Communicate two microcontrollers via BLE
I'm using a nRF52 DK to test BLE communication with another microcontroller. What I need to test is the nRF52 pairing with another brand microcontroller, send a data stream and close the connection.
Could you please tell me which example from the Bluetooth samples list I can use for starting?
Thanks for your attention.
  • msu said:
    In the project I've sent the UUIDs were already changed :
    The NUS client is implemented in the SDK tree, so the changes you made were not included in the project you shared.
    msu said:
    Yes, it still fails after several seconds (31 send failed tries). Below the terminal output:
    The Service discovery callback is invoked almost immediately after the connection is established, so I suspect the pairing process is interfering with the discovery procedure in your case.
    Please build your project with the following settings to print the services and characteristics found in the discovery procedure:
    CONFIG_LOG=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_LOG_PRINTK=n
    CONFIG_BT_DEBUG_LOG=y
    CONFIG_BT_GATT_DM_DATA_PRINT=y
    Here is the log I got for comparison:
    Starting Bluetooth Central UART example
    Scanning successfully started
    Failed to send data over BLE connection(err -128)
    [00:00:00.016,296] <inf> fs_nvs: nvs_mount: 6 Sectors of 4096 bytes
    [00:00:00.016,326] <inf> fs_nvs: nvs_mount: alloc wra: 0, fb8
    [00:00:00.016,326] <inf> fs_nvs: nvs_mount: data wra: 0, 88
    [00:00:00.016,510] <inf> bt_sdc_hci_driver: hci_driver_open: SoftDevice Controller build revision:
                                                d8 0c 2d 2f 36 ae e2 5c  80 26 80 4c 3f 4d 16 53 |..-/6..\ .&.L?M.S
                                                50 96 c7 73                                      |P..s
    [00:00:00.020,233] <inf> bt_hci_core: hci_vs_init: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.020,263] <inf> bt_hci_core: hci_vs_init: HW Variant: nRF52x (0x0002)
    [00:00:00.020,294] <inf> bt_hci_core: hci_vs_init: Firmware: Standard Bluetooth controller (0x00) Version 216.11532 Build 3803067951
    [00:00:00.020,935] <inf> bt_hci_core: bt_init: No ID address. App must call settings_load()
    [00:00:00.024,353] <inf> central_uart: main: Bluetooth initialized
    [00:00:00.025,329] <inf> bt_hci_core: bt_dev_show_info: Identity: C4:A1:E3:04:97:3B (random)
    [00:00:00.025,360] <inf> bt_hci_core: bt_dev_show_info: HCI: version 5.3 (0x0c) revision 0x124b, manufacturer 0x0059
    [00:00:00.025,390] <inf> bt_hci_core: bt_dev_show_info: LMP: version 5.3 (0x0c) subver 0x124b
    [00:00:00.033,874] <inf> central_uart: scan_init: Scan module initialized
    [00:00:00.039,367] <inf> central_uart: nus_client_init: NUS Client module initialized
    [00:00:00.050,048] <inf> central_uart: main: Scanning successfully started
    [00:00:00.054,962] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:00.061,187] <wrn> central_uart: main: NUS send timeout
    connected conn_err: 0
    [00:00:00.430,145] <inf> central_uart: scan_filter_match: Filters matched. Address: E0:73:95:EE:95:5F (random) connectable: 1
    [00:00:00.433,166] <inf> central_uart: scan_filter_match: Filters matched. Address: E0:73:95:EE:95:5F (random) connectable: 0
    [00:00:00.433,197] <wrn> central_uart: scan_connecting_error: Connecting failed
    [00:00:00.534,973] <inf> central_uart: connected: Connected: E0:73:95:EE:95:5F (random)
    [00:00:00.534,973] <wrn> central_uart: connected: Sending pairing req.
