I'm trying to use an accelerometer from Analog Device (ADXL345) with the nRF52840 Eval kit. I'm using SES and I tried to rely on the example given in the SDK.
I've first written a program that worked but I created all the functions that I need in the main file. However, I'd like to adapt this code by creating two files (a .c file and a .h) that would handle the different functions targeting the accelerometer. Unfortunately, I always get the same problem whenever I try to build which is the one written in the title.
Here is a screenshot of the code with the output:
This main.c file is the one already working:
#include <string.h> #include <math.h> #include "nrf.h" #include "nrf_gpio.h" #include "nrf_delay.h" #include "nrf_drv_spi.h" #include "boards.h" #include "SEGGER_RTT.h" // Must include these headers to work with nrf logger #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" #define ADXL345_REG_DEVID 0x00 #define ADXL345_REG_DATAX0 0x32 #define ADXL345_REG_DATA_FORMAT 0x31 #define ADXL345_REG_POWER_CTL 0x2D #define ADXL345_REG_FIFO_CTRL 0x38 #define ADXL345_REG_FIFO_STS 0x39 #define ADXL345_REG_BW_RATE 0x2C #define SCALE_FACTOR_4G 7.8 #define ADXL345_SPI_INSTANCE 0 #define ADXL345_CS_PIN 31 static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(ADXL345_SPI_INSTANCE); static volatile bool spi_xfer_done; void spi_event_handler(nrf_drv_spi_evt_t const * p_event, void * p_context) { spi_xfer_done = true; //nrf_gpio_pin_set(ADXL345_CS_PIN); } # if 0 void ADXL375_SPI_writeRegister(uint8_t reg_addr, uint8_t * p_data, uint8_t bytes) { uint32_t err_code; uint8_t m_tx_data_spi[bytes+1]; uint8_t m_rx_data_spi[bytes+1]; memcpy(&m_tx_data_spi+1,p_data,bytes); if(bytes > 1) { m_tx_data_spi[0] = (reg_addr|0x40); } else { m_tx_data_spi[0] = reg_addr; } // Pull Chip Select line low nrf_gpio_pin_clear(ADXL345_CS_PIN); err_code = nrf_drv_spi_transfer(&spi, m_tx_data_spi, sizeof(m_tx_data_spi), m_rx_data_spi, sizeof(m_rx_data_spi)); APP_ERROR_CHECK(err_code); // Set Chip Select line high nrf_gpio_pin_set(ADXL345_CS_PIN); spi_xfer_done = false; } void ADXL375_SPI_readRegister(uint8_t address, uint8_t * p_data, uint8_t bytes) { uint32_t err_code; uint8_t m_tx_data_spi; if(bytes > 1) { m_tx_data_spi = (0x80|address)|0x40; } else { m_tx_data_spi = 0x80|address; } // Pull Chip Select line low nrf_gpio_pin_clear(ADXL345_CS_PIN); err_code = nrf_drv_spi_transfer(&spi, &m_tx_data_spi, bytes, p_data, bytes); APP_ERROR_CHECK(err_code); // Set Chipselect line high nrf_gpio_pin_set(ADXL345_CS_PIN); spi_xfer_done = false; } void ADXL375_SPI_setDataRate(uint8_t rate) { // NRF_LOG_INFO("Setting Data Rate Register: %x \n", rate); uint8_t m_rx_data_spi[2]; ADXL375_SPI_writeRegister(0x2C,&rate,1); // Read the register and check if it was set correctly ADXL375_SPI_readRegister(0x2C,m_rx_data_spi, sizeof(m_rx_data_spi)); if(m_rx_data_spi[1] != rate) { SEGGER_RTT_WriteString(0,"Failed to set data rate!\n"); } else { SEGGER_RTT_WriteString(0,"Data rate set sucessful!\n"); } } #endif void adxl345_init(void) { uint32_t err_code; // Read measurement mode uint8_t tx_data4[2] = {ADXL345_REG_POWER_CTL|0x80, 0}; uint8_t rx_data4[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data4, 2, rx_data4, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); NRF_LOG_INFO( "Read measurement mode: 0x%02X \n",rx_data4[1]); // Set to measurement mode uint8_t tx_data[2] = {ADXL345_REG_POWER_CTL, (uint8_t)(rx_data4[1u] | 0x08u)}; uint8_t rx_data[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data, 2, rx_data, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); // Read measurement mode uint8_t tx_data5[2] = {ADXL345_REG_POWER_CTL|0x80, 