Interrupt routine not working as intended. Did I do setup wrong?
Hello. I have a custom board with a digital sensor that gives a data-packet once every 8 seconds approximately. I have set up my code to enter an interrupt when a positive flank is received from the sensor. After the datapacket has been read, the receiving GPIO is first set to low output for 0.5 seconds and then set to high impedance input. After that I want the NRF to wait for the next positive flank on this GPIO from the sensor.
This seems to work for the most part. But sometimes, seemingly random, the NRF doesn't react on the received positive flank, and the NRF stays in the background-while loop. In the picture below I have measured on the GPIO which receives the data packet. On the left there is a data-packet which the ISR reacted on correctly. But for the next positive flank, the NRF did nothing. I suspect there is something wrong with my interrupt setup.
Below you can check my setup code for the interrupt. Is there anything you can see that is wrong or missing?
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    nrf_drv_gpiote_in_event_disable(PIN_IN);
    nrf_drv_gpiote_in_uninit(PIN_IN);
    readlowpowerpyro(); // Read data packet from sensor
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
    in_config.pull = NRF_GPIO_PIN_NOPULL;
    ret_code_t err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
    nrf_drv_gpiote_in_event_enable(PIN_IN, true);
  //  __WFE();
  //  __SEV();
  // __WFE();
static void gpio_init(void)
    ret_code_t err_code;
Here is the code for setting the GPIO to low output for 0.5 seconds and then to high impedance, making it ready to receive the next datapacket.
  nrf_gpio_pin_clear(PIN_IN);
  nrf_gpio_cfg_output(PIN_IN);
  nrf_delay_us(500);
  nrf_gpio_cfg_input(PIN_IN,NRF_GPIO_PIN_NOPULL);
  • Now I see it's all just 0. Not sure how to read the register values out.
    The register values should update if you pause the application execution by clicking the pause symbol in the debug controls. If not, you can also read out the entire registers using nrfjprog:
    # Read GPIOTE:
    nrfjprog --memrd 0x40006000 --n 0x1000
    # Read GPIO (P0):
    nrfjprog --memrd 0x50000000 --n 0x1000
    The GPIO registers should also be accessible in the debug viewer, but it is likely named P0 and not GPIO, since the nRF52 series can support multiple GPIO ports.
    nicsam1992 said:
    When it happens I am stuck in this state until i have performed "nrf_drv_gpiote_in_uninit(PIN_IN);" inside of the while-loop. If I dont do "nrf_drv_gpiote_in_uninit(PIN_IN);" then the GPIO stays high forever since the positive flank (from the sensor) has set the GPIO high, and the GPIO is stuck in its "high Z state".
    Is there any possibility to trigger a new pulse on the input by shorting the pin/pad to VDD, to see if this triggers the interrupt again (just for debugging purposes)?
    Jørgen
  • Ok, there is the register info:
    GPIOTE
        TASKS_OUT[0]                      0x40006000
            TASKS_OUT                     [0:0]
        TASKS_OUT[1]                      0x40006004
            TASKS_OUT                     [0:0]
        TASKS_OUT[2]                      0x40006008
            TASKS_OUT                     [0:0]
        TASKS_OUT[3]                      0x4000600c
            TASKS_OUT                     [0:0]
        TASKS_OUT[4]                      0x40006010
            TASKS_OUT                     [0:0]
        TASKS_OUT[5]                      0x40006014
            TASKS_OUT                     [0:0]
        TASKS_OUT[6]                      0x40006018
            TASKS_OUT                     [0:0]
        TASKS_OUT[7]                      0x4000601c
            TASKS_OUT                     [0:0]
        TASKS_SET[0]                      0x40006030
            TASKS_SET                     [0:0]
        TASKS_SET[1]                      0x40006034
            TASKS_SET                     [0:0]
        TASKS_SET[2]                      0x40006038
            TASKS_SET                     [0:0]
        TASKS_SET[3]                      0x4000603c
            TASKS_SET                     [0:0]
        TASKS_SET[4]                      0x40006040
            TASKS_SET                     [0:0]
        TASKS_SET[5]                      0x40006044
            TASKS_SET                     [0:0]
        TASKS_SET[6]                      0x40006048
            TASKS_SET                     [0:0]
        TASKS_SET[7]                      0x4000604c
            TASKS_SET                     [0:0]
        TASKS_CLR[0]                      0x40006060
            TASKS_CLR                     [0:0]
        TASKS_CLR[1]                      0x40006064
            TASKS_CLR                     [0:0]
        TASKS_CLR[2]                      0x40006068
            TASKS_CLR                     [0:0]
        TASKS_CLR[3]                      0x4000606c
            TASKS_CLR                     [0:0]
        TASKS_CLR[4]                      0x40006070
            TASKS_CLR                     [0:0]
        TASKS_CLR[5]                      0x40006074
            TASKS_CLR                     [0:0]
        TASKS_CLR[6]                      0x40006078
            TASKS_CLR                     [0:0]
        TASKS_CLR[7]                      0x4000607c