    [00:00:00.932,800] <inf> central_uart: security_changed: Security changed: E0:73:95:EE:95:5F (random) level 2
    [00:00:01.061,492] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:01.067,596] <wrn> central_uart: main: NUS send timeout
    Service discovery completed
    ATT[1]:         UUID: 0x2803    Handle: 0x0011  Value:
            Characteristic: 0x6e400003-b5a3-f393-e0a9-e50e24dcca9e  Properties: 0x0010
    ATT[2]:         UUID: 0x6e400003-b5a3-f393-e0a9-e50e24dcca9e    Handle: 0x0012  Value:
    ATT[3]:         UUID: 0x2902    Handle: 0x0013  Value:
            CCCD
    ATT[4]:         UUID: 0x2803    Handle: 0x0014  Value:
            Characteristic: 0x6e400002-b5a3-f393-e0a9-e50e24dcca9e  Properties: 0x000C
    ATT[5]:         UUID: 0x6e400002-b5a3-f393-e0a9-e50e24dcca9e    Handle: 0x0015  Value:
    [00:00:01.882,415] <inf> central_uart: discovery_complete: Service discovery completed
  • The NUS client is implemented in the SDK tree, so the changes you made were not included in the project you shared.
    But are the changes included in the project in my computer?
    Below the log I got:
    *** Booting Zephyr OS build v3.2.99-ncs2 ***
    bt_conn_auth_cb_register
    bt_conn_auth_info_cb_register err: 0
    bt_enable err: 0
    uart_init
    scan_init
    Address filter added 60:55:F9:F5:29:D2 (public)
    bt_nus_client_init
    scan err: 0
    Scanning
    return ENOTCONN
    NUS send timeout
    [00:00:00.017,456] <inf> fs_nvs: nvs_mount: 6 Sectors of 4096 bytes
    [00:00:00.017,486] <inf> fs_nvs: nvs_mount: alloc wra: 0, fe8
    [00:00:00.017,517] <inf> fs_nvs: nvs_mount: data wra: 0, 0
    [00:00:00.017,669] <inf> bt_sdc_hci_driver: hci_driver_open: SoftDevice Controller build revision:
                                                50 96 c7 73                                      |P..s
    [00:00:00.021,026] <inf> bt_hci_core: hci_vs_init: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.021,057] <inf> bt_hci_core: hci_vs_init: HW Variant: nRF52x (0x0002)
    [00:00:00.021,087] <inf> bt_hci_core: hci_vs_init: Firmware: Standard Bluetooth controller (0x00) Version 216.11532 Build 3803067951
    [00:00:00.021,667] <inf> bt_hci_core: bt_init: No ID address. App must call settings_load()
    [00:00:00.025,177] <inf> central_uart: main: Bluetooth initialized
    [00:00:00.025,817] <inf> bt_hci_core: bt_dev_show_info: Identity: D7:C8:04connected conn_err: 0
    Connected: 60:55:F9:F5:29:D2 (public)
    :2D:97:BA (random)
    [00:00:00.025,848] <inf> bt_hci_core: bt_dev_show_info: HCI: version 5.3 (0x0c) revision 0x124b, manufacturer 0x0059
    [00:00:00.025,909] <inf> bt_hci_core: bt_dev_show_info: LMP: version 5.3 (0x0c) subver 0x124b
    [00:00:00.034,240] <inf> central_uart: scan_init: Scan module initialized
    [00:00:00.039,733] <inf> central_uart: nus_client_init: NUS Client module initialized
    [00:00:00.052,795] <inf> central_uart: main: Scanning successfully started
    [00:00:00.058,654] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:00.064,880] <wrn> central_uart: main: NUS send timeout
    [00:00:00.117,584] <inf> central_uart: scan_filter_match: Filters matched. Address: 60:55:F9:F5:29:D2 (public) connectable: 1
    [00:00:00.120,239] <inf> central_uart: scan_filter_match: Filters matched. Address: 60:55:F9:F5:29:D2 (public) connectable: 0
    [00:00:00.120,269] <wrn> central_uart: scan_connecting_error: Connecting failed
    [00:00:00.287,994] <inf> central_uart: connected: Connected: 60:55:F9:F5:29:D2 (public)
    return ENOTCONN
    NUS send timeout
    [00:00:00.586,059] <inf> central_uart: exchange_func: MTU exchange done
    [00:00:01.069,122] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:01.075,317] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:02.079,681] <wrn> central_uart: main: Failed to senreturn ENOTCONN
    NUS send timeout
    [00:00:02.086,212] <wrn> central_uart: main: NUS send timeout
    [00:00:03.090,545] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:03.096,740] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:04.101,104] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:04.107,330] <wrn> central_uart: main: NUS send timeout
    [00:00:05.111,602] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:05.117,797] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:06.122,100] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:06.128,326] <wrn> central_uart: main: NUS send timeout
    [00:00:07.132,598] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:07.139,129] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:08.143,524] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:08.149,719] <wrn> central_uart: main: NUS send timeout
    [00:00:09.153,961] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:09.160,156] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:10.164,459] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:10.170,654] <wrn> central_uart: main: NUS send timeout
    [00:00:11.174,957] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:11.181,182] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:12.185,821] <wrn> central_uart: main: Failed to sreturn ENOTCONN
