Maximum time
Sample resolution
500 days
1 Hz
50 days
10 Hz
120 hours
100 Hz
12 hours
1 kHz
72 minutes
10 kHz
100 kHz
PPkit2 is a game-changer. There are only a handful of DC power analyzers and the most expensive(~700$) although spec is better. PPK2 is good enough for low power applications. especially single cell battery…
PPkit2 is a game-changer. There are only a handful of DC power analyzers and the most expensive(~700$) although spec is better. PPK2 is good enough for low power applications. especially single cell battery based applications.