            TASKS_CLR                     [0:0]
        EVENTS_IN[0]        0x00000000    0x40006100
            EVENTS_IN       0             [0:0]
        EVENTS_IN[1]        0x00000000    0x40006104
            EVENTS_IN       0             [0:0]
        EVENTS_IN[2]        0x00000000    0x40006108
            EVENTS_IN       0             [0:0]
        EVENTS_IN[3]        0x00000000    0x4000610c
            EVENTS_IN       0             [0:0]
        EVENTS_IN[4]        0x00000000    0x40006110
            EVENTS_IN       0             [0:0]
        EVENTS_IN[5]        0x00000000    0x40006114
            EVENTS_IN       0             [0:0]
        EVENTS_IN[6]        0x00000000    0x40006118
            EVENTS_IN       0             [0:0]
        EVENTS_IN[7]        0x00000000    0x4000611c
            EVENTS_IN       0             [0:0]
        EVENTS_PORT         0x00000000    0x4000617c
            EVENTS_PORT     0             [0:0]
        INTENSET            0x80000001    0x40006304
            IN0             1             [0:0]
            IN1             0             [1:1]
            IN2             0             [2:2]
            IN3             0             [3:3]
            IN4             0             [4:4]
            IN5             0             [5:5]
            IN6             0             [6:6]
            IN7             0             [7:7]
            PORT            1             [31:31]
        INTENCLR            0x80000001    0x40006308
            IN0             1             [0:0]
            IN1             0             [1:1]
            IN2             0             [2:2]
            IN3             0             [3:3]
            IN4             0             [4:4]
            IN5             0             [5:5]
            IN6             0             [6:6]
            IN7             0             [7:7]
            PORT            1             [31:31]
        CONFIG[0]           0x00011001    0x40006510
            MODE            1             [1:0]
            PSEL            0x10          [12:8]
            POLARITY        1             [17:16]
            OUTINIT         0             [20:20]
        CONFIG[1]           0x00000000    0x40006514
            MODE            0             [1:0]
            PSEL            0x00          [12:8]
            POLARITY        0             [17:16]
            OUTINIT         0             [20:20]
        CONFIG[2]           0x00000000    0x40006518
            MODE            0             [1:0]
            PSEL            0x00          [12:8]
            POLARITY        0             [17:16]
            OUTINIT         0             [20:20]
        CONFIG[3]           0x00000000    0x4000651c
            MODE            0             [1:0]
            PSEL            0x00          [12:8]
            POLARITY        0             [17:16]
            OUTINIT         0             [20:20]
        CONFIG[4]           0x00000000    0x40006520
            MODE            0             [1:0]
            PSEL            0x00          [12:8]
            POLARITY        0             [17:16]
            OUTINIT         0             [20:20]
        CONFIG[5]           0x00000000    0x40006524
            MODE            0             [1:0]
            PSEL            0x00          [12:8]
            POLARITY        0             [17:16]
            OUTINIT         0             [20:20]
        CONFIG[6]           0x00000000    0x40006528
            MODE            0             [1:0]
            PSEL            0x00          [12:8]
            POLARITY        0             [17:16]
            OUTINIT         0             [20:20]
        CONFIG[7]           0x00000000    0x4000652c
            MODE            0             [1:0]
            PSEL            0x00          [12:8]
            POLARITY        0             [17:16]
            OUTINIT         0             [20:20]
    P0
        OUT                 0x00040000    0x50000504
            PIN0            0             [0:0]
            PIN1            0             [1:1]
            PIN2            0             [2:2]
            PIN3            0             [3:3]
            PIN4            0             [4:4]
            PIN5            0             [5:5]
            PIN6            0             [6:6]
            PIN7            0             [7:7]
            PIN8            0             [8:8]
            PIN9            0             [9:9]
            PIN10           0             [10:10]
            PIN11           0             [11:11]
            PIN12           0             [12:12]
            PIN13           0             [13:13]
            PIN14           0             [14:14]
            PIN15           0             [15:15]
            PIN16           0             [16:16]
            PIN17           0             [17:17]
            PIN18           1             [18:18]
            PIN19           0             [19:19]
            PIN20           0             [20:20]
            PIN21           0             [21:21]
            PIN22           0             [22:22]
            PIN23           0             [23:23]
            PIN24           0             [24:24]
            PIN25           0             [25:25]
            PIN26           0             [26:26]