    NUS send timeout
    [00:00:12.191,925] <wrn> central_uart: main: NUS send timeout
    [00:00:13.196,258] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:13.202,484] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:14.206,756] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:14.212,951] <wrn> central_uart: main: NUS send timeout
    [00:00:15.217,193] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:15.223,388] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:16.227,722] <wrn> central_uart: main: Failed to sreturn ENOTCONN
    NUS send timeout
    [00:00:16.233,947] <wrn> central_uart: main: NUS send timeout
    [00:00:17.238,372] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:17.244,598] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:18.248,870] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:18.255,065] <wrn> central_uart: main: NUS send timeout
    [00:00:19.259,307] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:19.265,533] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:20.269,866] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:20.276,092] <wrn> central_uart: main: NUS send timeout
    [00:00:21.280,303] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:21.286,743] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:22.291,107] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:22.297,302] <wrn> central_uart: main: NUS send timeout
    [00:00:23.301,696] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:23.307,891] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:24.312,286] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:24.318,481] <wrn> central_uart: main: NUS send timeout
    [00:00:25.322,784] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:25.329,010] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:26.333,343] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:26.339,843] <wrn> central_uart: main: NUS send timeout
    [00:00:27.344,207] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:27.350,433] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:28.354,766] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:28.360,992] <wrn> central_uart: main: NUS send timeout
    [00:00:29.365,264] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:29.371,490] <wrn> central_uart: main: NUS send timeout
    Pairing failed conn: 60:55:F9:F5:29:D2 (public), reason 9
    return ENOTCONN
    NUS send timeout
    ATT[1]:         UUID: 0x2803    Handle: 0x0029  Value:
            Characteristic: 0xff01  Properties: 0x0008
    ATT[2]:         UUID: 0xff01    Handle: 0x002A  Value:
    ATT[3]:         UUID: 0x2803    Handle: 0x002B  Value:
            Characteristic: 0xff02  Properties: 0x0012
    ATT[4]:         UUID: 0xff02    Handle: 0x002C  Value:
    ATT[5]:         UUID: 0x2902    Handle: 0x002D  Value:
            CCCD
    [00:00:30.293,670] <err> bt_smp: smp_timeout: SMP Timeout
    [00:00:30.294,281] <wrn> central_uart: security_changed: Security failed: 60:55:F9:F5:29:D2 (public) level 1 err 9
    [00:00:30.294,677] <wrn> central_uart: pairing_failed: Pairing failed conn: 60:55:F9:F5:29:D2 (public), reason 9
    [00:00:30.375,762] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:30.381,958] <wrn> central_uart: main: NUS send timeout
    [00:00:30.936,035] <inf> central_uart: discovery_complete: Service discovery completed
    [00:00:30.978,515] <err> nus_c: bt_nus_handles_assign: Missing NUS TX CCC in characteristic.
    [00:00:31.436,035] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:32.436,065] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:33.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:34.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:35.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:36.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:37.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:38.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:39.536,010] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:40.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:41.536,071] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:42.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:43.586,029] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:44.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:45.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:46.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:47.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:48.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:49.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:50.536,010] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:51.486,022] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
    [00:00:52.585,998] <wrn> central_uart: ble_data_sent: ATT error code: 0x01
  • Now I can see the pairing is failing due to a timeout. It is probably blocked by the service discovery.
    The ESP32 uses 16-bit services not 128-bit vendor specific services as NUS does. This means you need to change the UUID declarations from 128-bits to 16-bits uuids with BT_UUID_DECLARE_16().
    Yes, in your local NCS copy.
