Communicate two microcontrollers via BLE
I'm using a nRF52 DK to test BLE communication with another microcontroller. What I need to test is the nRF52 pairing with another brand microcontroller, send a data stream and close the connection.
Could you please tell me which example from the Bluetooth samples list I can use for starting?
Thanks for your attention.
  • I am not able to spot any errors in your implementation. Could you upload the full project so I can try reproducing this here?
  • I see the problem now: your main loop is always running as you have commented the k_fifo_get() function.
    As a test, try to add a call to k_msleep(1000); in your loop. This will allow the other threads such as the system workqueue to run.
  • Thanks! Now the connection is established but the pairing still doesn't work. I have uncommented the 'bt_nus_client_send' and 'k_sem_take' functions but no data is received by the ESP32 and the pairing fails after some time:
    *** Booting Zephyr OS build v3.2.99-ncs2 ***
    bt_conn_auth_cb_register
    bt_conn_auth_info_cb_register err: 0
    bt_enable err: 0
    Bluetooth initialized
    uart_init
    scan_init
    Address filter added 60:55:F9:F5:29:D2 (public)
    Scan module initialized
    bt_nus_client_init
    NUS Client module initialized
    Starting Bluetooth Central UART example
    scan err: 0
    Scanning
    Scanning successfully started
    Failed to send data over BLE connection(err -128)
    NUS send timeout
    connected conn_err: 0
    Connected: 60:55:F9:F5:29:D2 (public)
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    Pairing failed conn: 60:55:F9:F5:29:D2 (public), reason 9
    Service discovery completed
    NUS send timeout
    Do you know why this could be happening?
  • Did you add k_msleep(1000) to your main loop? Like this:
    	for (;;) {
    		/* Wait indefinitely for data to be sent over Bluetooth */
    		//struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
    		//				     K_FOREVER);
    		struct uart_data_t *buf;
    		buf->data[0] = 0;
    		buf->data[1] = 1;
    		buf->data[2] = 2;
    		buf->len = 3;
    		//err = bt_nus_client_send(&nus_client, buf->data, buf->len);
    		if (err) {
    			LOG_WRN("Failed to send data over BLE connection"
    				"(err %d)", err);
    			printk("Failed to send data over BLE connection"
    				"(err %d)\n", err);
    		//err = k_sem_take(&nus_write_sem, NUS_WRITE_TIMEOUT);
    		if (err) {
    			LOG_WRN("NUS send timeout");
    			//printk("NUS send timeout\n");
    		k_msleep(1000);