            PIN27           0             [27:27]
            PIN28           0             [28:28]
            PIN29           0             [29:29]
            PIN30           0             [30:30]
            PIN31           0             [31:31]
        OUTSET              0x00040000    0x50000508
            PIN0            0             [0:0]
            PIN1            0             [1:1]
            PIN2            0             [2:2]
            PIN3            0             [3:3]
            PIN4            0             [4:4]
            PIN5            0             [5:5]
            PIN6            0             [6:6]
            PIN7            0             [7:7]
            PIN8            0             [8:8]
            PIN9            0             [9:9]
            PIN10           0             [10:10]
            PIN11           0             [11:11]
            PIN12           0             [12:12]
            PIN13           0             [13:13]
            PIN14           0             [14:14]
            PIN15           0             [15:15]
            PIN16           0             [16:16]
            PIN17           0             [17:17]
            PIN18           1             [18:18]
            PIN19           0             [19:19]
            PIN20           0             [20:20]
            PIN21           0             [21:21]
            PIN22           0             [22:22]
            PIN23           0             [23:23]
            PIN24           0             [24:24]
            PIN25           0             [25:25]
            PIN26           0             [26:26]
            PIN27           0             [27:27]
            PIN28           0             [28:28]
            PIN29           0             [29:29]
            PIN30           0             [30:30]
            PIN31           0             [31:31]
        OUTCLR              0x00040000    0x5000050c
            PIN0            0             [0:0]
            PIN1            0             [1:1]
            PIN2            0             [2:2]
            PIN3            0             [3:3]
            PIN4            0             [4:4]
            PIN5            0             [5:5]
            PIN6            0             [6:6]
            PIN7            0             [7:7]
            PIN8            0             [8:8]
            PIN9            0             [9:9]
            PIN10           0             [10:10]
            PIN11           0             [11:11]
            PIN12           0             [12:12]
            PIN13           0             [13:13]
            PIN14           0             [14:14]
            PIN15           0             [15:15]
            PIN16           0             [16:16]
            PIN17           0             [17:17]
            PIN18           1             [18:18]
            PIN19           0             [19:19]
            PIN20           0             [20:20]
            PIN21           0             [21:21]
            PIN22           0             [22:22]
            PIN23           0             [23:23]
            PIN24           0             [24:24]
            PIN25           0             [25:25]
            PIN26           0             [26:26]
            PIN27           0             [27:27]
            PIN28           0             [28:28]
            PIN29           0             [29:29]
            PIN30           0             [30:30]
            PIN31           0             [31:31]
        IN                  0x00210000    0x50000510
            PIN0            0             [0:0]
            PIN1            0             [1:1]
            PIN2            0             [2:2]
            PIN3            0             [3:3]
            PIN4            0             [4:4]
            PIN5            0             [5:5]
            PIN6            0             [6:6]
            PIN7            0             [7:7]
            PIN8            0             [8:8]
            PIN9            0             [9:9]
            PIN10           0             [10:10]
            PIN11           0             [11:11]
            PIN12           0             [12:12]
            PIN13           0             [13:13]
            PIN14           0             [14:14]
            PIN15           0             [15:15]
            PIN16           1             [16:16]
            PIN17           0             [17:17]
            PIN18           0             [18:18]
            PIN19           0             [19:19]
            PIN20           0             [20:20]
            PIN21           1             [21:21]
            PIN22           0             [22:22]
            PIN23           0             [23:23]
            PIN24           0             [24:24]
            PIN25           0             [25:25]
            PIN26           0             [26:26]
            PIN27           0             [27:27]
            PIN28           0             [28:28]
            PIN29           0             [29:29]
            PIN30           0             [30:30]
            PIN31           0             [31:31]
        DIR                 0x00045000    0x50000514
            PIN0            0             [0:0]
            PIN1            0             [1:1]
            PIN2            0             [2:2]