  • This means you need to change the UUID declarations from 128-bits to 16-bits uuids with BT_UUID_DECLARE_16().
    I have just made this change and now I have errors like this in many lines:
    error: macro "BT_UUID_INIT_16" passed 2 arguments, but takes just 1
      161 |         gatt_desc = bt_gatt_dm_desc_by_uuid(dm, gatt_chrc, BT_UUID_NUS_RX);
    Do I have to replace functions?
  • I solve this problem by replacing:
    /** @brief UUID of the NUS Service. **/
    #define BT_UUID_NUS_VAL \
    	BT_UUID_16_ENCODE(0xFFFF)
    /** @brief UUID of the TX Characteristic. **/
    #define BT_UUID_NUS_TX_VAL \
    	BT_UUID_16_ENCODE(0xFF01)
    /** @brief UUID of the RX Characteristic. **/
    #define BT_UUID_NUS_RX_VAL \
    	BT_UUID_16_ENCODE(0xFF02)
    by:
    	(BT_UUID_16_ENCODE(0xFFFF))
    	(BT_UUID_16_ENCODE(0xFF01))
    	(BT_UUID_16_ENCODE(0xFF02))
    After having flashed the nRF52 the data is not sent yet and I don't see anymore the UUID in the log (the discovery service is not found). Below the log output:
    bt_enable err: 0
    uart_init
    scan_init
    bt_nus_client_init
    scan err: 0
    Scanning
    return ENOTCONN
    NUS send timeout
    [00:00:00.017,303] <inf> fs_nvs: nvs_mount: 6 Sectors of 4096 bytes
    [00:00:00.017,333] <inf> fs_nvs: nvs_mount: alloc wra: 0, fe8
    [00:00:00.017,364] <inf> fs_nvs: nvs_mount: data wra: 0, 0
    [00:00:00.017,486] <inf> bt_sdc_hci_driver: hci_driver_open: SoftDevice Controller build revision:
                                                50 96 c7 73                                      |P..s
    [00:00:00.020,843] <inf> bt_hci_core: hci_vs_init: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.020,874] <inf> bt_hci_core: hci_vs_init: HW Variant: nRF52x (0x0002)
    [00:00:00.020,904] <inf> bt_hci_core: hci_vs_init: Firmware: Standard Bluetooth controller (0x00) Version 216.11532 Build 3803067951
    [00:00:00.021,453] <inf> connected conn_err: 0
    [00:00:00.024,963] <inf> central_uart: main: Bluetooth initialized
    [00:00:00.025,604] <inf> bt_hci_core: bt_dev_show_info: Identity: D7:C8:04:2D:97:BA (random)
    [00:00:00.025,634] <inf> bt_hci_core: bt_dev_show_info: HCI: version 5.3 (0x0c) revision 0x124b, manufacturer 0x0059
    [00:00:00.025,695] <inf> bt_hci_core: bt_dev_show_info: LMP: version 5.3 (0x0c) subver 0x124b
    [00:00:00.034,118] <inf> central_uart: scan_init: Scan module initialized
    [00:00:00.039,611] <inf> central_uart: nus_client_init: NUS Client module initialized
    [00:00:00.052,642] <inf> central_uart: main: Scanning successfully started
    [00:00:00.058,929] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:00.065,124] <wrn> central_uart: main: NUS send timeout
    [00:00:00.069,824] <inf> central_uart: scan_filter_match: Filters matched. Address: 60:55:F9:F5:29:D2 (public) connectable: 1
    [00:00:00.072,082] <inf> central_uart: scan_filter_match: Filters matched. Address: 60:55:F9:F5:29:D2 (public) connectable: 0
    [00:00:00.072,113] <wrn> central_uart: scan_connecting_error: Connecting failed
    [00:00:00.241,516] <inf> central_uart: connected: Connected: 60:55:F9:F5:29:D2 (public)
    return ENOTCONN
    NUS send timeout
    [00:00:00.539,489] <inf> central_uart: exchange_func: MTU exchange done
    [00:00:01.069,519] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:01.075,714] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:02.080,017] <wrn> central_uart: main: Failed to senreturn ENOTCONN
    NUS send timeout
    [00:00:02.086,242] <wrn> central_uart: main: NUS send timeout
    [00:00:03.090,759] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:03.096,954] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:04.101,257] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:04.107,482] <wrn> central_uart: main: NUS send timeout
    [00:00:05.111,785] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:05.118,011] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:06.122,375] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:06.128,601] <wrn> central_uart: main: NUS send timeout
    [00:00:07.132,904] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:07.139,221] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:08.143,402] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:08.149,627] <wrn> central_uart: main: NUS send timeout
    [00:00:09.153,900] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:09.160,125] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:10.164,520] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:10.170,745] <wrn> central_uart: main: NUS send timeout
