Interrupt routine not working as intended. Did I do setup wrong?
Hello. I have a custom board with a digital sensor that gives a data-packet once every 8 seconds approximately. I have set up my code to enter an interrupt when a positive flank is received from the sensor. After the datapacket has been read, the receiving GPIO is first set to low output for 0.5 seconds and then set to high impedance input. After that I want the NRF to wait for the next positive flank on this GPIO from the sensor.
This seems to work for the most part. But sometimes, seemingly random, the NRF doesn't react on the received positive flank, and the NRF stays in the background-while loop. In the picture below I have measured on the GPIO which receives the data packet. On the left there is a data-packet which the ISR reacted on correctly. But for the next positive flank, the NRF did nothing. I suspect there is something wrong with my interrupt setup.
Below you can check my setup code for the interrupt. Is there anything you can see that is wrong or missing?
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    nrf_drv_gpiote_in_event_disable(PIN_IN);
    nrf_drv_gpiote_in_uninit(PIN_IN);
    readlowpowerpyro(); // Read data packet from sensor
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
    in_config.pull = NRF_GPIO_PIN_NOPULL;
    ret_code_t err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
    nrf_drv_gpiote_in_event_enable(PIN_IN, true);
  //  __WFE();
  //  __SEV();
  // __WFE();
static void gpio_init(void)
    ret_code_t err_code;
Here is the code for setting the GPIO to low output for 0.5 seconds and then to high impedance, making it ready to receive the next datapacket.
  nrf_gpio_pin_clear(PIN_IN);
  nrf_gpio_cfg_output(PIN_IN);
  nrf_delay_us(500);
  nrf_gpio_cfg_input(PIN_IN,NRF_GPIO_PIN_NOPULL);