            PIN3            0             [3:3]
            PIN4            0             [4:4]
            PIN5            0             [5:5]
            PIN6            0             [6:6]
            PIN7            0             [7:7]
            PIN8            0             [8:8]
            PIN9            0             [9:9]
            PIN10           0             [10:10]
            PIN11           0             [11:11]
            PIN12           1             [12:12]
            PIN13           0             [13:13]
            PIN14           1             [14:14]
            PIN15           0             [15:15]
            PIN16           0             [16:16]
            PIN17           0             [17:17]
            PIN18           1             [18:18]
            PIN19           0             [19:19]
            PIN20           0             [20:20]
            PIN21           0             [21:21]
            PIN22           0             [22:22]
            PIN23           0             [23:23]
            PIN24           0             [24:24]
            PIN25           0             [25:25]
            PIN26           0             [26:26]
            PIN27           0             [27:27]
            PIN28           0             [28:28]
            PIN29           0             [29:29]
            PIN30           0             [30:30]
            PIN31           0             [31:31]
        DIRSET              0x00045000    0x50000518
            PIN0            0             [0:0]
            PIN1            0             [1:1]
            PIN2            0             [2:2]
            PIN3            0             [3:3]
            PIN4            0             [4:4]
            PIN5            0             [5:5]
            PIN6            0             [6:6]
            PIN7            0             [7:7]
            PIN8            0             [8:8]
            PIN9            0             [9:9]
            PIN10           0             [10:10]
            PIN11           0             [11:11]
            PIN12           1             [12:12]
            PIN13           0             [13:13]
            PIN14           1             [14:14]
            PIN15           0             [15:15]
            PIN16           0             [16:16]
            PIN17           0             [17:17]
            PIN18           1             [18:18]
            PIN19           0             [19:19]
            PIN20           0             [20:20]
            PIN21           0             [21:21]
            PIN22           0             [22:22]
            PIN23           0             [23:23]
            PIN24           0             [24:24]
            PIN25           0             [25:25]
            PIN26           0             [26:26]
            PIN27           0             [27:27]
            PIN28           0             [28:28]
            PIN29           0             [29:29]
            PIN30           0             [30:30]
            PIN31           0             [31:31]
        DIRCLR              0x00045000    0x5000051c
            PIN0            0             [0:0]
            PIN1            0             [1:1]
            PIN2            0             [2:2]
            PIN3            0             [3:3]
            PIN4            0             [4:4]
            PIN5            0             [5:5]
            PIN6            0             [6:6]
            PIN7            0             [7:7]
            PIN8            0             [8:8]
            PIN9            0             [9:9]
            PIN10           0             [10:10]
            PIN11           0             [11:11]
            PIN12           1             [12:12]
            PIN13           0             [13:13]
            PIN14           1             [14:14]
            PIN15           0             [15:15]
            PIN16           0             [16:16]
            PIN17           0             [17:17]
            PIN18           1             [18:18]
            PIN19           0             [19:19]
            PIN20           0             [20:20]
            PIN21           0             [21:21]
            PIN22           0             [22:22]
            PIN23           0             [23:23]
            PIN24           0             [24:24]
            PIN25           0             [25:25]
            PIN26           0             [26:26]
            PIN27           0             [27:27]
            PIN28           0             [28:28]
            PIN29           0             [29:29]
            PIN30           0             [30:30]
            PIN31           0             [31:31]
        LATCH               0x00000000    0x50000520
            PIN0            0             [0:0]
            PIN1            0             [1:1]
            PIN2            0             [2:2]
            PIN3            0             [3:3]
            PIN4            0             [4:4]
            PIN5            0             [5:5]
            PIN6            0             [6:6]
            PIN7            0             [7:7]
            PIN8            0             [8:8]
            PIN9            0             [9:9]
            PIN10           0             [10:10]
            PIN11           0             [11:11]
