unable to program Arduino Nano 33 BLE using JTAG
I have a JLINK JTAG connected to Arduino Nano 33 BLE and able to connect and flash from JLINK application.
In NRF Connect I see the connection detected.
When trying to flash (Blinky) I have errors
Flashing build to 260111299
west flash -d d:\2023\projects\Nordic\blinky2\build --skip-rebuild -r nrfjprog --dev-id 260111299
-- west flash: using runner nrfjprog
FATAL ERROR: board arduino_nano_33_ble does not support runner nrfjprog
To fix, configure this runner in C:\ncs\v2.3.0\zephyr\boards\arm\arduino_nano_33_ble\board.cmake and rebuild.
How to configure board.cmake? I was trying to modify it but no change.
Kindly advice
I modify board.cmake and restarted, but no luck, no change
board_runner_args(jlink "--device=nRF52840_xxAA" "--speed=4000")
board_runner_args(pyocd "--target=nrf52840" "--frequency=4000000")
board_runner_args(blackmagicprobe "--gdb-serial=/dev/ttyBmpGdb")
include(${ZEPHYR_BASE}/boards/common/jlink.board.cmake)
include(${ZEPHYR_BASE}/boards/common/pyocd.board.cmake)
include(${ZEPHYR_BASE}/boards/common/blackmagicprobe.board.cmake)
    One option is to use nrfjprog directly, instead of west flash.
    But if you want to use west flash, did you try to copy from the board.cmake for nrf52840dk_nrf52840:
    include(${ZEPHYR_BASE}/boards/common/nrfjprog.board.cmake)
    include(${ZEPHYR_BASE}/boards/common/openocd-nrf5.board.cmake)
    Let me know if it doesn't work.
    Edvin
    Thanks for responding.I'm using VSCode with nRFConnect on Windows. there is a button
    Everything works with nrf52840 evalution board
    after clicking flash i see in terminal
    west flash -d d:\2023\projects\Nordic\blinky1\build --skip-rebuild -r nrfjprog --dev-id 683340261
    -- runners.nrfjprog: Flashing file: d:\2023\projects\Nordic\blinky1\build\zephyr\zephyr.hex
    Parsing image file.
    Verifying programming.
    Verified OK.
    Enabling pin reset.
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number 683340261 flashed successfully.
    Step 2 - using Arduino Nano 33 BLE
    build works well:
    163/167] Generating isr_tables.c, isrList.bin
    [164/167] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [165/167] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [166/167] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [167/167] Linking C executable zephyr\zephyr.elf
    Memory region         Used Size  Region Size  %age Used
               FLASH:       27448 B       928 KB      2.89%
                 RAM:        6400 B       256 KB      2.44%
            IDT_LIST:          0 GB         2 KB      0.00%
     *  Terminal will be reused by tasks, press any key to close it.
    Trying to flash:
    west flash -d d:\2023\projects\Nordic\blinky2\build --skip-rebuild -r nrfjprog --dev-id 260111299 --erase
     *  The terminal process terminated with exit code: 1.
    original board.cmake (located in C:\ncs\v2.3.0\zephyr\boards\arm\arduino_nano_33_ble0 is:
    board_runner_args(trace32
      "--startup-args"
        "elfFile=${PROJECT_BINARY_DIR}/${KERNEL_ELF_NAME}"
    include(${ZEPHYR_BASE}/boards/common/bossac.board.cmake)
    include(${ZEPHYR_BASE}/boards/common/trace32.board.cmake)
    After changing it to suggested by you:
    rebuilding and...
    See also "D:/2023/projects/Nordic/blinky2/build/CMakeFiles/CMakeOutput.log".
    See also "D:/2023/projects/Nordic/blinky2/build/CMakeFiles/CMakeError.log".
    FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.3.0\opt\bin\cmake.EXE' '-DWEST_PYTHON=c:\ncs\toolchains\v2.3.0\opt\bin\python.exe' '-Bd:\2023\projects\Nordic\blinky2\build' -GNinja -DBOARD=arduino_nano_33_ble -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DCONF_FILE:STRING=d:/2023/projects/Nordic/blinky2/prj.conf '-Sd:\2023\projects\Nordic\blinky2'
    REBUILD UNSUCCESSFUL
    going back to original board.cmake - build successful, flashing error
    1. Kindly advice of possible fix
    2. How to invoke nrfjprog from Terminal ti perform flashing for this specific case?
    Cheers,
    Jan
  • Well, the flash error comes because it can't communicate it believe that it can, according to the board files.
