Porting i2c driver to Zephyr
I would like porting i2c driver from RF5_SDK_16 to Zephyr. Does Zephyr provide functions related to the following RF5_SDK_16 functions?
nrf_drv_twi_init()
nrf_drv_twi_enable()
nrf_drv_twi_uninit()
nrf_drv_twi_tx()
Does any sample code for nRF52832 i2c?
  • #include "i2c.h"
    #include "nrf_drv_twi.h"
    #include "app_error.h"
    #include "nrf.h"
    #include "bsp.h"
    #include "nrf_delay.h"
    #include <string.h>
    static uint8_t slave_addr;
    //static const nrf_drv_twi_t m_twi_master = NRF_DRV_TWI_INSTANCE(1);
    static bool _gI2CInitialzed = false;
    ret_code_t I2C_Init(void)
    	ret_code_t ret;
    	const nrf_drv_twi_config_t config =
    		.scl                = TWI_SCL_M,
    		.sda                = TWI_SDA_M,
    		.frequency          = (nrf_drv_twi_frequency_t) NRF_TWI_FREQ_400K,
    		.interrupt_priority = APP_IRQ_PRIORITY_HIGH
    	//nrf_drv_twi_uninit(&m_twi_master);
    	do
    		ret = nrf_drv_twi_init(&m_twi_master,&config,NULL,NULL);
    		if(NRF_SUCCESS != ret)
    		nrf_drv_twi_enable(&m_twi_master);
    	}while(0);
        _gI2CInitialzed = true;
    	return ret;
    void I2C_Uninit(void)
    	//nrf_drv_twi_disable(&m_twi_master);
    	if (_gI2CInitialzed) {
    	//nrf_gpio_pin_set(TWI_SCL_M);
    	//nrf_gpio_pin_set(TWI_SDA_M);
    	//nrf_gpio_cfg_input(TWI_SCL_M,NRF_GPIO_PIN_PULLDOWN);
    	//nrf_gpio_cfg_input(TWI_SDA_M,NRF_GPIO_PIN_PULLDOWN);
    void I2C_SlaveAddr(uint8_t addr)
    	slave_addr = addr;
    ret_code_t I2C_WriteReg(uint8_t reg,uint8_t data)
    	static ret_code_t ret;
    	uint8_t buff[2];
    	//static ret_code_t ret;
    	//uint8_t data = 0;
    	buff[0] = reg;
    	buff[1] = data;
    	ret = nrf_drv_twi_tx(&m_twi_master, slave_addr, buff, sizeof(buff), false);
    	return ret;
    ret_code_t I2C_WriteData(uint8_t reg,uint8_t *data,int len)
    	uint8_t buff[256];
    	//uint8_t data = 0;
    	//nrf_delay_ms(20);
    	//buff = malloc(len+1);
    	buff[0] = reg;
    	memcpy(&buff[1],data,len);
    	ret = nrf_drv_twi_tx(&m_twi_master, slave_addr, buff, len+1, false);
    	//free(buff);
    	return ret;
    ret_code_t I2C_ReadBatchData(uint8_t reg,uint8_t *data,int len)
    	//uint8_t data = 0;
    	//nrf_delay_ms(7);
    	ret = nrf_drv_twi_tx(&m_twi_master, slave_addr, &reg, 1, true);
    		return ret;
    	ret = nrf_drv_twi_rx(&m_twi_master, slave_addr, data,len);
    	return ret;
    ret_code_t I2C_ReadData(uint8_t reg,uint8_t *data,int len)
    	//uint8_t data = 0;
    	//nrf_delay_ms(20);
    		return ret;
    	return ret;
    uint8_t I2C_ReadReg(uint8_t reg)
    	uint8_t data = 0xFD;
    	//NRF_LOG("I2C_ReadReg\r\n");
    	//NRF_LOG("I2C_ReadReg End\r\n");
    		return data;
    	ret = nrf_drv_twi_rx(&m_twi_master, slave_addr, &data,1);
    	return data;
    You could take a look at the I2C drivers in DevAcademy: https://academy.nordicsemi.com/topic/i2c-driver/
    Best Regards,
    Swathy
  • Thanks for your reply! I have writes the following code for testing i2c_burst_read(). But i2c_burst_read() return -5. What is meaning of -5 error code and how can I fix this issue?
    testing code:
    int i2cInit(void) {
    int ret;
    if (!device_is_ready(_gI2cDev)) {
    printk("I2C: Device is not ready.\n");
    return ERROR_I2C_INITIALIZE_FAIL;
    printk("I2C: Device is ready.\n");
    const uint32_t i2cCfg = I2C_MODE_CONTROLLER | I2C_SPEED_SET(I2C_SPEED_FAST);
    ret = i2c_configure(_gI2cDev, i2cCfg);
    if (ret < 0) {
    printk("I2C: Configure failed err=%d\n", ret);
    printk("I2C: Configure okay.\n");
    #define AFE4900_I2C_ADDRESS 0x5B
    i2cSlaveAddr(AFE4900_I2C_ADDRESS);
    uint8_t buf[3];
    ret = i2c_burst_read(_gI2cDev, AFE4900_I2C_ADDRESS, 0x28, buf, 3);
    if (ret < 0) {
    printk("I2C: i2c_burst_read() failed err=%d\n", ret);
    } else {
    printk("0x%x 0x%x 0x%x\n", buf[2], buf[1], buf[0]);
    return 0;
    log messages:
    00> *** Booting Zephyr OS build v3.2.99-ncs2 ***
    00> Starting button Test example
    00> before calling i2cInit()
    00> I2C: Device is ready.
    00> I2C: Configure okay.
    00> [00:00:00.511,199] <err> i2c_nrfx_twim: Error on I2C line occurred for message 0
    00> I2C: i2c_burst_read() failed err=-5