    [00:00:11.175,048] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:11.181,274] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:12.185,638] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:12.192,108] <wrn> central_uart: main: NUS send timeout
    [00:00:13.196,350] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:13.202,575] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:14.206,970] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:14.213,195] <wrn> central_uart: main: NUS send timeout
    [00:00:15.217,468] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:15.223,693] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:16.227,996] <wrn> central_uart: main: Failed to sreturn ENOTCONN
    NUS send timeout
    [00:00:16.234,222] <wrn> central_uart: main: NUS send timeout
    [00:00:17.238,525] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:17.244,995] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:18.249,267] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:18.255,462] <wrn> central_uart: main: NUS send timeout
    [00:00:19.259,704] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:19.265,899] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:20.270,263] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:20.276,489] <wrn> central_uart: main: NUS send timeout
    [00:00:21.280,670] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:21.286,895] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:22.291,442] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:22.297,668] <wrn> central_uart: main: NUS send timeout
    [00:00:23.301,940] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:23.308,166] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:24.312,408] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:24.318,634] <wrn> central_uart: main: NUS send timeout
    [00:00:25.322,967] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:25.329,193] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:26.333,435] <wrn> central_uart: main: Failed to senreturn ENOTCONN
    NUS send timeout
    [00:00:26.339,965] <wrn> central_uart: main: NUS send timeout
    [00:00:27.344,238] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    return ENOTCONN
    NUS send timeout
    NUS send timeout
    [00:00:28.361,022] <wrn> central_uart: main: NUS send timeout
    [00:00:29.365,295] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:29.371,551] <wrn> central_uart: main: NUS send timeout
    Service not found
    return ENOTCONN
    NUS send timeout
    [00:00:30.247,192] <err> bt_smp: smp_timeout: SMP Timeout
    [00:00:30.247,802] <wrn> central_uart: security_changed: Security failed: 60:55:F9:F5:29:D2 (public) level 1 err 9
    [00:00:30.248,168] <wrn> central_uart: pairing_failed: Pairing failed conn: 60:55:F9:F5:29:D2 (public), reason 9
    [00:00:30.339,447] <inf> central_uart: discovery_service_not_found: Service not found
    [00:00:30.375,793] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:30.382,019] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:31.386,260] <wrn> central_uart: main: Failed to sreturn ENOTCONN
    NUS send timeout
    [00:00:31.392,517] <wrn> central_uart: main: NUS send timeout
    [00:00:32.396,789] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:32.403,015] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:33.407,287] <wrn> central_uart: main: Failed to sendreturn ENOTCONN
    NUS send timeout
    [00:00:33.413,513] <wrn> central_uart: main: NUS send timeout
    [00:00:34.417,907] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:34.424,102] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:35.428,405] <wrn> central_uart: main: Failed to senreturn ENOTCONN
    NUS send timeout
    [00:00:35.434,631] <wrn> central_uart: main: NUS send timeout
    [00:00:36.439,147] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:36.445,251] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:37.449,523] <wrn> central_uart: main: Failed to sreturn ENOTCONN
    NUS send timeout
    [00:00:37.455,749] <wrn> central_uart: main: NUS send timeout
    [00:00:38.460,052] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:38.466,247] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    [00:00:39.470,550] <wrn> central_uart: main: Failed to sereturn ENOTCONN
    NUS send timeout
    [00:00:39.476,745] <wrn> central_uart: main: NUS send timeout
    [00:00:40.481,018] <wrn> central_uart: main: Failed to send data over BLE connection(err -128)
    [00:00:40.487,243] <wrn> central_uart: main: NUS send timeout
    return ENOTCONN
    NUS send timeout
    Which could be the problem?