    The build error I am not sure. Can you please copy/save the entire build log and upload it here?
    Just use either the terminal from your screenshot (the one that says "press any key to close it"), or another terminal open in the same folder as your project on your computer, and write:
    nrfjprog --program build\zephyr\zephyr.hex --verify --reset
    Edvin
  •  Executing task: nRF Connect: Build [pristine]: blinky2/build (active)
    Building blinky2
    west build --build-dir d:\2023\projects\Nordic\blinky2\build d:\2023\projects\Nordic\blinky2 --pristine --board arduino_nano_33_ble -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="d:/2023/projects/Nordic/blinky2/prj.conf"
    -- Application: D:/2023/projects/Nordic/blinky2
    -- Found Python3: C:/ncs/toolchains/v2.3.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v2.3.0/zephyr/.cache
    -- Zephyr version: 3.2.99 (C:/ncs/v2.3.0/zephyr)
    -- Board: arduino_nano_33_ble
    -- Found host-tools: zephyr 0.15.2 (C:/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.2 (C:/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/v2.3.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v2.3.0/zephyr/boards/arm/arduino_nano_33_ble/arduino_nano_33_ble.dts
    -- Generated zephyr.dts: D:/2023/projects/Nordic/blinky2/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: D:/2023/projects/Nordic/blinky2/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: D:/2023/projects/Nordic/blinky2/build/zephyr/dts.cmake
    Parsing C:/ncs/v2.3.0/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v2.3.0/zephyr/boards/arm/arduino_nano_33_ble/arduino_nano_33_ble_defconfig'
    Merged configuration 'd:/2023/projects/Nordic/blinky2/prj.conf'
    Configuration saved to 'D:/2023/projects/Nordic/blinky2/build/zephyr/.config'
    Kconfig header saved to 'D:/2023/projects/Nordic/blinky2/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: C:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    CMake Error at C:/ncs/v2.3.0/zephyr/boards/common/openocd-nrf5.board.cmake:13 (message):
      Can't match nrf5 subfamily from BOARD name.  To fix, set CMake variable
      OPENOCD_NRF5_SUBFAMILY.
      C:/ncs/v2.3.0/zephyr/boards/arm/arduino_nano_33_ble/board.cmake:8 (include)
      C:/ncs/v2.3.0/zephyr/cmake/modules/kernel.cmake:169 (include)
      C:/ncs/v2.3.0/zephyr/cmake/modules/zephyr_default.cmake:117 (include)
      C:/ncs/v2.3.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      C:/ncs/v2.3.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:4 (find_package)
    ______________________________
    CMakeErrorLog
    Compiling the C compiler identification source file "CMakeCCompilerId.c" failed.
    Compiler: C:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    Build flags:
    Id flags:
    The output was:
    1
    c:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: c:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/lib\libc.a(lib_a-exit.o): in function `exit':
    exit.c:(.text.exit+0x34): undefined reference to `_exit'
    collect2.exe: error: ld returned 1 exit status
    Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
    Build flags:
    Id flags:
    The output was:
    1
    __________________________________
    CMakeOutput.log
    The target system is: Generic - 3.2.99 - arm
    The host system is: Windows - 10.0.19045 - AMD64
    Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
    Build flags:
    Id flags: -c
    The output was:
    0
    Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.o"
    The C compiler identification is GNU, found in "D:/2023/projects/Nordic/blinky2/build/CMakeFiles/3.20.5/CompilerIdC/CMakeCCompilerId.o"
    Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
    Build flags:
    Id flags: -c
    The output was:
    0
    Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.o"
    The CXX compiler identification is GNU, found in "D:/2023/projects/Nordic/blinky2/build/CMakeFiles/3.20.5/CompilerIdCXX/CMakeCXXCompilerId.o"
    Checking whether the ASM compiler is GNU using "--version" matched "(GNU assembler)|(GCC)|(Free Software Foundation)":
    arm-zephyr-eabi-gcc.exe (Zephyr SDK 0.15.2) 12.1.0
    Copyright (C) 2022 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    To save our time, I think I use nrf52840dk_nrf52840 for development and after done, I will flash the code into Arduino Nano 33 BLE board using programmer (JLink or nrfjprog) Maybe with a new release of tools things will be fixed.
    Thanks for your support.
    Cheers
    Jan
