Hello
I am using the nrf52833, zephyr version 3.199, sdk 0.14.1. In our board we didn't connect the 32khz oscillator, so I configure the board with:
Hello
Hi Ilan,
According to documentation, HFINT is only used when HFCLK is requested and HFXO is not running. There is no dependency with LFCLK.
Are you using vanilla Zephyr for this test? Or are you using the nRF Connect SDK?
Hieu
Hi
I am using connect sdk v2.1.2 (I had noted wrong version number on the previous post)
I change my setting in prj.conf from:
Unfortunately, such a guide as you asked for is not available. I too agree that the documentation still have much room for improvement. I appreciate your feedbacks on the matter and will inform our teams of it.
The fact that you need to use the synthesized clock source instead of the internal RC oscillator is still an issue. It is great that you could use it now instead. I will still put a note with our internal team next week to investigate this.
Hi Ilan,
Sorry for the late follow up. I would like to double check a point:
Is the HF clock source HFINT/not use HFXO even when the radio is active?
When the radio is not active, the clock source can be automatically reconfigured to HFINT to save power. However, it should be automatically reconfigured to HFXO when the radio is active again.
Hi Hieu,
In my code the radio is activated(ble scan) but not using the nrf connect driver but by accessing directly the radio registers (the nrf connect ble do not support the operation I need from the radio). I also configure the clock register directly.