0}; uint8_t rx_data5[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data5, 2, rx_data5, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); NRF_LOG_INFO( "Read measurement mode: 0x%02X \n",rx_data5[1]); //Set data rate uint8_t tx_data_2[2] = {ADXL345_REG_BW_RATE, 0x0A}; uint8_t rx_data_2[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_2, 2, rx_data_2, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); // Read data rate uint8_t tx_data_3[2] = {ADXL345_REG_BW_RATE | 0x80, 0}; uint8_t rx_data_3[2]= {0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_3, 2, rx_data_3, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); NRF_LOG_INFO( "Check of data rate sent: %X \n Check of data rate received: %X \n",tx_data_2[1], rx_data_3[1]); //Set resolution and range uint8_t tx_data_4[2] = {ADXL345_REG_DATA_FORMAT, 0x01}; uint8_t rx_data_4[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_4, 2, rx_data_4, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); //Read resolution range uint8_t tx_data_5[2] = {ADXL345_REG_DATA_FORMAT | 0x80, 0}; uint8_t rx_data_5[2]= {0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_5, 2, rx_data_5, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); NRF_LOG_INFO( "Check of resolution range sent: %X \n Check of resolution range received: %X \n",tx_data_4[1], rx_data_5[1]); // Set FIFO CTL uint8_t tx_data_6[2] = {ADXL345_REG_FIFO_CTRL, 0x80}; uint8_t rx_data_6[2]= {0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_6, 2, rx_data_6, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); //Read FIFO CTL uint8_t tx_data_7[2] = {ADXL345_REG_FIFO_CTRL | 0x80, 0}; uint8_t rx_data_7[2] = {0,0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_7, 2, rx_data_7, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); if (rx_data_7[1]!=tx_data_6[1]) { NRF_LOG_INFO( "FIFO_CTL sent: 0x%02X \n FIFO_CTL received: 0x%02X \n",tx_data[1], rx_data_2[1]);}//NRF_LOG_INFO( "Not same value sent and received from FIFO_CTL \n");} else {NRF_LOG_INFO( "Same value sent and receive");} } void adxl345_FIFO_write_CTL(void){ // Set FIFO CTL uint8_t tx_data[2] = {ADXL345_REG_FIFO_CTRL, 0x80}; uint8_t rx_data[2]= {0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data, 2, rx_data, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); /* //test comm initial uint8_t tx_data_3[2] = {0x00| 0x80, 0x00}; uint8_t rx_data_3[2]= {0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_3, 2, rx_data_3, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); NRF_LOG_INFO( "Adress of accelerometer is: 0x%02X \n",rx_data_3[1]); */ //Read FIFO CTL uint8_t tx_data_2[2] = {ADXL345_REG_FIFO_CTRL | 0x80, 0}; uint8_t rx_data_2[2] = {0,0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_2, 2, rx_data_2, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); if (rx_data_2[1]!=tx_data[1]) { NRF_LOG_INFO( "FIFO_CTL sent: 0x%02X \n FIFO_CTL received: 0x%02X \n",tx_data[1], rx_data_2[1]);}//NRF_LOG_INFO( "Not same value sent and received from FIFO_CTL \n");} else {NRF_LOG_INFO( "Same value sent and received from FIFO_CTL \n");} } bool adxl345_read_fifo_status(void) { // Read FIFO status and return true if there are values to read uint8_t tx_data[2] = {ADXL345_REG_FIFO_STS|0x80, 0}; uint8_t rx_data[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data, 2, rx_data, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); //NRF_LOG_INFO( "FIFO Entries : 0x%02X \n",(rx_data[1] & 0x3Fu)); return (bool)((rx_data[1] & 0x3Fu) != 0u); } void adxl345_read_acceleration(int16_t *x, int16_t *y, int16_t *z) { uint8_t tx_data = ADXL345_REG_DATAX0 | 0x80 |0x40; uint8_t rx_data[8] = {0, 0, 0, 0, 0, 0, 0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, &tx_data, 8, rx_data, 8); while (!