Adding in test task for nRF Connect with VS Code
Hello!
I am trying to add testing as a task for VS Code.
So far, I have tested with twister. I can add a new nRF Connect terminal and run the python script to test on hardware.
Now, I would like to add this process as a task, but I'm not sure what to do to add the nRF Connect shell as the executable:
Is there anyway to create a task which invokes commands from the nRF Connect terminal?
Or is there a better method of testing which uses nRF Connect for VS Code?
Thanks!
    We just came back from Easter vacation and that was the reason for no response from out end. Due to very high traffic during this period on devzone and fewer people working this week, we did not manage to assign this to an expert yet. We will look into this as soon as possible, but please expect more delays the first two days. Thanks for your patience so far.
  • Hi Rahul,
    I have asked internally whether there is a recommended way to invoke Twister through the VS Code extension, but I have yet to receive an answer (there might be nothing better).
    Meanwhile, could you try using the following as the executable?
    C:\ncs\toolchains\v2.3.0\git-bash.exe
    Alternatively: This "generate environment script" option has been added to the nRF Connect Toolchain Manager recently (you might have to update nRF Connect for Desktop first). It creates a shell script that sets your environment variables. So you could try adding your shell of preference as the executable in your task, and then try executing this shell script, with a call to Twister added at the end.
    Let me know if one of those options work!
    Raoul
  • Hello Raoul,
    Thanks for the response. So far, I have found the best approach is within an nRF Terminal instance in VS Code to call a windows script which then invokes Twister to test and provide coverage.
    I can get it potentially work with the git-bash approach assuming python was setup there, but I didn't want to go through the hassle if I could just use the nRF Connect terminal. At a later time, I will try out the git bash approach and with environment variables with python to see if that can help.
    Thanks!
