Log continuously for up to 500 days with the PPK2
How did we do it?
Maximum time
Sample resolution
500 days
1 Hz
50 days
10 Hz
120 hours
100 Hz
12 hours
1 kHz
72 minutes
10 kHz
100 kHz
Why buy an expensive oscilloscope? Use the PPK2!
Digital Channels are now 10x better!
    $core_v2_ui.UserPresence($comment.User.Id) $comment.User.DisplayName over 2020 years ago
