map 09 -> (04/07): 000c0000-000f0000 (00030000) flash-controller@39000 default flash_map 09 -> (05/07): 000f0000-000fa000 (0000a000) flash-controller@39000 default flash_map 09 -> (06/07): 000fa000-00100000 (00006000) flash-controller@39000 W: Failed reading sectors; BOOT_MAX_IMG_SECTORS=128 - too small? default flash_map 03 -> (00/07): 00000000-00010000 (00010000) flash-controller@39000 default flash_map 03 -> (01/07): 00010000-00050000 (00040000) flash-controller@39000 default flash_map 03 -> (02/07): 00050000-00080000 (00030000) flash-controller@39000 default flash_map 03 -> (03/07): 00080000-000c0000 (00040000) flash-controller@39000 default flash_map 09 -> (00/07): 00000000-00010000 (00010000) flash-controller@39000 default flash_map 09 -> (01/07): 00010000-00050000 (00040000) flash-controller@39000 default flash_map 09 -> (02/07): 00050000-00080000 (00030000) flash-controller@39000 default flash_map 09 -> (03/07): 00080000-000c0000 (00040000) flash-controller@39000 default flash_map 09 -> (04/07): 000c0000-000f0000 (00030000) flash-controller@39000 default flash_map 09 -> (05/07): 000f0000-000fa000 (0000a000) flash-controller@39000 default flash_map 09 -> (06/07): 000fa000-00100000 (00006000) flash-controller@39000 W: Cannot upgrade: not a compatible amount of sectors default flash_map 03 -> (00/07): 00000000-00010000 (00010000) flash-controller@39000 default flash_map 03 -> (01/07): 00010000-00050000 (00040000) flash-controller@39000 default flash_map 03 -> (02/07): 00050000-00080000 (00030000) flash-controller@39000 default flash_map 03 -> (03/07): 00080000-000c0000 (00040000) flash-controller@39000 default flash_map 03 -> (00/07): 00000000-00010000 (00010000) flash-controller@39000 default flash_map 03 -> (01/07): 00010000-00050000 (00040000) flash-controller@39000 default flash_map 03 -> (02/07): 00050000-00080000 (00030000) flash-controller@39000 default flash_map 03 -> (03/07): 00080000-000c0000 (00040000) flash-controller@39000 E: Unable to find bootable image