            PIN12           0             [12:12]
            PIN13           0             [13:13]
            PIN14           0             [14:14]
            PIN15           0             [15:15]
            PIN16           0             [16:16]
            PIN17           0             [17:17]
            PIN18           0             [18:18]
            PIN19           0             [19:19]
            PIN20           0             [20:20]
            PIN21           0             [21:21]
            PIN22           0             [22:22]
            PIN23           0             [23:23]
            PIN24           0             [24:24]
            PIN25           0             [25:25]
            PIN26           0             [26:26]
            PIN27           0             [27:27]
            PIN28           0             [28:28]
            PIN29           0             [29:29]
            PIN30           0             [30:30]
            PIN31           0             [31:31]
        DETECTMODE          0x00000000    0x50000524
            DETECTMODE      0             [0:0]
        PIN_CNF[0]          0x00000002    0x50000700
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[1]          0x00000002    0x50000704
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[2]          0x00000002    0x50000708
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[3]          0x00000002    0x5000070c
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[4]          0x00000002    0x50000710
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[5]          0x00000002    0x50000714
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[6]          0x00000002    0x50000718
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[7]          0x00000002    0x5000071c
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[8]          0x00000002    0x50000720
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[9]          0x00000002    0x50000724
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[10]         0x00000002    0x50000728
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[11]         0x00000002    0x5000072c
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[12]         0x00000003    0x50000730
            DIR             1             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[13]         0x00000002    0x50000734
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[14]         0x00000003    0x50000738
            DIR             1             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[15]         0x00000002    0x5000073c
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[16]         0x00000000    0x50000740
            DIR             0             [0:0]
            INPUT           0             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[17]         0x00000002    0x50000744
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[18]         0x00000003    0x50000748
            DIR             1             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[19]         0x00000002    0x5000074c
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[20]         0x00000002    0x50000750
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[21]         0x00000002    0x50000754
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[22]         0x00000002    0x50000758
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[23]         0x00000002    0x5000075c
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[24]         0x00000002    0x50000760
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[25]         0x00000002    0x50000764
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[26]         0x00000002    0x50000768
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[27]         0x00000002    0x5000076c
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[28]         0x00000002    0x50000770
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[29]         0x00000002    0x50000774
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[30]         0x00000002    0x50000778
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
        PIN_CNF[31]         0x00000002    0x5000077c
            DIR             0             [0:0]
            INPUT           1             [1:1]
            PULL            0             [3:2]
            DRIVE           0             [10:8]
            SENSE           0             [17:16]
    I am able to trigger a new pulse like you said. Then it works again for some time, until a pulse is ignored and the NRF gets stuck again in the same way.
    Sounds like the nRF is configured correctly when exiting the event handler then. Have you verified that the next pulse does not arrive before the current interrupt handler is completed? You have some quite long delays in there. If the next pulse arrives before the event is cleared and the interrupt handler is completed, a new interrupt may not be triggered. You can check this by toggling a second GPIO when entering/exiting the handler, and scope this along with the interrupt trigger signal.
    Ideally, I would recommend you to reduce the time spent in the interrupt handler, and perform the lengthy delays in the main context:
    nrf_gpio_pin_set(LED);
    nrf_delay_ms(1000);
    nrf_gpio_pin_clear(LED);
    nrf_delay_ms(1000);