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); *x = (((int16_t)rx_data[2] << 8 | rx_data[1])) * SCALE_FACTOR_4G; *y = (((int16_t)rx_data[4] << 8 | rx_data[3])) * SCALE_FACTOR_4G; *z = (((int16_t)rx_data[6] << 8 | rx_data[5])) * SCALE_FACTOR_4G; } int main(void) { //Initialize the LEDs on board to use them bsp_board_init(BSP_INIT_LEDS); // Initialize the Logger module and check if any error occured during initialization APP_ERROR_CHECK(NRF_LOG_INIT(NULL)); // Initialize the default backends for nrf logger NRF_LOG_DEFAULT_BACKENDS_INIT(); // print the log msg over uart port NRF_LOG_INFO("This is log data from nordic device.."); NRF_LOG_INFO("Initialisation \n"); int16_t x, y, z; float xg, yg, zg; nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG; spi_config.ss_pin = ADXL345_CS_PIN; spi_config.miso_pin = 30; spi_config.mosi_pin = 29; spi_config.sck_pin = 26; spi_config.frequency = NRF_DRV_SPI_FREQ_1M; spi_config.mode = NRF_DRV_SPI_MODE_3; APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL)); nrf_gpio_cfg_output(ADXL345_CS_PIN); nrf_gpio_pin_set(ADXL345_CS_PIN); adxl345_init(); adxl345_FIFO_write_CTL(); while (true) { if (adxl345_read_fifo_status() != false) { //NRF_LOG_INFO( "Range acceleromter: %X \n", adxl345_read_range()) adxl345_read_acceleration(&x, &y, &z); xg= (float)x *SCALE_FACTOR_4G /(pow(10,3)); yg= (float)y *SCALE_FACTOR_4G/(pow(10,3)); zg= (float)z *SCALE_FACTOR_4G/(pow(10,3)); NRF_LOG_INFO("x avec facteur: "NRF_LOG_FLOAT_MARKER" g, x: %d \r", NRF_LOG_FLOAT(xg), x); NRF_LOG_INFO("y avec facteur: "NRF_LOG_FLOAT_MARKER" g, y: %d \r", NRF_LOG_FLOAT(yg), y); NRF_LOG_INFO("z avec facteur: "NRF_LOG_FLOAT_MARKER" g, z: %d \r\n", NRF_LOG_FLOAT(zg), z); } NRF_LOG_FLUSH(); nrf_delay_ms(100); } }
Theses next three files are respectively the main.c. I just send this one because it seems that I can't send the rest directly
#include "ADXL345.h" /* #include <string.h> #include <math.h> #include "nrf.h" #include "nrf_gpio.h" #include "nrf_delay.h" #include "nrf_drv_spi.h" #include "boards.h" #include "SEGGER_RTT.h" // Must include these headers to work with nrf logger #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" #define ADXL345_REG_DEVID 0x00 #define ADXL345_REG_DATAX0 0x32 #define ADXL345_REG_DATA_FORMAT 0x31 #define ADXL345_REG_POWER_CTL 0x2D #define ADXL345_REG_FIFO_CTRL 0x38 #define ADXL345_REG_FIFO_STS 0x39 #define ADXL345_REG_BW_RATE 0x2C #define SCALE_FACTOR_4G 7.8 #define ADXL345_SPI_INSTANCE 0 #define ADXL345_CS_PIN 31 */ static volatile bool spi_xfer_done; /* Flag used to indicate that SPI instance completed the transfer. */ static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(ADXL345_SPI_INSTANCE); #if 0 //flag géré dans l'interruption de la com SPI. Passe True après envoie de trame void spi_event_handler(nrf_drv_spi_evt_t const * p_event, void * p_context) { spi_xfer_done = true; //nrf_gpio_pin_set(ADXL345_CS_PIN); } #endif # if 0 void ADXL375_SPI_writeRegister(uint8_t reg_addr, uint8_t * p_data, uint8_t bytes) { uint32_t err_code; uint8_t m_tx_data_spi[bytes+1]; uint8_t m_rx_data_spi[bytes+1]; memcpy(&m_tx_data_spi+1,p_data,bytes); if(bytes > 1) { m_tx_data_spi[0] = (reg_addr|0x40); } else { m_tx_data_spi[0] = reg_addr; } // Pull Chip Select line low nrf_gpio_pin_clear(ADXL345_CS_PIN); err_code = nrf_drv_spi_transfer(&spi, m_tx_data_spi, sizeof(m_tx_data_spi), m_rx_data_spi, sizeof(m_rx_data_spi)); APP_ERROR_CHECK(err_code); // Set Chip Select line high nrf_gpio_pin_set(ADXL345_CS_PIN); spi_xfer_done = false; } void