Communicate two microcontrollers via BLE
I'm using a nRF52 DK to test BLE communication with another microcontroller. What I need to test is the nRF52 pairing with another brand microcontroller, send a data stream and close the connection.
Could you please tell me which example from the Bluetooth samples list I can use for starting?
Thanks for your attention.
  • I tested your sample against the peripheral_uart sample and had to make a few additional changes to make it work:
        //main loop
    	for (;;) {
    		/* Wait indefinitely for data to be sent over Bluetooth */
    		//struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
    		//				     K_FOREVER);
    		struct uart_data_t buffer; // allocate buffer on stack
    		buffer.data[0] = 1;
    		buffer.data[1] = 2;
    		buffer.data[2] = 3;
    		buffer.len = 3;
    		err = bt_nus_client_send(&nus_client, buffer.data, buffer.len);
    		if (err) {
    			LOG_WRN("Failed to send data over BLE connection"
    				"(err %d)", err);
    			printk("Failed to send data over BLE connection"
    				"(err %d)\n", err);
    		//err = k_sem_take(&nus_write_sem, NUS_WRITE_TIMEOUT);
    		if (err) {
    			LOG_WRN("NUS send timeout");
    			//printk("NUS send timeout\n");
    		k_msleep(1000);
    // Remove k_free() and k_sem_give() in this function.
    static void ble_data_sent(struct bt_nus_client *nus, uint8_t err,
    					const uint8_t *const data, uint16_t len)
    	ARG_UNUSED(nus);
    	struct uart_data_t *buf;
    	/* Retrieve buffer context. */
    	buf = CONTAINER_OF(data, struct uart_data_t, data);
    	//k_free(buf); //you are not using heap so there is nothing to free
    	//k_sem_give(&nus_write_sem);
    	if (err) {
    		LOG_WRN("ATT error code: 0x%02X", err);
  • Why is it necessary to comment k_free() and k_sem_give()? When I try connecting to an ESP32 the test still fails:
    *** Booting Zephyr OS build v3.2.99-ncs2 ***
    bt_conn_auth_cb_register
    bt_conn_auth_info_cb_register err: 0
    bt_enable err: 0
    Bluetooth initialized
    uart_init
    scan_init
    Address filter added 60:55:F9:F5:29:D2 (public)
    Scan module initialized
    bt_nus_client_init
    NUS Client module initialized
    Starting Bluetooth Central UART example
    scan err: 0
    Scanning
    Scanning successfully started
    Failed to send data over BLE connection(err -128)
    NUS send timeout
    connected conn_err: 0
    Connected: 60:55:F9:F5:29:D2 (public)
    NUS send timeout
    The ESP32 already has a UUID which allows sending strings from a mobile application. Is there something particular to nRF52 in the implementation of NUS?
    Moreover, could you please explain me how the 'pairing_failed' function is called? As it is declared as a callback function it is not clear for me under which situation it is launched.
  • You will get a code assert if you call k_free() on a pointer that has not been allocated from heap, and k_sem_give() is redundant as you are not using k_sem_take().
    You need to implement your own GATT Client which matches the GATT server on your ESP32. The NUS client will only work with the NUS service: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/libraries/bluetooth_services/services/nus.html
    You may be able to use the existing NUS client as a starting point and change out the UUIDs to match the UUIDs used by the ESP.
    The pairing is handled by the Zephyr Bluetooth host and it will invoke the pairing failed or pairing success callback depending on the outcome.
    Are you still getting the pairing error? If so, is there a long (i.e. several seconds) delay before the pairing failed is called?
  • You may be able to use the existing NUS client as a starting point and change out the UUIDs to match the UUIDs used by the ESP.
    In the project I've sent the UUIDs were already changed :
    /** @brief UUID of the NUS Service. **/
    #define BT_UUID_NUS_VAL \
    	BT_UUID_128_ENCODE(0x0000FFFF, 0x0000, 0x1000, 0x8000, 0x00805F9B34FB)
    /** @brief UUID of the TX Characteristic. **/
    #define BT_UUID_NUS_TX_VAL \
    	BT_UUID_128_ENCODE(0x0000FF01, 0x0000, 0x1000, 0x8000, 0x00805F9B34FB)
    /** @brief UUID of the RX Characteristic. **/
    #define BT_UUID_NUS_RX_VAL \
    	BT_UUID_128_ENCODE(0x0000FF02, 0x0000, 0x1000, 0x8000, 0x00805F9B34FB)
    Yes, it still fails after several seconds (31 send failed tries). Below the terminal output:
    scan err: 0
    Scanning
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    NUS send timeout
    Pairing failed conn: 60:55:F9:F5:29:D2 (public), reason 9
    Service discovery completed
