Maximum time
Sample resolution
500 days
1 Hz
50 days
10 Hz
120 hours
100 Hz
12 hours
1 kHz
72 minutes
10 kHz
100 kHz
PPkit2 is a game-changer. There are only a handful of DC power analyzers and the most expensive(~700$) although spec is better. PPK2 is good enough for low power applications. especially single cell battery…
Is the constraint for the "Maximum time" a capture can run the amount of RAM on the host PC? Or is it due to a constraint in the PPK2 hardware itself?