ADXL375_SPI_readRegister(uint8_t address, uint8_t * p_data, uint8_t bytes) { uint32_t err_code; uint8_t m_tx_data_spi; if(bytes > 1) { m_tx_data_spi = (0x80|address)|0x40; } else { m_tx_data_spi = 0x80|address; } // Pull Chip Select line low nrf_gpio_pin_clear(ADXL345_CS_PIN); err_code = nrf_drv_spi_transfer(&spi, &m_tx_data_spi, bytes, p_data, bytes); APP_ERROR_CHECK(err_code); // Set Chipselect line high nrf_gpio_pin_set(ADXL345_CS_PIN); spi_xfer_done = false; } void ADXL375_SPI_setDataRate(uint8_t rate) { // NRF_LOG_INFO("Setting Data Rate Register: %x \n", rate); uint8_t m_rx_data_spi[2]; ADXL375_SPI_writeRegister(0x2C,&rate,1); // Read the register and check if it was set correctly ADXL375_SPI_readRegister(0x2C,m_rx_data_spi, sizeof(m_rx_data_spi)); if(m_rx_data_spi[1] != rate) { SEGGER_RTT_WriteString(0,"Failed to set data rate!\n"); } else { SEGGER_RTT_WriteString(0,"Data rate set sucessful!\n"); } } #endif void adxl345_init(void) { uint8_t rx_data4[2]; ADXL375_SPI_readRegister(ADXL345_REG_POWER_CTL, rx_data4, sizeof(rx_data4)); NRF_LOG_INFO( "Read measurement mode avec fonction: 0x%02X \n",rx_data4[1]); /*// Read measurement mode uint8_t tx_data4[2] = {ADXL345_REG_POWER_CTL|0x80, 0}; uint8_t rx_data4[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data4, 2, rx_data4, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); NRF_LOG_INFO( "Read measurement mode: 0x%02X \n",rx_data4[1]); */ // Set to measurement mode uint8_t tx_data[2] = {ADXL345_REG_POWER_CTL, (uint8_t)(rx_data4[1u] | 0x08u)}; uint8_t rx_data[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data, 2, rx_data, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); // Read measurement mode uint8_t tx_data5[2] = {ADXL345_REG_POWER_CTL|0x80, 0}; uint8_t rx_data5[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data5, 2, rx_data5, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); NRF_LOG_INFO( "Read measurement mode: 0x%02X \n",rx_data5[1]); //Set data rate uint8_t tx_data_2[2] = {ADXL345_REG_BW_RATE, 0x0A}; uint8_t rx_data_2[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_2, 2, rx_data_2, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); // Read data rate uint8_t tx_data_3[2] = {ADXL345_REG_BW_RATE | 0x80, 0}; uint8_t rx_data_3[2]= {0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_3, 2, rx_data_3, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); NRF_LOG_INFO( "Check of data rate sent: %X \n Check of data rate received: %X \n",tx_data_2[1], rx_data_3[1]); //Set resolution and range uint8_t tx_data_4[2] = {ADXL345_REG_DATA_FORMAT, 0x01}; uint8_t rx_data_4[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_4, 2, rx_data_4, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); //Read resolution range uint8_t tx_data_5[2] = {ADXL345_REG_DATA_FORMAT | 0x80, 0}; uint8_t rx_data_5[2]= {0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_5, 2, rx_data_5, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); NRF_LOG_INFO( "Check of resolution range sent: %X \n Check of resolution range received: %X \n",tx_data_4[1], rx_data_5[1]); // Set FIFO CTL uint8_t tx_data_6[2] = {ADXL345_REG_FIFO_CTRL, 0x80}; uint8_t rx_data_6[2]= {0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_6, 2, rx_data_6, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); //Read FIFO CTL uint8_t tx_data_7[2] = {ADXL345_REG_FIFO_CTRL | 0x80, 0}; uint8_t rx_data_7[2] = {0,0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_7, 2, rx_data_7, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); if (rx_data_7[1]!