nrf21540 working confirmation
Hi All!
I am using nrf21540DK, NCS version 2.3.0, Radio Test example, RSSI Viewer as a Scanner, and VSCODE studio as an IDE.
I am getting -23dbm when set to nrf52840 at -4 to 4dbm and -46dbm when setting nrf52840 at -20dbm. The distance between Scanner (nrf52833 connected to RSSI Viewer) and nrf21540 is 1 Meter almost.
I want to confirm that nrf21540 is working properly and reading out the internal registers like CONFREG0-3. Can you please help me with that
1)how to read them via SPI any code example?
2)As we are configuring the nrf21540 in Radio test example via UART commands (like output_power pos8dBm,start_channel 20 , and start_tx_sweep, etc) .So we are basically configuring these registers . Can you help me to find out where we can read those registers (CONFREG0-3) in the Radio test example?
3)I am also testing the custom board (nrf21540 + nrf52833).I configured pins according to our design but got -67dbm. This means nrf21540 is not working properly So to ensure that nrf21540 registers are properly configured, I need the above-mentioned point # 1-2 suggestions/solutions if possible.
Thanks & Regards,
Muhammad Usman
  • Hi
    Thank you so much for the detailed answer.
    Are you planning to make your own custom board files?
     I configured the project in a .verlay file according to my custom board pin configuration.
    As you said, RSSI values are not accurate but just for reference whether FEM is working or not I used it.
    1) nrf21540DK radio test sample gave me a -23dbm. when I disable the FEM it gave me -67dbm almost
    2)But the custom board gave me -66dbm almost. This Means nrf21540 SOC is not working.
    All the above tests were performed at a distance of 1 meter. And nrf52833 output was 0dbm.
    Now question is that, can we make sure that nrf21540 SOC is working by reading
    1)Its internal registers ? if yes then any direction/ help?
    2)Can I access these values from the radio test sample and print them on UART? As we are configuring the nrf21540 SOC via commands to set the output power and channel selection etc. I tried to find out but fail to find them.
    3)Can u please help me that how to fully enable the radio test example for the nrf21540 Dk / nrf52833+nrf21540 custom board? Yesterday, I monitored (radio test sample) the SPI signals but no signals on the SPI pins. But when I loaded the direct test mode as per your instructions able to see the sck , MISO and MOSI signals.
    Thanks & Regards,
    Muhammad Usman
  • Hi Muhammad
    Are you able to probe the SPI pins with a scope to see if there is any communication happening over the interface?
    How does your overlay look?
    You can use the nrf21540_ek.overlay as reference.
    I just tried modifying a standard Bluetooth sample to use the nRF21540EK on the nRF52833DK, and all I had to do to make it work was to include that overlay (by setting the SHIELD to nrf21540_ek) and set CONFIG_BT_CTLR_TX_PWR_ANTENNA=20 in my prj.conf file.
    Best regards
    Torbjørn
  • Hi Torbjørn
    Thank you for the response, yes I tried but there are no signals present on SPI pins (SCK, MISO, MOSI) with the "Radio test sample"
    But when I loaded the "Direct Test Mode" I am able to read the pulses at sck , MOSI, and MOSI as well.
    My .overlay file looks like
     * Copyright (c) 2022 Nordic Semiconductor ASA
    	chosen {
    		nordic,nus-uart = &uart0;
    &nrf_radio_fem{
        compatible = "nordic,nrf21540-fem";
        tx-en-gpios = <&gpio0 30 GPIO_ACTIVE_HIGH>;
        rx-en-gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>;
        pdn-gpios = <&gpio0 9 GPIO_ACTIVE_HIGH>;
    //	ant-sel-gpios = <&gpio0 21 GPIO_ACTIVE_HIGH>; IN HW ant_sel pin is GND
    //    mode-gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>;  IN HW Mode pin is GND
        spi-if = <&nrf_radio_fem_spi>;
        supply-voltage-mv = <3000>;
    &fem_spi{
    	status = "okay";
    	cs-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
    	pinctrl-0 = <&spi3_default_alt>;
    	pinctrl-1 = <&spi3_sleep_alt>;
    	nrf_radio_fem_spi: nrf21540_fem_spi@0 {
    		compatible = "nordic,nrf21540-fem-spi";
    		status = "okay";
    		reg = <0>;
    		spi-max-frequency = <8000000>;
    pin_cntrl.dtsi
    // added
    spi3_default_alt: spi3_default_alt {
    		group1 {
    			psels = <NRF_PSEL(SPIM_SCK, 0, 15)>,
    				<NRF_PSEL(SPIM_MISO, 0, 17)>,
    				<NRF_PSEL(SPIM_MOSI, 0, 20)>;
    	spi3_sleep_alt: spi3_sleep_alt {
    		group1 {
    			low-power-enable;
    .proj_conf
    CONFIG_MPSL=y
    CONFIG_MPSL_FEM=y
    CONFIG_MPSL_FEM_NRF21540_GPIO_SPI=y
    CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
    CONFIG_MPSL_FEM_NRF21540_RX_GAIN_DB=0
    CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB=20
    Thanks & Regards,
    Muhammad Usman
  • Hi Muhammad
    I can't see that you have set CONFIG_FEM=y in your configuration?
    As mentioned earlier the radio_test sample will work with the nRF21540, but you need to set this config parameter for the FEM functionality to be enabled.
    Regular Bluetooth samples does not need this config to be set.
    Best regards
    Torbjørn
  • Hi, Have updated you new ticket with follow up info on the use and testing of the radio test with nRF21540DK and the nRF52833DK+nRF21540EK.
