Log continuously for up to 500 days with the PPK2!
How did we do it?
Maximum time
Sample resolution
500 days
1 Hz
50 days
10 Hz
120 hours
100 Hz
12 hours
1 kHz
72 minutes
10 kHz
100 kHz
Why buy an expensive oscilloscope? Use the PPK2!
Digital Channels are now 10x better!
  • If you set the sample rate to 10s/s or less, the line graph doesn't draw/update; it appears to be a bug; toggling the live-view gets some trace data to appear, but it disappears the moment you re-enable live view. 100s/s (limited to ~128h) is the slowest the software can log and still work properly.
    If the kit is really sampling at high speed and just logging fewer samples, it would be *vastly* more useful if each sample logged and displayed 3 data points: low/avg/high rather than just the average, which largely defeats the purpose of a high bandwidth dynamic power measurement system.
  • Is the constraint for the "Maximum time" a capture can run the amount of RAM on the host PC?  Or is it due to a constraint in the PPK2 hardware itself?
  • PPkit2 is a game-changer. There are only a handful of DC power analyzers and the most expensive(~700$) although spec is better. PPK2 is good enough for low power applications. especially single cell battery based applications.