=tx_data_6[1]) { NRF_LOG_INFO( "FIFO_CTL sent: 0x%02X \n FIFO_CTL received: 0x%02X \n",tx_data[1], rx_data_2[1]);}//NRF_LOG_INFO( "Not same value sent and received from FIFO_CTL \n");} else {NRF_LOG_INFO( "Same value sent and receive");} } void adxl345_FIFO_write_CTL(void){ // Set FIFO CTL uint8_t tx_data[2] = {ADXL345_REG_FIFO_CTRL, 0x80}; uint8_t rx_data[2]= {0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data, 2, rx_data, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); /* //test comm initial uint8_t tx_data_3[2] = {0x00| 0x80, 0x00}; uint8_t rx_data_3[2]= {0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_3, 2, rx_data_3, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); NRF_LOG_INFO( "Adress of accelerometer is: 0x%02X \n",rx_data_3[1]); */ //Read FIFO CTL uint8_t tx_data_2[2] = {ADXL345_REG_FIFO_CTRL | 0x80, 0}; uint8_t rx_data_2[2] = {0,0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data_2, 2, rx_data_2, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); if (rx_data_2[1]!=tx_data[1]) { NRF_LOG_INFO( "FIFO_CTL sent: 0x%02X \n FIFO_CTL received: 0x%02X \n",tx_data[1], rx_data_2[1]);}//NRF_LOG_INFO( "Not same value sent and received from FIFO_CTL \n");} else {NRF_LOG_INFO( "Same value sent and received from FIFO_CTL \n");} } bool adxl345_read_fifo_status(void) { // Read FIFO status and return true if there are values to read uint8_t tx_data[2] = {ADXL345_REG_FIFO_STS|0x80, 0}; uint8_t rx_data[2]; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, tx_data, 2, rx_data, 2); while(!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); //NRF_LOG_INFO( "FIFO Entries : 0x%02X \n",(rx_data[1] & 0x3Fu)); return (bool)((rx_data[1] & 0x3Fu) != 0u); } void adxl345_read_acceleration(int16_t *x, int16_t *y, int16_t *z) { uint8_t tx_data = ADXL345_REG_DATAX0 | 0x80 |0x40; uint8_t rx_data[8] = {0, 0, 0, 0, 0, 0, 0, 0}; nrf_gpio_pin_clear(ADXL345_CS_PIN); spi_xfer_done=false; nrf_drv_spi_transfer(&spi, &tx_data, 8, rx_data, 8); while (!spi_xfer_done){} nrf_gpio_pin_set(ADXL345_CS_PIN); *x = (((int16_t)rx_data[2] << 8 | rx_data[1])) * SCALE_FACTOR_4G; *y = (((int16_t)rx_data[4] << 8 | rx_data[3])) * SCALE_FACTOR_4G; *z = (((int16_t)rx_data[6] << 8 | rx_data[5])) * SCALE_FACTOR_4G; } int main(void) { //Initialize the LEDs on board to use them bsp_board_init(BSP_INIT_LEDS); // Initialize the Logger module and check if any error occured during initialization APP_ERROR_CHECK(NRF_LOG_INIT(NULL)); // Initialize the default backends for nrf logger NRF_LOG_DEFAULT_BACKENDS_INIT(); // print the log msg over uart port NRF_LOG_INFO("This is log data from nordic device.."); NRF_LOG_INFO("Initialisation \n"); int16_t x, y, z; float xg, yg, zg; SPI_Init(); #if 0 nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG; spi_config.ss_pin = ADXL345_CS_PIN; spi_config.miso_pin = 30; spi_config.mosi_pin = 29; spi_config.sck_pin = 26; spi_config.frequency = NRF_DRV_SPI_FREQ_1M; spi_config.mode = NRF_DRV_SPI_MODE_3; APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL)); nrf_gpio_cfg_output(ADXL345_CS_PIN); nrf_gpio_pin_set(ADXL345_CS_PIN); #endif adxl345_init(); adxl345_FIFO_write_CTL(); while (true) { if (adxl345_read_fifo_status() != false) { //NRF_LOG_INFO( "Range acceleromter: %X \n", adxl345_read_range()) adxl345_read_acceleration(&x, &y, &z); xg= (float)x *SCALE_FACTOR_4G /(pow(10,3)); yg= (float)y *SCALE_FACTOR_4G/(pow(10,3)); zg= (float)z *SCALE_FACTOR_4G/(pow(10,3)); NRF_LOG_INFO("x avec facteur: "NRF_LOG_FLOAT_MARKER" g, x: %d \r", NRF_LOG_FLOAT(xg), x); NRF_LOG_INFO("y avec facteur: "NRF_LOG_FLOAT_MARKER" g, y: %d \r", NRF_LOG_FLOAT(yg), y); NRF_LOG_INFO("z avec facteur: "NRF_LOG_FLOAT_MARKER" g, z: %d \r\n", NRF_LOG_FLOAT(zg), z); } NRF_LOG_FLUSH(); nrf_delay_ms(100); } }
